Official Panasonic DMP-BDT 220/320/500 Owners Thread - Page 144 - AVS | Home Theater Discussions And Reviews
post #4291 of 4302 Old 01-03-2015, 09:31 PM
OrioniS's Avatar
Originally Posted by mdavej View Post
My PC also runs 10-20W max, so that's not an issue. Rather than trying to make one box do everything, use the best tool for the job, Roku for apps, PC (or Android) for files and a BD player for discs. Even the cheapest universal remote makes switching sources simple and seamless.
...and this is exactly what I do all the time, PC Media Player for 95% of my watching time, Virgin Box/Android Tablet for netflix if I need it... Panasonic BD Player... -> back to box ;-)
OrioniS is offline
post #4292 of 4302 Old 01-04-2015, 02:56 AM
bernardo61's Avatar
Originally Posted by OrioniS View Post
Youtube is not the problem, Netflix is. It's proprietary software and it will not be distributed without Netflix approval, so.. no.
Fortunately, there is way out of this: It will depend on what platform you want to use.
On Android and Windows there is XBMC/KODI (OpenELec is derivative of them, and is just made very light).
Install Android x86 and KODI and Netflix app and just run it as you would... I need to check it out if is possible, but should be fine...
Will report back my finding soon as I got somewhere.
Hi and thanks again for the valuable advice
I would stop here not to go OT too much but i got your message about the higher flexibility of a pc based media player
Much higher actually
Thanks again, bern
bernardo61 is offline
post #4293 of 4302 Old 01-04-2015, 08:26 AM
Wendell R. Breland's Avatar
Quoted: 148 Post(s)
Liked: 82
My NVidia 610 can do 4K without any fuss, but I don't have 4K TV just yet, so... and it will add 10W to total power usage of x86 platform...
According to the NVIDIA site the 610 is limited to 2560x1600 max, well below 4K (4096 x 2160) or UHD (3840 x 2160). The GTX 650 is the lowest model that supports 4K as seen here.
Wendell R. Breland is offline
post #4294 of 4302 Old 01-04-2015, 08:40 AM
OrioniS's Avatar
Oh.. that's a new one: When I was looking for gfx card they specifically said 4k ready. We all knew that 610 is rebranded 520, but they upgrade firmware on it, also DirectX and stated that 610 DOES 4k, where 520 did not... Interesting... Thanks for letting me know, you always learn something new about NVidia ;-)
tossers ;-) Had a look in both cards just now and is straight copy of specification... unbelievable...
ehh... never mind, you know the score, I can always replace it if I need it... but with low powered windows box you can run both xbmc/kodi and netflix and hulu and whatever you like not losing much in case of upgrades... this part I'm sure ;-)
OrioniS is offline
post #4295 of 4302 Old 01-04-2015, 08:47 AM
Super Moderator
teachsac's Avatar
Quoted: 199 Post(s)
Liked: 220
Please video card discussion to the HTPC area.
Thank you.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself
teachsac is online now
post #4296 of 4302 Old 02-22-2015, 05:18 PM
toofast68's Avatar
Quoted: 102 Post(s)
Liked: 27
Long thread, but I could not find anything.
I have a lightly used DMP-BDT220.
Lately it has had some issues reading disks. It might get 1/2 way through, and then the BluRay gets all jumbled, etc...like the disc is bad.
But I play it my old school PS3 and it plays perfectly.
Do the internals get dirty ? Any "heads" need cleaning ?
If I missed it in this long thread, sorry!
Thanks in advance for helping!
toofast68 is online now
post #4297 of 4302 Old 03-01-2015, 10:44 AM
Liked: 2
is your 220 on the latest firwmare ver 1.80
and is your 220 connected to the internet so that you can update the firmware from the gui on the 220
pcourtney is offline
post #4298 of 4302 Old 03-01-2015, 11:07 AM
Liked: 2
according to Panasonic, BD Live content requires a fast internet connection and an SD card with at least 1 GB of free space
so I have finally hooked up a fast ethernet cable from the garage to the lounge, and put a 2GB SD in the 320
has anyone found BD Live content to be useful, or is it a bit of a fad ?
which discs have the best BD Live material so I can buy a few :-)
post #4299 of 4302 Old 03-13-2015, 01:01 PM
zeez's Avatar
Quoted: 17 Post(s)
Hi All,
I tried searching for the word "burned" in this thread and didn't find what I was looking for. I would like to try and burn the the Reference Demo Discs that the AVS community has put together (link below) and would like to know if they will work on the bdt220 or if I am wasting time. I ask before attempting since I do not have a burner and would need to ask a friend to do this.
AVSForum Demo discs - Independently Authored
zeez is offline
post #4300 of 4302 Old 04-05-2015, 01:04 PM
Liked: 1
I didn't have any luck making DVD versions of the demo discs even with trying the different ways to make compatible versions. I broke down and got a Blue-Ray burner and those have worked great.
zeez likes this.
Quigley.Wyatt is offline
post #4301 of 4302 Old 04-07-2015, 11:59 AM
Quoted: 41 Post(s)
Liked: 9
Originally Posted by zeez View Post
Hi All,
Old question but I did burn the AVS forum calibration disk and play it in my Panny BDT220, worked well and was able to calibrate my tv.
zeez likes this.
iluvwahoo is offline
post #4302 of 4302 Old 04-08-2015, 03:53 PM
zeez's Avatar
Quoted: 17 Post(s)
Thank you, quigley.wyatt and iluvwahoo. I did try to make the BD9 discs and they played..kind of. I think my dvd burner is on it's way to heaven so that may have caused some problems. I will see if I can get someone to make a bluray for me.. thank you very much for letting me know this player can handle it.
zeez is offline
Reply Blu-ray Players
Blu Ray Players , blu-ray , Panasonic , panasonic 220 , Panasonic Dmp Bdt220 Integrated Wi Fi 3d Blu Ray Dvd Player , Panasonic Dmp Bdt320 Integrated Wi Fi 3d Blu Ray Dvd Player , Panasonic Dmp Bdt500 Integrated Wi Fi 3d Blu Ray Dvd Player , purple , receiver , tint
Gear in this thread - Bdt220 by PriceGrabber.com
