Official 2012 Sony BDP-S790 Thread - Page 117 - AVS Forum | Home Theater Discussions And Reviews
 66Likes
post #3481 of 3943 Old 04-04-2014, 03:33 PM
Geoff D's Avatar
Quoted: 300 Post(s)
Liked: 326
I picked up a BDPA6000 (BDPS790 in a chunkier casing) today to play around with the 4K upscaling. After having it running for just two hours I got my first lockup: after playing a few bits from Catching Fire, changing the player's settings and then playing the disc again, it refused to load the disc any more. I cleared the BD-Live cache, no change so I had to unplug and start again.
Needless to say, it's going back. I've done what I needed to do with the 4K upscaling, anyway.
Geoff D is offline
post #3482 of 3943 Old 04-04-2014, 04:55 PM
Mark1_M's Avatar
WDMyCloud DLNA server
Has anybody tried to connect a WDMyCloud and stream videos to a S790? I just got one and placed several MP4 video files on it. When trying to play the files on the S790, it will say that the files are either corrupt or unsupported. These same files play just fine on the S790 when streamed from a Windows machine, also a PS3 plays the files just fine from the WDMyCloud. I've tried to research this and haven't really found anything, other than maybe the Sony player has a bug. Any help appreciated...
Mark1_M is offline
post #3483 of 3943 Old 04-05-2014, 09:52 AM
S_G7's Avatar
Quoted: 99 Post(s)
Liked: 37
Originally Posted by p5browne View Post
Not into disassembly while under warranty.
No need to disassemble. All you have to do is hit eject to see the tray design.
S_G7 is offline
post #3484 of 3943 Old 04-08-2014, 10:03 AM
p5browne's Avatar
Quoted: 2730 Post(s)
Liked: 2053
Both trays looked identical. With same Code Markings.
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is online now
post #3485 of 3943 Old 04-08-2014, 02:01 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
I week after unplugging, no hang ups on DVDs or BDs. Apparently the reboot from holding the power button does not completely mimic an unplug.
DoctorM is offline
post #3486 of 3943 Old 04-08-2014, 07:35 PM
Zap Branigan's Avatar
Originally Posted by apw2607 View Post
^^ try turning gracenote disk lookup to manual. Sometimes that service goes down and can cause issues with the player.
So far, since switching gracenote to manual, I haven't had any DVDs freeze up. It's been about 6 weeks now. Hopefully that's all it was.
Zap Branigan is offline
post #3487 of 3943 Old 04-08-2014, 10:42 PM
apw2607's Avatar
Quoted: 104 Post(s)
Liked: 219
Glad it worked out for you.
apw2607 is offline
post #3488 of 3943 Old 04-10-2014, 05:15 AM
Geoff D's Avatar
Quoted: 300 Post(s)
Liked: 326
That's the first thing I did when setting up the two S790s (well, one S790, one rebadged A6000) that I've owned. Both were still flaky as ****.
Geoff D is offline
post #3489 of 3943 Old 04-16-2014, 09:45 AM
HelloWorld77's Avatar
Hello,
Does anybody know if BDP-S790 has any issues with big USB 3.0 drives?
I am about to purchase a USB 3.0 pendrive of 32, 64 or 128 GB and format with NTFS. Will it work with this player?
Apologies if it was already answered - this thread is so long I was unable to find an answer :)
Cheers
HelloWorld77 is offline
post #3490 of 3943 Old 04-16-2014, 01:43 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
Originally Posted by HelloWorld77 View Post
Hello,
Apologies if it was already answered - this thread is so long I was unable to find an answer smile.gif
Cheers
I've used a Corsair Flash Voyager USB 3.0 16gb drive with no issues. I don't know how larger drives will react, but I do know 3.0 is backwards compatible. Nothing should have an issue with the higher speed, it just doesn't take advantage of it.
DoctorM is offline
post #3491 of 3943 Old 04-17-2014, 03:54 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
Now I have a question. Has anyone played a DVD with PCM audio on these units?
I tested a couple today and found the audio to be just slightly out of sync.
I do route the audio via optical cabling and the video directly to the TV via HDMI. I use an audio delay to compensate.
Is there a reason PCM audio would react differently?
Anyone else find PCM weirdness, at least where DVDs are concerned?
DoctorM is offline
post #3492 of 3943 Old 04-20-2014, 03:16 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
I will reply to my own post.
Apparently any audio delay set on the S790 is NOT applied to PCM audio (at least when the source is DVD).
I am unable to test this for BD PCM audio tracks, but then again most of you probably route A/V to the tuner and let the tuner handle the delay(?).
My work around is to set my tuner to my TV's audio input instead of the S790. That way the audio is passed via HDMI to the TV, which applies it's own delay and then the TV outputs the track back to the tuner.
Probably less lossy by that time, but at least it's in sync.
DoctorM is offline
post #3493 of 3943 Old 04-26-2014, 10:59 PM
Mattyo1612's Avatar
Quoted: 23 Post(s)
Liked: 40
Can anyone tell me if playing a Sony 4k remastered blu-ray on the BDP-S790 is it playing the disc with xvYCC (expanded colour) on or do I need to switch it on via my Samsung tv which gives you the option to switch on xvYCC in the advanced settings?
Mattyo1612 is offline
post #3494 of 3943 Old 04-26-2014, 11:12 PM
apw2607's Avatar
Quoted: 104 Post(s)
Liked: 219
The feature only works when you use a supported sony tv. In addition the s790 doesn't support the feature.
apw2607 is offline
post #3495 of 3943 Old 04-26-2014, 11:30 PM
Mattyo1612's Avatar
Quoted: 23 Post(s)
Liked: 40
So you're saying that even if the Samsung tv has the option of switching xvYCC on, it's actually not activating the expanded colour because the player doesn't support it?
post #3496 of 3943 Old 04-27-2014, 05:12 AM
HDPERSON's Avatar
Quoted: 17 Post(s)
I own the S790 and it is connected to the Samsung 6300 60" HDTV for me. When I turn on the expanded color of the TV, it works with the Blu Ray player. The Natural color setting of the TV works with any input.
HDPERSON is offline
post #3497 of 3943 Old 04-27-2014, 06:53 AM
mdray's Avatar
Quoted: 14 Post(s)
On my Sharp TV l get an extra mode when l play a mastered in 4k disc, so it does work on other TVs.
On the Samsung, l don't know how it works, because in Movie mode the xvycc Colour Mode is always available, 4k disc or not.
mdray is offline
post #3498 of 3943 Old 05-01-2014, 03:21 PM
Geoff D's Avatar
Quoted: 300 Post(s)
Liked: 326
On my Sony TV I have to activate the xv colour in the TV menu. It doesn't do it automatically.
Geoff D is offline
post #3499 of 3943 Old 05-15-2014, 02:26 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
Is it possible to view YouTube streams that are live on the s790? I tried with the regular YouTube app, but it can't find the video when I search.
The new app I've never signed up with so I don't think I can test it. Anyone know?
DoctorM is offline
post #3500 of 3943 Old 06-13-2014, 03:52 PM
iatacs19's Avatar
Quoted: 229 Post(s)
Liked: 145
Do you guys have a Spiderman advertising icon for the trailer in the middle of your Video section menu?
I find this ridiculous, I bought and paid for this hardware and now Sony is pushing ads into the menu of my bluray hardware which I cannot pot-out of nor remove.
XBR65X930C, AVR-X4200W, NVIDIA ShieldTV, SVS SB12-NSD, RF-42 II, RC-52 II, RB-41 II
iatacs19 is offline
post #3501 of 3943 Old 06-13-2014, 11:06 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
Yup, we get that but not a reasonable firmware updates. I'm pretty sure ASM2 had bombed enough that no one is looking for more info on it.
DoctorM is offline
post #3502 of 3943 Old 06-14-2014, 08:54 PM
AVfile's Avatar
Quoted: 236 Post(s)
Liked: 123
Like previous Sony models it supports xvYcc (just not the Mi4K metadata). Actually it officially supports the Sony version, x.v.Color™ Technology : Yes (from page 1, post 1).
AVfile is offline
post #3503 of 3943 Old 06-22-2014, 02:37 PM
Kirk Out79's Avatar
anyone having issues playing the descent on there s790? i get freezes and skips when trying to play the movie. what are the best settings i have mine set to 4:4:4 and auto for everything else?any help thanks
Kirk Out79 is offline
post #3504 of 3943 Old 06-23-2014, 10:20 AM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
Try unplugging your unit for a minute. These things go funny sometimes and soft resets don't always help.
DoctorM is offline
post #3505 of 3943 Old 06-28-2014, 02:31 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
A question: I just added a new av receiver. It has a LAN port but no wifi.
Although undocumented, is it possible to use the BDPS790's LAN port as a bridge to the S790's wifi?
I could just test it, but I figured I'd ask first.
DoctorM is offline
post #3506 of 3943 Old 06-29-2014, 08:03 AM
mdavej's Avatar
Quoted: 2102 Post(s)
Liked: 934
No
mdavej is offline
post #3507 of 3943 Old 06-29-2014, 02:31 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
DoctorM is offline
post #3508 of 3943 Old 07-07-2014, 10:18 AM
sbddvm's Avatar
Will someone give me some guidance on how to watch video files that are on my PC (Windows 8.1) via wifi using this BD player. Thank you.
"Oh what a tangled web we weave, when first we practice to deceive." -Sir Walter Scott
sbddvm is offline
post #3509 of 3943 Old 07-07-2014, 03:38 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
My recommendation is download Serviio. It's free and seems to work better than many other alternatives. http://serviio.org/download
Other considerations:
Audio-
-FLAC is NOT supported
-Audio tracks are selectable
-LPCM5.1 is not supported in MKV (may be too high a bitrate for M2TS, needs more testing).
Subtitles-
-Subtitles are selectable.
-(M2)TS does not support any compatible format of subtitles.
-SRT embedded subtitles work in MKV.
-SRT external subs work with TS, AVI and MP4 if on the fly re-encoding is selected.
-VOBSUB works embeded in MKV OR authored DVD, but can only be 720p resolution and lower. (Which makes them a poor option for 1080p video.)
-PGS (BD-SUP) doesn't work except as an authored Blu-ray disc.
Video-
-XviD is supported in any container.
-DivX works if you change the header to XviD. You can do this with mkvtoolnix or http://www.fourcc.org/changer/.
-MPEG2 is supported in .MPG or .(M2)TS, but not MKV.
-H.264/x264/AVC is supported in .MP4, .MKV or .(M2)TS
-High@L4.1 is best (even if it is LOWER patching seems to improve playback)
You can patch other levels to 4.1 with tsMuxerGUI. Results vary.
-For all MKV files add the following command line options: --engage no_cue_duration --engage no_cue_relative_position
If you have subtitles and chapters, the mux needs to be in this order: Video, Audio Tracks, Chapters, Subtitles.
Subtitles before chapters will cause playback problems.
For BD Remuxes-
MKV is best but high bitrates may cause stuttering.
Convert subtitles with BDSup2Sub to VOB/SUB or to .SRT with your favorite OCR software.
...Hope that helps, I've been meaning to collect that coherently for awhile.
sbddvm likes this.
DoctorM is offline
post #3510 of 3943 Old 07-08-2014, 11:11 AM
sbddvm's Avatar
Thanks DrM..this is working for my needs.
sbddvm is offline
Reply Blu-ray Players
Blu Ray Players , Sony , Sony Bdps790 3d Blu Ray Player , Sony Blu Ray Disc Player Bdp S790 , Sony Open Box Bdp S790 3d Blu Ray Disc Player
