Official OPPO BDP-103/BDP-105 Anticipation Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #721 of 2837 Old 09-23-2012, 01:17 PM
scenemissing's Avatar
Originally Posted by kluken View Post
Here is what excites me about the Oppo 103, the "SMB/CIFS Access - The BDP-103 comes with an experimental feature that can access video, audio and picture files shared by computers on the local network via the Server Message Block (SMB) or Common Internet File System (CIFS) protocol."
If this will allow me to point the Oppo to my NAS device that has all my MKV rips of my BD and play them handling the TrueHD and DTS-HD stream to my AVR then sign me up I am all over this Oppo as I have yet to find a satisfactory stream setup that work short of building a HTPC
Yeah! This has gotten my interest as well. I'll have to see how the Cineava works out though - no fun in ripping my stuff only to have it error out on me.
LIkely sticking with the 93 for a few more years, but I will keep my eyes out.
scenemissing is offline
post #722 of 2837 Old 09-23-2012, 06:50 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 248
What's wrong with Dunes? Mine have never failed to play a file correctly.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #723 of 2837 Old 09-23-2012, 07:09 PM
chrisb42's Avatar
Originally Posted by Esteban Medaglia View Post
Hi folks. I was the user that made that phone call to Oppo. They basically explained that due to the high cost of licensing Apple codecs, etc., they won't be incorporating AIFF nor ALAC compatibility any time soon on their players.
[Edit:]I have now caught up and have nothing new to offer to the previous discussion. Move along, nothing to see here biggrin.gif[/Edit]
Sorry, haven't been able to read the rest of the thread yet, but this is false and I'm kind of shocked that this is information that is being given out. The Apple Lossless Audio Codec has been released under the Apache license last year already:
http://alac.macosforge.org/
There should be no reason short of engineering and/or time constraints to support it.
-Christian
chrisb42 is offline
post #724 of 2837 Old 09-23-2012, 07:55 PM
seditious3's Avatar
Originally Posted by o.o604 View Post
OPPO this is 2012 - NOT 2014 - so no thank you for SCREWING us out of analog outputs.
Oppo hasn't "screwed" you out of anything. If you don't like it, don't buy it. And stop complaining.
scanspeak likes this.
seditious3 is offline
post #725 of 2837 Old 09-23-2012, 08:02 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
-Christian
You haven't really missed anything, just back-and-forth arguments. wink.gif Again, Oppo's response tells me they either didn't have the latest information OR the patent situation is more complicated than the open source licensing announcement has led us to believe.
vinnie97 is offline
post #726 of 2837 Old 09-23-2012, 08:24 PM
hawkfan's Avatar
What do you expect OPPO lies to its customers
Ok, now this is officially trolling/baiting. I come here to get tidbits about the 103/105 and all this does is derail the thread.
hawkfan is offline
post #727 of 2837 Old 09-23-2012, 08:48 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1286 Post(s)
Liked: 1351
Please either ignore him or use the report post button to ask the moderators to take action.
gsr is online now
post #728 of 2837 Old 09-23-2012, 09:10 PM
williamsdl58's Avatar
From the BDP-103 User Manual:
"Preference should be given to the HDMI 1 output for video since it is the only output to benefit from the superior Marvell QDEO video processor."
"Due to the hardware limitation, DSD output is only available from the HDMI 2 OUT port. To listen to SACD using the HDMI 1 OUT port, please set SACD Output to PCM."
Since I am only running one HDMI cable to my front projector from my AVR, I will need to run both HDMI outs from the BDP-103 to the AVR to be able to have the benefit of the QDEO on HDMI 1 and SACD Bitstream on HDMI 2? Am I reading this right?
williamsdl58 is offline
post #729 of 2837 Old 09-23-2012, 10:43 PM - Thread Starter
Neuromancer's Avatar
Quoted: 96 Post(s)
Liked: 370
If you want to use SACD DSD, then yes, you would need to HDMI 1 and HDMI 2 connected concurrently. Use HDMI 1 for everything other than SACD, then switch to the new input on your receiver to listen to SACD DSD over HDMI 2.
Neuromancer is offline
post #730 of 2837 Old 09-24-2012, 01:36 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3789 Post(s)
Liked: 4928
Or alternatively, also wire the multi-channel Analog outputs and use those for SACD DSD listening (with HDMI Audio temporarily set to OFF).
This limitation -- inability to send HDMI DSD on the HDMI 1 output -- is a hardware limitation, so don't expect it to change in future firmware.
Note that you CAN play SACD music over HDMI 1 using LPCM. In fact if you set SACD Output DSD, the HDMI 1 cable will still carry LPCM when you play an SACD -- the same sort of thing that happens if you try to send HDMI DSD to an AVR that says it can't accept DSD. Set this way, the Analog outputs will also use PCM while audio output is active on HDMI 1 because the DSD to PCM conversion is engaged due to that HDMI 1 output. To enable DSD-Direct-to-Analog conversion on the Analog outputs, change HDMI Audio to OFF to shutdown the DSD to PCM conversion needed when sending the audio out on HDMI 1. You can do this on-the-fly (while the SACD is playing). The on-screen display (and the front panel lights) will tell you whether DSD or PCM output is in use while playing an SACD, so you can double check that way. Switching between DSD and PCM output will cause the currently playing SACD track to restart.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #731 of 2837 Old 09-24-2012, 01:47 AM
Read the FAQ!
Liked: 4928
Originally Posted by pipetabor View Post
Bob,
many of us are excited about being able to have a DAC decode DSD downloaded files. Cookie Marenco from Blue Coast Records recently did a test showing off a DSD file going through a $1,595 MyTek DSD DAC (using the same SABRE DACs as the Oppo 105/95) compared to it's SACD physical disc counterpart (played on a $20k SACD player), and everyone overwhelming preferred the DSD file through the affordable DAC.
I think many of us are wondering that since this is the same SABRE DAC chip, whether or not we will be able to play DSD download files through the asynchronous USB connection. (that dCS established). This is where the future of great digital download audio is going, and what many of us have been waiting for since the BDP-95 came out.
Can the BDP 105 do DSD native download files (it obviously already decodes DSD from SACD discs, so this shouldn't be a technical issue as much as firmware/software of choice)
For me, this would be the deal maker. Especially when comparing the current Oppo BDP-95 to the Cambridge Azur 751BD... the BDP-105 would tip the scales with an external DAC that can do DSD.
-Brian
I know everyone is eager for information, but we'll have to defer this. OPPO has not yet released such specs for the 105, so the Beta Testers have to stay mum for the moment.
--Bob
post #732 of 2837 Old 09-24-2012, 03:08 AM
onesolo's Avatar
As usual, Oppo like to screw european consumers with their products...
I would love to know why here in Europe, this player is being charge around €650/700 (I already saw some stores with this price) and the in US the MSRP is $500 !!!!
When doing conversions it costs about €385 !!! More than €300 of difference!!!
And don't give me that old excuse of price without taxes... if you take the taxes from the EU price, it would be around €550, not even close to the $500 in US
Are we so that different who lives in USA to deserve this?!?
Webmonkey likes this.
Panasonic TX-P42V10E; Onkyo TX-NR808; PS3; Cambridge Audio Azur 640C; Raspberry Pi (Model B)
Wharfedale Diamond 9.4 / 9 CS / 9.1; BK Gemini; Just Racks JRA120‑SW‑BG
2x3m e 2x10m Supra 2.5 Classic; 3m QED P-CV1; 1m QED P-75; 3m Ixos XFA02
onesolo is offline
post #733 of 2837 Old 09-24-2012, 04:11 AM
Read the FAQ!
Liked: 4928
^ OPPO Digital in the US does not set prices in Europe. European model players come from OPPO UK.
The tax and regulatory environment in European markets are quite a bit different than in the US. As just one example, and I'm going from recollection here, the players in Europe must be sold with a two year warranty. OPPO Digital in the US sells the players with a one year warranty, and sells an optional extension to two years (for $69 in the case of the BDP-95). In addition, European distributors typically have to contribute to end of product life (recycling) programs. Which also brings up that two tier distribution system. OPPO sells direct in the US. In Europe there are regional distributors who buy from OPPO UK and probably want to make a few Euros themselves. I don't know what all else is different, but every home theater electronics product I know of originating in North America is sold for substantially more money in Europe -- by all manufacturers. I suppose it's possible that ALL of them don't like their European customers, but it seems more likely to me that there are costs of doing business in Europe that you haven't considered in your math.
--Bob
post #734 of 2837 Old 09-24-2012, 05:03 AM
Lotus00's Avatar
has anyone commented on the how the 105 sounds compared to the 95?
Rotel is not involved anymore how does the new setup sound?
Are they still using the ESS Sabre32 9018's?
Have you tried usb playback and the asynch usb port? How does it sound? How easy is it to use your computer thru the aynch usb & HDMI port?
Does anyone have the pioneer sc-68 or another nice receiver? How does it sound when you play thru the receivers asynch usb or regular usb or hdmi as opposed to 105 playback?
Lotus00 is offline
post #735 of 2837 Old 09-24-2012, 05:33 AM
eliwankenobi's Avatar
Quoted: 14 Post(s)
Liked: 32
It would be a safe guess that since the bdp-95 had the top of the line Sabre 9810 DACs (two of them), the same DACs are being used for the bdp-105. One for 7.1 analog outs, and another for stereo in quad-differential mode, hence the balanced XLR connections.
I'm very excited about the USB DAC feature and the possibility of DSD playback over USB. If it does multichannel as well, taking advantage of both ESS Dacs depending on what you want to hear, OPPO would be really on a class of its own regarding usb DACs. We already know OPPO is king of universal disc players.
Another possibility, would be the ability to accept an I2S connection through one the hdmi inputs. That way one can use a device like this: http://www.exadevices.com/Home.aspx and have DSD and PCM up to 32bit / 384khz which the 9018 can accept. smile.gif
Don't follow me, I'm lost too -Unknown
SETUP: PC with JRiver MC and PS3 -> Onkyo TX-SR705 -> Sierra-2 LCR & Energy Take Classic for surrounds \-> Epson 8350
eliwankenobi is offline
post #736 of 2837 Old 09-24-2012, 05:43 AM
Lotus00's Avatar
The 95 must have some cirrus dac's in there too I guess.
the 103 might be using same dacs as the 93.
Lotus00 is offline
post #737 of 2837 Old 09-24-2012, 05:55 AM
Bill Mac's Avatar
Quoted: 1591 Post(s)
Liked: 1859
Why would you think that the 95 has Cirrus DACs "in there too"?
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #738 of 2837 Old 09-24-2012, 06:06 AM
Lotus00's Avatar
Bill
because the ESS dac's are for the 7.1 analog and XLR setup.
the 93 uses Cirrus Logic dacs.
it would be very cool if Oppo released 105 info today
Lotus00 is offline
post #739 of 2837 Old 09-24-2012, 06:44 AM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
How would you guys say this OPPO 103 compares with the Sony S790 in bluRay watching only? I dont stream I just watch BluRay.I use HDMI ALSO. The oppo 103 is twice the price of the Sony S790.
kutlow is offline
post #740 of 2837 Old 09-24-2012, 07:03 AM
Bill Mac's Avatar
Liked: 1859
I suggest while you are over at the Oppo site you look at the specs of the 95 wink.gif. If you do you will see no mention of Cirrus DACs. Below is direct from the 95 features and spec page.
The BDP-95 uses two ES9018 DAC chips - one for the 7.1-channel output, and another for the dedicated stereo output.
Dedicated Stereo Output - The BDP-95 features a dedicated 2-channel analog output with specially optimized ES9018 DAC and output driving stages. Each output is driven by 4 DAC channels stacking together to achieve even greater audio performance.
http://www.oppodigital.com/blu-ray-bdp-95/
Bill
Bill Mac is offline
post #741 of 2837 Old 09-24-2012, 07:12 AM
guima's Avatar
I bet the build quality of the 103 will be a whole different ball game.
Sony is a good streamer, but it's got a fan and its drive unit is very noisy (noisier than the panasonic too). It's very lightweight, so vibration and drive noise aren't shielded well enough. I'd say that for BD watching only, the BDT500 (same price as the sony) is better, while the sony is better for streaming (a lot faster and more streaming services). My experience is that players tend to make more noise as they age, and the fan is just another potential source (of noise) in the long run.
guima is offline
post #742 of 2837 Old 09-24-2012, 07:15 AM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
Hard to say, since it's not officially out, but if it compares well with previous Oppos, then it will be the best at bluray display. The differences between it and the S790 in just bluray will probably be small, limited to proper colorspace mapping, which previous Sonys did not do correctly, and the Oppos did. It would depend on your screen size and other factors, but not great differences.
There are many more things that the Oppo does well and are probably important now and going to be important as time comes, like DVD upscaling, support of remote media (local area network based and streaming), support of multiple audio formats, use of the 103 to clean up a cable signal, etc.
But it's like asking whether an economy car will get you to the corner store better than a really reliable high end sedan. Both will do it, but if that's all you need and the money difference is important, then get the economy and things will be good, as long as you don't need the things that the high end delivers.
hernanu is offline
post #743 of 2837 Old 09-24-2012, 07:24 AM
Lotus00's Avatar
Bill
Yes I have been to that page but you know how marketing material can sometimes be misleading, as has already been discussed previously smile.gif
Appreciate you confirming. I didnt see any mention of Cirrus on the 93 page either...just wanted to double check there weren't any others.
The 105 might have a new ESS dac??
Lotus00 is offline
post #744 of 2837 Old 09-24-2012, 07:31 AM
Lotus00's Avatar
you know what would be nice, if Oppo would add vtuner. Isn't it free? I love vtuner and it's great to have access to radio stations all over the world. For example, there was a music festival in a small town in Germany one time. The local radio station was broadcasting it. I was able to find that radio station and tune in for the whole 3 day festival! Another time was an event near Mt Fuji that was broadcast by local station. Very cool service.
Lotus00 is offline
post #745 of 2837 Old 09-24-2012, 07:56 AM
cglenn's Avatar
Quoted: 26 Post(s)
There were previous posts about the DACs in the 103 and 105. I believe the 105 will have two Sabre32 DACs. Is this the same as the ES9018?
I posted a reply from Oppo about the 103 chip earlier: "The DAC is the same as the BDP-93, the Cirrus Logic CS4382A (8-ch, 24-bit, 192khz). There have however been some incremental improvements in circuit design that should improve on the audio some."
HDMI Main Out to Samsung JS8500 (4K & HDR)
HDMI Audio Only Out to Denon 3312
cglenn is offline
post #746 of 2837 Old 09-24-2012, 10:11 AM
smurraybhm's Avatar
Quoted: 1680 Post(s)
Liked: 2099
Streaming services never seemed to be a high priority for them, look at the 93/95 as examples. Your best option for VTuner is the Roko streaming stick which is a nice option to add to the new players if streaming is important to you and you don't own a Roku or something similar already. From the cheap seats I think its easy to see that Oppo has decided offer this option to satisfy those who want streaming services beyond the basics found on the 93/95. I don't see it VTuner offered by Roku but they have a number of different radio streaming channels available that should suffice. Sometimes I think we are spoiled by everything Oppo does so well and lose sight that these quality blu-ray players can't do it all.
There is no perfect display, quit looking for faults and enjoy
LG B7 OLED 65" (waiting for cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 and other toys
smurraybhm is online now
post #747 of 2837 Old 09-24-2012, 10:11 AM
sdrucker's Avatar
Quoted: 887 Post(s)
Liked: 600
The last few generations of Pioneer and Denon receivers, and models of Anthem, Onkyo, Sony and Yamaha, have vTuner capability:
http://www.vtuner.com/features.asp
(there's undoubtedly more counting this year's AVRs, but this is the most recent list)
You can also stream Reciva Radio or TunedIn from an iDevice to an Apple TV connected to your AVR or one of the HDMI inputs on the upcoming 103/105.
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Misc.: Oppo 103, Oppo 203 UHD player, JRiver
Speakers: PSB Imagine T3 LCR, Imagine T Wides and Side Surround 1, T2 Side Surrounds, Imagine XB rears, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 11.4.6
sdrucker is online now
post #748 of 2837 Old 09-24-2012, 10:27 AM
stevekale's Avatar
Quoted: 374 Post(s)
Liked: 45
What, if anything, do we know about upgrades to:
1. power supply
2. DSD->LPCM conversion and bit rate output
3. the clocks
From the pics of the 103 it looks like it will still be easy to disconnect the power to the analogue section which is good.
Demand greater honesty and transparency in high-end audio
With Theta, Egglestonworks and Krell since 1998!
stevekale is offline
post #749 of 2837 Old 09-24-2012, 10:31 AM
bakerwi's Avatar
Quoted: 81 Post(s)
Liked: 47
I have a BDP-93 and the Sony BDP-S790 and when I turn off ALL the processing in the Sony the pictures are comparable. I would expect the same results when compared to the S790 with all procesing turned off. Also, there is a justifiable reason why the Oppo cost twice as much given its feature set compared to the Sony. If your main priority is blu-ray PQ and you have no need for all the Oppo does above and beyond the Sony, then I would endorse the Sony.smile.gif
Home theater - LG OLED65E6P, Sony UBP-X800, Oppo UDP-203, Arcam FMJ BD300, Denon DVD-5910
Master bedroom - Oppo BDP-103
Breakfast area - Pioneer BDP-320
Office - Sony BDP-S5000ES
Family room - Pioneer BDP-320, Sony BDP-S790
Revel Performa3 F208, C208, M106, M105
bakerwi is offline
post #750 of 2837 Old 09-24-2012, 10:46 AM
dmusoke's Avatar
Quoted: 388 Post(s)
Liked: 192
IIRC, it was Neuromancer a few posts back who said that he prefers the implementation of the anolog sound of the 105 than the 95 when listening through his headphones.
Yes, the 105 uses the same exact ESS Dacs as the 95 but the filter and amplification circuitry after the dacs is different in the 105 than the 95, with different meaning better or enhanced per Oppo.
I'll have to defer to others knowldegable than i to answer your other questions ...
- David
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
Reply Blu-ray Players
Oppo , Blu Ray Players , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player
