No audio once bluray starts - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-12-2012, 08:21 AM - Thread Starter
Browninggold's Avatar
Liked: 37
Alright. I had a pj when watching bluray. Sold that so using the 50" plasma again. I put in bluray and it has picture and sound during previews. But once the title starts it has picture but no sound. It only is showing PLII also. Take it ez on me I am taking pain pills. It's running through a Denon A100. I had Craig Rounds calibrate pj and setup, so whatever he set i cannot find it where it will have sound. When I had it setup I could watch either on pj or plasma. Now no sound. I know it has to be a ez fix but I'm not finding it right now. Gonna pop another Vicodin. Thanks in advance. I decided to hit the bluray input again on the Denon remote which it was on anyways and it has sound now. And showing DTS so it is working now. But any ideas why this happened? Ok just turned everything off and back on no sound again.
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
post #2 of 2 Old 06-12-2012, 08:44 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
What is the input setup on the Denon? It should be Auto so that it will play all formats. The menus and previews are usually PCM or DD, while the movie tracks on most BDs are DTS. If you have the input set to PCM, then you'd get audio most of the time until the movie starts.
BIslander is offline
Reply Blu-ray Players
