Reverse Firmware update on Panasonic BD-30 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-23-2012, 07:48 AM - Thread Starter
viscommbozak's Avatar
I downloaded and followed the instructions to update the firmware on my Panasonic BD-30 to version 3.1 using a burned CD. Now I can only get 2 channel stereo output. The player worked fine until I decided to get cute and "improve" the situation. Any ideas on how to reverse the process or fix it?
Robert
viscommbozak is offline
post #2 of 3 Old 09-23-2012, 08:47 AM
Super Moderator
teachsac's Avatar
Quoted: 857 Post(s)
Liked: 1397
Welcome to AVS. Mods ask that you post all questions in the owner's thread in the player. There is no way to revert to a previous version of software. If you are getting stereo, make sure that Secondary audio is turned off. Also make sure the player is set to bitstream. If you run through a receiver, make sure it is set to Amp and not TV (or however your receiver kists it). If all else fails do a reset of the player. That has been known to work.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #3 of 3 Old 09-24-2012, 07:02 AM
Moderator
rboster's Avatar
Quoted: 1236 Post(s)
Liked: 1363
rboster is offline
Closed Thread Blu-ray Players
Panasonic Blu Ray Disc Player Dmp Bd30k , Blu Ray Players , Panasonic
