Denon DBP-2010ci wont play any bluray - AVS Forum | Home Theater Discussions And Reviews
Old 02-19-2012, 07:51 AM - Thread Starter
Ps0831's Avatar
I was noticing that my 2010ci was freezing during Tron and True Grit BD's, then Jurassic Park. It plays DVD's just fine but now any BD I load will not play. It sits on 'Loading' for a while and then rejects the disk. I checked the firmware and it's listed as 1.015, which isn't even available on the Denon website, so I'm not sure how it was updated but i did notice that most of these problems started after my latest network update. Is it possible that an update would render all BD's unplayable or is this a problem with the player that needs service? Any thoughts are greatly appreciated.
Ps0831 is offline
Old 02-19-2012, 08:26 AM
Super Moderator
teachsac's Avatar
Quoted: 667 Post(s)
Liked: 1022
Welcome to the forum. Please copy your post in the owner's thread of the Denon as mods will lock this one. Sorry you are having trouble. Mine is still chugging along just fine. Usually not playing any blu-ray means the blue laser is going out or shot.
http://www.avsforum.com/avs-vb/showt...ght=denon+2010
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Old 02-19-2012, 08:32 AM - Thread Starter
Ps0831's Avatar
Thanks, post has been copied.
Ps0831 is offline
