Samsung BD-E5900 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 72 Old 01-04-2014, 12:13 PM
nyrmetros's Avatar
There was a Netflix update it seems....
nyrmetros is offline
post #62 of 72 Old 01-04-2014, 03:32 PM
Louis1's Avatar
I received the update also I'm not having any issues with my 2 units. They've been so good, I ordered a 3rd one for our guest room.
Louis1 is offline
post #63 of 72 Old 01-04-2014, 05:52 PM
nyrmetros's Avatar
I finally got the dlna function to work. The player can now connect to my phone as well as my network and all of the movies storedon the computer.
post #64 of 72 Old 01-16-2014, 02:15 PM
showstopper15's Avatar
Hi All,
Can one of you please let me know if you see "DishWorld" app in this player?  Samsung says its my device issue and they support it. Please let me know if you see it with the s/w version.
showstopper15 is offline
post #65 of 72 Old 01-21-2014, 11:09 AM
nyrmetros's Avatar
Originally Posted by showstopper15 View Post
Hi All,
I will check when I can...
post #66 of 72 Old 02-11-2014, 06:20 PM
Louis1's Avatar
I did not see DishWorld in the app search.  Maybe in a future update.
Louis1 is offline
post #67 of 72 Old 02-11-2014, 09:52 PM
Westly-C's Avatar
Quoted: 357 Post(s)
Liked: 230
This is a 2011 model isn't it? Which Netflix UI does it now have? This one-https://picasaweb.google.com/112011548845311819722/Panasonic2011NetflixHTML5?authkey=Gv1sRgCKPXjcjg1LOdZg&feat=embedwebsite#5618885022287863826
or this one-https://picasaweb.google.com/112011548845311819722/Playstation3HTML5V2Netflix?authuser=0&authkey=Gv1sRgCNjIkdbiu9rRbA&feat=embedwebsite#5616757515625823202 ...that was just replaced by the new version?
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is offline
post #68 of 72 Old 03-20-2014, 06:54 AM
nyrmetros's Avatar
I am not sure which UI it has. How do I know?
Oh based on your pictures, I will double check in a day or 2.
post #69 of 72 Old 03-10-2015, 11:36 AM
scope11's Avatar
Samsung BD-E5900 Problems with 3d & Upgrade Question BD-H5900
Hello all.
Recently I picked up a used BD-E5900. I've been using it successfully for streaming Netflix and connecting to my Plex server through the Plex app. As recently as last night, I finally tried to play some disc media on it. Blu-ray discs play flawlessly, but the unit will not play any of my 3D Blu-ray discs. It tries to load the disc for a couple minutes, and comes back with an error message saying the disc is not compatible. This has happened with several brand new 3D discs. I've not been successful at all in having any 3D discs play on it, and have tried 6 different movies now. I am however, able to successfully stream 3D content via my Plex library. What gives? Is the 3D portion of this unit defective? I've tried updating firmware, resetting the unit, clearing the BD Live etc... Any ideas?
Second to this... I have the opportunity to purchase a used BD-H5900 unit used for about the same price I paid for this E-5900. Not sure, but I'm assuming the H-5900 is a newer version - but I don't know what the differences are. I've read that there have been some issues with the "E" series releases, so I'm wondering if picking up this unit will solve my problems.
scope11 is offline
post #70 of 72 Old 03-10-2015, 12:11 PM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
You need to tell us how you have your 5900 run. Does it run through a receiver (which one), straight to TV, etc.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #71 of 72 Old 03-10-2015, 12:47 PM
scope11's Avatar
My E-5900 runs to a Onkyo TX-NR636 receiver, and then out to a BenQ W1070 projector. Using hi-speed HDMI connections between both.
scope11 is offline
post #72 of 72 Old 04-04-2017, 08:14 AM
fdm2000's Avatar
Question Help with Samsung DVD player stopping after startup
I have the Samsung BD- E5900 and am encountering a strange issue. I rent movies at Redbox and normally have no problem playing the disk, however, on occasion when renting a Redbox movie the player advances to a count of 17 or 18 and hangs and will not play. Recently I rented Patriot's Day and it would not advance beyond count 17. Redbox gave me a credit and I rented the movie at a different Redbox. It also stopped playing at count 17. I tried the movie in my laptop and it played and in an old basic DVD player in my bedroom and it played without issue ruling out a defective disk? Wondering if anyone might have a suggestion on a cause/fix for this unusual problem?
fdm2000 is offline
Reply Blu-ray Players
Blu Ray Players , Samsung , Samsung 3d Blu Ray Disc Player Bd E5900 , Samsung Bd D6500 Za D6500 Serivce Blue Ray Disc Player 3d Stereo , Samsung Bd E5900 3d Wifi Blu Ray Disc Player
