Players that stream MKV with HD Audio passthrough? 3D MKV? - AVS Forum | Home Theater Discussions And Reviews
Old 09-28-2012, 07:40 AM - Thread Starter
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
Do any of the cheaper players (not Oppo) support streaming MKVs over a local network with HD audio passthrough (DTS-HD, TrueHD, etc.)? Also, can any play 3D MKVs ripped from 3D blu-rays? Thanks.
crbaldwin is offline
Old 02-10-2013, 06:34 AM - Thread Starter
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
Are there any?
Old 02-10-2013, 09:09 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
I know Sony s390/590/790 streams HD audio and full bit rate rip but not sure about 3d rips because I never tried.
Sent from my RM-820_nam_canada_246 using Board Express
Foxbat121 is offline
Old 02-10-2013, 03:23 PM - Thread Starter
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
I have the older s470 and it doesn't even seem to do normal AC3 via DLNA but I will look into the s*90 series. Thanks.
Old 02-10-2013, 05:42 PM
apw2607's Avatar
Quoted: 111 Post(s)
Liked: 220
Yea, all the testing I've done .... Dolby TrueHD will not play on the S590/790 in a MKV container, even if the video is AVC H264. Regular Dolby Digital will play though. As I mentioned in another thread, DTS Master Audio will play fine however.
The Oppo 103/105 will play Dolby True HD in a MKV container, only if you set the players output to PCM. It will not pass bitstream out for TrueHD.
So all players have their quirks with TrueHD.
apw2607 is offline
Old 02-11-2013, 06:49 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
yeah, that old generation player barely stream anything.
Old 02-11-2013, 07:28 AM - Thread Starter
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
Do you know if the s*90 still has the annoying "Checking network connection" message that is always popping up on the s470 and if they have improved the Netflix interface at all (the thumbnails are too small in the grid/list and I find it hard to find what I'm looking for).
Old 02-11-2013, 07:58 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Not sure of which message you mean. If you mean the message just after you launch Netflix, it is there with a slightly different message. All streaming feature must call home to Sony for approval before the player let you do it. This is done so that Sony can turn off your streaming if you refuse to upgrade to the latest firmware (which comes with Cinavia detection to prevent you playback BD copies).
The netflex interfaces is million years ahead of what you have on 470 (I had 570 before).
Old 02-11-2013, 09:11 AM - Thread Starter
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
Every time I select Netflix it shows a message "Checking network connection" that I have to manually dismiss/close when it is done. I then have to select Netflix again to actually launch Netflix. I was hoping that they now do this in the background or at least have removed the requirement to manually dismiss the message.
Old 02-11-2013, 10:55 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
It is more or less the same. Sometimes, if I power on the player and wait for a short while, I don't get to see that message. A lot of other times, I do see the message and need to press close.
Old 02-11-2013, 03:26 PM
apw2607's Avatar
Quoted: 111 Post(s)
Liked: 220
yes, it does do similar, although it should be noted that once its done ... its then good for "a bit". I.e you can even turn the player off and back on again and you wont see this message.
I believe its some kind of authentication that the device needs to do before it then connects to a service. Its the way Sony implemented it, and why this can't be done in the background like you say seems very odd.
apw2607 is offline
Old 02-11-2013, 04:04 PM - Thread Starter
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
Were you able to try multiple DLNA servers for Dolby TrueHD or is it just a playback limitation of the Sony?
The specifications seem to suggest that MPEG2 is not supported in MKV. Is this the case?
Is fast forward and rewind possible and stable with DLNA video? Thanks for your help.
Old 02-11-2013, 04:21 PM
apw2607's Avatar
Quoted: 111 Post(s)
Liked: 220
Mpeg2 is not supported in MKVs, however is supported in M2TS.
The problem with TrueHD is a limitation of the player and not the server. Infact no where does Sony mention even supporting any HD audio formats with USB or DLNA ... so I guess we are lucky with DTS - MA support !
apw2607 is offline
Old 02-24-2013, 09:17 PM - Thread Starter
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
So I tried the S590 and while it is a nice player the DLNA could be improved (no thumbnails, no skip to time, limited resume, no truehd, limited MKV support). Does anyone know if any other players support HD audio passthrough and might have a better DLNA implementation or is the Sony the best of the bunch? Thanks.
Old 02-26-2013, 10:12 AM
apw2607's Avatar
Quoted: 111 Post(s)
Liked: 220
Dune smart series
apw2607 is offline
Old 03-08-2013, 12:26 PM
Mr. Pseudonym's Avatar
I've been looking for the same thing and the NAD T567 appears to fit the bill. Kind of pricey however.
http://nadelectronics.com/products/blu-ray/T-567-Network-Blu-ray-Disc-Player
DLNA, PC
.avi, .divx, .mpg, .mpeg, .mkv, .mp4, .asf
DIVX3.xx, DIVX4.xx, DIVX5.xx,
DIVX6.xx (standard playback only),
XVID, MPEG1 SS, H.264/MPEG-4 AVC,
MPEG2 PS, MPEG2 TS, VC-1 SM (WMV3)
Dolby Digital, DTS, MP3, WMA, AAC, AC3
Mr. Pseudonym is offline
Sony Blu Ray Disc Player Bdp S390 , Sony Bdp S590 3d Blu Ray Player , Sony Blu Ray Disc Player Bdp S790 , Sony Bdp S470 3d Blu Ray Disc Player
