Bluraychip.dk Region Free Kits - Help - AVS Forum | Home Theater Discussions And Reviews
Old 07-12-2011, 06:59 PM - Thread Starter
aragno's Avatar
Maybe this can turn into some sort of "official" thread where troubleshooting, firmware releases, known issues, etc can be posted. Until then, I have a problem.
I have an Oppo BDP-93, F/W Official BDP-9x 42-0323 installed on my player.
I received the bluraychip.dk PRO kit on 10-July-2011 and installed the kit as per instructions found on bluraychip.dk.
1) I hooked up HDMI and power cable with no disc in the tray.
2) I powered on by pressing the "1" button on the Oppo remote.
3) The unit powers on but never leaves the Oppo splash screen and says "Hello" on the front panel of the player.
4) I unplugged the player.
5) I powered on the player using the "Power" button on the remote.
6) It starts as normal.
7) I powered off the player.
8) I pressed the "Eject" button the front of the player.
9) I inserted a Region 2 DVD.
10) I pressed the "Eject" button the front of the player.
11) The player loads and then tells me "Wrong Region Code"
12) I powered off the unit and powered on with remote and also by pressing "1" on the remote, but nothing... wrong region code again.
I have already checked all connections (3 times now).
I have erased Persistent storage.
I have reset to factory defaults.
- The above continues to occur.
Has anyone else experienced the same? Am I doing something wrong? I would be happy to post any photos or provide further information if of value.
I powered off the unit and inserted a DVD (region 2). It says the disc is the wrong region and opens the tray.
Looking forward to getting the kit up and running.
-Trey
aragno is offline
Old 07-13-2011, 12:09 AM
SeriousHorse's Avatar
Sounds like something is definitely going wrong here, either with the way you've installed it or the chip itself. If it's the chip, you'll need a replacement.
You should definitely contact bluraychip.dk and let them know you're having problems. They'll probably want to see photos of the install so they can verify all the cables are connected properly. It might help if you post some photos here. Maybe somebody with an eagle eye will pick up a problem.
SeriousHorse is offline
Old 07-13-2011, 09:06 AM - Thread Starter
aragno's Avatar
I reseated the USB stick attached to the mod kit and seems to be resolved. I will rent a BD soon to verify BD zones are working ok too.
-Trey
aragno is offline
Old 07-13-2011, 12:33 PM
JazzGuyy's Avatar
Quoted: 290 Post(s)
Liked: 272
Are you by any chance using an alternate set of remote codes for your Oppo? Previous kits like this on the Oppo 83 series required some special procedures with the bluraychip kit if you were using an alternate codeset. You will have to contact Bluraychip for the proper procedure if this is the case.
JazzGuyy is online now
Old 08-23-2011, 04:08 PM
mikey mo's Avatar
In anticipation of viewing out of region blu-rays I bought and installed the pro ($149.00) dk board in my OPPO 95. No problems.
I am not sure if the unit works or not. The remote powers up the OPPO by pressing the 1,2 or 3 keys as it is supposed to. This auto power up feature can be disabled and reenables by pressing the blue or yellow key on the remote as per the instructions.
Since I don't as yet have an out of region Blu-ray disc, I attempted to play several of my Region A discs after enabling Region B or C playback. My discs played fine after pressing the 2 or 3 key which was a surprise as I figured they would play only after pressing the 1 key thus enabling Region A.
Thus I don't know if the thing works or not.
I would be willing to invest in an out of region disc, but don't know where to get one.
Any ideas or thoughts?
Mikey Mo
"Survived Charley, Frances & Ivan. But Jeanne got me."
Anxiously Awaiting 2014 Hurricane Season.
"OAR OR DIE"
They killed the SACD. Bring it back.
mikey mo is offline
Old 08-23-2011, 05:57 PM - Thread Starter
aragno's Avatar
I you are in US, look on Amazon and search for the region code you wish to test
-Trey
aragno is offline
Old 09-16-2011, 02:09 PM
mikey mo's Avatar
The unit works just fine. I believe I have everything worked out, so, if any of you need help please PM me.
Mikey Mo
"OAR OR DIE"
mikey mo is offline
Old 09-10-2013, 12:54 AM
Chopsus's Avatar
Location: Arse End of the World: http://en.wikipedia.org/wiki/Warrnambool
OK, Digging up an old thread here with a similar problem.
I have an Oppo 103AU (region 2 Australian version)
Bought the .dk pro mod in late December of 2012, installed and it all worked fine.
Updated the Oppo firmware about a month ago and this forced a change to the way the Mod works
Updated the Mod as per the .dk instructions and all seems to work correctly ... powers down when X X 2 or X X 3 or X X 1 is pressed
When powered back up it is locked to region A, although it is a region B machine, no matter what region code is applied by remote.
I contacted bluraychip.dk and Sofie Angelstrom was very helpful asking a number questions and getting me to try various things (re install, double check settings, clear persistent storage, factory reset, etc.), but none of them have worked.
More than a week ago Sophie said she would get an engineer to look into the emails to see if he can spot anything - I have not heard anything back, despite another three emails form me reporting other things I had tried and asking for an update.
I have a feeling the chip has died, but if they are ignoring my emails I guess I don't have much chance of getting a replacement.
Has anyone had a similar experience and know how to fix the Mod?
Has anyone else managed to get a replacement out of bluraychip.dk?
Cheers
Chopsus
Chopsus is offline
Old 09-10-2013, 06:19 AM
Super Moderator
teachsac's Avatar
Quoted: 666 Post(s)
Liked: 1019
Instead of digging up a two year old thread, why not use the current 103 thread?
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Old 09-10-2013, 07:24 AM
Chopsus's Avatar
Because it will likely be buried in other 103 discussion ... This thread seemed more appropriate, after having done a search ... Either way you probably would have criticized.
Chopsus is offline
Old 11-06-2013, 05:30 AM - Thread Starter
aragno's Avatar
When I was having a problem in 2011, Casper sent me a replacement chip/kit. Don't give up but do give them a friendly reminder of your issues. I had great service when I required it.
-Trey
aragno is offline
Old 11-06-2013, 05:58 AM
Chopsus's Avatar
Yes after sending them a weekly reminder for about 12 weeks they finally sent me another chip .. It won't work either .. Weird.
Ordered the standard chip, as the region change is now the same on both, and it works like a charm. ... I would not bother with the pro chip given there s little advantage anymore fr a lt more complexity.
Chopsus is offline
Old 11-06-2013, 07:30 AM
doushijiade's Avatar
doushijiade is offline
Old 01-04-2015, 02:47 PM
Chopsus's Avatar
Originally Posted by doushijiade View Post
<p>Don't give up but do give them a friendly reminder of your issues. I had great service when I required it.</p>
<p><img alt="10.gif" src="http://www.hupu.us/s/images/10.gif"></p>
Just an update on this ... I sent both pro chips to a local installer, who confirmed that they had issues (this included the replacement chip that .dk sent).
I have now moved both my 105 and 103 to the standard chip with no further problems.
Having done this i am still at a loss as to the advantage of the pro chip, especially at the premium ... None of .dks promises about it have ever eventuated anyway.
Chopsus is offline
Old 08-05-2016, 04:13 AM
kk_f1's Avatar
I sent 5 emails so far with no answer. My Oppo BDP-93/95 multiregion DIY kit PRO does not work. They removed the Pro version from the bluraychip.dk site, I wonder if there is a bug with this version and that's why they are not selling it anymore.
kk_f1 is offline
Old 08-05-2016, 04:27 PM
JohnAV's Avatar
Quoted: 308 Post(s)
Liked: 453
Look your discussing a unknown 3rd party danish site that sells regional mods, they came up with a workaround to bypass regional playback, when it breaks what are they going to do? Initially had some patch now they quietly disappear as they made their money.
Example:
I ordered the Oppo Region Free Mod Chip Pro from them. It arrived quickly and worked great until Oppo's firmware ruined it.
Since then, I've tried to install the new mod chip firmware but it doesn't work on my machine. I've sent three or four very detailed emails to bluraychip.dk asking for assistance or advice and have received absolutely zero response from them. I'm incredibly disappointed by this total lack of customer service. The products themselves seem fine but if you expect any sort of help or assistance in future when ordering a product it might be best to try to buy from somewhere else.
Oppo Beta Group
JohnAV is offline
Old 08-08-2016, 06:53 AM
kk_f1's Avatar
The point is they are still offering the standard version, the Pro version has been removed from their site. I wonder why.
kk_f1 is offline
Old 08-14-2016, 10:09 PM
vld
vld's Avatar
Quoted: 34 Post(s)
Liked: 45
I have no clue as to why the Pro Kit has been removed. But the one that I ordered 06/11 is still working perfectly in my BDP-95.
vld is offline
Old Today, 02:57 AM
xtrips's Avatar
Quoted: 13 Post(s)
Hello,
I used these kits for a while on several units.
Lately the kit stopped working on a BDP-103.
And yesterday I installed a kit on a new UDP-203 and it also doesn't work.
Both units have performed a firmware upgrade over the net yesterday, probably upgrades that were pending.
Is there any known issues with the bluraychip mod and the Oppo's firmwares?
The display on the units doesn't even react to the Dimmer command as they used to.
xtrips is offline
Old Today, 06:56 AM
JazzGuyy's Avatar
Quoted: 290 Post(s)
Liked: 272
The Pro kit was supposed to be firmware upgradeable to support all sorts of additional functions. None of these functions ever appeared, to my knowledge, and firmware updates to the Oppo players sometimes required firmware updates to the bluraychip to continue working. So the Pro version never delivered what it was promised to do and created lots of problems. It made sense to discontinue it.
Old Today, 07:05 AM
JazzGuyy's Avatar
Quoted: 290 Post(s)
Liked: 272
Originally Posted by xtrips View Post
Hello,
There has never been a problem with any previous Oppo firmware. I haven't done the latest firmware upgrade to my 105 to test whether something has happened. (I've mostly been playing with my new 203 lately.) I'll have to try this. I have had minor problems in the past after an Oppo firmware update. I always solved it by unplugging the Oppo for a couple of minutes and then plugging it back in. I was always advised that you should do the Oppo firmware update with the player set to its default region. I don't know if this really matters. You should also probably do a factory reset and clear persistent storage on the Oppo. Save your settings first on a USB stick.
Which kit did you install on your 203? The kits for the 10x Oppos are supposed to work, according to some postings in the 203 thread, but I have no experience of this myself.
Oppo Bdp 93 Blu Ray Player , Oppo Bdp 83 Blu Ray Player , Oppo Bdp 95 Blu Ray Disc Player
