Sony BDP-S185 BDP-BX18 Blu-ray Disc player - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 118 Old 01-26-2013, 12:30 PM
engus's Avatar
Hi, new to the forum and have a question regarding the remote for the BDP-S185. I have a Vizio TV and through some research found code
4 will work for power and volume.
My question is does anyone know how to get the TV input to work for the Vizio? Many thanks.
engus is offline
post #92 of 118 Old 01-26-2013, 03:56 PM
beauxtiger's Avatar
Hi: I connected a new BDP-BX18 today and all seemed fine. I paused the disc as I had to take the dog out, and when I came back in, the unit and the tv were both turned to Off. The tv started right up, but the dvd player will not come back on and I am unable to get the disc out...which I was just borrowing from someone else! Any ideas on what problem could be, or at the very least, how to get their disc out without breaking it to pieces before I return this possible pile of junk? Thanks!!
beauxtiger is offline
post #93 of 118 Old 02-01-2013, 11:56 AM
kerednai's Avatar
I bought this player a while back to replace a much higher spec'd Sony Bluray.. It plays fine but my main issue is that it doesn't seem to resume if I stop a bluray. I have to say I just assumed this was standard in all bluray players.
Is this the same with all BDP-S185 players or has it been fixed in a later firware release?
kerednai is offline
post #94 of 118 Old 02-01-2013, 12:18 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
It's the same with all. Resume depends entirely on how the disc was authored. Some will, some won't.
mdavej is offline
post #95 of 118 Old 02-01-2013, 02:33 PM
kerednai's Avatar
Really? I can never remember having this problem with my PS3, yet it hasn't resumed on a single disc I have put in the S185. I can't remember it ever failing on my old Sony player either.
kerednai is offline
post #96 of 118 Old 02-01-2013, 02:56 PM
mdavej's Avatar
Liked: 940
Do you press STOP, or do you just power off or eject? I think you have to press STOP for the resume point to get marked.
I don't have the 185 per se, but have had other 2011 sony models and they all worked the same way as every other player I've had. Do you not get a screen asking if you want to resume? Have you tried setting bookmarks instead?
Maybe it really is a bug. Unfortunately, there probably won't be many more firmware updates for that model, if history is any guide.
EDIT: I see now this is a very low end model. It's entirely possible it has no resume at all. Sorry for the bad info.
mdavej is offline
post #97 of 118 Old 02-15-2013, 12:53 AM
Jamosb78's Avatar
I have one of these players...and am very happy with it for streaming and disc playback.
I've recently converted a bunch of DVD's to mp4 files, and put them on a 1.5TB portable harddrive that's formatted FAT32. When plugged into the Sony, all works well, the machine can navigate to and play a file...
My issue is that, after about a half hour, playback stops and I get the error message "overload occurred, please power down system and disconnect USB device".
Not cool. Anyone else encounter this? Any fix? My firmware is updated to the latest.
Additionally, anyone using a specific kind of drive in this way that works well? I'd be happy to buy a new, smaller drive if I knew it could play nice with the Sony.
Thanks all.
Jamosb78 is offline
post #98 of 118 Old 02-16-2013, 07:30 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
I assume your portable HD is powered from an outlet.... right? IF not, I think you are lucky the player warned you before it had a "melt down".
budwich is offline
post #99 of 118 Old 02-16-2013, 08:06 PM
Jamosb78's Avatar
No, it's a bus-powered Western Digital My Passport drive. A chat with Sony tech support resulted in them saying the same thing as you...that the drive needs to be AC powered separately. The player plays fine from flash media, so I may continue to dump whatever file I want to watch onto a flash drive for now.
Jamosb78 is offline
post #100 of 118 Old 04-07-2013, 07:28 PM
Ka7niq's Avatar
Quoted: 17 Post(s)
Liked: 24
Originally Posted by ADU View Post
You might also try using it on a different type of surface. A flat smooth surface that the rubber feet will "stick" to is better than a more roughly textured surface (like particle-board or bare wood, for example) where the player can move and vibrate more freely.
As mentioned earlier though, the S185 is pretty lightly built and mostly made of plastic, so it will tend to vibrate more easily (and noisily) than heavier, more sturdily built metal players. Excellent picture quality though on the unit.
I bought mine recently (3-11-13) off of EBAY for around 40.00 Delivered!
I am much more of an Audiophile then a video nut, and I only have a 73 inch Mitsubishi DLP, not the highest resolution monitor. But still, Pic quality seems decent, and CD Audio performance is outstanding.
It works just fine for everyday movie watching with friends and family. Blu Ray Discs look great, and CD Audio Quality is exceptional.
If I were a hard code videophile, I might pass on this unit.
But, for the average guy, who just wants to watch Blu Ray and DVD's with their family, Or, for the audiophile who wants a killer sounding player to play CD's on, I think it is an incredible bargain.
I have several high end stereo speakers that allow me to quickly hear differences between CD players, and DAC's.
This little Sony is warm, rich, and quite 3 dimensional, when playing regular CD's.
In fact, it is so good at it, it actually beats several older, stand alone, high end DAC's that I own, including the internal DAC's in a top of the line Yamaha 7.1 receiver.
I paid 40.00 for it "seller refurbished" off EBAY, so WTF do people expect, for so low a price ?
If anyone who knows of a BETTER overall unit for 40 dollars delivered, I am all ears:)
Ka7niq is offline
post #101 of 118 Old 06-19-2013, 12:17 PM
tanglecord's Avatar
Hope it's okay to post this info. Factory refurbished models of this player are available TODAY ONLY (June 19) for $39.99 shipped from 1saleaday.com.
"This is my ancestor, Philo Farnsworth, inventor of television ... and, as a bonus, childhood obesity."--Professor Hubert J. Farnsworth on the Futurama episode "All the Presidents' Heads."
tanglecord is offline
post #102 of 118 Old 06-19-2013, 01:11 PM
mdavej's Avatar
Liked: 940
Does the 185 have the older sony netflix interface as shown on the left or the newer one as shown on the right? Thanks
mdavej is offline
post #103 of 118 Old 06-22-2013, 12:57 PM
ADU
ADU's Avatar
Quoted: 313 Post(s)
Liked: 519
^ Never got a chance to try the NF or other online features on this unit, so I can't answer your query mdavej.
Maybe someone else knows?
ADU
ADU is offline
post #104 of 118 Old 06-22-2013, 02:40 PM
ADU
ADU's Avatar
Quoted: 313 Post(s)
Liked: 519
Thanks for your comments above Ka7niq. It's always good to get multiple opinions/viewpoints on something like this. And I'm glad to hear that you're getting such good performance from the S185.
If my previous comments came across as overly negative, then let me reiterate a few of the positives on this unit as I saw them...
PROS:
  • Small footprint.
  • Generally fast load times.
  • Good detail/resolution. Player passed both DVD and HD still resolution tests without issue.
  • No fan!
 ...Excellent picture quality though on the unit.
If so, then that could mean that the YCbCr HDMI modes on the S185, S380 and S390 are working correctly (and potentially even "bit-perfect"), which needless to say would be a very good thing for such low cost players.
Another "pro" on this model is the RCA audio outputs, which have been dropped from most 2013 players.
My biggest gripe with the S185 was the green push/clipping in the RGB HDMI mode (which is a fairly common issue on low-cost players). But I suspect that was probably fixed in the 8-28-12 M09.R.0054 firmware update. (My S390 now has essentially flawless color in the RGB HDMI mode after a similar update.)
Other minor gripes included the occasionally bad vibration noise, which is undoubtedly related to the lightweight/plastic construction. (2013 Sony players now have metal cases again.) And the occasional lockups when scanning discs in fast-forward or reverse.
By "lockup", I mean that the player would get stuck in fast-forward or fast-reverse mode and couldn't be stopped. I still get these same kinds of "lockups" from time to time on my S390 (even with the AUTO DISPLAY setting turned OFF). And the only solution is to hold down the power button on the player until the unit goes completely off. I sometimes get noticeable vibration noise when playing BD or DVD discs on the S390 as well.
I also wish that the S185 and S390 had a little better virtual surround sound processing for its stereo RCA audio outputs. I mainly listen on headphones via the RCA jacks, and Sony's virtual surround is not quite as flexible or dimensional as some other V-surround systems I've tried. The Sony players are pretty good with "front-to-back" virtual FX, but not as good with "side-to-side" virtual FX in the rear/surround channels. And sometimes I also have to switch the player's Downmix setting from Surround back to Stereo to deal with "imaging" issues on certain DTS-MA Blu-ray audio tracks. (Snow White & the Huntsman, and On Her Majesty's Secret Service are two Blu-ray discs where I found this necessary.)
If you're using a 5.1+ receiver though, then the player's virtual surround capabilities are probably a non-issue. And the new 2013 Sony players don't even include stereo RCA jacks anymore. So for most other listeners, the players' virtual surround capabilities would be irrelevant.
Aside from those minor issues, I've been very satisfied with my Sony player, and generally very happy with it's AV performance. Lately, I've been experimenting with 1080p H.264 MP4 video playback from a thumb-drive on my S390, and I'm very pleased with results. The player can even handle progressive 1080p files encoded at 60 frames/sec, which exceeds the official Blu-ray spec.
If I'm overly critical btw, it's because I expect alot from Sony video products (even the low-end ones), because I've had pretty good experiences with them in the past.
ADU
ADU is offline
post #105 of 118 Old 07-14-2013, 10:57 AM
weberman's Avatar
Sony is aggressively pushing Firmware upgrades for all of its older Blu-Ray machine for one main reason. To add CINAVIA protection.
weberman is offline
post #106 of 118 Old 07-14-2013, 06:44 PM
Rich86's Avatar
Quoted: 128 Post(s)
Liked: 64
That is simply not true. The Sx80 series was apparently developed to include cinavia and cinavia was activated via a firmware update. The Sx90 series came with cinavia out of the box. As far as I can tell, nothing earlier than the Sx80 series knows anything about cinavia even with the latest firmware for each of these models.
And Sony has been good about noting when a firmware includes cinavia on their website.
A long-time audio/video addict!
Rich86 is offline
post #107 of 118 Old 08-05-2013, 09:38 PM
gary-in-dc's Avatar
Quoted: 16 Post(s)
I have 2 Sony devices using the same remote code. Can I change one of the remote's code (and device) so both units don't respond to the same remote?
I know some manufacturers allow you to change a device's signal code for avoiding such problems.eek.gif
gary-in-dc is offline
post #108 of 118 Old 08-05-2013, 10:44 PM
ADU
ADU's Avatar
Quoted: 313 Post(s)
Liked: 519
Don't see anything about it in the manual...
http://www.docs.sony.com/release/BDPS185_BX18.pdf
Maybe tech support can help.
ADU
ADU is offline
post #109 of 118 Old 08-05-2013, 10:51 PM
mdavej's Avatar
Liked: 940
Panny yes, Sony no. Only their mega changer is addressable. Sorry.
You could cover the IR window of one player and control it exclusively by Bravia Sync or the smart phone app. Or you could get an RF remote or addressable IR distribution system (both more expensive than a different brand player).
Is there a particular reason you need 2 BD players in the same location?
mdavej is offline
post #110 of 118 Old 11-03-2013, 11:52 AM
Ben Molloy's Avatar
Hi all, can you see my thread on this player here?
http://www.avsforum.com/t/1497829/2-sony-bdp-s185-bdp-bx18-blu-ray-players-have-been-fried-by-my-hard-drive
Thank you,
Ben
Ben Molloy is offline
post #111 of 118 Old 02-11-2014, 01:29 PM
kilmister's Avatar
Does anybody have trouble with the RSS feeds not updating? NBC nightly news updates every day on my RSS feed but CNN hasn't changed since I bought it.
kilmister is offline
post #112 of 118 Old 04-16-2015, 08:08 PM
Electric_Haggis's Avatar
Quoted: 24 Post(s)
Hi all.
When streaming Sony Video Unlimited through the BDP-S185, is there some way you can tell the player to output the original bitstream?
All I can see in the menu is Auto or PCM... and both options output PCM via HDMI.
Thanks in advance....
Electric_Haggis is offline
post #113 of 118 Old 04-18-2015, 10:58 AM
Rich86's Avatar
Quoted: 128 Post(s)
Liked: 64
Originally Posted by Electric_Haggis View Post
Hi all.
See page 16 & 17 in the manual for your S185.
Firmware Settings should be:
"Audio" = auto
"Audio Mix" = off (I expect this is the setting you have wrong maybe?)
"Dolby Digital" = dolby digital
"DTS" = DTS
"DTS-Neo 6" = off
"Audio DRC" = auto
"Downmix" = surround
Rich86 is offline
post #114 of 118 Old 04-18-2015, 01:24 PM
Quoted: 24 Post(s)
"Audio" = auto
"DTS" = DTS
"DTS-Neo 6" = off
"Audio DRC" = auto
But with Australian firmware, it's called BD Audio Mix Setting, which is about mixing BD interactive audio & input.
Btw, best to leave Audio DRC to OFF and Downmix to Stereo.
post #115 of 118 Old 04-18-2015, 11:06 PM
Rich86's Avatar
Quoted: 128 Post(s)
Liked: 64
did setting the "BD Audio Mix Setting" to Off solve the problem you had described?
Rich86 is offline
post #116 of 118 Old 04-19-2015, 08:25 AM
Quoted: 24 Post(s)
Actually, the rental had just expired when I went to check, but will have a look next time.
Thanks for the tip!
post #117 of 118 Old 05-12-2015, 02:21 PM
brickyardz's Avatar
Quoted: 531 Post(s)
Liked: 563
Arcam AVR 600 and Sony BDP-S185?
Using my Arcam AVR 600 and Sony BDP-S185, all previews play fine. Once the video starts, screen shrinks and is locked in the upper left hand corner of the screen.Do I need to set the video output settings on the Sony BDP-S185? All dvd's played fine with old receiver.Any ideas on what this could be? Thanks
brickyardz is online now
post #118 of 118 Old 08-25-2015, 02:29 PM
captain camacho's Avatar
BDP-S185 Sony with Denon AVR-1612 Receiver
Hope someone can help. I have had this blu ray player and receiver set up for some time and I am finally posting this issue. The brightness on my TV changes as I play blue ray discs with the Sony blue ray player. I have the BDP-S185 connected thru a Dennon AVR-1612 receiver to the TV.
I do not see this issue with my DirecTV box as the picture is sharp and no noticable changes in brightness here. I also don't seem to have a brightness issue when viewing streaming netflix from the blu ray player. (this connection is the same through the receiver) I don't think it is a TV issue as the DirecTV feed works fine.
I've been living with this issue for sometime but if there are any suggestions for a fix I would really appreciate it. Thanks.
captain camacho
captain camacho is offline
Reply Blu-ray Players
Blu Ray Players , Sony , Sony Bdp S185 Blu Ray Disc Player , Sony Blu Ray Disc Dvd Player Bdp Bx18 With Mini Tool Box , Sony Blu Ray Disc Player Bdp S185
