Opinions on the Cambridge Audio Azur 751BD - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 07-08-2012, 05:42 AM
dond2's Avatar
Originally Posted by rdgrimes View Post
You cannot "push" content to the player, only "pull" from the player.
Wow, that's a major drawback for me. I don't have a tv in my listening room and, even if I did, the ca751 'my network' screen just doesn't seem adequate somehow for browsing large numbers of audio files.
dond2 is offline
Old 07-08-2012, 02:53 PM
Tank_PD's Avatar
Quoted: 113 Post(s)
Liked: 67
Twonky is a DLNA compatible media server. I do not think this player is a DLNA compatible device. It seems to just play files directly from USB / SATA. Though, this is the right idea. DLNA or Airplay should allow you to use any number of remote apps on your phone / tablet to choose which content to stream without needing any sort of TV output.
Tank_PD is offline
Old 07-10-2012, 05:03 PM
dond2's Avatar
Its 'My Network' facility does allow the 751 to 'see' media servers, interrogate their content and 'pull' content to itself. But the server cannot push content to the player. The user manual is not completely clear on this. It says 'My Network option enables the player to receive streaming audio, video and photo from upnp media servers on the network'. Cambridge Audio Support have confirmed to me that 'The UPnP section of the 751 is an adjunct to the blu ray section so it is designed with a view that an on screen interface is available. As such it does not support control via web browser or UPnP remote.'
Could you expand a bit on that please?
My android phone has an app (MediaHouse) which streams media on my wireless network from any source device to any target device which is compatible with dnla/upnp. My 'dream' target device would be about phone-size, plug into the usb port of the 751 and appear to it exactly like a memory stick. It wouldn't need dacs or display and would, ideally, cost £5. smile.gif
dond2 is offline
Old 07-11-2012, 12:03 AM
Tank_PD's Avatar
Quoted: 113 Post(s)
Liked: 67
I do not own the player --am just interested in it, so I can't say for sure. It sounds like the upnp section of the 751 is not as feature rich in this area as some other players / devices. Cambridge's website doesn't seem to mention the streaming features in much detail and does not advertise the player as DLNA certified.
I am saying I have seen AirPlay / DLNA certified devices that supports both on screen navigation from a media server to select items to play, and Android / iOS apps that can control the media server and push content to the player without the need for the on screen navigation or any screen at all.
For example I used both JRiver Media Center and iTunes to push content to a Marantz NA7004 network player that is in a two channel system with no screen. I can push the content directly from the PC, or from a remote application running on an Android / iOS device. (The iTunes remote only works on iOS.)
Tank_PD is offline
Old 08-07-2012, 09:08 PM
com5984's Avatar
Originally Posted by Nerd View Post
For all 751BD users, I suppose you may know by hints in its manual if you ever noticed, let me just emphasize how important is it for you to TURN ON the QDEO processor by tweaking the SHARPNESS to +1 or above, it is night and day for the PQ, it is so crispy and bring your bluray experience to whole new level. We all shared this trick in Hong Kong and most of us consider 751BD can achieve 20% better picture you can ever get in Oppo 95.
Thanks for the tip
com5984 is offline
Old 08-07-2012, 09:14 PM
com5984's Avatar
Originally Posted by damienbuckley View Post
Any Aussies here can offer an opinion on whether theres much value in ordering the multi-region version of the 751BD? I've looked online and prices of BluRays dont seem to be hugely different overseas, especially when factoring in shipping.
If I lived in the states Iwouldn't bother
com5984 is offline
Old 08-16-2012, 04:45 AM
com5984's Avatar
I finally got my 751 back after it's tune up from JLTI including a Terra Firma clock, all the multi channel 5532 ic's replaced with LM4562's noise reduction on all dacs. I'm very happy with the results.
com5984 is offline
Old 11-21-2012, 08:26 PM
Tank_PD's Avatar
Quoted: 113 Post(s)
Liked: 67
Originally Posted by Knight7m View Post
Hi Folks,
I would like to have your opinion choosing blu ray player, I have Arcam 137 DVD player and happy with its AQ, now I want to buy Blu ray player but I want AQ at least good as Arcam. Would you recommend Cambridge 651 or 751? or which model/brand you recommend?
Please note, I'm using only coaxial digital bitstream output for the sound, so high grade analog 7.1 outputs are useless, better save money and get high end transport player.
Anyone like to answer. Many thanks to all.
I would not buy either of these players right now as the chipset they are based on is old at this point and many other manufactures have just refreshed their Blu-ray players to newer tech. i.e. with much faster disc loading, many have dropped the need for fans if they had them. I wouldn't be surprised if there is a product refresh from Cambridge Audio soon. If not, I'd say these are behind the current designs of Oppo / Marantz, etc.
Also, if the player is not doing the decoding, the audio quality will be determined by your receiver or wherever you are sending the HDMI signal.
Tank_PD is offline
Old 11-22-2012, 04:15 AM
kelseyhorne's Avatar
I wouldnt buy a 751 right now. Too close to CES 2013 I am sure they will announce a new version with 4k and other features
kelseyhorne is offline
Old 11-22-2012, 03:39 PM
Tank_PD's Avatar
Quoted: 113 Post(s)
Liked: 67
Thank you Tank PD for reply, its very helpful. So is it better as general role I keep using Arcam for a while until new tech or go a head with Marantz/oppo?
Also may i ask is Marantz blu ray players video and audio performance are high end? I don't see reviews about them, if they are can someone please recommend a model.
Just let you know, I have been advised Sony S790 which have good reviews and its best buy, but i feel its entry level, it may have good PQ but i suspet AQ is good enough when using RCA digital output.
As for digital output, i'm using only Coaxial output because i don't have HDMI receiver input. As far i learned in the past the clock and power supply make different even the player is transport (streaming signal only from RCA digital output), if this changed now i mean any cheap player perform as high end please let me know. Also i compare Sony DVD player with Arcam 137 using RCA coaxial digital output bitstreem and i found big different as Arcam: warm, realistic and rich. Sony player price tag was $950 in 2003.
By the way im using Krell gear.
Does your Krell gear not have HDMI or multichannel analog in?
Coaxial or optical digital connections will only carry the older Dolby Digital or DTS formats. Both of these formats are lossy. You will experience a much larger gain in audio quality by using HDMI or a player that can decode the Dolby TrueHD or DTS HD formats and output via multichannel analog outputs. Going from a mid-level entry level player to a high-end player will not make as big of a difference as using the latest loseless codecs.
Players I've heard great things about:
Panasonic DMP-BDT500
Marantz UD5007 / UD7007
Oppo BDP-103 / BDP-105
Pioneer Elite BDP-62FD
Sony S790 (Yes, the drive mechanism may seem cheap, but it is a fantastic player.)
These players are fairly new. Anything else, like from Cambridge, whose players are older than all of these listed, I would wait on as mentioned CES 2013 is around the corner. Not that these players are bad, they are just behind the most recent players and are likely due for a refresh.
You may have better luck in the choosing a blu-ray player thread:
http://www.avsforum.com/t/959985/official-help-me-choose-a-player-thread-cant-decide-start-here/14250
Tank_PD is offline
Old 11-23-2012, 03:54 AM
You could try the new Denon 3313UD. I had the Oppo 95 and the 751. Cambridge in my opinion was better for sound, might be the way the oppo implements the sharc DAC but I always found the sound on the oppo not very welcoming. Anyway just my 2 cents.
Old 12-03-2012, 07:46 AM
MartinStevens10's Avatar
Hello
I've just bought the Cambridge Audio BD751 - I need to set it up to use the HDMI 2 output through a Pioneer VSX LX70 receiver, which can't process 3D. I am a bit new to AV, and cannot get the second HDMI output to work.I am using the optical digital output for sound at the moment (I think). Any advice?
Many thanks
Martin
MartinStevens10 is offline
Old 12-19-2012, 08:56 AM
budlyte's Avatar
I've owned a Denon 3910 since 2007 and am happy with it overall. I use it mainly for audio (CDs, SACDs, and DVD-As) via multi-channel analog along with the occasional DVD. I don't own a Blu-Ray player, as I'm more into audio quality than video, but I do own a 42" HDTV.
That being said, I have had my eye on the 751BD for a few months as a replacement for the 3910 mainly based on the positive reviews regarding audio quality. But since the 3910 works fine, I haven't pulled the trigger because I can't really justify the expense of a new one.
Recently I noticed that Crutchfield dropped the price on the 751BD by $250 down to $899, so now I'm really tempted to buy one, but I'm looking for opinions on the audio quality of the 751BD vs the 3910 via analog outputs. I'm sure the 751BD is an overall improvement from the 3910, especially in the video department, but is the audio improvement enough to justify the $899 expense?
budlyte is offline
Old 12-19-2012, 12:49 PM
Tank_PD's Avatar
Quoted: 113 Post(s)
Liked: 67
You should make sure you have read the above posts, which speculate the 751 is about to be refreshed next year. Though it could just be a holiday sale, I have not seen many discounts from Crutchfield on products that were not about to be discontinued.
Tank_PD is offline
Old 12-19-2012, 03:49 PM
budlyte's Avatar
I noticed those posts and thought the same thing about it being replaced next year. In fact, when I bought my 3910 from Crutchfield in '07 it was half price because it was being replaced.
Are you thinking I should hold off on the 751 in case the price drops further next year, or hold off and wait for the potential new player?
I don't necessarily need the latest and greatest player; I'm looking for a balance between performance and price, which is why I bought the Denon in '07, and it's also why the Cambridge on sale is tempting right now.
The 3910 has been a great unit so far, which is why I'm hesitant to buy a new one (if it ain't broke....) On the other hand, if the audio will be a big improvement over the Denon, I don't mind spending the money on the Cambridge, especially with it being on sale.
Hopefully some forum members have heard both players and can provide some input on the audio differences.
budlyte is offline
Old 12-19-2012, 04:14 PM
Tank_PD's Avatar
Quoted: 113 Post(s)
Liked: 67
I can't say for sure, but I have not seen steep discounts on old equipment from Crutchfield. Often the first closeout price is the final closeout. You can try contacting them for a better deal. You'll have to wait for someone else to comment on the audio differences.
Tank_PD is offline
Old 12-22-2012, 12:27 AM
808///M3's Avatar
I am expecting delivery of a 751BD soon. In the speaker setup menu, where you adjust the speaker distances, in what increments are the adjustments? I know it's in feet; please tell me that the adjustments are in 0.5 ft steps or smaller! Thanks in advance, the manual doesn't state this spec, and searches turn up nothing.
Pioneer | Cambridge Audio | Dynaudio | Identical + equidistant 5.0 | KISS
808///M3 is offline
Old 12-23-2012, 11:13 AM
budlyte's Avatar
I just finished connecting mine and the speaker increments are 0.25 feet. Looking forward to giving my new player a workout!
budlyte is offline
Old 12-23-2012, 04:44 PM
budlyte's Avatar
I'm very impressed with the audio on this player so far. My Denon 3910 is no slouch, but the Cambridge is a definite improvement. I've listened to America's Homecoming DVD-A, Billy Joel's 52nd Street multi-channel SACD, and I'm watching Porcupine Tree's Anesthetize DVD right now. All via the multi-channel analog outs.
This is my first Blu-ray player so I'll have to pick up a few of those discs and check out the sound and picture quality as well.
budlyte is offline
Old 12-23-2012, 05:19 PM
808///M3's Avatar
Thank you, budlyte, for your response. Glad to hear you're enjoying your new player.
808///M3 is offline
Old 12-23-2012, 06:50 PM
budlyte's Avatar
You are welcome. Hope you enjoy yours as well.
budlyte is offline
Old 01-01-2013, 04:15 PM
Indy60's Avatar
I am looking to upgrade to the Cambridge 751BD (from the 650BD). Has anyone tried the component outputs? Does it transmit 1080i for Blu Ray, or is it limited to 480P like some of the newer Blu Ray players?
I asked Cambridge customer support. I could not get a straight answer. They say officially it is limited to 480P, like my 650BD (which isn't limited). But to check with my dealer. The dealer says it does 1080i, because he saw it written in the manual. The manual also says it does 1080P over the component output, which is an obvious mistake.
Bottom line is, my HDTV has no HDMI inputs. If I want 1080i, I need it to be output through the analog component output. The 751BD is being liquidated at 899$, which is a great price. But, if it cannot do 1080i over the component output, I will unfortunately have to pass on this deal...
If anyone has tried the component output, I would be very happy to know your results.
Indy60 is offline
Old 04-07-2013, 01:37 AM
marooned66's Avatar
I have a bad luck with a second Cambridge audio device.. First of all my 751R receiver got a bug of not switching on neither from remote control nor from button of front panel, then 2 months later, yesterday my 751BD began to show enormous lags on remote control commands. I am angry on CA...
Is it kind of a general scheme problem and CA should fix it with a new firmware? What's going on?
marooned66 is offline
Old 04-07-2013, 01:43 AM
Tank_PD's Avatar
Quoted: 113 Post(s)
Liked: 67
I'm not sure, but new models are already out. You should contact CA customer support to see if any new firmware will even apply to the old models.
Tank_PD is offline
Old 04-07-2013, 06:01 AM
marooned66's Avatar
CA was approached before this case and the answer (in February) was - what you have is the latest. Seems CA closed bugfixing for old equipment. Well I can accept it from Nokia or other companies with thousands of unique devices produced, but CA is having dozens..
Cost saving?
Old 04-07-2013, 10:49 AM
Klemi's Avatar
does the Cambridge Azur 751BD arrival in silver?
Thanks for comments!
klemi
Klemi is offline
Old 04-20-2013, 12:31 AM
luter1978's Avatar
Hi everyone, thanks in advance for your opinions.
have just invested in the 751 mainly for picture quality via hdmi, however I also have a large collection of DVD-a's, SACD AND DTS 96/24. I am blown away with the picture however my Onkyo 608 AVR doesn't have analogue inputs which I believe is the best way to hear audio!
My questions are, can the 751 convert the digital audio from dvd audio and sacd to LPCM/PCM and feed my AVR lossless audio via HDMI, and if so will this be as good as analogue?
Also, I've heard that even when using analogue outs to make use of the 751's on board DACS, some AVR's will convert it back to digital! Do you guys think its worth me reinvesting in a new AVR with analogue inputs and pure direct mode.?
Hopefully, the 751 can convert to PCM and feed my existing Onkyo 608 with lossless audiophile quality music. Please help smile.gif
Thank you, david
luter1978 is offline
Old 05-16-2013, 04:21 AM
Neilsy's Avatar
Thank you, david
I'm not sure on the conversion question but I know the new Cambridge 65x, 75x series would have 7.1 analogue in. My CA 650R does. I run HDMI for videa and 5.1 analogue out of my 751BD. Vast tonal difference from running audio via HDMI and in my opinion, more brightness less sparkle (which I like) - more of an analogue sound and I believe better detail, ambiance and separation.
Hope that is useful!
-- 133" AT 2.35:1 Screen -- JVC X500 -- Oppo BDP105-D -- CA 650R -- 2x KlarkTeknik DN360 G-EQ -- Emotiva XPA-5 -- 3x JTR Triple 12; L,C,R -- 3x Velodyne DD18 + DD15 --
Neilsy is offline
Old 05-30-2013, 10:57 AM
komarfamily's Avatar
Hi just one comment to that.
I have auditioned both the oppo 95 and CA 751 and there was no disagreement between a few of us that CA has much better performance in stereo. For the moment I own an emotiva umc1 along with upa700 and the CA751bd and every time I listen to a dvd I realise that music is far more energic/dynamic via HDMI than via 7.1 analog.
However I must admit that I only listen to CD via the dedicated stereo outputs.
Best from Hungary
Emotiva UMC1
Emotiva UPA 700
CA 751 Bd
Quad 22L2
komarfamily is offline
Old 05-08-2014, 08:48 PM
ogvh5150's Avatar
Did support for sacd-r drop now that there's an update dated may 1, 2014?
ogvh5150 is offline
Cambridge Audio , Cambridge Audio Azur 751bd 3d Compatible Universal Blu Ray Player Black , Blu Ray Players
