Which Blu Ray player??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-31-2012, 06:32 PM - Thread Starter
jeffelliott's Avatar
All -
My needs are not too complicated (I think)... Before I order, I'd love some input.
My setup is fairly simple:
Denon 4311
Panasonic AR100U
120" screen
Will mostly watch BR disks but will also watch standard def. If I could find a player that will connect to my NAS for ripped disks that would be a plus. Finally, looking for one that will work well and potentially bi-directionally communicate with one of the android based remote apps (irule, roomie, etc.).
Not looking to spend a fortune if avoidable.
Thanks to all for any suggestions!
Jeff
jeffelliott is offline
post #2 of 5 Old 05-31-2012, 06:41 PM
chuckg1's Avatar
panasonic dmp bdt500. Worth every penny.
chuckg1 is offline
post #3 of 5 Old 05-31-2012, 06:59 PM
Rich86's Avatar
Quoted: 128 Post(s)
Liked: 64
This may be an issue for you if you purchase a blu-ray player licensed for production after Feb 2012 as these players must include cinavia processing which will foil your ability to play ripped discs which are infected with cinavia drm from anywhere other than the original disc itself.
A long-time audio/video addict!
Rich86 is offline
post #4 of 5 Old 06-03-2012, 07:44 AM - Thread Starter
Thanks for the suggestions! I take it that I'll need to find a player on the used market to avoid the cinavia issue?
Any other player suggestions?
post #5 of 5 Old 06-03-2012, 03:33 PM
rboster's Avatar
Quoted: 885 Post(s)
Liked: 741
Jeff please repost your question in the "help me chose a BR player" sticky
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is online now
Closed Thread Blu-ray Players
Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Panasonic Pt Ar100u Lcd Projector , Panasonic Dmp Bdt500 Integrated Wi Fi 3d Blu Ray Dvd Player
