Official 2012 Sony BDP-S790 Thread - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 66Likes
post #2791 of 3947 Old 07-15-2013, 04:58 PM
bakerwi's Avatar
Quoted: 78 Post(s)
Liked: 46
Originally Posted by Chise View Post
Do what I did get all three of them,then you don't have to worry when one don't act right.
Home theater - LG OLED65E6P, Sony UBP-X800, Oppo UDP-203, Arcam FMJ BD300, Denon DVD-5910
Master bedroom - Oppo BDP-103
Breakfast area - Pioneer BDP-320
Office - Sony BDP-S5000ES
Family room - Pioneer BDP-320, Sony BDP-S790
Revel Performa3 F208, C208, M106, M105
bakerwi is offline
post #2792 of 3947 Old 07-16-2013, 05:26 AM
poormxdad's Avatar
Folks,
My fatboy PS3 died and I decided to upgrade to the S790. I've had it a week or so but haven't watched much. "Fifth Element" looked and sounded fantastic. But last night I decided to do the "Matrix" test, starting the movie from "The Lobby Scene", scene 29, since I know the movie well. I had the volume on my Onkyo 805 maxed out, and it was no where near as loud as the PS3 could get playing BDs. I played around with some of the S790 audio settings, but only made slight gains in volume.
A search here did not show others having a volume issue. Has anyone else noticed inadequate volume output from the 790? It may have to go back to Amazon.
poormxdad
poormxdad is offline
post #2793 of 3947 Old 07-16-2013, 03:41 PM
iatacs19's Avatar
Quoted: 239 Post(s)
Liked: 149
Originally Posted by jamieuk147 View Post
Does this play MKV files from USB?
YES.
XBR65X930C, AVR-X4200W, NVIDIA ShieldTV, SVS SB12-NSD, RF-42 II, RC-52 II, RB-41 II
iatacs19 is offline
post #2794 of 3947 Old 07-17-2013, 02:04 AM
Mattyo1612's Avatar
Quoted: 26 Post(s)
Liked: 42
In the Audio settings, make sure you have the Audio DRC switched off and in the DTS Neo:6 switch the sound to Cinema mode which should give the sound more oomph!
Mattyo1612 is offline
post #2795 of 3947 Old 07-17-2013, 04:04 PM
rodelius's Avatar
Hello all.
Hope somebody can shed some light on this.
I have my BDP-S790 connected via twin HDMi cables to my Epson TW9000 projector and to my Denon AVC-A11XVA receiver.
Everything worked great so far. Great picture quality and crisp sound from my old receiver both with 2D and 3D discs. (My receiver IS NOT 3D compatible).
Last week I finally allowed the last firmware to be installed and suddenly the audio separation mode stopped working.
Now the receiver does not get any audio from the player when it is set to audio separation mode. When I try to play a disc or a file over the network, the receiver display briefly flashes some info, but then defaults to external in as if no audio was entering through the HDMi input. As a curious note, after resetting the receiver to factory default and while configuring some surround parameters I briefly got some sound from the player, but it suddenly went off immediately after I confirmed the settings.
I reset both the receiver and the player to factory defaults several times with no luck.
Any ideas? Is there any way to download and install a previous firmware version?
Thanks in advance.
Rod.
rodelius is offline
post #2796 of 3947 Old 07-18-2013, 04:05 AM
poormxdad's Avatar
I should have mentioned I had already checked DRC. It was off. We have since watched the new Schwarzenegger movie, "The Last Stand" and "Hansel & Gretel", and had no volume issues. I have no explanation, but the player seems fine. Still, sometimes I really like cranking up "The Matrix"...
poormxdad
post #2797 of 3947 Old 07-18-2013, 05:33 AM
poormxdad's Avatar
I have another question. Is it possible to use the S790 as a CD player WITHOUT turning on my TV? Right now, I get a "No Signal" message from the Onkyo 805 if the TV is not on.
poormxdad
post #2798 of 3947 Old 07-18-2013, 03:25 PM
mdavej's Avatar
Quoted: 2223 Post(s)
Liked: 972
poormxdad
That doesn't sound right. Why should the Onkyo care if the TV is on, ARC maybe? In any case, you could also use the coax or analog outs for sound only to your Onkyo, then the no signal thing definitely wouldn't be an issue. Just set the sony to auto-play discs. But someone will need to confirm that works with CDs too.
mdavej is offline
post #2799 of 3947 Old 07-19-2013, 02:37 AM
thibsie's Avatar
Except for SACD if it is needed (it'd need HDMI).
thibsie is offline
post #2800 of 3947 Old 07-22-2013, 08:41 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 59
poormxdad
Indeed.
I send DSD bitstream direct to AVR. Only way this will be accomplished is via HDMI.
BTW, I never use display device for audio only media as I consider it inefficient and a waste of resources (power-hungry Panasonic plasma display device).
Iain- is offline
post #2801 of 3947 Old 07-23-2013, 09:02 PM
p5browne's Avatar
Quoted: 3068 Post(s)
Liked: 2389
Seiki 50" 4K coming in this week. Can one HDMI out go to my Radiance XE-3D to fire up my LG 55LHX, and the other HDMI output 4K to the Seiki? Then can I compare the 2 sets?
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is offline
post #2802 of 3947 Old 07-24-2013, 06:01 AM
moxie1617's Avatar
I don't think you'll get 4K out because the EDID feedback will limit the player to the lowest resolution reported if both sets are powered on.
moxie1617 is offline
post #2803 of 3947 Old 07-24-2013, 08:40 AM
p5browne's Avatar
Liked: 2389
May try to circumvent that issue by putting the one HDMI into my Yamaha RX-V673, which will then upconvert to 4K for the Seiki. The other HDMI to my Lumagen XE-3D for the LHX.
p5browne is offline
post #2804 of 3947 Old 07-25-2013, 08:18 AM
thibsie's Avatar
But you can out both HDMI with both audio+video at the same time, can't you ?
thibsie is offline
post #2805 of 3947 Old 07-25-2013, 11:27 AM
moxie1617's Avatar
Yes, but the highest resolution will be that of the lowest resolution supported, ie, no 4K if the other set is on.
post #2806 of 3947 Old 07-25-2013, 05:52 PM
p5browne's Avatar
Liked: 2389
Yes, but as stated above, if I go to my AVR first, then upconvert to the 4K, I should be OK. But since AIT decided to put the delivery of the Seiki in limbo until next week, won't be able to test this weekend.
p5browne is offline
post #2807 of 3947 Old 07-25-2013, 08:21 PM
moxie1617's Avatar
Please update this when you get it. I'd like to know what your results are with 4k upscaling.
post #2808 of 3947 Old 07-26-2013, 03:17 PM
p5browne's Avatar
Liked: 2389
Seiki now here, FW updated, and currently on Pixel Protector Washes. Pixel protector Demo Pics on the Blu-ray looked great. Blacks looked great.
Should start calibrating later tonight once I get the feel for the Menuing system. So far impressed - this could could go either way once I get into it. A good way to get into 4K without spending $ thousands, hoping Manufactures will do HW upgrades in the future, while waiting for the final 4K Standarizations to take place.
p5browne is offline
post #2809 of 3947 Old 07-27-2013, 06:33 AM
p5browne's Avatar
Liked: 2389
Sony 790 works great with the Yamaha upconverting! (Once you figure out how to do it. The Yamaha Manual is very vague with the instructions!)
Sony to the Yamaha HDMI Input and upscaled to 4K and out to the Seiki 4K
Sony HDMI 2 to the Radiance XE-3D and out to the LG 55LHX for 1080P.
Seiki 4K - Great looking PQ, would have been Amazing if they had incorporated Local Dimming. Greyscale Flat from 30 to 100. Very detailed. Those who say you don't see a difference between a 1080P set and the 4K from 10 feet, are wrong, and I need cataract surgery and can see the difference. CMS; bulk of the colours are below the 3 line. For $1100 and getting 4K for now, small price to pay. If I AutoCal with my iScan Duo could make PQ even better, but wanted to see how good I could get it with just the Seiki adjustments.
Tonight will retweak my LHX, and the Seiki. Watched Samsara Upconverted last night. Will let you know
p5browne is offline
post #2810 of 3947 Old 07-27-2013, 03:42 PM
p5browne's Avatar
Liked: 2389
Update: Milky Blacks on the Seiki completely disappeared after everthing was shut down overnight, then restarted today. Probably what CNN Didn't do when they tested the 4K Seiki, and gave bad Black ratings. Re-starting from scratch and calibrating both my LH 55LHX and Seiki from the bottom up, but from what I'm seeing, especially after a Sharpness re-calibration, it was Sharp lines on the Seiki, and Fuzzy lines for the 1080P. So Samsara upconverted from the Sony 790 looks absolutely amazing on the 4K Seiki - and people are paying thousands for a non-standardized 4K TV? Go cheap, go Seiki for now if you want to play with 4K, then put out the monies later when the dust settles and we have real 4K TVs!
p5browne is offline
post #2811 of 3947 Old 07-27-2013, 04:43 PM
moxie1617's Avatar
Have you tried 4K from the 790 to the Seiki? I'm curious how it performs compared to your Radience.
post #2812 of 3947 Old 07-28-2013, 02:14 AM
mariner888's Avatar
Or letting the Seiki do the 4k upconversion?
mariner888 is offline
post #2813 of 3947 Old 07-28-2013, 02:37 AM
canton160's Avatar
Quoted: 24 Post(s)
Liked: 50
No way, the tvs upscaling are not that good.
upscaling dvd > HD from oppo103 was better than the sony KD- 55X9005A (4000£) own upscaling engine
They had same performance upscaling 1080p > 4k
Check this review
http://hometheaterreview.com/sony-xbr-55x900a-ultra-hd-lcd-tv-reviewed/?page=2
so my next step was to test the XBR-55X900A's scaling and other video-processing skills. I compared the TV's internal upconversion with that of the OPPO BDP-103; since the OPPO has a source direct mode, I could easily switch between the TV's UHD scaler and the OPPO's UHD scaler. The Sony processor did only an average job with SD DVDs; the detail level was good, but the Sony failed many of the assorted cadence tests on my HQV Benchmark DVD, and it was a little slow to detect the 3:2 cadence in real-world DVD scenes from The Bourne Identity (Universal) and Gladiator (DreamWorks), resulting in some moiré and jaggies. The OPPO scaler did a better job with all of these tests. I will add, though, that the Sony TV did a better job than the Panasonic VT60 in the deinterlacing and upscaling of SD DVDs. With HD sources, the Sony and OPPO were closer in performance.
Anthem MRX310 | XTZ 93.23 DIY 5.1 (Seas Jantzen Mundorf) | DXD808 | Oppo 103D | LG OLED 55EC930V | Mitsubishi HC5 | Lusoscreen 100"
canton160 is offline
post #2814 of 3947 Old 07-28-2013, 10:05 AM
goldberg96's Avatar
Hey folks. I recently purchase the BDP-S790. Really like it a lot. But I want it on all the time and there's a timeout function that turns it off even when I don't want it off. This is a really big thread so I admit I haven't read it all the way through. Just want to know if there's any way to disable that function so that the unit will stay on all the time?
Thanks ................ Rob
goldberg96 is offline
post #2815 of 3947 Old 07-28-2013, 11:40 AM
drhankz's Avatar
Quoted: 93 Post(s)
Liked: 72
It is a FEATURE you CAN NOT DELETE
drhankz is online now
post #2816 of 3947 Old 07-28-2013, 12:08 PM
wargod's Avatar
Quoted: 45 Post(s)
I am considering this unit and for those of you that have it, what does it not do that another model does do that you are unhappy with?
wargod is offline
post #2817 of 3947 Old 07-28-2013, 09:20 PM
wargod's Avatar
Quoted: 45 Post(s)
I'm considering this player. I want to be able to play an mkv file that is on my PC or on a USB stick. Can this player do it or do I need an Oppo?
wargod is offline
post #2818 of 3947 Old 07-29-2013, 07:36 AM
bluechunks's Avatar
Quoted: 153 Post(s)
Liked: 194
The S790 will do it.
But remember: MKV is only a "container" and the video and audio files within it must also use codecs that the player supports if you want to avoid transcoding/remuxing the files on your media server (PC). The list of officially supported combinations is listed in the S790 user manual available on the Sony support site. Also note that there are different combinations of native container/codec support for local (USB) and network (PC via DLNA) connections.
FWIW, I sold my S790 and use an Oppo 103 for all of my local streaming (I still provide "tech support" for the S790 I bought my parents so I follow this thread.) The DLNA performance, IMHO, is not comparable between the two units as the Oppo plays virtually everything natively while the S790 performs best with a DLNA server than is able to transcode/remux to meet the S790's more limited container/codec support. For example, Serviio works great because it has a profile for Sony players and can automagically serve the Sony media it supports.
BUT.....the Oppo is also a $499 player. There are dedicated media streamers from Dune and Mede8er for much less if you don't need/want everything in a single unit. The S790 is an awesome disc player and purchased in conjunction with a dedicated media player is still less expensive than the Oppo. The Oppo simply has the advantages of being built like a tank, great support, and contained in a single unit. And the Oppo still doesn't offer all the streaming services of the S790 (Amazon for example.)
It's simply a matter of deciding which features are important and at which price point.
__________
Visio P65-C1 / Oppo UDP-203 / Nvidia Shield / Roku Ultra / TiVo Bolt
Yamaha RX-A2060 5.1.4 / KEF iQ / Speakercraft (Ceiling) / Hsu sub / Celerity 50' Fiber HDMI
bluechunks is offline
post #2819 of 3947 Old 07-29-2013, 02:57 PM
wargod's Avatar
Quoted: 45 Post(s)
Thanks for the very informative reply! Where can I find a good price on a dune media streamer?
wargod is offline
post #2820 of 3947 Old 07-29-2013, 03:11 PM
bluechunks's Avatar
Quoted: 153 Post(s)
Liked: 194
For a used unit, try the AVS classifieds. Otherwise the hyperlink in my post above takes one to the USA store. Other worldwide Dune dealers are linked on Dune's main web site.
__________
Reply Blu-ray Players
Blu Ray Players , Sony , Sony Bdps790 3d Blu Ray Player , Sony Blu Ray Disc Player Bdp S790 , Sony Open Box Bdp S790 3d Blu Ray Disc Player
