Official Sony BDP-S590 and BDP-390 Thread - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #1 of 4198 Old 02-25-2012, 06:37 PM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
Do you have a issue with HD audio from these players? DTS HD or Dolby TrueHD not showing up on your receiver?
See the following posts within this thread.
See posts #193, #203, #204, #499, and #740.
590 features over 390.
1. 3D support
2. Additional rear USB port
3. Optical audio output
4. Front display
5. Standard width
Comparison (courtesy of Amazon):
DLNA and USB update with the S590/S390/S790
NTFS formatted USB drive fully supported.
Sony will play the following formats NATIVELY over DLNA.
Video:
Container: MKV. Video Codec: AVC Mpeg4/H264. Audio Codec: DTS/Dolby Digital/DTS-MA
Container: M2TS Video Codec: AVC Mpeg4/H264, VC-1, Mpeg2. Audio Codec: DTS/Dolby Digital/DTS-MA
Container: VOB Video codec:Mpeg 2. Audio codec: LPCM, Dolby Digital
Container: m4v mp4 Video Codec: AVC Mpeg4/H264, XVID. Audio Codec: AAC
Audio:
Mp3, AAC
Tested with
Mac:
Playback DLNA server (Yazsoft)
Serviio and  Homestream
PLAYBACK DLNA from Yazsoft
For the best iLife integration with iTunes and iPhoto, Playback DLNA server is superb !!
Get Playback Here > http://www.yazsoft.com/products/playback/
Serviio/Homestream work with Windows, Mac and Linux
Sony has its own re-branded version of Serviio called HomeStream. You can download it here.
Use the BRAVIA profile. Don't use the default BD player profile, as Sony made some changes during a recent firmware update !
Serviio users, use the "Bravia 2012 - US" profile for best compatibility and minimum transcoding or remuxing. You can decide if you enable transcoding or not on the server. See files supported above.
Basically, if you have a bunch of MKVs using the VC-1 or Mpeg2 codecs and don't want to remux with TSMuxer, then you will need to enable transcoding on Serviio or Homestream to playback the files.
A note about MKVs. You may find FF/REW will not work very well with the player. M2TS containers work fine, but then dont support chapter markers ... so there are trade-offs.
Support Info
Sony has added the S590 (and S390) to their USA support pages. Available here.
Useful Settings
During playback of BD or DVD
Picture Quality : Normal (standard mode. Avoid using the others)
BNR: Off
MNR: Off
During Internet video playback
IP Content Noise Reduction: Off
Screen Settings:
All defaults other than:
Screen Format: Actually toggle this one back and forth between Full and Normal depending on if I want 4:3 content to be stretched across 16:9. This setting only effects DVD. Streaming content is not effected (with latest firmware).
** Ensure you download the latest firmware that addresses an issue with YCbCr 4:2:2, 4:4:4 and RGB colorspaces **
The firmware may also introduce a problem playing back some files with DLNA. If you are using Serviio or HomeShare, refer to the following post with a fix:
http://www.avsforum.com/t/1396469/official-sony-bdp-s590-and-bdp-390-thread/1560#post_22244982
Audio settings:
DSD Output mode: DSD (note, you can only do this if you're receiver can decode DSD directly
BD Audio Mix: Off (Allows for high-resolution audio bitstream from player)
Audio DRC: Off (Hate compression generally)
Downmix: Surround (if you're receiver supports Dolby Pro Logic / II or DTS Neo, etc)
A note about 24p
There are now two settings for 24p output.
By default they are
BD-ROM 24p output: On
DVD-ROM 24p output: Off
and I left them like that. Many DVDs are not 24p compatible, and with DVD generally a last resort, can't be bothered to keep toggling this one.
SEN Portal:
Read this post within the thread: here
apw2607 is offline
post #2 of 4198 Old 02-28-2012, 10:02 AM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
Added buying links to first post for easier access.
apw2607 is offline
post #3 of 4198 Old 02-29-2012, 12:52 PM
tjarrett999's Avatar
On the sonyrewards.com web site they actually have this player available to order. I actually just ordered it for the equivalent of $108 + tax since I am a Sony Credit Card holder.
I already own the bdp-s580 so I am anxious to see how this compares.
There was nothing on the site that said that it was not shipping until later in March, so I am hoping that I will get it soon.
Todd
tjarrett999 is offline
post #4 of 4198 Old 02-29-2012, 01:55 PM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
Thats great. Even if you don't have points its $134.99 which includes shipping. Retail is $149.00. I'm sure we will see prices dropping shortly.
I've also owned the s580. Overall I like it, but it could be better. The streaming user interfaces are OK ... but could do with a overhaul. As I mentioned above, I would like to see 1080p netflix and 5.1.
Overall though, I still prefer the 580 to the new Panasonic 220 (and 210 before that). As much as I wanted to like the Panasonic, I absolutely hated the Viera Connect portal, and user interface. It just looks tacky. THe color scheme is from hell ... I could go on and on. On top of that, some of the apps, just dont work. Hulu plus for example. The S580 on the other hand, once you have figured out what you want to watch ... i've never had any issues with interrupted playback on any of the VOD services (amazon, hulu, netflix or vudu hdx).
apw2607 is offline
post #5 of 4198 Old 03-02-2012, 05:15 PM
SireTV's Avatar
I'm also trying to compare the 590 to the Panny 220. From reading the manuals so far this is what I could ascertain as the differences...
Things the Panny can do:
-Play files from a network share
Thing the Sony can do:
-Built-in web browser
-Play xVid files
Other than these two things they seem to be pretty similar. The Sony has a redesigned look which looks kind'a cool. If the Sony can do Netflix 1080p streaming&DD+&24p streaming output I will probably get it. Otherwise I'll probably go for the Panasonic. Right now I have the S470 and I have been pretty happy with it but it's getting kind of old with an antiquated Netflix interface and other limitations. That unit will go upstairs to replace a DVD player.
SireTV is offline
post #6 of 4198 Old 03-02-2012, 06:55 PM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
The Sony won't do 24p out for vod.
apw2607 is offline
post #7 of 4198 Old 03-04-2012, 08:21 PM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
The S390 is now in stock at the Sony online store (USA) available here
The S390 is similar to the S590, but doesn't include 3D and has one USB port. All models this year are Wireless.
Hopefully someone will purchase and tell us all what the new UI looks like !
apw2607 is offline
post #8 of 4198 Old 03-04-2012, 11:58 PM
zoro's Avatar
Quoted: 212 Post(s)
Liked: 41
Are new Sony are still USB fat32 or NTfs?
zoro is offline
post #9 of 4198 Old 03-05-2012, 08:57 AM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
According to the specs for S590:
USB Memory: Yes (FAT32,NTFS)
apw2607 is offline
post #10 of 4198 Old 03-06-2012, 04:53 PM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
The S590 is now in stock at B&H.
apw2607 is offline
post #11 of 4198 Old 03-06-2012, 08:17 PM
zoro's Avatar
Quoted: 212 Post(s)
Liked: 41
You mean both?
zoro is offline
post #12 of 4198 Old 03-07-2012, 11:52 AM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
Originally Posted by zoro View Post
You mean both?
Supports both, yes.
I will post a update later on the new UI, with the S390.
apw2607 is offline
post #13 of 4198 Old 03-07-2012, 02:29 PM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
Hi Guys.
My S390 arrived today. I've got some very interesting updates. Didn't have a chance to properly test things out but I can report the following updates:
1) Good news for you Netflix fans. The Netflix UI is completely overhauled and is using one of the standard Netflix UI's. Looks just like the PS3 to me. The new S390 supports 1080p streams and Dolby Digital + bitstream. I can confirm it is 1080p, because selecting DISPLAY when a movie is playing shows the X-High setting (like the PS3). Finally !!!!!!!!
2) Amazon VOD has had a small update. It now will push Dolby Digital bitstream out for Movies in 5.1. Before with the x80 series, the audio was converted inside the player to mutli-channel PCM and sending out via HDMI. Now you just get the 5.1 bitstream.
3) Same apps as before. No changes I can see. VUDU is on here which is good.
4) HULU+ app is as it was before. That's a small disappointment, was hoping to see the PS3 HULU+ app moved over. Still ... at least HULU+ works.
5) iPhone app works as before, however the text input does not work inside VUDU or Netflix since its using a custom UI.
6) Favorites has being completely removed from the XMB. This is because this feature will be incorporated into the new SEN portal. The SEN portal is showing "Coming Soon", so I can't let you know what thats about yet .....
Overall, I've very encouraged by this new 2012 player from Sony. More later.
** update **. I can confirm the above info on streaming is also applicable to the Sony SDP-S590 as well.
apw2607 is offline
post #14 of 4198 Old 03-08-2012, 11:42 AM
dlarkin_dc's Avatar
5.1 on Netflix and Amazon, & updated Netflix app! It might be time to retire my Roku!
How is the picture quality on the 1080p Netflix... anyone? Anyone? Bueller?
dlarkin_dc is offline
post #15 of 4198 Old 03-08-2012, 02:50 PM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
Excellent (certainly as good as the PS3 Netflix app, which was considered by many as the best Netflix streamer).
apw2607 is offline
post #16 of 4198 Old 03-08-2012, 07:31 PM
Krutsch's Avatar
Liked: 36
Hi Guys.
Actually, the BDP-S580 does Amazon 5.1 now, as well, which was a pleasant surprise after the last firmware update.
"Play the volume as loud as you want - but don't touch my levels now. I got them set just like I like them"
Krutsch is offline
post #17 of 4198 Old 03-08-2012, 07:44 PM
Krutsch's Avatar
Liked: 36
Figured it was time to kick this one off since it should be arriving soon (hopefully).
What do we know about the S590:
The really, really BIG thing I am hoping Sony adds to the 590 - full decoding of the HD audio codec to LPCM. I am basing this presumption on the wording of their marketing sheet (i.e. the HDMI Audio Out section).
Current players (all Sony and most of everyone else's) are limited to core DTS audio (1.5 Mbps) for decoding to LPCM; most (if not all) mid-range AVRs cannot both decode bit streamed lossless audio *and* apply post-processing (e.g. Yamaha's Cinema DSP). If Sony fixes this problem, this player is a home run and basically eliminates the need for higher-end BD players.
Crossing my fingers...
Krutsch is offline
post #18 of 4198 Old 03-08-2012, 08:55 PM
HDMI Guy's Avatar
Quoted: 162 Post(s)
Liked: 39
Is this for both the 390 and 590 or just the 590?
HDMI Guy is offline
post #19 of 4198 Old 03-08-2012, 08:56 PM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
Both.
apw2607 is offline
post #20 of 4198 Old 03-08-2012, 09:06 PM
audio/videoman's Avatar
How do you all like BR PQ and DVD upconversion on the 390/590?
audio/videoman is offline
post #21 of 4198 Old 03-08-2012, 09:12 PM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
I would say pretty much the same as last years players ... Note, I don't bother with any of those picture settings to smooth stuff out on DVDs.
apw2607 is offline
post #22 of 4198 Old 03-08-2012, 09:20 PM
michaeltscott's Avatar
Quoted: 2305 Post(s)
Liked: 1241
Not having a 3D television or any interest in 3D, I'm gonna check out the 390. I was going to order it from B&H but decided to pre-order from Amazon instead. No rush--I'll save $12 in shipping and have Amazon's wonderful return policy (and buttery smooth return mechanism) if I should need it.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #23 of 4198 Old 03-08-2012, 09:23 PM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
My only negative complaint about the 2012 players is the overall external design. I'm not really digging the curves. I guess I'll get use to it. Looks like the S790 is the more conservative design out of the three .....
Guess, they were trying to make them look a bit different this year.
apw2607 is offline
post #24 of 4198 Old 03-08-2012, 09:28 PM - Thread Starter
apw2607's Avatar
Quoted: 103 Post(s)
Liked: 218
Sony online store (not rewards) offers a painless return policy. You do have to pay for return shipping though. Just shipped back my S390 ... keeping the S590 !
apw2607 is offline
post #25 of 4198 Old 03-08-2012, 09:35 PM
Liked: 1241
Amazon will pay for the shipping if it's broken. In any case they'll give you an addressed prepaid label to print and will alert UPS to stop by your house to get it.
post #26 of 4198 Old 03-08-2012, 09:49 PM
John Stockton's Avatar
Quoted: 18 Post(s)
Do either of the 390 or the 590 have component video output??
John Stockton is offline
post #27 of 4198 Old 03-08-2012, 10:07 PM
Liked: 1241
Those became "illegal" on BD players last year (see this). Well, the outputs aren't illegal until next year but outputting HD over them is and I don't think that any of the manufacturers are equipping players with them.
post #28 of 4198 Old 03-08-2012, 10:16 PM
Quoted: 18 Post(s)
Thanks for the heads up.
post #29 of 4198 Old 03-08-2012, 11:45 PM
DaGamePimp's Avatar
Quoted: 320 Post(s)
Liked: 352
There are converter boxes out there that will do HDMI -> Component but the good units cost as much or more than many of these BD players.
Jason
HT = JVC RS40 / Lumagen Radiance / Vivitek 1186 /@133"/ Samsung 50" Plasma / Denon x5200 7.3.4 Atmos / B&K 5000 II amp / Boston VR2/VR12/CR67 speakers / Rythmik 12" subs x2 / CV 15" sub / Sony BDP s1000ES / Yamaha DV-S5860 / Toshiba HD-A3 / PureAV PF31
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4/X1/WiiU/PS3/360/Wii/Game PC/Multi-Arcade My HT SLIDESHOW
DaGamePimp is offline
post #30 of 4198 Old 03-09-2012, 01:33 AM
sacflies's Avatar
Do the Sony blu-rays have an MLB.tv app? Deciding between the Panasonic 220 and the Sony 390 or 590. Although I don't think I will do the 3D thing any time soon, I prefer the 590 for the USB in the front and the back. But I absolutely have to have the MLB.tv app!
sacflies is offline
Reply Blu-ray Players
bdp , Blu Ray Players , connect , physical , router , Sony Bdp S390 Blu Ray Player , Sony Bdp S590 3d Blu Ray Player , switch
taboola here
