The Pioneer BDP-62FD/150/450 2012 Blu-ray Player Thread - Page 24 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #691 of 718 Old 08-03-2015, 09:53 PM
truelies1's Avatar
How to remove cinavia on this player?really tired it can't read backup Blurays.
truelies1 is offline
post #692 of 718 Old 08-04-2015, 05:10 AM
Super Moderator
teachsac's Avatar
Quoted: 681 Post(s)
Liked: 1058
Unfortunately, Cinavia is part of the BD spec. We do not allow player hack chat in the forums.
As always, no hacking chat.
Moderator request: please read BEFORE you Post
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #693 of 718 Old 10-19-2015, 11:32 PM
latreche34's Avatar
Quoted: 136 Post(s)
Liked: 64
Version 1.08 is on the Pioneer website for the BDP-150 anyone installed it? If installed can it be downgraded?
latreche34 is offline
post #694 of 718 Old 10-21-2015, 12:20 AM
latreche34's Avatar
Quoted: 136 Post(s)
Liked: 64
Ok we received the BDP-150 today and it came with V01.02 firmware, I see now that Pioneer has v1.08 on their website, so if I ever upgrade to it will I be able to downgrade later on, I just want to check it out before I load the custom firmware, not that I have any issue at all with v01.02, so far it played everything I thru at it, except for region B blu-ray discs, although id did play one original region B disc TAXI 4 maybe they just labeled it B on the case but they didn't actually code it.
post #695 of 718 Old 11-02-2015, 07:19 PM
latreche34's Avatar
Quoted: 136 Post(s)
Liked: 64
After playing with the BDP-150 for over a week now, I see that after loading the CFW I can't keep BD-Live on all the time, every power down it goes to disabled by default, is there a way to keep it on or just to get rid of the message that pops up every time I load a disc?
post #696 of 718 Old 12-01-2015, 05:57 PM
truelies1's Avatar
Weird thing happened to 62fd 4.04. Today the TV shows "unsupported signal....", seems after play a PAL blu ray, it keeps output PAL on 'home menu', so the TV can't recognize it. Also HDMI->Resolution can't select "Auto".
post #697 of 718 Old 12-01-2015, 06:40 PM
truelies1's Avatar
The problem may be it shows 50hz on the panel, how to make it 60hz so TV can show menu.
post #698 of 718 Old 12-01-2015, 08:02 PM
truelies1's Avatar
Originally Posted by hardcorrwin View Post
anyone know how to get the 62FD out of 50hz mode? I tried to watch an Australian blu-ray and it switched the output to 50hz and now I've had to hook it up to a small PC monitor and I cannot seem to find anywhere how to return it to 60hz so my 52" and receiver will work with it. thanks.
Seems I have same problem with you. 62FD saves the 60hz, but the menu is at 60hz, did you figure out how to go back to 60hz?
post #699 of 718 Old 12-02-2015, 07:53 AM
hardcorrwin's Avatar
Been awhile but I seem to recall it was a matter of putting an NTSC DVD into the player - not a PAL DVD or any Blu-ray
hardcorrwin is offline
post #700 of 718 Old 12-05-2015, 05:33 AM
Skylinestar's Avatar
Quoted: 1080 Post(s)
Liked: 188
I'm thinking of getting a Pioneer bdp. How often do Pioneer release firmware update?
Skylinestar is offline
post #701 of 718 Old 12-13-2015, 03:58 PM
hotshaggy's Avatar
Liked: 0
Yes, after upgrade my 62fd to CFW 0404 I lost PAL to NTSC automatic conversion as well , I can watch only Region B blurays in 24Hz not 50 Hz on Panasonic plasma. Put any DVD Region 1 60 HZ and Pioneer 62 fd will be back to NTSC....
hotshaggy is offline
post #702 of 718 Old 12-13-2015, 03:59 PM
hotshaggy's Avatar
Liked: 0
PAL to NTSC
post #703 of 718 Old 01-01-2016, 10:07 AM
Quoted: 12 Post(s)
Liked: 0
BDP-62FD Player
Hi everyone, I'm in the market for a new blue ray player, normally I just download everything I watch. I came across this player on kijiji and was wondering if this is a good player for 200cnd
Aceman2101 is offline
post #704 of 718 Old 01-01-2016, 10:29 AM
Edllguy's Avatar
Quoted: 124 Post(s)
Liked: 57
It is a good blu-ray player. I have one myself. Purchased for $200.00 U.S. when they were on clearance at Magnolia Home Theater in buffalo.
I think that price is kind of high since it is a 2012 model, however, I remember these units would not sell in Canada below $350.00 Canadian NIB.
Personally the price is a little high for 2nd hand player if that is the case.
All the best in your decision.
Edllguy is offline
post #705 of 718 Old 01-01-2016, 11:25 AM
Quoted: 12 Post(s)
Liked: 0
What would you say is a reasonable price ?
post #706 of 718 Old 01-05-2016, 05:21 AM
akhil7j's Avatar
BDP-450 has Netflix? Its showing on the official website but in the web contents, i only see YouTube Picasa..
akhil7j is offline
post #707 of 718 Old 01-23-2016, 04:07 PM
jerrold14's Avatar
I have a BDP-62FD, I'm having a weird problem. Every old blu-ray movie I have plays fine, any new blu-ray I purchased over the past month keeps skipping in the player yet all of the old movies play fine. I purchased inside out, ant man and Jurassic World they all seem to skip like crazy during the movie previews but once the movie starts (if I can get past the freezing and skipping) the movie itself seems to play fine. has anyone heard of this? any help would be appreciated.
jerrold14 is offline
post #708 of 718 Old 04-21-2016, 02:13 AM
Two Cents's Avatar
Quoted: 17 Post(s)
Hey all. First post in this thread. Haven't needed to till now.
I have a BDP 150 & today all of a sudden it's decided it's too good to play DVDs.
Plays any Bluray fine. No problems. Just DVD not doing it.
Tried five different DVDs.
Anyone experience this or know of a fix?
Samsung JS9000. Epson TW-9100, Alienware Alpha i7. Xbox one, Samsung UBD K8500.
Two Cents is offline
post #709 of 718 Old 05-17-2016, 04:56 PM
lasab's Avatar
Quoted: 21 Post(s)
Liked: 7
I have new (old stock) BDP 450 which developed not reading DVDs and SACDs after just one hour of use.
Reads BluRays and CDs fine
I have ordered a new laser carriage with laser pickup SF-BD415
Hope this will fix it.
Does anyone know if I have to adjust the laser or just install?
http://www.ebay.com/itm/152031756638
lasab is offline
post #710 of 718 Old 05-18-2016, 09:40 PM
Two Cents's Avatar
Quoted: 17 Post(s)
I got told it would cost more to fix than to buy a new one so I just bought a new one.
post #711 of 718 Old 05-20-2016, 07:13 PM
lasab's Avatar
Quoted: 21 Post(s)
Liked: 7
FYI the loader part number for the BDP450 is
LOADER ASSY is 08-LTCA19-LD0
lasab is offline
post #712 of 718 Old 08-10-2016, 12:35 AM
Liked: 0
Did the new pick-up fix the problem?
tarkatehen is offline
post #713 of 718 Old 09-25-2016, 05:05 AM
Liked: 0
I like to purchase this player:
Pioneer BDP 450 and I like to know if this player support MKV file with audio DTS HD master and Dolby True HD.
My marantz UD5005 support file MKV only with audio Dolby digital and DTS.
alex5671 is offline
post #714 of 718 Old 01-04-2017, 05:30 PM
Liked: 1
Originally Posted by scoughlan View Post
If anyone, at their own risk, wants to install custom firmware on the Pioneer BDP-450 then please contact me directly. I had an 'instructional' post but the moderator slapped my wrist and deleted it.
The modification can be done from version 2.12 (current) downwards.
Hello Scoughlan
Greetings from Norway!
If you're still around on this forum, reading this message and have a bit of spare time:
I would like your opinions and advices regarding a unused Pioneer BDP-450 with original firmware 2.09.
It seems I need to post 5 times before I can leave any contact info.
Kind Regards
Allan
Electric Rod is offline
post #715 of 718 Old 01-04-2017, 05:42 PM
Liked: 1
Does anyone know if there's Region A BD-players (NTSC) that can accept 230V without an external adapter?
Any multiformat BD-players found at Amazon which actually plays all BD-zones?
post #716 of 718 Old 01-04-2017, 05:45 PM
Super Moderator
teachsac's Avatar
Quoted: 681 Post(s)
Liked: 1058
There's a dedicated thread for region free players.
Region Free Blu Ray player discussion
teachsac is offline
post #717 of 718 Old 01-04-2017, 06:49 PM
Liked: 1
Please contact me at ajstroe@online.no
post #718 of 718 Old Today, 04:30 AM
Super Moderator
teachsac's Avatar
Quoted: 681 Post(s)
Liked: 1058
S~
No hack chat. Take all CFW chat to pm.
teachsac is offline
Reply Blu-ray Players
Blu Ray Players , Pioneer
