What features would you like in your next Oppo BR - e.g. Oppo BDP-113 and BDP-115. - Page 44 - AVS | Home Theater Discussions And Reviews
View Poll Results: DIRAC Live Software
Yes 38 73.08%
No 14 26.92%
Voters: 52. You may not vote on this poll
 45Likes
post #1291 of 1310 Unread 02-19-2015, 11:04 PM - Thread Starter
boe
boe's Avatar
Quoted: 201 Post(s)
Liked: 91
Originally Posted by rakosnicek View Post
I'm going to give the WD-TV appliance a go. It will do (1), (2) and (4). Not sure about (3) and definitely no for (5).
However at $99, there's no real obstacle to buying one and taking it for a test drive.
I'm waiting to hear back from Oppo what the Oppo Stick for $50 gives me. It doesn't have RJ45 which is a bummer. Not sure about the rest.
boe is online now
post #1292 of 1310 Unread 02-20-2015, 01:00 AM
rakosnicek's Avatar
Quoted: 14 Post(s)
The Oppo Stick is for Roku integration with a BDP-103/105 only.
So if you own a 93/95/83/83SE then this stick may as well not exist.
Interestingly the URL on the Oppo page (www.roku.com/oppo) does not exist on the Roku website.
With respect to the above list, of 5 items, I can't see it meeting any of those needs. All that the Roku stick does is save you from buying a Roku if you've already got an Oppo BDP-103/105. Nothing else. And that makes it kind of useless for streaming in a home NAS environment.
rakosnicek is offline
post #1293 of 1310 Unread 02-20-2015, 06:48 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 300 Post(s)
Liked: 272
It's not an "Oppo" stick. It's a Roku Streaming Stick and is compatible with ANY device that has a MHL capable HDMI input, which some TV's and AVR's have. It's not usable only with the Oppo BDP-10x players.
The older Oppo players don't have any HDMI inputs at all, so by your logic any other HDMI source device might as well not exist.
The capabilities of the Roku Streaming Stick that Oppo resells are the same as other Roku products, so app specific questions may best be asked elsewhere in a Roku thread as there should be a larger pool of users available to help with answers. The only real limitation of the streaming stick compared to the larger Roku products is that it's WiFi only - some of (not all) Roku's other products have a network jack. The remote control integration and small size are nice pluses, but I think I'd gladly give those up to have a network jack.
gsr is offline
post #1294 of 1310 Unread 02-20-2015, 07:27 AM
rakosnicek's Avatar
Quoted: 14 Post(s)
I've read up on what Roku can do and what it can do is not what is required of those looking for a network media player that integrates with DLNA, NAS, etc. Thus the Roku Stick is a useless addition to an Oppo environment when what you're looking for is a more comprehensive network streaming device such as a Popcorn Hour or Dune HD, etc. So thanks for mentioning it but lets move on past it.
At present the WD TV puck seems to be the closest and is available for a good price too.
post #1295 of 1310 Unread 02-20-2015, 07:34 AM - Thread Starter
boe
boe's Avatar
Quoted: 201 Post(s)
Liked: 91
Thanks - I'll try to find a good Roku forum.
While I really want the RJ45, I also really want an IR remote controlled device. I have an RF remote for my cable and I basically never use cable partially because I really hate switching remotes(sad but true). I think their more capable device the Roku 3 uses an RF remote.
boe is online now
post #1296 of 1310 Unread 02-20-2015, 07:53 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 300 Post(s)
Liked: 272
Look here:
https://www.roku.com/accessories
You would want the "Roku Standard Remote" or "Roku Standard Remote with Channel Shortcut Buttons" which both use Infrared (the IR sensor is built into the Roku 3). If using a universal remote, such as a Harmony, the codes may already be built in, so you might not need to buy the remote. But this is OT in this thread, which is why I suggesting looking for a Roku thread - this might be a good starting point.
gsr is offline
post #1297 of 1310 Unread 02-20-2015, 08:16 AM - Thread Starter
boe
boe's Avatar
Quoted: 201 Post(s)
Liked: 91
Thanks. I've posted the questions in Roku's forums. I'll post back what I find out. It looks like the IR one does not work with the stick (but does if you have the Oppo connected with the MHL version).
boe is online now
post #1298 of 1310 Unread 02-20-2015, 08:46 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 300 Post(s)
Liked: 272
Roku's IR remotes do not work with the Streaming Stick at all (either the MHL version or the other HDMI version that's externally powered). If you want to use an IR remote with the MHL version of the Streaming Stick, you can only use the remote of the device that the Streaming Stick is currently connected to (ie: the Oppo remote or the TV or AVR's remote). I don't believe there's a way to use an IR remote at all with the HDMI (non MHL) version of the Streaming Stick. Since you mentioned you wanted to use a Roku 3 to get the network jack, the IR remotes I mentioned would work with that. In their lists of which devices their remotes are compatible with, the MHL version of the Streaming Stick is the "Roku Ready Version", part numbers 3400R, 3400M, or 3420H.
I'd get answers to your other questions before worrying about the remote control options as those answers may make the IR remote control issue a moot point. I suspect that rakosnicek is correct that the Roku options aren't your best option to achieve what you're looking for.
gsr is offline
post #1299 of 1310 Unread 02-21-2015, 08:25 PM
rakosnicek's Avatar
Quoted: 14 Post(s)
I've done more research on this.
Whilst the WD TV series are good with subtitles and networking, they can't do DTS HD over HDMI.
Next for me is to look at what Dune's HD Base 3D can do.
boe likes this.
post #1300 of 1310 Unread 02-22-2015, 01:08 AM
AVS Club Gold
Keenan's Avatar
Quoted: 667 Post(s)
Liked: 561
Are you sure about that? My WD-TV Live will output DTS-HD over HDMI.
Keenan is offline
post #1301 of 1310 Unread 02-22-2015, 01:29 AM
rakosnicek's Avatar
Quoted: 14 Post(s)
Which model do you have?
It would appear that this doesn't work in the latest model but it does in the previous one.
post #1302 of 1310 Unread 02-22-2015, 01:43 AM
AVS Club Gold
Keenan's Avatar
Quoted: 667 Post(s)
Liked: 561
It's not the current model, it's a WDBHG70000NBK-01, as I recall DTS-HD MA was added in a firmware update sometime last year I believe.
Data sheet,
http://wdc.custhelp.com/app/answers/...h/1/a_id/8539#
Keenan is offline
post #1303 of 1310 Unread 02-22-2015, 01:50 AM
rakosnicek's Avatar
Quoted: 14 Post(s)
Data sheet,
This is consistent with what I'm seeing elsewhere. The "Red Box" WD TV works with DTS-HD, the newer "Blue Box" does not.
post #1304 of 1310 Unread 02-22-2015, 03:38 AM
michaelharvey's Avatar
Probably already mentioned, but Plex would be great.
Even if just off a streaming stick.
michaelharvey is offline
post #1305 of 1310 Unread 02-27-2015, 11:38 PM
CatBus's Avatar
Liked: 27
I don't know if it's been mentioned already yet, but different AVR sync settings for 24p and otherwise. At least in my experience, at 60Hz my display can keep sync issues within the unnoticeable (to me) range, but at 24p, it's out of sync (even with all the special 24p processing off, it's still worse than 60Hz, not sure why). Anyway, discrete sync settings could solve 24p sync problems without creating a new one at 60Hz.
CatBus is offline
post #1306 of 1310 Unread Yesterday, 07:15 AM
audiovue's Avatar
Oppo gave the chance to owners of bdp-105d or higher-end having hardware update with cost $
I am angry change the player one time a year.
just charge me for hardware update.
Regards.
audiovue is offline
post #1307 of 1310 Unread Yesterday, 12:59 PM
JazzGuyy's Avatar
Quoted: 94 Post(s)
Liked: 111
You seem to think a hardware update is a simple thing to do. In most cases it isn't and really requires extensive changes to a player (often requiring a new chassis and cabinet) that would probably cost more to do (if even possible) than simply buying a newer one.
Oppo, by the way, does not bring out a new player every year unlike the big Japanese and Korean companies. It's more like every 2 to 3 years.
JazzGuyy is offline
post #1308 of 1310 Unread Yesterday, 05:21 PM
dnoonie's Avatar
Quoted: 60 Post(s)
Liked: 76
I have an older BDP-93. I still think it plays BDs great! It also streams Vudo great. I'm very happy with it. If I really wanted the latest streaming/Web features I'd get a "TV box" like WD TV or Apple TV or <whatever> TV. Right now I'm happy to supplement my OPPO experience with the computer I have connected to my HT. I really don't see the point in buying a new <major AV component> every year just to keep up with the latest internet connected features.
OPPO teamed with Roku with the streaming stick for the 103/105, maybe they can team with a "TV box" provider to offer the latest in internet connected features and add things like downloadable media. I think the present model with 2 HDMI inputs works good for that type of expansion/updates when the built in web connected features become obsolete. I see little point in having a new OPPO player every year. Don't get me wrong, I'd like to see more web connected features in the next OPPO like downloading to an external drive for Vudu, etc and I'd use them, but when those features become too old I'd rather spend $70 on a TV box than $500 on a new OPPO or $5000 on a new TV.
And I really like using my OPPO as my pre/pro. More pre/pro features would be great!
Cheers,
dnoonie is online now
post #1309 of 1310 Unread Today, 11:10 AM - Thread Starter
boe
boe's Avatar
Quoted: 201 Post(s)
Liked: 91
I would love it if it could handle plex or a number of other good media server additional functionality.
I'm not sure when it happened but the Oppo does play subtitles from streamed MKVs (I tried it a number of times a while back and never got it to work). I pressed subtitles on a movie a couple of days ago and it let me select the forced track. I've since watched 2 more movies. It had a little trouble with a good day to die hard but it was acceptable. I'm thrilled as I was about to get a WD or some other player just to get the subtitles. Hopefully it will handle most of my MKV files. While you do have to select subtitles at least it plays them! This Oppo doesn't disappoint.
boe is online now
post #1310 of 1310 Unread Today, 11:10 AM - Thread Starter
boe
boe's Avatar
Quoted: 201 Post(s)
Liked: 91
boe is online now
Reply Blu-ray Players
Oppo , Oppo Bdp 105 Blu Ray Player , Oppo Digital Inc Bdp 105
