OFFICAL SAMSUNG BD-E6500 owner's therad - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 135 Old 07-03-2013, 07:30 PM
taylormade1987's Avatar
Hey guys I just bought this unit for $30 because it didn't play DVDs. So I thought, what the heck? Its $30!? So I break it open and take out the disc drive. I figured I'd just blow a little canned air into it and see if it helped. If not, I'll see if I just can't purchase a whole new disc drive all together. So I tear open the disc drive and blow the canned air on the 2 eyes that read the disc. So when I go to put it back together, I noticed that these 2 little black arms came out. Problem is, I have NO IDEA where they go. I hovered over that thing for a couple hours trying to figure it out. I put the drive back in just to try it out and the loader won't take a disc without those 2 arms. Disc will only go half way in.
So, my question is, does anyone know where I can find any information on the assembly of the disc drive that this unit takes? Or, does anyone know what model of loader it takes and where I could purchase a new one?
I appreciate any help.
Thank You.
taylormade1987 is offline
post #122 of 135 Old 07-31-2013, 01:28 PM
mikek's Avatar
Quoted: 152 Post(s)
Liked: 70
I had a problem with my BD-E6500 not connecting to the internet lately. I would get the message that it was connected to the network but not the internet. Strangely, I could still connect and download firmware updates.
I finally fixed the problem by shutting off IPv6 on my router. Once I did that it connects flawlessly. Apparently the smarthub isn't compatible with IPv6 with my ISP or router. I am not sure what the precise problem is. What is interesting is that I did a test and turned IPv6 back on while Netflix was playing and it worked fine. Upon exiting and going to the smarthub the error message came back up.
I hope this helps someone else out there.
mikek is offline
post #123 of 135 Old 07-31-2013, 03:50 PM
Vishwa Somayaji's Avatar
Quoted: 21 Post(s)
Thanks for that info. Which make and model is your router. That would be useful too.
Vishwa Somayaji is offline
post #124 of 135 Old 07-31-2013, 04:50 PM
mikek's Avatar
Quoted: 152 Post(s)
Liked: 70
I have Uverse and a Motorola NVG510 router.
mikek is offline
post #125 of 135 Old 08-01-2013, 11:25 AM
Quoted: 21 Post(s)
Thanks. I had an SMC and now have actiontec(changed ISP) and so far haven't experienced any trouble. But your info is useful in the future if there is any trouble connecting.
post #126 of 135 Old 12-01-2013, 12:28 AM
corvid's Avatar
If I come out the HDMI on my cable box in HDMI on the BD-E6500 then out the HDMI on the BD-E6500 in HDMI on my HDTV will it improve the picture quality of non HD channels? I haven't purchased the Samsung BD-E6500 yet. If i do it would be for that reason.
corvid is offline
post #127 of 135 Old 12-01-2013, 04:19 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 109
This BD player does upscale a DVD played on it and as for the signal from the cable box that a ? Most HDTV sets have an upscaling circuit in them. The HDMI will give you the best signal. I have to guess that you do not have an HD cable box, so remember 480i is 480i and the upscaled signal will never match an HD one.
Phil17108 is offline
post #128 of 135 Old 12-01-2013, 04:38 AM
BillP's Avatar
Quoted: 277 Post(s)
Liked: 223
I think he does have an HD cable box, but watches some non-HD channels. Non-HD channels will never look good on an HDTV, no matter what you do to the signal!
On a separate note, I don't recommend Samsung BluRay players due to poor reliability. Check out Oppo if you are interested in HDMI inputs.
BillP is offline
post #129 of 135 Old 12-01-2013, 07:11 PM
Bladerunner1959's Avatar
Location: Pittsburgh, PA...Preferably the Virgin Islands....
Quoted: 13 Post(s)
Liked: 67
My bd-e6500 has been excellent since June 2012 for bluray and streaming from SmartHub. Every 6 to 10 weeks the player may not load a bluray. All I have to do is pull the plug..wait 30 seconds and restart the unit.
Love for all things Hi-def...Losing count; 200 plus bluray, 500 plus dvd, 30 plus HDdvd and a rapidly growing 50 plus in the cloud.
Bladerunner1959 is offline
post #130 of 135 Old 03-10-2014, 10:29 AM
heresnowhy's Avatar
Liked: 34
Thank You.
Doubtful you still have this unit, but I just took one of mine apart and cleaned the lens. It's a MONSTER to put back together and have the loader function, but I know how it works now if you wanna give it a go again.
heresnowhy is offline
post #131 of 135 Old 11-22-2014, 08:21 PM
Liked: 0
Question
I would like a definitve answer from someone who actually owns a Samsung BD-H5900 player. Do these units support the DivX format. Are they DivX Certified. I talked to two different customer support people at Samsung and they gave me conflicting answers. The first one said, YES, they definitely did and the second said Samsung does NOT support DivX. My video collection was recorded using the DivX codec and this is a pivotal matter. How about Xvid? Just what formats does it support.
Thank you,
Wayne H. Harke
8wharke8 is offline
post #132 of 135 Old 11-22-2014, 08:49 PM
Super Moderator
teachsac's Avatar
Quoted: 814 Post(s)
Liked: 1335
This is the E series thread. You might ask in the H series thread.
Official 2014 Samsung BD-H5100, BD-H5900, & BD-H6500 Blu-ray Player Thread
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #133 of 135 Old 02-07-2015, 09:02 AM
Liked: 0
Hi, My unit is consistently dropping audio signals or video or both while playing a disc of either type or streaming Netflix. Audio drops can appear as seeing the regular video continuing. Combined drops go to either black screen, white noise screen, or a screen that the receiver interprets as no signal at all. I will check on the firmware v (set to auto update) and swap out hdmi cable to see if that helps. Anyone else have this issue?
machtansc is offline
post #134 of 135 Old 06-30-2015, 04:59 PM
darklight_tr's Avatar
Samsung BD-E6500 Power Button Issues
Hello,
I have a Samsung BD-E6500 Blu-ray player that I've had for several years. I've had no issues until recently, when I noticed that the player was powering on and then off by itself.
Fast forward to today, a few weeks later, where the touch power button has completely flaked out. It constantly thinks something is touching it (you can tell as the button "flashes" whenever it registers contact) no matter what I've tried, so the player constantly powers on and off when plugged in. At this point the player itself is unusable, as it won't stay powered on for more than 10-15 seconds before powering off again, only to start the cycle anew.
Is there anything I can do to repair it or should I just look at purchasing a replacement?
darklight_tr is offline
post #135 of 135 Old 01-03-2016, 09:17 AM
Quoted: 13 Post(s)
Liked: 67
My bd-e6500 has been excellent since June 2012 for bluray and streaming from SmartHub however in the past two weeks I get this error message sometimes when loading a bluray, 3d or dvd. All the discs are mint condition and I have updated the player with the most recent firmware. Has anyone seen this error? All of the discs eventually play, some after multiple reloads and some on a first time insertion.
My thought at this point is should I be running some kind of a lens cleaning process or disc?
" Cannot Read this disc. Try the following.
-Ensure the playback side is not damaged and wipe the disc with a soft cloth.
-Refer to the user manual to check supported disc formats. "
Problem resolved with a cleaning disc from Best Buy
Reply Blu-ray Players
Blu Ray Players , Samsung , Samsung Bd D6500 Za D6500 Serivce Blue Ray Disc Player 3d Stereo , Samsung Bd E5900 3d Wifi Blu Ray Disc Player , Samsung Bd E6500 3d Wifi Blu Ray Disc Player Black
