Official 2012 Sony BDP-S790 Thread - Page 118 - AVS Forum | Home Theater Discussions And Reviews
 66Likes
post #3511 of 3943 Old 07-09-2014, 06:36 PM
Apostate's Avatar
Quoted: 100 Post(s)
Liked: 134
Originally Posted by DoctorM View Post
Video-
-XviD is supported in any container.
-DivX works if you change the header to XviD. You can do this with mkvtoolnix or http://www.fourcc.org/changer/.
-MPEG2 is supported in .MPG or .(M2)TS, but not MKV.
-H.264/x264/AVC is supported in .MP4, .MKV or .(M2)TS
No need to change the header. Serviio will transcode DivX into a format that Sony BD players can play. In fact, you can set it up that Serviio will transcode anything into a format that Sony BD players can play.
Apostate is offline
post #3512 of 3943 Old 07-10-2014, 02:28 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
True, but that also means substantial CPU impact on the server and a loss of image quality because it's on-the-fly encoding.
I was trying to make clear what the S790 natively recognizes. With re-encoding you can serve pretty much anything.
The header patch is a lossless change to the source. I believe Sony didn't want to pay DivX royalties so they ONLY support generic versions of the codec. The patch makes the file lie that it is not 'official' DivX.
DoctorM is offline
post #3513 of 3943 Old 07-10-2014, 02:54 PM
Apostate's Avatar
Quoted: 100 Post(s)
Liked: 134
I have an almost four-year old PC that I use as DLNA server and never found that to be the case. New-ish PCs have horsepower to transcode on-the-fly and plenty left over for other tasks.
Funny thing is Canadian Sony BD players can do Divx. Sony just cheapened out on US BD players.
Apostate is offline
post #3514 of 3943 Old 07-10-2014, 10:17 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
I had the same problem with an old Panasonic DVD player. The Canadian model could play DivX, but the U.S. model, although it had the same chip could not because of the firmware (and Panasonic being cheap).
Still, I was trying to be clear on what the Sony BD player supports. Other file formats will be server and software dependent.
In fact that list is also true for files on USB drives and media files burned to CD, DVD or BD (although I wouldn't try burning x264/MKV files to a CD because they can't spin fast enough).
DoctorM is offline
post #3515 of 3943 Old 07-13-2014, 10:27 PM
scorpion901's Avatar
My recommendation is download Serviio. It's free and seems to work better than many other alternatives. http://serviio.org/download
Other considerations:
Audio-
-FLAC is NOT supported
-Audio tracks are selectable
-LPCM5.1 is not supported in MKV (may be too high a bitrate for M2TS, needs more testing).
Subtitles-
-Subtitles are selectable.
-(M2)TS does not support any compatible format of subtitles.
-SRT embedded subtitles work in MKV.
-SRT external subs work with TS, AVI and MP4 if on the fly re-encoding is selected.
-VOBSUB works embeded in MKV OR authored DVD, but can only be 720p resolution and lower. (Which makes them a poor option for 1080p video.)
-PGS (BD-SUP) doesn't work except as an authored Blu-ray disc.
Video-
-High@L4.1 is best (even if it is LOWER patching seems to improve playback)
You can patch other levels to 4.1 with tsMuxerGUI. Results vary.
-For all MKV files add the following command line options: --engage no_cue_duration --engage no_cue_relative_position
If you have subtitles and chapters, the mux needs to be in this order: Video, Audio Tracks, Chapters, Subtitles.
Subtitles before chapters will cause playback problems.
For BD Remuxes-
MKV is best but high bitrates may cause stuttering.
Convert subtitles with BDSup2Sub to VOB/SUB or to .SRT with your favorite OCR software.
...Hope that helps, I've been meaning to collect that coherently for awhile.
Are your encoding remarks unique to the S790 or is it a Servio issue for streaming? Thanks for the info, I've been looking for guidelines on how to remux my mkv video files to stream to the S790. I am presently using Nero Media Home 4 that I bought a couple of years ago and I like the simple interface and folder structure of the app. I use Foobar2000 to stream my flac audio files to my Onkyo NR818 and that works well. I have a lot of trouble streaming my mkv files to the S790, they will start and then the unit freezes and I have to unplug it to reset. Some mkv files seem to play fine while others just choke. I thought it might have something to do with the file size but I just recently made a 35 gig mkv file that played fine from a usb stick while smaller files on the same stick cause the unit to freeze.
I don't understand how to apply "-For all MKV files add the following command line options: --engage no_cue_duration --engage no_cue_relative_position". Could you please elaborate how to use this command.
Any wisdom you could impart would be greatly appreciated. Thanks
Home Theater Setup
Polk RTi10 +CSi5+FXi5+RTi6
SVS PB2000 Subwoofer
Sharp LC-70SQ15U HDTV
Onkyo TX-NR818 AVR
Oppo BDP-103D & Toshiba HD-XA2 HD Player
scorpion901 is offline
post #3516 of 3943 Old 07-15-2014, 10:02 AM
Quoted: 72 Post(s)
I'm about to buy a Samsung HU9000 and I own a Sony S790 and PS4. How does the Sony S790 work on it? Or should I get a different player?
MatiPlaneteer is offline
post #3517 of 3943 Old 07-15-2014, 10:42 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
Welcome to AVS for now the PS4 does not do 3D so I would keep both of them.
Chise is offline
post #3518 of 3943 Old 07-15-2014, 11:40 AM
E55 KEV's Avatar
Quoted: 22 Post(s)
Perhaps you already sold on the HU9000 curved screen but IMHO its a gimmick. CNET thinks the same - http://www.cnet.com/products/samsung-un65hu9000/
IMO, home theater is about creating a Big Screen Movie Theater picture, sound, environment and experience - no movie theater has a curved screen. FWIW.
AVfile likes this.
E55 KEV is offline
post #3519 of 3943 Old 07-15-2014, 12:11 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
@scorpion901 - My comments were intended to be specific to the needs of the S790. The same details are true if you are playing from a ROM disc, a USB drive or streaming.
Serviio, in theory, is capable of transcoding just about anything to work. In theory, anyway.
Make sure you have Serviio set to Sony BDP-Sx90 (2012) profile. I don't know if the latest version does it, but when I first started using Serviio it would start with an older profile that didn't work as well.
As far as freezes, yeah that happens on occasion in general. This guide (and unplugging) should minimize that.
It could also be a network/wifi issue as well.
You got a 35gb file to work? That sounds like a BD remux. I've never gotten one play smoothly (because the bitrate can peak so high). That's pretty impressive.
In mkvmerge's GUI:
Pull down the 'Muxing' menu and select 'Add Command Line Options'.
From the drop down Available Options, select '--engage no_cue_duration', click 'Add', then select '--engage no_cue_relative_position' and again click 'Add' again.
I would check the box 'Save as default for new jobs' so you never have to do it again, and click 'Ok'.
The cue stuff are new features added within the last year or so to mkvmerge and they are enabled by default. It's supposed to improve scanning through files better, but it make it worse on these devices.
We are actually disabling them which makes the outputted files more like older versions of mkvtoolnix.
Zaim likes this.
DoctorM is offline
post #3520 of 3943 Old 07-15-2014, 12:21 PM
In mkvmerge's GUI:
Thank you very much DoctorM for your very informative response! I have been struggling for some time on trying to get my streamed mkv files to play on the BDP-S790.
I use the BDP-S790 to stream my video files to, and use my Onkyo NR818 to stream flac files to, and stream my photos directly to my Sharp HDTV. I am in the process of remuxing all my mkv video files and will use your guidelines in mkvmerge.
Thank you for the detailed explanation of how to implement the remuxing arguments in mkvmerge otherwise I would have never known how to do it.
Yes, the 35 gig file was a blu-ray remux for a concert video with two audio streams. It was on a usb memory stick, not streamed, but it played with no stuttering that really surprised me. That was partially why I was in such a quandary about remuxing guidelines for my video files.
I have installed serviio on my pc and like it so much that I bought the pro version to help support the development team. It now also serves flac audio files which was a great need for me. I presently do not use the transcoding option but prefer to use the original file format. Maybe I should experiment with the transcoding option since my pc has an I7 4770 processor with plenty of ram (I use a 4 gig temp ramdisk).
Thanks again for all the help, I really appreciate it, it should improve my video streaming.
Home Theater Setup
Onkyo TX-NR818 AVR
post #3521 of 3943 Old 07-15-2014, 02:30 PM
Quoted: 72 Post(s)
Thank you, I love the S790. It worked great for my F7100; however, I am hoping it works great on the 2014 4ks.
I was looking at the HU8550 and the Sony X850b as well. I figure I can try out the HU9000 and if I don't like it, I will revert back to the flat 4k.
post #3522 of 3943 Old 07-15-2014, 03:00 PM
E55 KEV's Avatar
Quoted: 22 Post(s)
I have a S580 and wanted the S790 until Sony removed CinemaNow streaming app.
E55 KEV is offline
post #3523 of 3943 Old 07-20-2014, 01:19 AM
mdray's Avatar
Quoted: 14 Post(s)
Not now, but in the past there were the Cinerama and Todd AO systems, which both had curved screens.
mdray is offline
post #3524 of 3943 Old 07-20-2014, 07:45 AM
E55 KEV's Avatar
Quoted: 22 Post(s)
Exactly. I have How The West Was Won on Blu-ray with curved "SmileBox" viewing. That plus the ones you mention were all fads that did not last and I doubt the curved LCD's will be around.
E55 KEV is offline
post #3525 of 3943 Old 07-22-2014, 02:33 PM
cinema13's Avatar
Quoted: 177 Post(s)
Liked: 139
They also removed all 3D apps. And have added...nothing! Not even Netflix 3D. Personally, will never purchase another Sony product ever.
cinema13 is offline
post #3526 of 3943 Old 07-22-2014, 11:47 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
I mostly bought the Sony for some of the extra output connections and that Panasonic's remote was garbage.
Not sure I'd buy a Sony BD player again either though. It's pretty flaky considering the technology is mature by now.
They could seriously buy a lot of good will with a few extra apps and one more firmware update.
DoctorM is offline
post #3527 of 3943 Old 07-26-2014, 04:09 PM
In mkvmerge's GUI:
DoctorM,
Do you have any guideline recommendations for bitrate limitations on video or audio streams in order to successfully stream and play on the S790?
This information seems hard to find and isn't documented in the S790 user manual. If you have any recommendations, I would truly appreciate it.
Do you think the Oppo blu-ray players are better at handling and decoding streamed mkv video files? I would think about buying one if they did.
Home Theater Setup
Onkyo TX-NR818 AVR
post #3528 of 3943 Old 07-26-2014, 05:15 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
I've never owned an Oppo, but not because I haven't wanted one. I'm sure others here can give you better details on that. I would say, definitely better than Sony though.
As far as stream limitations, based on guessing, MeGUI profiles and Googling:
20-25Mbps bitrate is the DLNA "conformance" value (meaning shoot for this as your average bitrate).
Sony BD and PS3 units should be able to handle PEAKS of up to 30+mbps, but if it is sustained you may get stuttering.
Of course if your network is slower than that, then that is your limit.
DoctorM is offline
post #3529 of 3943 Old 07-26-2014, 05:30 PM
In mkvmerge's GUI:
Thank you DoctorM for the fast and informative response. That is valuable information that I will keep in mind when transcoding/creating my files.
I've captured your various responses in a document for my reference. Thanks again.
Home Theater Setup
Onkyo TX-NR818 AVR
post #3530 of 3943 Old 07-26-2014, 10:08 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
If you using an encoder like MeGUI, using a PS3 profile will probably work out just fine.
Although to be fair, except BD remuxes, I've found little that the BDPS790 couldn't play.
DoctorM is offline
post #3531 of 3943 Old 07-28-2014, 07:42 AM
Liked: 0
Split image on screen
I have a Sony BDP S790 player.
A connected hard drive video viewed through the TV (or projector) is displayed as a split image, side by side. The only way I have found to overcome this is to switch on the projector, select "3D format" in settings and change it from "auto" to "side by side" While on this setting the on screen menu is split with part on the left and part on the right cut off making navigating impossible. Therefore, after watching the blu-ray, I must make sure to change the setting back to auto.
I would like to know how I would be able to sort this out if I did not own a projector. Setting the 3D output to "auto" on the blu-ray does no sort out the problem.
Boeriemore is offline
post #3532 of 3943 Old 07-28-2014, 07:08 PM
Thanks DoctorM, I haven't used MeGUI but will have a look at it. I use VSO products and like them along with multiAVCHD, tsMuxeR GUI, AVCHDCoder, Leawo Blu-ray to MKV Converter, and Leawo Total Media Converter Ultimate.
Home Theater Setup
Onkyo TX-NR818 AVR
post #3533 of 3943 Old 07-28-2014, 08:54 PM
In mkvmerge's GUI:
From the drop down Available Options, select '--engage no_cue_duration', click 'Add', then select and again click 'Add' again.
DoctorM,
Will these same arguments ('--engage no_cue_duration', '--engage no_cue_relative_position') in mkvmerge work for the Oppo BDP-103D?
I just ordered a refurbished unit while they were available and hope I don't have to remux my video library to optimize them for the Oppo.
Many thanks for your continued support.
Home Theater Setup
Onkyo TX-NR818 AVR
post #3534 of 3943 Old 07-28-2014, 09:57 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
@scorpion901 - MeGUI is a less friendly sort of encoder, but something the more serious techies tend to use.
All in one packages can be much easier, just make sure you can set some sort of guidelines for it and you should be fine.
I've tried some AiO in the past and been very unhappy with the output.
As far as the Oppo, it may not have the same limitations. You can try an Oppo thread or just wait until it arrives and see how it works. Some of my suggestions just make life easier, but aren't critical.
For example the no_cue stuff aren't always used in stuff you obtain elsewhere, and if you don't remux something that needs it, you just may not be able to FF or REW during playback.
DoctorM is offline
post #3535 of 3943 Old 07-28-2014, 10:04 PM
Many thanks for the reply and further explanation. I'll let you know how my experience with the Oppo goes. I haven't found much info about streaming mkv's to it on this forum.
Home Theater Setup
Onkyo TX-NR818 AVR
post #3536 of 3943 Old 07-28-2014, 11:52 PM
DoctorM's Avatar
Quoted: 649 Post(s)
Liked: 196
Oppo's site make it sound like it accepts just about any format you can throw at it. Considering their support (unlike Sony), I would expect you should have very few problems.
DoctorM is offline
post #3537 of 3943 Old 07-29-2014, 06:09 PM
Thanks for the encouraging words about the Oppo. I can see from my encoding that I am trying to preserve to high of a bitrate on my video with no reduction in original audio quality. I will have to experiment to find the right balance between streaming ability and acceptable video/audio quality. Your response on bitrate guidelines will give me some direction.
Home Theater Setup
Onkyo TX-NR818 AVR
post #3538 of 3943 Old 07-31-2014, 04:25 AM
Mattyo1612's Avatar
Quoted: 23 Post(s)
Liked: 40
Owning both the Sony BDP-S790 and the Oppo BDP-103AU (Australian model) which has the region free kit I can vouch for both players as they both have their strengths and weaknesses... If you have both they will compliment each other....
Mattyo1612 is offline
post #3539 of 3943 Old 07-31-2014, 02:07 PM
Mattyo1612,
Could you please explain in greater detail what you think are the strengths and weaknesses of the two players as I am not sure I will keep the S790 once I have the 103D.
I am curious about your experiences with the two players. I would appreciate some detail about your experience.
Many thanks.
Home Theater Setup
Onkyo TX-NR818 AVR
post #3540 of 3943 Old 08-01-2014, 09:39 AM
Daffietje's Avatar
Quoted: 54 Post(s)
I really wonder what a Sony BDP-S790 can do better than an Oppo 103 ...
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
Reply Blu-ray Players
Blu Ray Players , Sony , Sony Bdps790 3d Blu Ray Player , Sony Blu Ray Disc Player Bdp S790 , Sony Open Box Bdp S790 3d Blu Ray Disc Player
