What features would you like in your next Oppo BR - e.g. Oppo BDP-113 and BDP-115. - Page 16 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: DIRAC Live Software
Yes 152 62.30%
No 92 37.70%
Voters: 244. You may not vote on this poll
 347Likes
post #451 of 2100 Old 09-20-2012, 11:16 AM
Neuromancer's Avatar
Quoted: 95 Post(s)
Liked: 360
Originally Posted by scolumbo View Post
With two years of lead time since the 93 was released, i find it hard to believe gapless playback has eluded Oppo/Mediatek unless it just wasn't a priority.
It is not MediaTek's priority since only OPPO really wants it. Their other vendors (Sony, Panasonic, etc) don't really care about user generated media. If the people who are buying millions of units don't want it, why put in the resources? This is similar to reasons why companies like Amazon, Hulu and other streaming services are not offering their support to OPPO, as OPPO can only bring in or retain several thousand customers, versus several hundred thousand or more customers.
Neuromancer is offline
post #452 of 2100 Old 09-20-2012, 11:34 AM
scolumbo's Avatar
Liked: 36
I hope you can appreciate the frustration since it shouldn't be that difficult to figure it out with more and more media streamers and software players incorporating the feature. If it was a video-related flaw, instead of audio-related, I'll bet it would have already been addressed.
If Oppo can't rely on their chip-maker to support user generated media, they should start looking for other solutions. After all, ripping CDs to digital media is hardly new and not going away any time soon.
Since my post seems to have been overlooked in the 103/105 thread, can you answer it here?
"In my never-ending quest to achieve gapless playback, is it possible that the SMB/CIFS Access could allow the Oppo to read a cue sheet with track points? Assuming there are hardware limitations that prevent gapless playback directly, maybe there could be some ability to recognize a .cue file and have gapless playback through a software solution via a cue sheet? I believe this is how some Dune players achieve gapless playback."
scolumbo is offline
post #453 of 2100 Old 09-20-2012, 11:45 AM
Quoted: 95 Post(s)
Liked: 360
No. Look at the BDP-83 which still have issues with user generated files showing up stretched because there was a bug in the MediaTek SDK that stopped sending AR data to the ABT VRS. This issue is resolved by changing the Primary Output to COMPONENT, but it is still a long standing issue with the player.
As far as I know CUE/PLS is not supported. This was something that was being investigated in the firmware development, but at this time it is not and there is no guarantee that it will be.
The only way to get gapless audio is to transcode (so the server just keeps making one massive file), you re-encode the file as a single file, or you use USB (BDP-105 only) to push data to the player.
post #454 of 2100 Old 09-20-2012, 11:56 AM
scolumbo's Avatar
Liked: 36
I use the second option currently. Can you explain how the USB option on the 105 will work yet? I use a pc or some other device connected to the Oppo to play audio tracks with a software player such as Foobar? How would that be different than if I connect the pc directly to my AVR via HDMI?
scolumbo is offline
post #455 of 2100 Old 09-20-2012, 12:04 PM
Quoted: 95 Post(s)
Liked: 360
Basically the player works as an external soundcard. The computer will be processing the file then sends it to the BDP-105 to be processed into analog (or remain digital if you want to use HDMI, digital coaxial or optical output). So you can get gapless playback since the PC, not the player, is doing the audio decoding and processing.
Asynchronous USB is better as it does not suffer from jitter (something HDMI is notorious for) and the clocking is controlled by the DAC, rather than the computer's internal clock. Overall accuracy should be higher.
post #456 of 2100 Old 09-20-2012, 12:12 PM
scolumbo's Avatar
Liked: 36
Hmmm...while I like that you can get gapless playback via analog output, for a digital solution, it's an expensive alternative to a much cheaper streamer, or just using a pc directly to the AVR.
scolumbo is offline
post #457 of 2100 Old 09-20-2012, 12:41 PM
JazzGuyy's Avatar
Quoted: 327 Post(s)
Liked: 331
I don't think it would necessarily only be analog output. Wouldn't the 105's DAC be able to put out a PCM stream via HDMI to a receiver? Though I suspect none of the beta testers can tell us at this time.
JazzGuyy is offline
post #458 of 2100 Old 09-20-2012, 12:49 PM
scolumbo's Avatar
Liked: 36
I think Neuromancer answered in the affirmative.
scolumbo is offline
post #459 of 2100 Old 09-20-2012, 02:24 PM
slimoli's Avatar
Quoted: 647 Post(s)
Liked: 299
Assuming we have 4k capable TV and a 4K capable Bluray player, would a current BD disk look really better ? I can't find any intel on upcoming 4K media.
I was so happy without HDR...
slimoli is offline
post #460 of 2100 Old 09-20-2012, 02:30 PM
wse
wse's Avatar
Quoted: 2201 Post(s)
Liked: 805
I think, I will sit that one out until this is incorporated. Plus upgrading every year is a bot expensive at over a $1000 for the 105 frown.gif
http://www.folded-space.com/software_products.html
wse is offline
post #461 of 2100 Old 09-20-2012, 02:31 PM
wse
wse's Avatar
Liked: 805
Not anytime soon plus 8K is in the wing, give me OLED at LED prices and that will make me happy smile.gif
wse is offline
post #462 of 2100 Old 09-20-2012, 04:18 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Yikes, $1200 for gapless and requirement of another computing device to boot. eek.gif
vinnie97 is offline
post #463 of 2100 Old 09-20-2012, 04:21 PM
JazzGuyy's Avatar
Quoted: 327 Post(s)
Liked: 331
8K is hardly in the wing. It has merely been demonstrated by the Japanese. It is years away from production.
JazzGuyy is offline
post #464 of 2100 Old 09-20-2012, 05:32 PM
adidino's Avatar
Quoted: 362 Post(s)
Liked: 277
There's been some talk that there will be 4k movies will debut and CES this year. Not sure of the details. I have a 4k projector. I would be curious how the scaling on the Oppo is. I plan to have this player upon release.
adidino is offline
post #465 of 2100 Old 09-20-2012, 05:32 PM
Lotus00's Avatar
oh well oppo, so much for making this a "media hub" or whatever it is you are pretending to be focused on. I'll just keep the one I have and use it for playing hard media which I like a lot (thank you). Computer and external hard drive playback will be through my receiver via HDMI or asynchronous USB.
Lotus00 is offline
post #466 of 2100 Old 09-20-2012, 05:55 PM - Thread Starter
boe
boe's Avatar
Quoted: 936 Post(s)
Liked: 433
While I don't have any test equipment yet smile.gif I would imagine a BR upscaled on a 4K TV would look better than on a comprable 1080p TV. I have DVDs that the Oppo does a great job of upscaling. THey dont look as good as native BR 1080p but DVDs can look much better than they do without the upscaling. A friend has the same TV as me but his DVDs look like crap in comparison on his newer Sony BR player.
boe is online now
post #467 of 2100 Old 09-20-2012, 06:41 PM
slimoli's Avatar
Quoted: 647 Post(s)
Liked: 299
If the 1080p to 4K upscaling does what the 480i to 1080P does, it can be fantastic. I wonder if any betatester already has a 4K TV or projector...
slimoli is offline
post #468 of 2100 Old 09-20-2012, 08:24 PM
Lotus00's Avatar
Thanks for the info. If computer can be connected to player via USB or HDMI and flac can be played back gapless, then that is a nice option and upgrade. I want to confirm that's the case.
Lotus00 is offline
post #469 of 2100 Old 09-20-2012, 08:48 PM
Lotus00's Avatar
What millions of users really want does not mesh well with what Oppo users really want. Hopefully they can work that out. It's not all user generated by the way. Many bands and companies like HDtracks etc are selling FLAC files. For audio, this is a high end player for people who enjoy music. Naturally, they need to be able to play back the most popular digital Lossless storage format (FLAC) Gaplessly. "Lossless" and "Oppo" should go hand n hand.
If the new units can be connected to a computer via USB and HDMI, and Flac played back gapless, then that is a nice upgrade. If they will still be using the high-end DAC.
But, external hardrive playback needs to be gapless too or in the works I would hope. Again if the the computer playback option can handle this right now then that helps a lot.
Here's one band that sells Flac files in 16/44 and high rez.
http://www.livephish.com/catalog.aspx
click on "available"
Lotus00 is offline
post #470 of 2100 Old 09-21-2012, 10:40 AM - Thread Starter
boe
boe's Avatar
Quoted: 936 Post(s)
Liked: 433
I'm pretty excited about the 103. The oppo 103 is leading to me finally replacing my old TV in my bedroom and upgrading my AVP for the bedroom. All I need now is to find a good upgrade shop in Los Angeles for my AVP. Strangely, I would have thought a lot of AVP owners would be in Los Angeles but it doesn't seem like any have had theirs upgraded.
boe is online now
post #471 of 2100 Old 09-22-2012, 03:50 PM
slimoli's Avatar
Quoted: 647 Post(s)
Liked: 299
The ideal companion to the 103, Saw it today at a Sony store, 4K is unbelievable! 25 large can buy it. Sony 84".
Soory for the Iphone 3G picture, my new Iphone 5 is backordered.
slimoli is offline
post #472 of 2100 Old 09-22-2012, 06:20 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3570 Post(s)
Liked: 4644
^ Did you figure out what sort of Source they were using to drive that in the store?
I believe Sony has been using some method of feeding real 4K demo content into it for shows, which would not be available to a home user (neither the content nor the hardware). Or were they demoing it with either a 1080p feed or upscaled 1080p content?
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #473 of 2100 Old 09-22-2012, 07:31 PM
slimoli's Avatar
Quoted: 647 Post(s)
Liked: 299
--Bob
I asked them to show me everything:
The source was a dedicated desktop PC, linked to a HDMI input on the TV. The material was a real 4K demo video made by Sony . If you are old enough like me, you remenber the first HDTV demos using a dedicated Sencore system. The setup was very similar.
I asked them if I could see a Bluray disk fed to the TV and they said Sony doesn't allow any other source because the firmware is not on its final version.
The pictures I took with an Iphone 3G don't reflect the quality of the real image on the TV. One interesting thing was the set was placed on a corridor, leaving no more than 6 feet distance from the TV, certainly too close for normal viewing ,but I couldn't see a single glitch on the picture
slimoli is offline
post #474 of 2100 Old 09-22-2012, 07:44 PM
Read the FAQ!
Liked: 4644
^ Thanks for that. Yes the Sencore stuff was just what I was thinking about. Ah we'll, can't blame them for wanting to show it in the best light, even if that doesn't reflect real world usage.
--Bob
post #475 of 2100 Old 09-22-2012, 09:55 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1235 Post(s)
Liked: 1271
I'm picturing those of us who are old enough to remember that having to use walkers because it was so long ago biggrin.gif.
gsr is offline
post #476 of 2100 Old 09-22-2012, 10:44 PM
Read the FAQ!
Liked: 4644
What's that you say, sonny? Kids these days! And just try getting one of them to help figure out how to get a cracking good player piano roll fed into this so-called Universal player! Hmmph!
--Bob
post #477 of 2100 Old 09-23-2012, 07:29 AM - Thread Starter
boe
boe's Avatar
Quoted: 936 Post(s)
Liked: 433
It is funny but a lot of people who can't fathom the chicken and the egg post on engadget "who needs a 4K TV when there is no media". So who is going to create media if there is nothing to play it back on. I'm going to CES this year to check out the production 4K TVs. It won't be long before there is media and players to upscale.
boe is online now
post #478 of 2100 Old 09-23-2012, 09:40 AM
slimoli's Avatar
Quoted: 647 Post(s)
Liked: 299
At least two players already do 4K upscaling: The Sony S790 (already shipping) and the Oppo 103 (shipping soon). I bet 2013 will be the "4K year" with a lot of hardware being announced and VERY few media to play. It's gonna be interesting if we start seeing 4K streaming , with the very low average internet speed we have here. I can see 4K media and streaming coming first in countries like Japan and Korea, wouldn't be surprised to see even TV broadcasting in 4K in Japan next year. Another interesting event on the 4K realm are some new prosumer camcorders already in the market capable to shoot the higher resolution.
slimoli is offline
post #479 of 2100 Old 09-23-2012, 04:38 PM
Quoted: 95 Post(s)
Liked: 360
There are actually a couple of 4K documentaries and other material available, but they are expensive. The reason is that you have to purchase a flash/hard drive that has the files stored on them, as there is no physical disc media which can store the amount of data, or you will need to spend a lot of bandwidth downloading it.
One example is TimeScapes. It will set you back $99.00 for the 8-bit 4K version, or $299 for the 12-bit, 4K version which comes on a harddrive.
post #480 of 2100 Old 09-23-2012, 04:52 PM
slimoli's Avatar
Quoted: 647 Post(s)
Liked: 299
Wow! Even the Vimeo video is fantastic .
slimoli is offline
Reply Blu-ray Players
Oppo , Oppo Bdp 105 Blu Ray Player , Oppo Digital Inc Bdp 105
