Official 2012 Sony BDP-S790 Thread - Page 119 - AVS Forum | Home Theater Discussions And Reviews
 66Likes
post #3541 of 3947 Old 08-01-2014, 10:40 AM
william06's Avatar
Quoted: 111 Post(s)
Liked: 62
Someone above stated curved screens are outdated and not used. Visiting in an IMAX now waiting, looking at curved IMAX screen. Was to regal last week Hercules 3d curved screen. Many others nj and pa. Just saying
william06 is online now
post #3542 of 3947 Old 08-02-2014, 11:50 AM
AVfile's Avatar
Quoted: 239 Post(s)
Liked: 125
And how big is it compared to a home TV? At that size it of course, the geometry makes sense. Not so at home, unless you sit 3 ft from the screen.
DoctorM likes this.
AVfile is offline
post #3543 of 3947 Old 08-02-2014, 05:13 PM
CJayB's Avatar
Quoted: 45 Post(s)
Liked: 43
To my eye sitting 9 1/2 ft from the curved screen on my Sony 65" S990A is equivalent to sitting near the middle of a typical cineplex theater. I don't have to be 3 ft away to enjoy the benefits.
Believe it or not, the sale of curved screen TVs is projected to grow dramatically between now and 2017. Over 5.5 million projected annually by 2016, and most of those LCD, not OLED. I don't understand how people think curved screens are irrelevant. Same is true of 3D, it's more popular than you would think by reading comments in the forums.
CJayB is offline
post #3544 of 3947 Old 08-02-2014, 05:20 PM
Zaim's Avatar
Quoted: 29 Post(s)
Originally Posted by DoctorM View Post
I've never owned an Oppo, but not because I haven't wanted one. I'm sure others here can give you better details on that. I would say, definitely better than Sony though.
As far as stream limitations, based on guessing, MeGUI profiles and Googling:
20-25Mbps bitrate is the DLNA "conformance" value (meaning shoot for this as your average bitrate).
Sony BD and PS3 units should be able to handle PEAKS of up to 30+mbps, but if it is sustained you may get stuttering.
Of course if your network is slower than that, then that is your limit.
Just checked the manual for my BDP-S6200 and it says "The player can support video bit rate up to 40 Mbps" Not sure if its the same for the 790.
Zaim is offline
post #3545 of 3947 Old 08-03-2014, 12:08 AM
DoctorM's Avatar
Quoted: 652 Post(s)
Liked: 198
Are they referring to MKV media or BD discs?
DoctorM is offline
post #3546 of 3947 Old 08-03-2014, 08:28 AM
Zaim's Avatar
Quoted: 29 Post(s)
Its under the section "playable types of files", so yeah they're referring to media and not BD Discs:
https://docs.sony.com/release/BDPS6200_BX620_simple.pdf
Page 13
Zaim is offline
post #3547 of 3947 Old 08-03-2014, 11:13 AM
DoctorM's Avatar
Quoted: 652 Post(s)
Liked: 198
Page 13
That section is also talking about disc-ed media. If it can play that high a bit rate, give it a try.
DoctorM is offline
post #3548 of 3947 Old 08-03-2014, 11:15 AM
Zaim's Avatar
Quoted: 29 Post(s)
I've tried Mastered in 4k content with a bitrate around 39mbit without an issue
Zaim is offline
post #3549 of 3947 Old 08-03-2014, 11:32 AM
DoctorM's Avatar
Quoted: 652 Post(s)
Liked: 198
As a remux over DLNA or USB or burned to a BD?
DoctorM is offline
post #3550 of 3947 Old 08-03-2014, 11:45 AM
Zaim's Avatar
Quoted: 29 Post(s)
DLNA Remux, Both MKV/M2TS.
DoctorM likes this.
Zaim is offline
post #3551 of 3947 Old 08-03-2014, 11:44 PM
scorpion901's Avatar
@scorpion901 - MeGUI is a less friendly sort of encoder, but something the more serious techies tend to use.
All in one packages can be much easier, just make sure you can set some sort of guidelines for it and you should be fine.
I've tried some AiO in the past and been very unhappy with the output.
As far as the Oppo, it may not have the same limitations. You can try an Oppo thread or just wait until it arrives and see how it works. Some of my suggestions just make life easier, but aren't critical.
For example the no_cue stuff aren't always used in stuff you obtain elsewhere, and if you don't remux something that needs it, you just may not be able to FF or REW during playback.
Just ran a test with my new Oppo 103D using a blu-ray remux (mkv file) I made with original video and DTS MA 5.1 audio. This file froze my Sony S790 but played on my 103D with bit-rates varying between 35 to 40 Mbps over my home wi-fi network. I don't find any info in the Oppo manual on bitrate guidelines. One thing thats nice is the Oppo can use an attached usb thumb memory device (1 GB or larger) as cache which the S790 does not. This might be part of the reason the 103D is able to play the higher bitrate files.
Home Theater Setup
Polk RTi10 +CSi5+FXi5+RTi6
SVS PB2000 Subwoofer
Sharp LC-70SQ15U HDTV
Onkyo TX-NR818 AVR
Oppo BDP-103D & Toshiba HD-XA2 HD Player
scorpion901 is offline
post #3552 of 3947 Old 08-04-2014, 11:45 AM
Zaim's Avatar
Quoted: 29 Post(s)
From what I know only the 2014 players are fine with DTS-HD MKV's, 2012/2013 models don't like them. I have no issues with DTS-HD MKV's on my 6200. Its not a bitrate issue as if you remux the mkv to m2ts the files will play fine.
Zaim is offline
post #3553 of 3947 Old 08-04-2014, 11:38 PM
DoctorM's Avatar
Quoted: 652 Post(s)
Liked: 198
First, I wanted to mention that I tested a BD remux of a bonus feature tonight. As soon as the bitrates cracked 30mbps for more than a fraction of a second, it stuttered. I think the PS3 profile is probably still the best recommendation for these players.
Second, I'm still new to blu-rays, and I'm confused by something. When I watch DVDs and stop the film in the middle (to the Home menu), as with other DVD players, pushing Play will resume where I let off in the film.
This does not happen with most BD's which reboot the disc from the beginning.
Is this a BDPS790 issue, or is it true for all BD players?
DoctorM is offline
post #3554 of 3947 Old 08-05-2014, 10:29 PM
Kevin M. Dean's Avatar
This is true for all BD players. Resume features need to be programmed into the title during the disc authoring process and many early titles did not.
Kevin M. Dean is offline
post #3555 of 3947 Old 08-09-2014, 05:46 PM
swizzchard's Avatar
hey folks - I just picked up a demo s790 from bestbuy in maryland. ive held out for cheap prices and no one has NIB any longer. I needed the composite output for an old connection to the patio.
In any case, I wanted to know if there would be material difference in picture/sound compared to my bx57 (s570) from a few years ago. Just wondering if its worth switching with my mainroom player or not.
swizzchard is offline
post #3556 of 3947 Old 08-22-2014, 09:52 PM
Mattyo1612's Avatar
Quoted: 25 Post(s)
Liked: 40
Red face
Originally Posted by Daffietje View Post
I really wonder what a Sony BDP-S790 can do better than an Oppo 103 ...
The Oppo has always had lip sync issues from day one. With every firmware update there has been it has never improved whereas the Sony has never been a problem from day one. I've adjusted the lip sync in the Oppo to as best I can using the Spears & Munsil calibration disc but I'm still not totally convinced I've got it sorted yet. The Sony has never needed to be touched. That is really the only thing I can say that frustrates me regarding the Oppo as everything else is great. I don't use the online features of either player all that much so I'm not the right person to ask regarding the streaming performance of either player. I just mainly play Blu-ray and the occasional dvd through both players and I think they're both exceptional performers with their quality of Blu-ray and dvd playback.
Mattyo1612 is offline
post #3557 of 3947 Old 08-27-2014, 10:02 PM
apw2607's Avatar
Quoted: 109 Post(s)
Liked: 219
I have a Oppo 103D and it has no lip sync issues and I've never had to mess with the setting. Nor did the s790 however.
apw2607 is offline
post #3558 of 3947 Old 08-28-2014, 04:44 AM
Daffietje's Avatar
Quoted: 54 Post(s)
Lip sync problems can also be due to HDMI handshake problems with certain hardware.
Could be the Sony did not have handshake problems with your hardware.
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #3559 of 3947 Old 09-08-2014, 08:57 PM
pacman9270's Avatar
Quoted: 83 Post(s)
Liked: 49
Ok... Riddle me this. My s790 cannot play Amazing Spiderman 2 in 2D, however, i am able to play the 3D version. Tried the 2D disc in my PS3 Fatboy and it worked there. Anyone have any knowledge of this?
Theater Setup: 5.2.5 (10.1 Auro3D) / ~3100 cu.ft. / Vaulted Ceiling
Projector:Sony VPL-HW30ES Screen:SI Performance Series 16:9 100" Source Player:Oppo BDP-103D Pre/Pro:Marantz AV8802A Amps:Emotiva XPA-5(Fronts/Surrounds) and BasX A500(Heights) Fronts/Surrounds:Sonus Faber Venere 2.0 Center:Sonus Faber Venere Center Front/Rear Heights:Definitive Technology PM1000 / ProCenter1000(VOG) Subwoofer:Dual SVS SB-2000 Speaker Wire:Monoprice CL2 12-AWG w/Bananas ICs:BlueJeanCables and Mediabridge
pacman9270 is offline
post #3560 of 3947 Old 09-09-2014, 01:00 AM
cinema13's Avatar
Quoted: 177 Post(s)
Liked: 139
Also stuck with the 790...but it played both versions fine, A bad disc maybe?
cinema13 is offline
post #3561 of 3947 Old 09-10-2014, 08:32 AM
pacman9270's Avatar
Quoted: 83 Post(s)
Liked: 49
I don't think so. It played in another player. I checked for a SW update and nothing required. I did watch Captain America: Winter Soldier in 2D last night with no issues. I was afraid that I would have this problem with the new releases. Happy that is not the case. I really do enjoy my s790's performance.
post #3562 of 3947 Old 09-11-2014, 08:56 PM
levy07's Avatar
Player has been working great but I recently am getting a wait signal when trying to start up the S790 and it just stays there. Unplugged but doesn't help. Any suggestions? Thanks.
levy07 is offline
post #3563 of 3947 Old 09-16-2014, 11:33 AM
levy07's Avatar
Looks like I should just replace
levy07 is offline
post #3564 of 3947 Old 09-17-2014, 10:58 AM
pacman9270's Avatar
Quoted: 83 Post(s)
Liked: 49
Unless you haven't done a hard reboot, then this sounds like a replacement. That sucks. I dread the day that happens to me. I really like my player.
post #3565 of 3947 Old 09-17-2014, 11:30 AM
levy07's Avatar
Haven't tried that yet. I just unplugged for a minute and plugged back in. I did a search now for hard reset and it says hold power down for 10 seconds, is that correct?
levy07 is offline
post #3566 of 3947 Old 09-21-2014, 06:52 PM
pacman9270's Avatar
Quoted: 83 Post(s)
Liked: 49
That didn't work for me either. I unplugged the player for 10 seconds, then plugged back in and powered it up.
post #3567 of 3947 Old 09-22-2014, 06:20 PM
AVfile's Avatar
Quoted: 239 Post(s)
Liked: 125
What is the best replacement for this model from Sony?
Need dual HDMI output, 3D and xvColor.
AVfile is offline
post #3568 of 3947 Old 09-24-2014, 02:25 PM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
bdp-7200 or 6200
Chise is offline
post #3569 of 3947 Old 09-24-2014, 03:17 PM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
Originally Posted by Chise View Post
bdp-7200 or 6200
OOp's I was wrong they have one Hdmi input.
Chise is offline
post #3570 of 3947 Old 09-25-2014, 09:23 AM
AVfile's Avatar
Quoted: 239 Post(s)
Liked: 125
This sucks. I can't find any players that support xvColor (on BD) with dual HDMI out.
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is offline
Reply Blu-ray Players
Blu Ray Players , Sony , Sony Bdps790 3d Blu Ray Player , Sony Blu Ray Disc Player Bdp S790 , Sony Open Box Bdp S790 3d Blu Ray Disc Player
