The Pioneer BDP-62FD/150/450 2012 Blu-ray Player Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #181 of 718 Old 03-14-2013, 10:47 PM
Advizer's Avatar
Liked: 24
ralf71,
try to change some picture settings.
Advizer is offline
post #182 of 718 Old 03-15-2013, 11:52 PM
scorilo's Avatar
New here.Hi to everybody and thanks for all your work/help.
I want to buy a Pioneer so please help.What i undestand by now-please correct if i'm wrong:
-the 450 model needs version 2.05 to aply cfw,the 440 model does not matter which version it has.
-the cfw for 440-4.02 is better then the one for 450-4.03.All cfw are Cinavia free.
-if i aply the 4.03 cfw on the 440 can i go back to 4.02?
-are there differences in picture quality between the 440 and 450?Which one do you recomend to buy?
scorilo is offline
post #183 of 718 Old 03-16-2013, 03:47 AM
Advizer's Avatar
Liked: 24
Originally Posted by scorilo View Post
1)-the 450 model needs version 2.05 to aply cfw,the 440 model does not matter which version it has.
2)-the cfw for 440-4.02 is better then the one for 450-4.03.All cfw are Cinavia free.
3)-if i aply the 4.03 cfw on the 440 can i go back to 4.02?
4)-are there differences in picture quality between the 440 and 450?Which one do you recomend to buy?
1) Right.
2) Wrong. 4.04 (not 4.03) for 450 allows to use NFS protocoll and supports ext2/3/4 as well as 3TB external HDD.. These are real advantages over 4.02 (without alphabetical chaos) for 440. There's CFW 4.03 for 440 without NFS. Yes, Cinavia got killed rolleyes.gif
3) Right. Besides, you can simply downgrade to a factory FW by simply renaming FW-file as "BDP-440_SP.bin". It should work for 1.xx, but I don't know if it's possible for factory FW 2.xx.
NB: Be careful with BDP-450. You can downgrade only once, as the factory FW2.09 can't be hacked and FW2.05 can't be downloaded from the official Pioneer internet page.
4) It depends on prices. BDP-450 is definitely better as it has 2xHDMI, QDEO (DVD-upscaler, etc), but there's no any DAC.
Advizer is offline
post #184 of 718 Old 03-16-2013, 07:15 AM
scorilo's Avatar
Thank you Advizer!
I didn't know that the 440 doesn't have the Qdeo chip-for me it's important because i still have many DVDs.
I think the Qdeo offers better upscalling then what a TV does-right?
scorilo is offline
post #185 of 718 Old 03-16-2013, 07:45 AM
Advizer's Avatar
Liked: 24
scorilo,
If I were you, I would buy BDP-450. Yes, QDEO is good as DVD-upscaler. Besides, 450 is interesting regarding software support, cause this model is very popular in China.
Advizer is offline
post #186 of 718 Old 03-16-2013, 08:17 AM
scorilo's Avatar
Thanks again Advizer.Will follow your advice.
scorilo is offline
post #187 of 718 Old 03-24-2013, 06:09 PM
raif71's Avatar
Quoted: 129 Post(s)
Liked: 52
Anyone noticed lip-sync issue with bdp-450? I'm talking about playing mkv and bd-iso from the usb. My setup is hdmi(450 has 2, so this is from "main hdmi") to avr (onkyo). Appreciate any help to overcome this.
raif71 is offline
post #188 of 718 Old 03-24-2013, 10:49 PM
dreamworlds's Avatar
Hi all, I just flash my Pioneer BDP-150 with the CFW v4.03, and activated with the "keygen" software found from this thread.
I have a problem of displaying the "Other" subtitle from the USB I plugged in. From the previous thread, it seems like I just need to do the following:
1. Change the SRT subtitle file name to "Sub.srt", and put it on the root of the USB drive
2. Choose "Other" from the Subtitle button
I tried both Unicode and ASCII format, and also tried to change the subtitle format from the system menu. None of those steps help.
I am trying to play the original blu-ray disc (which is BDMV) with a subtitle that doesn't come with the disc.
Anyone can help me out on this problem? This is the main reason I bought this blu-ray player, I thought the CFW has this feature.
Thanks a lot!!!
dreamworlds is offline
post #189 of 718 Old 03-26-2013, 11:32 PM
Advizer's Avatar
Liked: 24
dreamworlds,
if I'm not mistaken, .srt file must have the same name as the video file does. Have you tried this already?
Advizer is offline
post #190 of 718 Old 03-27-2013, 12:27 AM
If I am playing the original blu-ray disc (not any ISO or MKV), what file name I should use on my srt file? Do I have to put the blu-ray disc on the blu-ray rom on the computer to find out the name? I thought somebody said they were able to use the "Sub.srt" when they play the blu-ray disc.
Have you tried this?
post #191 of 718 Old 03-28-2013, 07:33 AM
reki1978's Avatar
Originally Posted by Advizer View Post
dreamworlds,
Guys could you please help me out.I am in the process of buying the bdp 450 could you please verify that it can display external srt files with greek encoding?? CP1253??
Another questionIs it possble for bdp 450 or (150) to play mkvs with aac and dts-hd soundtracks??
Could you please spare some minutes to help me.I am trying here in greece to find a showroom in order to perform some tests but no luck
reki1978 is offline
post #192 of 718 Old 03-28-2013, 08:15 AM
raif71's Avatar
Quoted: 129 Post(s)
Liked: 52
reki1978, if your media is mostly mkvs, you're better off buying a media player. Imo, media player manage mkvs much better than bluray players especially in the subs department. I use the bdp-450 to play bd-iso though once in a while I play some mkvs but I have a media player for that.
raif71 is offline
post #193 of 718 Old 03-30-2013, 07:52 AM
grill's Avatar
Hi Folks,
I'm into SACD iso playback. I know there is already a Chinese CFW (2013/03/22) for SACD iso playback on 450. I d/l-ed that fw but I don't speek Chinese so I can't contact the developer for further details. Can any of you help me?
grill is offline
post #194 of 718 Old 03-30-2013, 01:45 PM
Advizer's Avatar
Liked: 24
Originally Posted by grill View Post
Hi Folks,
If you've installed it, get ready to pay...
Advizer is offline
post #195 of 718 Old 03-30-2013, 02:06 PM
ray16kv's Avatar
Oh good Lord! I just bought a 150, and am i going to have any problem playing 3-D Blu-ray on it? I have a Pioneer SC-61 Do I have to change any settings? Or can I just put the disc in and play?
ray16kv is offline
post #196 of 718 Old 03-30-2013, 02:18 PM
silvereyes's Avatar
sacd.iso playback is indeed worthwhile. But to who do you pay? How do you contact the Chinese programmer?
silvereyes is offline
post #197 of 718 Old 04-01-2013, 09:32 PM
raif71's Avatar
Quoted: 129 Post(s)
Liked: 52
I have this sacd iso for example named abc.iso. However looking through the "Music" folder, I cannot view this file. So, how do I actually play sacd iso? I'm using bdp-450 with cfw.
raif71 is offline
post #198 of 718 Old 04-02-2013, 02:36 AM
Richard Owen's Avatar
I don't suppose anyone has a copy of the CFW v5.09c or newer.??
PM me if you do..
Rich..
Richard Owen is offline
post #199 of 718 Old 04-02-2013, 10:08 AM
Advizer's Avatar
Liked: 24
Which version? Normally, you have to burn a DVD-R/RW using ImgBurn.
Advizer is offline
post #200 of 718 Old 04-02-2013, 10:16 AM
Sorry, I just saw your reply. After days of investigation and try-outs, I finally found out the answer of this.
The answer is Yes and No. Yes, after you flash the firmware v4.03/4.04, you will be able to use the external subtitle in srt format with the USB drive. However, not all the blu-ray disc works with this feature. (I was stuck on this for a while). So far, I tried the "Africa", "Planet Earth", they don't work with this feature, which I need the most. frown.gif But for other movies, it works, like "The Pacific". It seems like all those BBC blu-rays doesn't work.
I think the version 5.01 or above will solve this problem (meaning all the disc will work), but I am not sure, since there is NO keygen for the version 5 or above. Therefore, unless you find a way to pay to buy the key to unlock the new CFW, otherwise, flashing to version 5.01 doesn't give you any benefit. Also, there is no way to downgrade this as well. So unless you know what you doing, otherwise, don't flash the version 5 or above, stay in version 4.
For the Greek coding, I don't know, I will check that tonight for you, because I don't know Greek. I believe you will use the UTF-8 codec instead. So I think it should be fine. But I am not sure, and I can't test that for you.
I haven't tried any of the mkv or iso format yet. so I have no comment on that. Also, my machine is BDP-150, I believe the CFW has the same functionality.
If you really need this feature, and you don't want to waste your time on doing this, buy the OPPO BDP-93/95 or BDP-103/105, they will supported on its stock firmware, plus the quality is much better. I know it is very pricey, but you get what you pay for.
I hope this helps.
post #201 of 718 Old 04-02-2013, 10:22 AM
Advizer's Avatar
Liked: 24
DEL
Advizer is offline
post #202 of 718 Old 04-02-2013, 03:34 PM
raif71's Avatar
Quoted: 129 Post(s)
Liked: 52
5.05. Hmm, I really thought that I just could play sacd iso similar to bd-iso but I guess I'm mistaken, even with cfw - right?
raif71 is offline
post #203 of 718 Old 04-02-2013, 09:27 PM
Advizer's Avatar
Liked: 24
5.05=4.04. Right you are.
Advizer is offline
post #204 of 718 Old 04-02-2013, 10:53 PM
raif71's Avatar
Quoted: 129 Post(s)
Liked: 52
Thanks. I already burned the iso using imgburn. Got couple of warnings. I will get in touch if the disc is unplayable. Just for some info, is there another version of cfw that will read sacd iso without burning to dvd disc ?
raif71 is offline
post #205 of 718 Old 04-02-2013, 11:59 PM
Advizer's Avatar
Liked: 24
It already exists but it's not free of charge.
Advizer is offline
post #206 of 718 Old 04-03-2013, 06:58 AM
raif71's Avatar
Quoted: 129 Post(s)
Liked: 52
OK sacd burned to dvd disc success playing with bdp-450. 5.1 surround music smile.gif. Hmm, some of the other sacd - iso/nrg/flac that I have , have problems with imgburn however, thank you so much Advizer.
raif71 is offline
post #207 of 718 Old 04-04-2013, 01:20 AM
Kilian.ca's Avatar
Liked: 37
If you need to burn it to DVD for it to play that's not sacd.iso but only SACD-R support, which I suspect the player does natively without cfw (as last year's players do).
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #208 of 718 Old 04-04-2013, 03:45 AM
raif71's Avatar
Quoted: 129 Post(s)
Liked: 52
Yeah, I guess the current cfw that I have does not support playing sacd iso. That I understand now.
raif71 is offline
post #209 of 718 Old 04-04-2013, 10:56 AM
grill's Avatar
The latest Chinese fw supports SACD iso playback on 450 and LX55 ... for $160. I have no Pio players but waiting for such a fw for 140 (no ETA yet).
grill is offline
post #210 of 718 Old 04-06-2013, 07:34 PM
raif71's Avatar
Quoted: 129 Post(s)
Liked: 52
When you say that you have "no Pio players", you meant that you don't have any 450 or that you don't have any players ?
raif71 is offline
Reply Blu-ray Players
Blu Ray Players , Pioneer
