Need Help with Samsung BD-C5500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-18-2012, 12:29 AM - Thread Starter
supra94's Avatar
Hi guy,
I got a C5500 and i used Optical Quantum BD-R 25GB to burned some movies and put the disc in the C5500 it said cant read the disc and then eject by itself. And i use the same disc put in the LG BD611 and it work just fine. I wondering is cause by the discs or the Player(tried 10s discs already)?
Are anyone have the same problem and got it solved. Please help.
supra94 is offline
post #2 of 2 Old 02-18-2012, 08:16 AM
Super Moderator
teachsac's Avatar
Quoted: 652 Post(s)
Liked: 962
Welcome to AVS. Please direct your questions to your player thread. Good luck.
http://www.avsforum.com/avs-vb/showt...highlight=5500
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Closed Thread Blu-ray Players
Samsung Bd C5500 1080p Blu Ray Disc Player , Samsung Refurbished Blu Ray Disc Player Bd C5500 B
