AVS Owner's thread for the pioneer elite bdp-62fd.. - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #361 of 898 Old 04-20-2013, 06:22 PM - Thread Starter
pioneertop's Avatar
Quoted: 28 Post(s)
Liked: 176
Originally Posted by Edllguy View Post
Hello everyone,
I'm really enjoying my new 62. I is now my primary Blu-ray player in my home theater setup.
I have this connected to an SC-57 and Pro-111FD panel calibrated by D-Nice. I have a couple of questions about setting up the 62 and if someone could help me that would be great.
What colour space do I set it too. Choices are the following: RGB, Full RGB, YCbCr, YCbCr 422
What is the best resolution for my Panel: Auto or 1080p
What is the best setting for HDMI Deep colour: 30 bits, 36 bits or Off
What is the best setting for Digital Output: Bitstream, PCM, Reencode, Off
What is the best setting for downsampling: 48k, 96k, 192k
What is the best setting for Dynamic Range Control: On, Off, Auto
I think I have figured out the rest by reading the manual but I'm stuck with the above questions.
ok.. lets see i have minds set up like this ..to my kuro.(.1 )--YCbCr 422...(2) 1080P.. (3) 36bit.(4) bitstream...(5) 48k..( 6) atuo. .thats how i have minds setup ..i have hdmi control on ..as well on both the tv and the BD and the AVR..
loves...home theather/music/football:)
pioneertop is offline
post #362 of 898 Old 04-20-2013, 08:06 PM
Edllguy's Avatar
Quoted: 115 Post(s)
Liked: 57
^^^Thanks. Much appreciated. Take care.
Edllguy is offline
post #363 of 898 Old 04-20-2013, 11:15 PM
gonnapena's Avatar
Quoted: 18 Post(s)
I have a Samsung BD-2550 and I recently upgraded to a Pioneer Elite BDP-62FD. I'd like to know from anyone who has upgraded, what do I have to expect in improvements with this player? My other BR player is a Sony PS3. Is the Pioneer really better than it?
Is it worth keeping the Samsung player for a bedroom that doesn't currently have a Blu-ray player (but will barely get used) or better to sell it now while it still has value? I also have a DVDO Iscan Pro that looks like it's getting ebay'd or craigslisted if I put the Samsung for sale.
gonnapena is offline
post #364 of 898 Old 04-20-2013, 11:18 PM
Edllguy's Avatar
Quoted: 115 Post(s)
Liked: 57
I have been putting my 62 through its paces and giving it a good work out. I really like this blu-ray player. However, I have noticed on my first blu-ray movie for this player that I'm getting lip sync issues. Its not like slight lip sync, its very noticeable. I don't get lip sync with Netlix or You Tube. So my question is what am I doing wrong? Is it some set up or setting issue/adjustment it needs? I intend to keep this player, however, I'm thinking if I can't correct this problem maybe I should get an exchange unit.
Could other owners of the 62 please share their lip sync stories. Maybe I'm one the very few having this problem. I don't have this issue with the Oppo 93 or PS3. All my devices are Pioneer and HDMI 1.3a or 1.4a compliant.
Thanks everyone
Edllguy is offline
post #365 of 898 Old 04-20-2013, 11:39 PM
Sunny44's Avatar
Last Saturday I bought the 62 at BB, I tried most of the features that night and also watched a movie, everything worked great.
The next night I could not get the player to turn on, front panel buttons didn't work and no remote, I had to disconnect the power cord
for a few seconds and it started working again. I thought this was a one time glitch but it happened again the next day. I exchange the
62 for a new one, even asked for a different build date. The new unit is doing the same thing, first day I got it I set it up and watched a
movie, the next day it doesn't respond. This is a replacement for a pioneer 51 which never had this problem. No other components have
changed. Once I do the power cord reset the player works perfectly with no hiccups. It's plugged into a APC H15 power conditioner.
Tonight I disconnect the LAN cable to see if that has any effect. Has anyone else had this problem? Any ideas?
Sunny44 is offline
post #366 of 898 Old 04-21-2013, 05:20 AM
eNorm's Avatar
I got the same problem..
I'm on the third one that did the same thing...
When it happen I have to push the power button 10 sec,it reset the player...
eNorm is offline
post #367 of 898 Old 04-21-2013, 08:17 AM
Sunny44's Avatar
eNorm, is the third one working OK?
If I only wait a few hours after its working and
try to use it, It seems to work fine, it's after sitting a day
that it becomes unresponsive.
The build date on my first unit was August and
the second one is October.
Is anyone else seeing this problem?
Maybe a bad batch?
Sunny44 is offline
post #368 of 898 Old 04-21-2013, 08:48 AM
AVfile's Avatar
Quoted: 239 Post(s)
Liked: 125
Is there a quick start feature you can try disabling?
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #369 of 898 Old 04-21-2013, 08:59 AM
Sunny44's Avatar
AVFile,
The quick start feature is turned off, I thought about tuning
it on and seeing if it helps. The problem is it seems to take
a period of time for it to become unresponsive which makes
It difficult to troubleshoot. I have disconnect the LAN connection
and will see if that helps and I was gonna try plugging it directly
In the wall outlet to bypass the APC. The problem is I have a limited
amount of time to make a decision about returning it and looking for
something else.
Sunny44 is offline
post #370 of 898 Old 04-21-2013, 09:40 AM
Krutsch's Avatar
Liked: 36
Originally Posted by Sunny44 View Post
AVFile,
something else.
I have not seen this issue for quite some time and mine stays on a lot (I use the BDP as my Pandora player). I had assumed that the previous F/W update had fixed something.
Try enabling quick start, leaving the LAN cable plugged in and make sure it has power all the time (i.e. that your APC doesn't power it down). I used to have mine plugged into a monster power strip that automatically stopped power to mine, whenever the LCD was powered down, but I noticed that (a) it takes a long time to start cold (especially on the network side) and (b) iControlAV2012 doesn't like it when it starts up and can't see both the AVR and the BDP.
Otherwise, please contact Pioneer tech support and let them help you - they are very responsive, in my experience, and there might be something else happening.
"Play the volume as loud as you want - but don't touch my levels now. I got them set just like I like them"
Krutsch is offline
post #371 of 898 Old 04-21-2013, 10:05 AM
Sunny44's Avatar
Krutsch,
I will try your suggestions, thanks.
I did update the F/W on both units.
From your response, are you suggesting
that this was a problem and was supposedly
fixed by the F/W update?
Sunny44 is offline
post #372 of 898 Old 04-21-2013, 10:09 AM
Krutsch's Avatar
Liked: 36
Krutsch,
I *think* so... I've seen this lockup behavior, but it was months ago since the last occurrence. I recall there being a firmware update and then I didn't see this issue any more. In any case, it was rare - not like what you are describing.
Krutsch is offline
post #373 of 898 Old 04-21-2013, 11:11 AM
eNorm's Avatar
No! The third one as the same problem as the other...
But I do find that if I enable the quick start feature, The problem went away...I just think its a bug in the firmware...
eNorm is offline
post #374 of 898 Old 04-21-2013, 11:50 AM
LNEWoLF's Avatar
Quoted: 222 Post(s)
Liked: 133
My BDP-150 recently did the same thing. Would not turn on with the remote or by pressing the power button on the front panel. Had not used the unit in a couple of days. It only worked after unplugging the power cord for about a minute. Then it would turn on with the remote.
It does sound like a firmware concern. Since other models are experiencing this.
Twin Pioneer AVR Locomotives-Elite SC 97, SC 1222 7.1.4, DOLBY Atmos and DTS X, (Front Pre Out,) JBL Pro Synthesis LS Series Speakers, F L R-LS80, Cen-LS, S L R-LS60, SB L R-LS60, 4 Dolby Atmos Enabled Pioneer SP-T22A, JBL 12" Wireless Sub
Mitz 73740 DLP, Sony BDP-BX650, ATV G3, Yamaha ATS 1060 Sound Bar, True Depth Firestorm 2.0 3D Glasses, Harmony Smart Control with Touch Remote, EYE Pad Air, Winegard FL6550A
LNEWoLF is offline
post #375 of 898 Old 04-21-2013, 11:53 AM
LNEWoLF's Avatar
Quoted: 222 Post(s)
Liked: 133
The quick start function on mine is not turned on. I have to try with it on. Although this should be fixed with a firmware update.
LNEWoLF is offline
post #376 of 898 Old 04-21-2013, 02:47 PM
Sunny44's Avatar
I'm in the process of testing my 62 with quick start turned on.
I have also sent an email to pioneer support describing the problem.
I agree, this should be fixed in a F/W update.
Sunny44 is offline
post #377 of 898 Old 04-21-2013, 04:50 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
FYI, the problem is also on the BDP-53 after the last FW update.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #378 of 898 Old 04-21-2013, 05:01 PM
Sunny44's Avatar
David,
Doesn't turning on quick start fix it?
Sunny44 is offline
post #379 of 898 Old 04-21-2013, 05:19 PM
Quoted: 612 Post(s)
Liked: 584
Not on both BDP-53 and BDP-62. My "workaround" is now just unplug the unit when I don't use them.
my home theatre
post #380 of 898 Old 04-21-2013, 05:45 PM
bokes's Avatar
Quoted: 13 Post(s)
Can I play a non US Blu ray in this player?
bokes is offline
post #381 of 898 Old 04-21-2013, 05:49 PM
Quoted: 612 Post(s)
Liked: 584
If you mean 1080/50i (such as BBC's Sherlock), the answer is yes.
my home theatre
post #382 of 898 Old 04-21-2013, 06:00 PM
Sunny44's Avatar
David,
When was the last FW update for the 53?
I'm trying to determine if pioneer will have a fix for this
shortly or I should just return the 62 and get something else.
So you are saying that turning on the quick start on the 62 didn't
fix the problem? Does your 62 have the latest FW update?
Sunny44 is offline
post #383 of 898 Old 04-21-2013, 06:14 PM
Quoted: 612 Post(s)
Liked: 584
Honestly can't remember which FW I have but most definitely the latest one because everytime I'm about to watch a movie I always check for FW update (all my players around the house are internet connected.
The problem is somewhat 'fixed' when I set the playe to quick start but on ocassions it will still being unresponsive. So rather than playing Pioneer Roulette, I just unplug the player when I don't use them and just plug them in before I'm about to play a movie.
If I don't need PAL and 1080/50i playback, quite honestly I would've stayed with my Pana BDT-500 or the upcoming BDT-330. However, at the current price of $200, I don't find the problem to be big deal (well, kinda for me coz I bought it for $270)
my home theatre
post #384 of 898 Old 04-21-2013, 06:17 PM
Quoted: 612 Post(s)
Liked: 584
PS: the last FW for the 53 was back in October 2012, IIRC.
my home theatre
post #385 of 898 Old 04-21-2013, 08:04 PM
Krutsch's Avatar
Liked: 36
David,
So, did it *not* fix your problem?
There is something going on here; this unit is my daily driver for BD, streaming, Pandora and Netflix and I can't recall the last time I cold-booted the machine.
Krutsch is offline
post #386 of 898 Old 04-21-2013, 08:16 PM
Sunny44's Avatar
Krutsch,
I just turned on quick start this evening and reconnected the LAN.
I won't know until tomorrow evening if it helped. It becomes unresponsive
after about a day. So far it appears the 53, 62 and the 150 are experiencing
the problem.
Sunny44 is offline
post #387 of 898 Old 04-21-2013, 08:24 PM
Quoted: 612 Post(s)
Liked: 584
Most of the time it "fixes" the machine but still around once a week or once every two weeks the problem comes back.
You can just hook your power cord to a switch. At the end of the day before you go to bed, switch it off, in the morning, switch it back on. Or one of client is using a timer that powers off the machine at 3am and turn it back on at 7am.
my home theatre
post #388 of 898 Old 04-21-2013, 08:39 PM
Sunny44's Avatar
I really don't think we should have to unplug or setup timers to power off the machines to deal with this problem.
Has anyone had any feedback from pioneer?
I'm wondering if this is a hardware of FW problem.
Sunny44 is offline
post #389 of 898 Old 04-22-2013, 08:27 AM
Krutsch's Avatar
Liked: 36
Completely agreed. I don't know why I am not seeing this problem and others are, but if I had to reboot the thing every time I wanted to watch a video, I would chuck it off my balcony.
Krutsch is offline
post #390 of 898 Old 04-22-2013, 08:30 AM
Quoted: 612 Post(s)
Liked: 584
my home theatre
Reply Blu-ray Players
Pioneer Elite Bdp 62fd , Bdp 52fd , Pioneer Elite
