Official 2012 Sony BDP-S790 Thread - Page 109 - AVS Forum | Home Theater Discussions And Reviews
 66Likes
post #3241 of 3947 Old 12-10-2013, 07:06 PM
jah.volunteer's Avatar
Thanks for the reply.
Here are the details of the file. Would you expect this to work?
Bitrate ............: ~11800 kbps (x264 L4.1)
Audio 1.............: English DTS 5.1 Ch 1510 kbps
Chapters............: Yes
Source .............: 1080p Blu-Ray 3D AVC DTS-HD MA 5.1-LOTS
Is there an app out there that will tell me all of the details of a certain file? (whether the audio is FLAC or something else, the container type, etc?)
jah.volunteer is offline
post #3242 of 3947 Old 12-10-2013, 07:46 PM
California Joe's Avatar
Originally Posted by apw2607 View Post
Have you tried a variety of discs? DVD, BD, DVD-R, DVD+R, CD, CD-R ....
Do you hear the drive spinning up and trying to read data of the disc? If its all quiet and dead ... not a good sign. If its trying to read ...but failing, you could open the unit up and try cleaning the lens with some rubbing alcohol. Failing all of that ... hammer, hit ... hard .... ?!
Thanks for the reply. When I put any disc, or music CD the drive it's self will move however the screen will say "empty" as if the ready isn't seeing anything. I will give it a clean to see what happens.
California Joe is offline
post #3243 of 3947 Old 12-10-2013, 08:48 PM
apw2607's Avatar
Quoted: 292 Post(s)
Liked: 339
No if its a 3D Bd rip
jah.volunteer likes this.
apw2607 is offline
post #3244 of 3947 Old 12-10-2013, 08:56 PM
Aha!
post #3245 of 3947 Old 12-10-2013, 09:45 PM
DoctorM's Avatar
Quoted: 701 Post(s)
Liked: 215
Aha!
What format and resolution are you using? Half-SBS should work. If you have full resolution as on the disc I believe that makes it double 1080p... which you'd think it should still handle since it can on a disc. Is it a remux?
DoctorM is offline
post #3246 of 3947 Old 12-10-2013, 10:19 PM
apw2607's Avatar
Quoted: 292 Post(s)
Liked: 339
It won't play MVC 3D rips.
apw2607 is offline
post #3247 of 3947 Old 12-11-2013, 10:42 AM
DoctorM's Avatar
Quoted: 701 Post(s)
Liked: 215
Never heard of MVC is that an MKV interpretation of frame packing (what BDs do) or some custom sequential frame thing? [see Edit Below]
Is MVC what you're using jah.volunteer?
Edit: Got it. For those of you playing at home...
Blu-ray 3d is frame packed, which is pretty much two full HD frames stacked on top of each other.
MVC is a weird H264 format:
Basically, what happens is that two data streams L & R eyes are recorded to one frame. How this is accomplished is that the Left data stream is recorded at full resolution and the Right data stream is what's called a Delta stream meaning that it only reflects the differences between it and and the Left stream. In decompression, this missing data is filled in from the Left data to make two complete data streams.
MVC apparently is incompatible, there is no reason the most common re-encoding method of Half Side-By-Side shouldn't work fine for the Sony s790.
Although it would be very large, a remux of the movie should also play since the Sony is capable of playing BD M2TS files.
Edit 2: This may not be true either... I apparently have no idea what I'm talking about.
DoctorM is offline
post #3248 of 3947 Old 12-12-2013, 01:59 AM
Paul.R.S's Avatar
Quoted: 44 Post(s)
Originally Posted by skinimin View Post
Hi, Thanks for you reply.
I have a 3D TV, Non 3D Receiver & Non 3D projector. I want to be able to plug the S790 Main HDMI out into the TV for 3D video and Sub HDMI into the receiver for audio but also want to be able to send non 3D video through the receiver to the projector. The receiver has two HDMI outs so I can send all of my other sources to the TV or projector.
I have come to understand that HDMI queries a plugged in devices capabilities even when not powered on, causing 3D players to revert to 2D when non compatible devices are attached even if they are not turned on?
I don't want to be plugging HDMI cables in & out to enable 3D, I was hoping that it might "just work" or I would have to delve into the menu's & turn off video to the sub HDMI.
In short, I don't know. There is too much HDMI voodoo and variance between player behavior when it comes to 3D that I think the best answer anyone else could give you is YMMV ("your mileage may vary"). The better answers will be learned through trial and error. But I would suspect that it will NOT "just work."
Paul.R.S is offline
post #3249 of 3947 Old 12-14-2013, 03:00 PM
unifexx's Avatar
i have successfully coonverted my S790 into a region-free DVD player. I have read that no easy way exists for circumventing the Blu-Ray region coding. So how come completely "region-free" versions of S790 can be bought on eBay, although at a rather high price?
unifexx is offline
post #3250 of 3947 Old 12-14-2013, 03:05 PM
mdavej's Avatar
Quoted: 2255 Post(s)
Liked: 985
Because they've been converted the hard way. And since it's hard to do and requires some extra circuitry, they can charge for the material, knowledge and labor.
mdavej is offline
post #3251 of 3947 Old 12-14-2013, 08:24 PM
apw2607's Avatar
Quoted: 292 Post(s)
Liked: 339
At one point someone was selling hardware region free bd mods for the s790 (as well as 5100, 3100 etc). It involved a good bit of soldering and adding additional hardware. Not for the faint hearted. Seems shutdown now.
At the end of the day ... Your just wasting your money anyway, Any North American 790 can play PAL or 50i material via M2TS backups.
DoctorM likes this.
apw2607 is offline
post #3252 of 3947 Old 12-18-2013, 03:25 AM
kristoffer77's Avatar
Quoted: 54 Post(s)
Liked: 44
I am thinking about either getting this or a Pioneer BDP 160 ( I am in Europe ) . I like the s790 but I already have a PS3 slim and I am getting a little tired of the X media bar interface.
But how easy / hard is it to make this player region code free on DVDs? smile.gif
How much noise does the player have?
kristoffer77 is offline
post #3253 of 3947 Old 12-18-2013, 11:09 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 59
Originally Posted by Ted99 View Post
I ordered the BDP S 790 from the Sony Store at the "Cyber Monday" sale price of $199 because I just got a $60 gift card from the 1080p settlement on my Q 007. A day later got a message from Sony cancelling the order because of "no stock". Called customer support to complain (Sony web site showed in stock) and was told that the S 790 was being discontinued and no stock remaining at Sony. Any one know what is replacing it?
Originally Posted by Chise View Post
what for the CDs show
ces show
I'm hoping S790 replacement will have improved build quality and support gap-less, multi-channel FLAC files via USB 3.0 port. biggrin.gif
Iain- is offline
post #3254 of 3947 Old 12-18-2013, 11:17 AM
p5browne's Avatar
Quoted: 3099 Post(s)
Liked: 2414
Plus HDMI 2.0, and or Display Port 1.3 with the New Codecs .265
UN65HU9000 with SEK-3500U in JS Mod Mode + Input at 1080P 60HZ 444. 4K separate input- Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 still up for sale
p5browne is offline
post #3255 of 3947 Old 12-18-2013, 01:10 PM
unifexx's Avatar
It is very easy - you have to buy a One for all remote on Amazon and google for instructions (which buttons to press). I'm not sure whether the forum rules allow me to post more detailed instructions here, but trust me, this is really all there is to it. Apart from the Amazon delivery, the whole process (including googling) takes about 5 minutes.
unifexx is offline
post #3256 of 3947 Old 12-18-2013, 01:15 PM
unifexx's Avatar
As I am in Europe myself, I'm more concerned with the European players playing US disks. The two reasons for this is that I like to watch movies in their original language (which is English for 90% of what I'm watching) and second, prices on Amazon.com and Amazon.de can be very different sometimes. I also have a large number of US DVDs. It's easy to make the player play those, but with the Blu-Rays it's a different story. I did see those hardware kits sold on eBay, but honestly, I can't be bothered to solder some unknown chip to my player.
Now, what did you mean by m2ts backups? Did you mean the digital copy that is sometimes sold together with the disk or did you mean a home-made rip?
unifexx is offline
post #3257 of 3947 Old 12-18-2013, 01:16 PM
Super Moderator
teachsac's Avatar
Quoted: 834 Post(s)
Liked: 1360
Nothing wrong with posting the remote hacks when available. You just can't post outside links to forums that host hacked firmware.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #3258 of 3947 Old 12-18-2013, 06:37 PM
apw2607's Avatar
Quoted: 292 Post(s)
Liked: 339
This method is only suppose to work for European players and not North American players
apw2607 is offline
post #3259 of 3947 Old 12-20-2013, 12:44 PM
unifexx's Avatar
unifexx is offline
post #3260 of 3947 Old 12-20-2013, 12:54 PM
Selden Ball's Avatar
Quoted: 3427 Post(s)
Liked: 1698
Please consider adding that Location information to your AVS profile.
We don't all manage to remember who made which posts: there are just too many.
Selden
Selden Ball is offline
post #3261 of 3947 Old 12-22-2013, 04:40 AM
John Frank's Avatar
Originally Posted by WarrenD View Post
Hi! right on! The deep blacks on Direct mode are fantastic.
I agree that with a poor DVD transfer, then that would be a case to engage these enhancements.
Sorry to resurrect a topic of over a year ago but I just got this thng and am wondering about the quality of transfers. My personal collections of DVD's and concerts look fine, but the so called Bly-ray version of Hangover II from NETFLIX is absolutely horrible. The colors are really pushed, bloom like it was made from a 480i 1950's movies. I had to go into Custom and back off the COLOR setting as much as possible. Red push is bad too, so I adjusted the HUE. Is this normal, or just bad quality on the part of NetFlix discs?
2nd - Anyone have a problem with me using CUSTOM and playing with the Color and Hue settings while leaving everything else as Direct?
Thanks for saving me the time of not having gone thru 100 pages of this thread!
John Frank is offline
post #3262 of 3947 Old 12-22-2013, 09:56 AM
p5browne's Avatar
Liked: 2414
Direct and that's it. No other issues.
p5browne is offline
post #3263 of 3947 Old 12-22-2013, 11:41 AM
DoctorM's Avatar
Quoted: 701 Post(s)
Liked: 215
@John Frank - If you look, the last post before yours wasn't even two days old. Although the BDP-790 came out in 2012, it was held over for a second year as Sony's flagship model.
Welcome to the tread.
DoctorM is offline
post #3264 of 3947 Old 12-23-2013, 05:32 AM
John Frank's Avatar
Thanks again. Some DVD's I have are poor transfers so that is useful. But on a good DVD transfer, I noticed on Direct mode, the picture is so good, that no additional enhancements need to be added. I took Superbit Mapping off. Blu Ray needs no revisions and Direct is the way to go.
Contrary to some of the purists, there ARE issues with Direct. I'm not making this up, Netflix Hangover II is unwatchable until you go to CUSTOM and back the COLOR all the way down and bump up the HUE a notch towards GREEN.
I was referring to this discussion around page 37-38 (for my browser) - June 2012
http://www.avsforum.com/t/1386151/official-2012-sony-bdp-s790-thread/1110
post #3265 of 3947 Old 12-23-2013, 05:50 AM
WarrenD's Avatar
I was referring to Blu-ray and DVD with Direct mode. Nothing more.
As for Netflix, that depends on their side and how they are streaming. I use Lovefilm and sometimes the quality is poor depending on bandwidth. I would avoid judging this player using say Youtube as a guide. A lot depends on the person uploading and what they have done.
The main reason I bought the Sony is for it's amazing upscaling abilities with DVD!
WarrenD is offline
post #3266 of 3947 Old 12-23-2013, 06:24 AM
John Frank's Avatar
Hangover II was a Netflix disc, mail exchange program. I don't stream.
Crazy movie BTW, we laughed our butts off!
post #3267 of 3947 Old 12-23-2013, 03:59 PM
DoctorM's Avatar
Quoted: 701 Post(s)
Liked: 215
Has anyone tried these with Silicondust's new DLNA enabled hdhomeruns? I've been thinking of getting one, but I would need the Sony to access it.
I can find few details on their page about how it actually works. Do you navigate like you would files except they are channels? No clue how these work.
DoctorM is offline
post #3268 of 3947 Old 12-24-2013, 10:50 AM
So how does one take apart the S790. I have removed the screws, but having difficulty opening it up.
post #3269 of 3947 Old 12-24-2013, 09:25 PM
p5browne's Avatar
Liked: 2414
http://www.agoraquest.com/viewtopic.php?topic=40372&forum=66
p5browne is offline
post #3270 of 3947 Old 12-24-2013, 11:20 PM
Thanks for replying back, much appreciative.
Reply Blu-ray Players
Blu Ray Players , Sony , Sony Bdps790 3d Blu Ray Player , Sony Blu Ray Disc Player Bdp S790 , Sony Open Box Bdp S790 3d Blu Ray Disc Player
