Official Sony BDP-S590 and BDP-390 Thread - Page 139 - AVS | Home Theater Discussions And Reviews
Old 04-30-2015, 09:29 AM
Pioneer_Elte's Avatar
Quoted: 51 Post(s)
Liked: 49
Originally Posted by surreyjack604 View Post
I have a bdp-bx59 bluray player. I bought a seagate 1.5tb external hard drive but it says the usb device is not recognized when I connect it to the bluray player. I have tried many things like reformatting it to fat32 and nothing works. Does anyone know of a external hard drive that will work with my blu ray player for watching movies?
thanks for your help.
Try formatting using NTFS and default sizes. I have a 120GB Seagate that I've used on this player with no problems.
Pioneer_Elte is offline
Old 04-30-2015, 11:25 AM
mdavej's Avatar
Quoted: 1159 Post(s)
Liked: 612
A big drive is probably going to need external power as well. The USB ports on these players don't have a whole lot of juice.
mdavej is offline
Old 04-30-2015, 11:54 AM
tgm1024's Avatar
Quoted: 1237 Post(s)
Liked: 1248
Is it possible that it's the DRM code associated with this stuff? For instance, I know that if you want to hook an external drive to a Verizon DVR, it will only work if it's formatted by the DVR itself (which then performs it's own low-level encryption on it). The symmetric keys involved in the encryption is kept by the DVR and out of your hands entirely, rendering the data on the drive completely useless when disconnected.
In this way, the data of the movie itself is kept safe and you wouldn't be able to duplicate it. It was a cloak-and-dagger requirement of the MPAA I think. Perhaps something like that is going on here?
I would strongly advise you to avoid StackOverflow and the other StackExchange (SuperUser, etc.) sites. They reward anti-social behavior and pedantry by granting ever increasing moderator-like powers to anyone gaining enough reputation points (similar to "likes" in forums), including the ability to edit your question. If you must use them, please read this article first.
tgm1024 is offline
Old 04-30-2015, 02:34 PM
Quoted: 51 Post(s)
Liked: 49
No, the DVR thing ties that HD to your DVR, if you have to have your DVR replaced, you won't be able to see the file list or watch the shows on the new box. This is the DRM scheme to prevent someone from recording shows, say on HBO, and bringing it to a friends house to play.
Whether the Blu-Ray player will play the file is one thing. However, you should still be able to see files with the supported extension.
As mdavej said, make sure it's externally powered.
Old 05-01-2015, 06:05 AM
tgm1024's Avatar
Liked: 1248
I'm sorry, but you started with "No,".......are you disagreeing? You're rephrasing what I said.
They're not worried about you unplugging a hard-drive and shlepping it to a friends house at all. They're worried about you lifting the data and putting it up on thepiratebay or some other send-around vehicle, or otherwise burning a disc with it.
Well this is my question: It won't work if it's employing the same protection as the DVR purportedly does: you won't see anything in the filesystem at all. No filename, no directory structure, even the sectors themselves are opaque. The encryption occurs at the driver level where the most bottom level access to the drive happens.
tgm1024 is offline
Old 05-01-2015, 07:59 AM
mdavej's Avatar
Liked: 612
Maybe I'm reading too much into it, but it sounded to me like the OP simply bought a new drive for the purpose of hosting unprotected files he already had, not some external drive from a DVR full of protected content. I suspect formatting or power is the most likely culprit in this case.
A workaround would be to simply plug the drive in elsewhere and use a DLNA server. There is no easy workaround for DRM.
mdavej is offline
Old 05-01-2015, 08:04 AM
tgm1024's Avatar
Liked: 1248
I understand that. But a cable company DVR won't even allow you to do that. The moment you plug any drive into one of those, you are given only one option: reformat immediately (BY the DVR in encrypted format so that the only holder of the key is the DVR) or don't use it at all.
And I understand that he's talking about a BDP; my concern was whether or not the BDP was following the same cloak and dagger nonsense that the DVRs do.
tgm1024 is offline
Old 05-01-2015, 08:16 AM
mdavej's Avatar
Liked: 612
Ahh, I understand now. No, the BDP doesn't care what you plug into it, and there is no encryption. The BD Live drive is a different story.
mdavej is offline
Old 05-06-2015, 11:33 PM
Ungermann's Avatar
Quoted: 214 Post(s)
Liked: 36
Now, after April 20 cutoff, can someone owning the S590 verify that YouTube app works (the other one) and whether it shows ads. Thanks.
Ungermann is offline
Old 05-11-2015, 07:41 PM
See The Light's Avatar
Quoted: 25 Post(s)
I put in the 2010 45th Anniversary BD disc of The Sound Of Music in my S590, to play the movie, and I got this message:
"This feature requires Local Storage. Your Blu-Ray player supports local storage but none is currently installed. 3 MB minimum required."
I pressed "Continue" to watch the movie.
So, today, I bought a 16 GB USB 2.0 Flash Drive, a Micro Metal version ($9), and plugged it into the back of the S590.
When I reloaded The Sound Of Music, then the above message did not show anymore, nor will it show again in the future.
Cable Channel Choice is the only choice I want to make !!
See The Light is offline
Old Today, 11:32 PM
DWPC's Avatar
Recommended USB External HD for Music on BDP-S590?
My S590 won't play files from a wi-fi network drive cleanly. I suspect its because the wi-fi router from the cable company is cheap/weak, so I'm going to get a dedicated USB hard drive and would appreciate recommendations. Full-time music and video; no computer duty except when ripping. Do I need a DNLA drive if it's USB?
I'd also like to know if there's a way to avoid the extra file structure layers that the S590 seems to add to the Win 7 directory structure; when I create the ripped albums, there's only three levels, but when I open files through the S590, there are redundant empty levels I must work through.
DWPC is online now
Blu Ray Players , Sony Bdp S390 Blu Ray Player , Sony Bdp S590 3d Blu Ray Player
