BD players with no USB port? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-09-2012, 10:22 PM - Thread Starter
Babaganoosh's Avatar
I have noticed that some Blu-Ray players have no USB port at all, and for some (not all) that do, the port will only work with a USB *device* and not a thumb/flash drive (so the USB port can't be used for external storage). My question is this: Do these players - most of them are new, I think - have another way for dealing with titles that absolutely *require* external storage, like THX-1138?
For example, do the affected players have an internal 'hard drive' that can take the place of external USB storage? Or are titles like THX-1138 simply incompatible with such players?
"I bought a new camera. It's very advanced. You don't even need it."
- Steven Wright
Babaganoosh is offline
post #2 of 11 Old 06-10-2012, 08:27 AM
Selden Ball's Avatar
Quoted: 3074 Post(s)
Liked: 1503
Exactly what player models have you seen with these limitations?
It sounds like you might be describing a profile 3 BD-Audio player, which would not need to include any of the features seen in BD-video players. While there has been at least one audio-only disc released, this is the first I've heard of what might be audio-only players. See http://en.wikipedia.org/wiki/Blu-ray_Disc#Player_profiles
It seems rather strange that audio-only players would be produced, considering how the prices of profile 5 (3D) players are plummeting. I suppose they'd be attractive to some audiophiles, but that's a very limited market.
Selden
Selden Ball is online now
post #3 of 11 Old 06-10-2012, 12:58 PM - Thread Starter
I was not talking about audio-only players. I had no idea they even existed. I was referring to normal BR video units.
So what you're saying is, all BR players MUST have a USB port?
I have browsed the manuals of some of the current players that do. They make no mention of the USB port being used for storage, i.e. with a USB thumb drive. All they talk about is connecting USB devices, like a keyboard. So how can I tell if any given player which has a USB port, can use it for actual storage?
As I said, THX 1138 requires the presence of an external USB storage device. It won't play without one. So you can see the problem.
- Steven Wright
post #4 of 11 Old 06-10-2012, 01:30 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2697 Post(s)
Liked: 1923
I've played THX 1138 with no storage apart from what's built in to my OPPO player. Where are you getting this info? Is this some special edition of the title?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #5 of 11 Old 06-10-2012, 01:45 PM
Liked: 1503
While a player could be designed to provide enough internal memory to avoid the need for a USB port if the manufacturer should happen to want to do it that way, such a player certainly wouldn't be competitive in the current marketplace.
Can you provide a link to a manual which doesn't mention USB storage?
Support for non-storage devices (like keyboards) is a relatively recent development, so I'd expect companies to make a point of mentioning that feature in competition with players that don't provide that support.
Just because a manual doesn't mention it, doesn't mean USB storage isn't supported. As you can see in the various "profile" requirements described in the Wikipedia article, any BD player which supports either "BD Live" or 3D, must also support at least 1GB of storage. I doubt that Sony would allow companies to violate that licensing requirement. As an apparent cost-conainment measure, some current players actually provide no internal storage of their own, thus requiring users to purchase a USB flash drive to provide it if they want to use those features, but that storage is still "supported".
Selden
post #6 of 11 Old 06-10-2012, 01:48 PM - Thread Starter
-Bill
No, it's the normal Blu-Ray edition.
I have just heard too many stories from users who can't get the disc to play until they add external USB storage, apparently the menu is so elaborate that it requires more storage than players offer internally. But nobody seems to know how much more storage is needed. Just the luck of the draw, really.
But the trouble is, they never say exactly how much internal storage, if any, that a given player has. So not only is it impossible to tell if a player's USB port can be used with a thumb drive, but you also can't tell if this title will play without one!
As for a link, here is an example. The tech specs do say this unit has one USB port, but only for "playback & communication camera." Storage is not mentioned anywhere in those specs.
- Steven Wright
post #7 of 11 Old 06-10-2012, 02:01 PM
wmcclain's Avatar
Liked: 1923
-Bill
Have you tried the disc yourself yet? I forget if it has BD-Live. Turning off BD-Live in the player would be a good first step.
-Bill
post #8 of 11 Old 06-10-2012, 02:08 PM - Thread Starter
It works in the BR player I have now (Sony 360). My question is whether any of the new players will support the title. I already have a USB drive, so that shouldn't be a problem. Like I said, though, it's not easy to tell if these new players support USB storage.
I never use BD-Live anyway, so it won't be a problem if I can turn that off.
- Steven Wright
post #9 of 11 Old 06-10-2012, 03:11 PM
Liked: 1503
The link you provided is just to a spec sheet. They're always incomplete.
The manual says
USB device
≥ This unit does not guarantee connection with all
USB devices.
≥ This unit does not support USB device
charging.
≥ FAT12, FAT16, FAT32, and NTFS file systems
are supported.
≥ This unit supports USB2.0 High Speed.
≥ This unit can support an HDD formatted to
FAT32 and NTFS.
Some types of HDD may require the use of its
external power supply unit.
Selden
post #10 of 11 Old 06-10-2012, 03:24 PM - Thread Starter
I see. So is it a safe bet to assume that any player that has a USB port, will support it for storage in the manner you just described?
- Steven Wright
post #11 of 11 Old 06-10-2012, 03:33 PM
Liked: 1503
I believe so, yes. Otherwise it's defective. Sadly, a few defective units do wind up in customers' hands.
Selden
Reply Blu-ray Players
