Ability to Play Music Files DLNA- Random - AVS Forum | Home Theater Discussions And Reviews
Old 08-06-2012, 09:30 AM - Thread Starter
Yogi55's Avatar
I have looked thru the manual and tried to find a function on the player that allows you to have music file play randomly, I cannot. Does anyone know if this function is available on this player. Most of the other players I have had allow you set this up. It is nice to be able to select a music folder and have the music shuffled so to speak.
Yogi55 is offline
Old 08-06-2012, 11:24 AM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 949
What player? You might want to post your question in the owner's thread for your player.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Old 08-06-2012, 04:31 PM
apw2607's Avatar
Quoted: 110 Post(s)
Liked: 219
If memory serves you've got a Sony BDP-S590 right ?
Unfortunately, shuffle or random play is not supported under DLNA. Oddly it was supported by Sony on their Bravia TV line ... but not on their BD players. You can send a enhancement request to sony using their on-line forum. They do read it .... and may add it !
There is a sort of workaround. If you're DLNA server supports playlists then you could create a playlist thats being generated from Random tracks ..... thats what I do at least.
apw2607 is offline
Sony Bdp S590 3d Blu Ray Disc Player
