BD-D5500 causing source changes?????? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-24-2012, 07:50 AM - Thread Starter
TallEddie1981's Avatar
Hi, hope this is the correct section for this question.
First, my setup:
TV: Samsung UN55D7000
Blu Ray: Samsung BD-D5500
Receiver: Onkyo TX-NR609
Satellite: DirecTv
The satellite and blu ray connect to the reveiver via HDMI, and the receiver connects to the TV via HDMI (connects to HDMI 2 (ARC) on TV)
My issue: when i turn on the blu ray, the receiver switches to the correct input, and the TV input stays selected on HDMI2. No problem here. The problem is when I turn off the blu ray. When I turn it off, the receiver changes to the TV/CD input AND the TV changes to the TV input. I can then press the CBL/SAT button, and the audio from the directv receiver will play, but I have to manually change the input on the tv from TV back to HDMI2.
I can't fugure out what is causing the TV input to change, what can I do to make it stay on HDMI 2 all the time.
Also, if I change the receiver to CBL/SAT, and then turn off the blu ray, the TV input is not affected.
I also tried turning off the DirecTv box, and it doesn't cause any inputs on the receiver or the TV to change.
Not sure if this is a handshaking issue, anynet+ issue, or something else.
I appreciate any advice anyone has.
TallEddie1981 is offline
post #2 of 2 Old 02-24-2012, 08:05 AM
Super Moderator
teachsac's Avatar
Quoted: 859 Post(s)
Liked: 1397
Welcome. Please post your question in the thread for your player. Mods will lock this one. Do a search for HDMI CEC. Good luck.
http://www.avsforum.com/avs-vb/showt...ighlight=d5500
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Closed Thread Blu-ray Players
