Official 2012 Sony BDP-S790 Thread - Page 120 - AVS Forum
post #3571 of 3592 Old 09-26-2014, 08:37 AM
phannon's Avatar
I have recently begun using my 790 (purchased last year) as my prime player older my older 760 was beginning to show its age.
Last night I was watching Star Trek - Into Darkness (disc 2 from The Compendium) in DDTHD 7.1 and was having audio dropouts at various points throughout the first 30 min or so....the video was unaffected. The first Star Trek movie on disc 1 in DDTHD 5.1 worked perfectly the evening before. I switched "Into Darkness" over to the 760 and did not experience any dropouts. Has anyone else notic
ed any similar problems with the 790?
The firmware was the original 0460. I have downloaded
the most recent firmware 0497and will install it later today and see if that makes any difference. Other than this glitch, the 790 has not shown any other strange behaviour, except for not displaying a couple JPEG photos (from USB stick) that the 760 seems to show correctly.
Cheers,
P.E.Hannon
phannon is offline
post #3572 of 3592 Old 09-26-2014, 09:43 AM
DoctorM's Avatar
Quoted: 47 Post(s)
Liked: 45
Originally Posted by AVfile View Post
Sony's name for it is "x.v.Color" but in my s770 setup menu there is no option. It's automatic in the player, only needs to be enabled in the display.
(this space for rent)
DoctorM is offline
post #3573 of 3592 Old 10-02-2014, 11:45 PM
cinema13's Avatar
Quoted: 105 Post(s)
Liked: 111
I've watched ST:ID twice on the 790 (3D version) and have never experienced the issue. Of course, The Compendium is a different disc.
cinema13 is online now
post #3574 of 3592 Old 10-03-2014, 02:14 PM
pacman9270's Avatar
Same here. I've watched Into Darkness in 3D and never had audio dropouts. Could be the Compendium Edition disc.
There are never failures, only challenges.
pacman9270 is offline
post #3575 of 3592 Old 10-12-2014, 05:25 PM
jsmiddleton4's Avatar
Quoted: 59 Post(s)
Liked: 24
No problems here either. I do use the dual outs on my S790 so video/audio are split. But no audio drops noted. None on any disk in fact.
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is offline
post #3576 of 3592 Old 10-27-2014, 04:41 PM
Liked: 0
need help
my S790 seems to freeze alot of times when trying to switch it off and im forced to unplug it from the wall socket.
anyone with same problem?
thanx
MeGuinness is offline
post #3577 of 3592 Old 10-27-2014, 05:56 PM
joeycalda's Avatar
Quoted: 24 Post(s)
Hello,
I am not getting the bitstream output to my preamp regardless of setting it to bitsream or PCM. My Marantz 8801 always shows PCM. I have had the unit for just about a year, and never noticed it until recently when watching HD movies from Apple TV, as the Marantz will show the incoming signal.
Joey
joeycalda is offline
post #3578 of 3592 Old 10-27-2014, 08:10 PM
AVfile's Avatar
Quoted: 39 Post(s)
Liked: 58
Originally Posted by MeGuinness View Post
need help
thanx
It froze on me once, 2:04:00 into TF4 blu-ray (2D) but was able to FF a few seconds and keep watching.
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is online now
post #3579 of 3592 Old 10-27-2014, 08:12 PM
AVfile's Avatar
Quoted: 39 Post(s)
Liked: 58
Originally Posted by joeycalda View Post
Hello,
Joey
Are you using HDMI1 or 2 or both?
Is Secondary Audio Off?
- AVStefan
post #3580 of 3592 Old 10-28-2014, 07:59 AM
joeycalda's Avatar
Quoted: 24 Post(s)
Just checked and I a using HDMI 1, there is a small sticker covering the HDMI 2 out, but I see how 1 is video and 2 is audio out if using both. I have no problem using both. I'll Try that and see. Never noticed the secondary audio in the menus, but then again never looked.
Joey
post #3581 of 3592 Old 10-28-2014, 08:20 AM
AVfile's Avatar
Quoted: 39 Post(s)
Liked: 58
Don't use both unless you have to. It gets complicated.
Secondary Audio was ON by default on mine, so turn that OFF. That is most certainly your problem.
- AVStefan
post #3582 of 3592 Old 10-28-2014, 09:52 AM
JChin's Avatar
Quoted: 99 Post(s)
Liked: 135
Hello,
Joey
Hi joeycalda, go into Audio Setting menu to check HDMI Audio is at Auto and that "BD Audio Mix" is turn off (default is on).
JChin is offline
post #3583 of 3592 Old 10-28-2014, 12:49 PM
joeycalda's Avatar
Quoted: 24 Post(s)
That fixed it thanks!!!
post #3584 of 3592 Old 10-28-2014, 01:55 PM
DoctorM's Avatar
Quoted: 47 Post(s)
Liked: 45
Correct me if I'm wrong, but isn't Bitstream specifically for optical/toslink? I'm not convinced it has any effect on HDMI.
DoctorM is offline
post #3585 of 3592 Old 10-28-2014, 10:29 PM
AVfile's Avatar
Quoted: 39 Post(s)
Liked: 58
You're welcome
- AVStefan
post #3586 of 3592 Old Yesterday, 12:02 AM
zoro's Avatar
Quoted: 32 Post(s)
Is it obsolete yet
zoro is offline
post #3587 of 3592 Old Yesterday, 12:54 PM
Liked: 0
Hi im trying to decide between this bluray player or the samsung f7500. Can someone help me decide which is better? They both seem pretty comparable. Will be plugging in ethernet and dont need the smart apps at all since i have an atv. I care about loading time and picture quality. Is this any better then a ps3? Thanks in advance.
i really want the pioneer elite bdp 62fd but theres no way I can find one of those for less then $200 now. So I have to settle...
[edit] - I do like the novelty of having SACD playback on the sony compared to the samsung...thats the only thing I can see so far.
punjabby is online now
post #3588 of 3592 Old Yesterday, 07:01 PM
Turboo2u's Avatar
I have both the Sony and the Panny and I think the Sony is a better player. It gets greats reviews also.
Turboo2u is offline
post #3589 of 3592 Old Yesterday, 08:19 PM
Liked: 0
Thank you for the response. So now ive widenened my horizons and was wondering if you could make another suggestion. I thought I could get the s790 for $180 on the sony store but I cant. The samsung f7500 is $200 on amazon. I have found a pioneer elite 62 for $275. Any suggestions?
post #3590 of 3592 Old Yesterday, 08:58 PM
AVfile's Avatar
Quoted: 39 Post(s)
Liked: 58
I would get ANY Sony over the Samsung or Pioneer. Too many complaints about the latter, very unstable software. Sony has the best software interface, especially if you are used to the PS3. There is better build quality out there but the Sonys are cheap enough you can buy several for the price of one Elite, Oppo, Marantz whatever.
- AVStefan
post #3591 of 3592 Old Today, 05:09 AM
mdavej's Avatar
Quoted: 426 Post(s)
Liked: 383
You can still get 790's on ebay for well under $180, or a Panny 460 for about the same price. When you're trying to find obsolete models like this, you really have to leave the ebay/craigslist option on the table.
May I ask why you need dual HDMI? If you don't really need that, you can just get a current model for a lot less.
mdavej is offline
post #3592 of 3592 Old Today, 06:18 AM
Turboo2u's Avatar
I don't know much about Samsung but you may want to try Best Buy (go online first) and see if they might have
an open-box Pioneer 62. I picked up mine at BB for only $89 a few months ago! (open box). I saw an Elite BDP-80fd at BB yesterday for only $179. Good luck.
Turboo2u is offline
Reply Blu-ray Players
Blu Ray Players , Sony , Sony Bdps790 3d Blu Ray Player , Sony Blu Ray Disc Player Bdp S790 , Sony Open Box Bdp S790 3d Blu Ray Disc Player
