BD570 - Trying to use 3TB hard drive - AVS Forum | Home Theater Discussions And Reviews
Old 06-21-2012, 04:01 PM - Thread Starter
natemp21's Avatar
I just purchased a 3TB hard drive to use with my BD570. I formated the Drive to NTFS but the player does not recognize it. I can partition the drive with two partitions of 1.5 but when I plug in the drive it recognizes it but it shows "3 drives" instead of two.
Anyone know why it thinks their are three drives?
also
Is there a way around the player not seeing anything above a 2tb drive?
natemp21 is offline
Old 06-22-2012, 07:32 AM
Smackrabbit's Avatar
Quoted: 30 Post(s)
Liked: 90
It's likely the same issue that PCs see with 3 TB drives, where they see a maximum of 2^64 bytes of data which limits them to around 2 TB in size. Since many players are built onto some Linux core at this point, or a chipset that has these same limitations, they probably just can't see a full 3 TB drive. You can read about the issue with PCs here: http://www.pcworld.com/article/235088/everything_you_need_to_know_about_3tb_hard_drives.html. As far as seeing 3 drives that I do not know.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is offline
Old 06-22-2012, 08:17 AM - Thread Starter
natemp21's Avatar
Thanks for your help. That makes sense. I figured out that the drive was automatically creating a 60mb hidden "protective" partition so that's why there were three.
natemp21 is offline
Lg Bd570 Network Blu Ray Disc Player , Blu Ray Players
