Official LG BP620/520/420/320/220 Owners Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #361 of 403 Old 01-12-2014, 08:43 AM
geojay's Avatar
I have a LG BP520 Blu-ray player that I'd like to use to play video files from my Netgear ReadyNAS duo. I'm able to see a few files on the NAS but the vast majority of them aren't visible. The files that are visible seem to be of type "Codec: H264 - MPEG-4 AVC (part 10) (avc1)" when checked on a PC with VLC. The files which aren't visible are of types "Codec: MPEG-4 Video (XVID)", "Codec: MPEG-4 Video (mp4v)" and "Codec: MPEG-4 Video (DX50)".
Is this just a limitation of the machine or might there be another issue?
geojay is offline
post #362 of 403 Old 01-30-2014, 05:29 PM
kraftytwo's Avatar
Do these models support :
1) FLAC album art (embedded in file or external) ?
2) FLAC gapless playback ?
3) How is the SRT subtitles rendering? Crystal clear or "funny" ?
kraftytwo is offline
post #363 of 403 Old 02-02-2014, 01:21 AM
Lanzar2's Avatar
I only tried vi USB. I think it has something to do with 23,976fps material outputted as 24fps....
Lanzar2 is offline
post #364 of 403 Old 02-02-2014, 05:22 AM
Lanzar2's Avatar
...very noticable on end credits, the letters flickers when scrolls up over the screen
Lanzar2 is offline
post #365 of 403 Old 02-08-2014, 11:35 AM
gushin's Avatar
Anyone having trouble logging into Netflix through your BP620? All I get is black screen with a white horizontal line close to the top of the screen. I unplugged the device and did a factory reset, but it just gives me this blank screen.
Update
Router reset seemed to have cleared the problem.
gushin is offline
post #366 of 403 Old 02-08-2014, 11:40 AM
THe_Flash's Avatar
Liked: 25
All is fine on mine. I'm in the U.S. with latest firmware.
THe_Flash is offline
post #367 of 403 Old 02-08-2014, 12:55 PM
gushin's Avatar
Thanks. Reset my router and it seemed to have fixed the problem.
gushin is offline
post #368 of 403 Old 03-02-2014, 02:07 PM
Patterson108's Avatar
I have a BP630c latest update and I have a Iomega Personal Cloud with uses Twonky Server 7.2.6-2 and I have problems with MP4 I cant pause, fast forward, or rewind. I created the MP4 with ffmpeg and have tested them on other DLNA device like my droid and every thing is good. Are you having similar problems?
Patterson108 is offline
post #369 of 403 Old 03-07-2014, 03:51 PM
Gunzzo's Avatar
New firmware:
BD9.720.00.C
Gunzzo is offline
post #370 of 403 Old 03-09-2014, 12:13 PM
Dig and Spike's Avatar
I'm having an issue with my wifi connection, I can get to the premium app but when I try to open Any of the apps I lose my connection. Is anyone else witnessing this?
Update:
I reset my router which helped with the connection. Now I'm having an issue with slow internet speed with the BP620C only... I have my Apple TV below it and it's fine.
Any suggestions?
Dig and Spike is offline
post #371 of 403 Old 04-17-2014, 08:33 AM
Robert Ksiazek's Avatar
hi.
i just update my bp620 and it wont turn on after it.
any ideas?
Robert Ksiazek is offline
post #372 of 403 Old 04-21-2014, 10:54 PM
kantazo's Avatar
Originally Posted by Robert Ksiazek View Post
hi.
any ideas?
warranty??
kantazo is offline
post #373 of 403 Old 04-27-2014, 08:05 AM
Lanzar2's Avatar
I have now noticed that details flicker when i watch i.e cinetrailer or Viewster. Does anyone else experience theese artefacts? Happens also when wathing mkv:s and started after firmware update? The artefact is most noticable when camera pans and then small details in the picture starts flickering like a wavy pattern....
Lanzar2 is offline
post #374 of 403 Old 04-28-2014, 09:26 AM
luiznunes's Avatar
Hi,
Does anyone know if the BP620 ( LG ) reads Vobsub subtitles? if not, how do you play 3d movies with subtitles? :|
thanks
luiznunes is offline
post #375 of 403 Old 04-29-2014, 09:48 AM
Lanzar2's Avatar
Why is  the 3D setting grayed out to ON in my BP620N? I friend's BP620N is grayed out to OFF....???
Lanzar2 is offline
post #376 of 403 Old 05-01-2014, 04:27 AM
imkrishna's Avatar
I have a BP420 that shipped with a MAC address ff: ff: ff: ff: ff: ff.. I cant get it to connect to my wired internet.. Does this mean its faulty?
imkrishna is offline
post #377 of 403 Old 05-02-2014, 07:01 AM
skynetxt's Avatar
Hi guys.. i am  newbie  i have  the player lg  bp620  i wonder if is possible read external subtitles on usb drive  srt format..  on original blu ray disc.. How ? thanks...
blu ray disc + srt sub  on usb drive.
skynetxt is offline
post #378 of 403 Old 05-08-2014, 06:44 PM
Michael-7's Avatar
My 3D was grayed out in the On display as well until I hooked the HDMI cable directly to the TV versus going through the receiver for surround sound.  Prior to that cable change, it would not play the 3D blu rays - Now it is working .  Just need to find out how to run through for surround sound now.
Michael-7 is offline
post #379 of 403 Old 05-28-2014, 11:48 AM
luiznunes's Avatar
Hi all!
Isn't there any solution for the 3d external subtitles for the bp620?
Already tried that solution of converting it to lower the resolution but... Agly to see...
post #380 of 403 Old 06-03-2014, 09:25 AM
pommaq's Avatar
Made silly move to save 50€ and bought  BP420 as I did not check that local model should be with N. My country is not even listed when selecting country. Netflix would work if I'd select Ireland but that is not what I'm after.
firmware BD9.720.00
I've searched all over and with LG tv it is possible to change Nordic UI value for 0 to 1 and this I expect would be thing do with this BP also to make it BP420N and enable local "smart" content like Viaplay. I can access service menu of my LG plasma via Harmony remote when using but this 55ML7600 as reference for Harmony. But can't access service menu/EZ-adjust of BP420. Anyone having knowledge how to get there?
pommaq is offline
post #381 of 403 Old 06-07-2014, 01:44 PM
pommaq's Avatar
I have exactly the same 'challenge'. With that mac-address my dhcp-server from my Cisco ASA firewall refuses to give BP420 a dynamic IP-address. Resolution is to give fixed IP in instead. Faulty? In m$ world that would probably be called a 'featur'e :(
pommaq is offline
post #382 of 403 Old 09-26-2014, 11:45 AM
Liked: 0
BP420 in U.K won't register for U.K LG app store
firmware BD9.720.00
Did you get anywhere with this?
I am having exactly the same problem with my BP420 bought refurbished in the U.K. There's no N on mine.
I have exactly the same problem in that I cannot even select my country - U.K isn't on the list. Selecting "other" doesn't help.
Ireland is on the list, and as a test I tried getting apps via the Irish LG store. But it didn't work. However, it does seem to be connecting O.K to the net. I could at least register my account - I don't even have that option if I select "other".
My firmware is BD9.681.00.00.C. It doesn't seem to want to update.
Any advice very gratefully received!!!!!
frustratedbp420 is offline
post #383 of 403 Old 09-26-2014, 02:31 PM
luiznunes's Avatar
Anyone getting luck with 3d subtitle and mkv with the BP620?
post #384 of 403 Old 09-27-2014, 11:32 AM
Liked: 0
BP420-P? What does the -P stand for?
A close examination of my troublesome BP420 (see earlier post) shows that it has the model number BP420-P. Does anybody know what the -P suffix stands for?
I am somewhat alarmed that googling BP420P mostly turns up indian retail websites!
From the list of available countries in the set up menus my own unit would seem most likely to be continental european (no U.K option but many other european countries; also the DVD ratings system is set to DE for Germany, and there is a German language refurb test notice on the shipping box)
LG's tech support has washed their hands of it since it is likely a "grey" refurbed import but they do mention that the BP420 has a preset IP address and will not be able to access a given LG SmartWorld store unless the address matches - so you can't access the U.K store unless it is a bona fide U.K BP420.
Basically if anybody can give me any more info on the provenance of this BP420-P then I would be really grateful, so that I can negotiate with the outfit that sold it to me. LG said that an independent repair outfit might be able to fix this issue but this would probably cost more than the actual unit did!
I have attempted to upgrade the software using a download from LG's website but it just doesn't recognise it, and moreover it is a older software version than the one installed anyway - and presumably this wouldn't address the IP address issue. I have tried a factory restart but this makes no difference.
So any advice gratefully received!
ODP
post #385 of 403 Old 10-20-2014, 12:10 PM
pommaq's Avatar
ODP
Sorry for late reply. I got rid of mine by selling it in 'local' version of ebay. Have you tried to update via USB? I recall that it should be possible as well. Then again different firmware would not help I bet. www .lg.com/fi/tuki-tuote/lg-BP420N latest firmware is VER:BD9.720.00.C/DATE:2014.02.04 not sure if that will sink into yours, most likely yes. UK site has VER:BD9.593.00/DATE:2013.04.10 but strange thing is that file names are just the same. Typo?
Me as IT dude believe that instead of preset IP you(&LG) mean mac-address. At home network your ip-address is most likely something like 192.168.0.0-255 or 192.168.1.0-255. If LG would have that fixed it would be total madness.
What do we learn from this? Poor man should not buy cheap, it turns out be rubbish too often. Besides of that in college I was taught that the purpose of electronics manufacturing is to create products that last the warranty period. I don't think that is the objective of these unnamed companies.
My recommendation is to get rid of it unless you haven't already done it.
pommaq is offline
post #386 of 403 Old 10-21-2014, 10:31 AM
Liked: 0
LG Bluray player help
I have an LG Bluray player I bought for my dad 2 years ago from Target. When you power it on, It shows the LG logo but then goes to a blank (black) screen.
Is there a way to hard reset this?
mrnapolean1 is offline
post #387 of 403 Old 10-25-2014, 05:49 PM
Liked: 1
LG BP520 - Quick Start Mode
My Blu-Ray player will not change zones. It worked before.
Instructions say: "Make sure that the Quick Start mode of the unit is set to OFF!" I've searched the manual for "Quick Start mode" in vain.
How do I do that?
Any help will be greatly appreciated.
Meesty is offline
post #388 of 403 Old 10-25-2014, 08:18 PM
Liked: 1
PLEASE IGNORE PREVIOUS POST. IT'S ERRONEOUS.
Here's the situation:
1) The player is in fact a LG BP320 International MultiZone MultiRegion Blu Ray Player.
2) Until recently, there was no problem whatsoever playing Blu Ray discs from regions A, B and C.
3) The firmware has been updated recently.
4) Since then, it is only reading Zone A.
Does anybody know what could be the problem? Thanks!
Meesty is offline
post #389 of 403 Old 10-26-2014, 10:14 AM
Liked: 0
How do you play 3d subtitles with SBS 3d video? I cant find the way to play subtitles correctly. Anyone?
roberto30 is offline
post #390 of 403 Old 10-26-2014, 11:37 AM
Liked: 1
I'd like to add the following to my request for help above. Again, the unit is LG BP320 International MultiZone MultiRegion Blu Ray Player, with current firmware BD9.681.00, Servo Ver: H12IM2N0390.
I've tried to downgrade the firmware in case the source of the problem is the recent firmware upgrade. The downgraded version we tried to install is LG_BD_7000M51. Downgrading was not successful.
Any insight would be enormously appreciated.
Meesty is offline
Reply Blu-ray Players
Blu Ray Players , Lg , Lg Black 3d Blu Ray Disc Player Bp620 , Lg Bp220 2d Blu Ray Player Smart Tv Black , Lg Bp320 2d Blu Ray Player Built In Wi Fi Black , Lg Bp520 Wifi Ready 3d Blu Ray Player Black , Lg Smart Bp420 Blu Ray 3d Video Player
