Official LG BP620/520/420/320/220 Owners Thread - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #391 of 403 Old 10-26-2014, 12:59 PM
Liked: 0
As far as I know it is impossible to downgrade
roberto30 is offline
post #392 of 403 Old 10-26-2014, 02:09 PM
Liked: 1
Thanks ever so much, Roberto! I've visited LG's site & it would appear that you are right: *******.com/m3e87me
I guess the only alternative left is to wait for LG support to get back to us. I've left a message there explaining the problem. We're hoping they'll be able to help. This is a fairly new unit & it wasn't that cheap at the time of purchase.
roberto30 likes this.
Meesty is offline
post #393 of 403 Old 11-09-2014, 07:28 PM
Liked: 0
Originally Posted by HBNet View Post
Just got the BP620 last night, hooked it up, upgraded firmware, everything works great.
Quick question.
I'm connecting this to an older Toshiba 36" tube TV via the composite video cables (as TV doesn't have HDMI).
When I go into player's Setup menu, under DISPLAY, it won't let me choose 4:3 ratio; I can only choose between the 16:9 ones.
When I watch a 'widescreen' movie, it shows up on my TV in fullscreen, but it's a little out of whack, like it's stretched or something.
And if I watch a 'fullscreen' movie, it's even worse.
Any idea how I can get it set to 4:3 aspect ratio?
I realize this is a temporary issue until I upgrade my TV, but that's not happening for a few months...
thanks!
Did this ever get resolved? I also have a tube tv and would like to buy the BP620 if it looks good on a 4:3 tv.
yurune is offline
post #394 of 403 Old 02-25-2015, 02:10 PM
Gunzzo's Avatar
New firmware : BD9.756.00.00.C
Gunzzo is offline
post #395 of 403 Old 02-25-2015, 02:30 PM
dbe425's Avatar
So what's new with this firmware?
dbe425 is offline
post #396 of 403 Old 08-09-2015, 02:18 PM
Rick313's Avatar
I've owned a BP620 for the past couple of years, and I've never seen this before, but last night I noticed a red flashing LED located a couple of inches behind the control panel. It flashes 4 times every couple of seconds. Does anyone know what this means? I tried googling it but did not have any luck. The only unusual thing that I've noticed is when I open the Premium app menu, a window pops up saying that Hulu Plus will be removed on 8/20. Is it possible that the flashing LED is related to that? The unit is connected via ethernet, so it's not a wifi issue. I tried unplugging it for a couple hours, but that didn't make any difference. Has anyone else seen this?
Rick313 is offline
post #397 of 403 Old 08-11-2015, 05:43 AM
stonehengepics's Avatar
Liked: 0
I checked mine last night and I had the same message but didn't see a flashing led.
Sent from my TF700T using Tapatalk
stonehengepics is offline
post #398 of 403 Old 08-15-2015, 06:33 PM
Liked: 0
can't upgrade
I have the "C" model and I cannot upgrade. I have Main Ver:BD5.277.00, Servo Ver:H08IMN0505
  1. I've tried updating via network/ethernet, but it tells me that I have the latest version.
  2. I've tried updating via USB:
    • tried putting H12IM2N.zip and H12IM2N.ROM into the root dir and in an "UPG_ALL" folder.
    • tried putting LG_BD_7000M60.zip and LG_BD_7000M60.ROM into the root dir and in an "UPG_ALL" folder.
The update is never found. When the USB stick is inserted, it flickers to show that it's searching it, but then it just goes back to normal (home screen). If there're media files on the stick, it asks me what I'd like to play. Either way, it completely ignores the firmware files.
I'd really like to update because some mp4/mkv files do not play.
prometh is offline
post #399 of 403 Old 08-15-2015, 06:55 PM
Liked: 0
Update: I managed to at least downgrade to BD5.242.00 via information found at avforums.com/threads/wanted-old-firmware-updates-for-lg-bd550.1720677/#post-18682941
Where can I get BD9.756.00.00, and is it even compatible with my 620C?
prometh is offline
post #400 of 403 Old 09-15-2015, 02:13 AM
leiff's Avatar
Quoted: 83 Post(s)
Will bp620 player play BD - R discs of 3d iso movies burned from a Blu ray burner?
leiff is offline
post #401 of 403 Old 10-16-2015, 11:18 PM
jebusfreek666's Avatar
LG bp325w and external hdd question
Hi guys,
I was hoping you could help me out with a little problem I am having. I have all my movies converted to digital copies. Currently in my LG bp325w I have a 1tb Seagate free agent goflex portable hdd, which works flawlessly. I keep everything else on several seagate Expansion 3TB Desktop External hdd that need separate power supplies and don't just get power from the USB port. I have tried to connect these to the LG bp325w Blu-ray player but it can not see them. I would like to not have to switch files back and forth when I change my mind on what to watch and would just like to see everything all the time. Does anyone know what the issue is here? Does the Blu-ray player have a max size drive it will read? Does it have to be a portable? I could just get a bunch of 1tb drives like the one I have and connect them with a hub, but that would take a lot of drives and I doubt a hub could support that many. I tried to partition one of the 3tb drives into 3 1tb drives, but it still couldn't read it. Please help!
jebusfreek666 is offline
post #402 of 403 Old 09-06-2016, 02:44 PM
ceth's Avatar
Just bought a BP420, one of my burned BR works while many others are rejected with an "error" message and the player ejects the disc.
Those rejected discs are of the same brand than the one that works, and were burned exactly the same way (same PC burner, same burning software, same parameters).
Have you found burning parameters that help improving compatibility with this player ?
ceth is offline
post #403 of 403 Old 09-23-2016, 06:23 PM
ceth's Avatar
I found my compatibility issue was related to burning speed.
So if it can help, the BP420 reads well mediarange BDR (PHILIP-R04-000) burned at minium speed with a LG BH10LS30 burner (lastest firmware), using ISO9660 + UDF 1.02 file system.
edit: works also for Nierle Black edition BDR, which are also PHILIP-R04-00 mediacode.
ceth is offline
Reply Blu-ray Players
Blu Ray Players , Lg , Lg Black 3d Blu Ray Disc Player Bp620 , Lg Bp220 2d Blu Ray Player Smart Tv Black , Lg Bp320 2d Blu Ray Player Built In Wi Fi Black , Lg Bp520 Wifi Ready 3d Blu Ray Player Black , Lg Smart Bp420 Blu Ray 3d Video Player
