Official Panasonic DMP-BDT 220/320/500 Owners Thread - Page 149 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #4441 of 4448 Old 09-19-2016, 07:51 AM
Jben04's Avatar
Quoted: 51 Post(s)
Originally Posted by ausdavep View Post
Yeah, any brand is relatively cheap now, maybe time for UHD?
To further troubleshoot, could you try a different input into your amp. If the problem goes away, then that would make it more an amp issue (although thats probably worse :/ ).
Aww hell,, hope its not an amp issue.. but on the plus side i got a 3 year warranty on it..lol,,better get to work on it.
LG 47LW5600 (3D) - Energy take classic 5.0 - SVS PB-1000 - Panasonic BDT220 (3D) - Sony BD S350 - Sony BDP-S1700 (Region Free) -
Denon AVR X2100W - Harmony One Remote - Harmony Ultimate One.
Jben04 is offline
post #4442 of 4448 Old 12-22-2016, 11:03 AM
Liked: 0
I'm looking for some help - no video only getting audio from my Panasonic blu ray to my TV:
I have a Panasonic BDT220 Blu Ray, Sony XBR75x850, and Denon 3312ci receiver. The issue is I can't get video from the blu ray to the TV (through the receiver), although I do get audio.
I've check all cable connections and I am using high speed HDMI.
I've also tried hooking the Panasonic blu ray directly to the Sony TV via HDMI and that does infact work.
I also have hooked up my set top box (AT&T Uverse) through the receiver and I do get audio AND picture to the TV.
The receiver has two HDMI out ports, and I do get audio AND video from the other out port (using blu ray) to a separate television (it is a Samsung and uses a shorter HDMI cable and yes I've tried switching between the two HDMI out ports, with no success).
Any thoughts?
The only thing I can think is the HDMI cable is too long (I think it's 50 or 75 feet), but not sure this is the issue as I noted before I do get a audio and video with the Uverse box using the same cable and output/input ports. Or, is there some issue with the blu ray going through the receiver to the TV - possible "handshake" issue?
Any help would be greatly appreciated
Jon_V is offline
post #4443 of 4448 Old 04-28-2017, 07:06 PM
Liked: 0
Panasonic DMP-BDT 320 - No audio
Hello,
Wondering if anyone else has run across this.
Panasonic DMP-BDT 320 straight into a new Vizio 40: D series UHD 4K TV. Rented a copy of "The Founder" from Redbox. No issues until the actual movie begins. No audio on scene 1 or subsequent scenes. Title screen audio is fine. Bonus features audio is fine. Same thing on second disc from Redbox. No audio from either English or Spanish tracks. Ensured all audio options are off. Two other Blu-ray disc (different titles) play fine. Firmware up to date.
Any thoughts?
NWLLN is offline
post #4444 of 4448 Old 07-11-2017, 01:00 PM
Paul.R.S's Avatar
Quoted: 42 Post(s)
Panny DMP-BDT220 on latest fw (1.63) has stopped playing BDs (CDs and DVDs fine AFAIK so far). Likely nothing that can be done. Sigh. Will continue to use it for CDs.
Paul.R.S is offline
post #4445 of 4448 Old 07-11-2017, 01:14 PM
Super Moderator
teachsac's Avatar
Quoted: 783 Post(s)
Liked: 1285
If you haven't already, try cleaning the laser.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #4446 of 4448 Old 07-11-2017, 02:03 PM
Paul.R.S's Avatar
Quoted: 42 Post(s)
S~
Thanks, teachsac. I'm using a Trisonic cleaner I have on hand. Tried it dry (no "cleaning solution") applied the first time and it didn't work. I applied some of the solution and am running it longer now.
Paul.R.S is offline
post #4447 of 4448 Old 07-11-2017, 02:50 PM
Paul.R.S's Avatar
Quoted: 42 Post(s)
That did not work either.
Paul.R.S is offline
post #4448 of 4448 Old 07-16-2017, 10:55 PM
Jim McC's Avatar
Quoted: 157 Post(s)
Liked: 64
I stream Netflix thru my BDT-230, and tonite my Netflix screen looked terrible on my projector. I then checked my projector's(Mits. HC3800) resolution output, and it was 720X480. I then started a movie and there was no audio. I then tried my OTA-HD tuner and the image was good, but no audio there either. I then tried my receiver's FM stereo and it worked fine.
We had thunder and lightning last night, and all my components plug into a surge protector.
Does anyone have any advice how to troubleshoot this?
Is it possible the storm messed up the Blu-ray player AND the audio on my OTA-HD tuner?
Thanks for any advice.
Jim McC is offline
Reply Blu-ray Players
Blu Ray Players , blu-ray , blu-ray dvd player , Panasonic , panasonic 220 , Panasonic Dmp Bdt220 Integrated Wi Fi 3d Blu Ray Dvd Player , Panasonic Dmp Bdt320 Integrated Wi Fi 3d Blu Ray Dvd Player , Panasonic Dmp Bdt500 Integrated Wi Fi 3d Blu Ray Dvd Player , purple , receiver , tint , touchpad remote control
