Sony BDP-S580 major video "flicker" in menu sections - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-20-2012, 04:04 PM - Thread Starter
eph3's Avatar
For many months since I purchased my Sony BDP-S580 in Nov 2011, I didn't have any issues at all. A month+ ago I started seeing a completely new problem, and I hadn't changed anything in my setup other than upgrading the firmware on the Blu-ray player (as I typically keep everything up to date).
The problem I am seeing is a major amount of video "flicker" or digital white noise being displayed whenever in the menu level of the player or a disk. Interestingly enough, playback of content from a disk, whether Blu-ray or DVD works perfectly fine. I made a simple video from my phone which you can see at http://www.eph3.com/IMG_0920.MOV.
I tried several changes to see the behavior would change. I've tried different HDMI cables, different HDMI inputs into the AV processor, disconnected wired ethernet and connected straight into the TV. None of these changes made a difference. I opened a chat session with Sony Support yesterday and the two suggestions I got from them were to reduce the video resolution and also unplug the device to force a hard reset. The reset didn't do anything, but reducing the resolution seemed to work, but isn't a solution. Personally, I'm suspicious of the latest firmware which was released mid-May (M07.R.0620).
Anyone else seen this problem? And if so, what did you do to fix it? Does anyone know if it is possible to downgrade the firmware?
eph3
eph3 is offline
post #2 of 3 Old 07-20-2012, 05:11 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 949
Welcome to AVS. Mods ask that all questions go in the official thread for that player. You may want to repost there as mods will more than likely lock this one. Searching that thread might tell you if anyone else might have run across something similar.
http://www.avsforum.com/t/1319907/sony-bdp-bx58-and-bdp-s580-owners-thread-all-questions-comments-belong-here
Good luck,
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #3 of 3 Old 07-20-2012, 06:04 PM - Thread Starter
eph3's Avatar
Please remove this. I meant to post it in the thread for BDP-S580 players.
eph3 is offline
Closed Thread Blu-ray Players
Sony Bdp S580 Blu Ray Disc Player Black , Sony 3d Blu Ray Disc Player Bdp S580
