Official OPPO BDP-103 Owner's Thread - Page 185 - AVS Forum | Home Theater Discussions And Reviews
 860Likes
post #5521 of 24395 Old 02-12-2013, 12:51 PM
hodges69's Avatar
Quoted: 60 Post(s)
Liked: 44
Bob,
Thanks..I have done that several times while streaming....never has deviated from SD while the picture improves to HD quality.....perplexing to say the least.
hodges69 is offline
post #5522 of 24395 Old 02-12-2013, 01:26 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2253 Post(s)
Liked: 2819
Originally Posted by hodges69 View Post
Bob,
You are saying it has not cycled through Low/SD, Medium/SD, High/SD? What is it showing, then?
The lowest bit rate Netflix uses when in SD mode (which can even happen when you are supposedly playing an HD stream) is pretty godawful.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #5523 of 24395 Old 02-12-2013, 01:50 PM
hodges69's Avatar
Quoted: 60 Post(s)
Liked: 44
Bob,,,right now I am 6 minutes into THE sniper...video shows low/SD..looks like crap....8 minutes into the movie,the PQ has significantly ..but not HD quality..but the same info
Appears.
hodges69 is offline
post #5524 of 24395 Old 02-12-2013, 02:01 PM
jerreed's Avatar
Originally Posted by mominayal View Post
I couldn't get my oppo 103 to broadcast anything when passing the Comcast box through it, got the error message and a green low def image on any channel
Try what Recstar24 suggests. HDMI from cable box to HDMI input in back of Oppo and HDMI 2 out to TV. It worked for me. Still, it kind of sucks that HDMI1 does not play well with the cable boxes. However, Oppo is aware of the problem and is working on a solution. . .
jerreed is offline
post #5525 of 24395 Old 02-12-2013, 02:05 PM
Jacob305's Avatar
Quoted: 80 Post(s)
Liked: 48
Appears.
are you wired to the net or wireless? I would suggest trying wired if you can?
Jacob
Jacob305 is offline
post #5526 of 24395 Old 02-12-2013, 02:19 PM
Read the FAQ!
Liked: 2819
Appears.
It has probably shifted to the High/SD file, but for some reason Netflix hasn't sent the updated status info. Another possibility is that you really are stuck in Low/SD but for some reason the encoding for the earlier minutes of that title for Low/SD was even more godawful than usual.
I don't know what stream you are watching. "The Sniper" only shows as available on shiny disc at the Netflix web site.
Try going into the VUDU app > My Vudu > Info & Settings > Network Speed Test and see what VUDU reports as the network speed from their server into your 103.
--Bob
post #5527 of 24395 Old 02-12-2013, 02:22 PM
hodges69's Avatar
Quoted: 60 Post(s)
Liked: 44
Jacob,
Wireless mo other option that would not incur a pretty big expense....I am going to upgrade to
Time Warner's turbo....see if that makes a difference....since this upgraded charge is per diem,I thought I would give it a shot ..of nothing changes I can always revert with a very slight charge.
hodges69 is offline
post #5528 of 24395 Old 02-12-2013, 02:23 PM
Jacob305's Avatar
Quoted: 80 Post(s)
Liked: 48
Jacob,
what speed are you at up to 18 or so?
Jacob
Jacob305 is offline
post #5529 of 24395 Old 02-12-2013, 02:28 PM
hodges69's Avatar
Quoted: 60 Post(s)
Liked: 44
Right now 11...the turbo can take a while to kick in...we will see.
hodges69 is offline
post #5530 of 24395 Old 02-12-2013, 02:45 PM
Jacob305's Avatar
Quoted: 80 Post(s)
Liked: 48
most companies will say up to 11 or so.. I am at up to 18. but I really only get 14. that might help a bit to upgrade.
Jacob
Jacob305 is offline
post #5531 of 24395 Old 02-12-2013, 02:48 PM
Recstar24's Avatar
Originally Posted by clidaw View Post
I like the idea of having two connections, because using HDMI2 also solved my handshake issues. I liked the picture from HDMI1 a little better (more punch, at least on my 50" 2008 Panny Plasma), but I'll take the small trade-off in exchange for ending the handshake problems. I definitely have plenty of HDMI connections; all I need to do is find another HDMI cable. I do have one strange problem, which is present using both HDMI1 and HDMI2. Whenever I switch from a HD to a SD station (or the on-demand menu option), switching back to a HD picture gives me black bars on the side. Switching to the blu-ray player input and then back to the HDMI back input returns the HD picture to full screen. I don't switch from the HD channels often, so it isn't a big deal. I just find it odd.
Good to hear. I agree that hdmi1 has more punch which I like but sometimes when i am surfing channels it is simply faster and less buggy on hdmi2. For bluray I use hdmi1 exclusively and I've labeled that input on my tv as bluray, and the tv input as cable that is connected to hdmi2.
Recstar24 is offline
post #5532 of 24395 Old 02-12-2013, 03:21 PM
hodges69's Avatar
Quoted: 60 Post(s)
Liked: 44
--Bob
Bob,
Tried Vudu..got a network problem message...I did go to Time Warner's website and did a speed test on my Road runner account. ..12.9. Which should be plenty,right?looks like turbo has not kicked in..I will reboot the modem in about 2 hrs. Or so and retest.
Thanks to all for the help offered...
hodges69 is offline
post #5533 of 24395 Old 02-12-2013, 03:22 PM
subavision212's Avatar
Quoted: 62 Post(s)
Liked: 38
I have had the 103 for a few days now......the only problem I have encountered so far deals with Netflix streaming.....for about 60-90 seconds.....the picture is fuzzy and looks worse than SD...after that...all is golden....I have changed my DNS1 and 2 settings per OPPO...but still having problems....using the 103 wireless(at a clocked speed of 11)..thru a Denon cs2311 receiver....input 1 on 103...directv...panny vt30 65"TV....all thru HDMI...
Any suggestion?
I've read that Netflix is using adaptive bitrate streaming which starts at a low SD quality and quickly ramps up to the highest HD quality if the bandwidth is available. They say it works differently on different devices, speeds and other factors. Perhaps this is what you are seeing on the 103. My Roku 2XS works this way. Haven't tried watching Netflix on my 103 yet so can't compare. Read this about how Netflix is changing it encoding technology:
http://www.hometheater.com/content/yes-virginia-there-netflix-1080p-streaming-video
subavision212 is offline
post #5534 of 24395 Old 02-12-2013, 03:33 PM
candoan's Avatar
Quoted: 13 Post(s)
I got it 3 weeks ago and it was working great. Today I tried to watch a movie and the player stop working. What I can see is only one screen with white OPPO on the top and a blue Bluray on the bottom and that is it. I can't go to setup screen or any thing alse even the home screen. If we know a combination of button on the remote might help or anything else.
Please help me out and thanks for your inputs.
Pana 60ST60, Onkyo TX-NR3009, OPPO BDP-103, Klipsch WF-35, Klipsch WS-24, Klipsch WC-24, Klipsch Reference RW-12d, BIC America DV62si.
candoan is offline
post #5535 of 24395 Old 02-12-2013, 03:37 PM
Read the FAQ!
Liked: 2819
Call OPPO Tech Support and they'll walk you through things to try.
--Bob
post #5536 of 24395 Old 02-12-2013, 03:37 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2684 Post(s)
Liked: 1920
Try pulling the power cord for about 20 minutes.
If still no good, contact OPPO support.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #5537 of 24395 Old 02-12-2013, 03:40 PM
Read the FAQ!
Liked: 2819
Press the power button on the front panel once and be patient. After a delay (about 15 seconds) the player will power off.
Now press the tray open button on the front panel, which should turn the player on and also open the tray so that any disc in the tray won't start trying to play.
--Bob
post #5538 of 24395 Old 02-12-2013, 05:09 PM
candoan's Avatar
Quoted: 13 Post(s)
--Bob
Thanks to Bob and Bill.
I have sent an email to Oppo.
I pulled the power cord now and waiting for some 20 minutes. Let's see what's next.
candoan is offline
post #5539 of 24395 Old 02-12-2013, 05:25 PM
dstr212's Avatar
Dstr,
Thanks...but I am coming off the BD93 which,while I had the same problem.the length of the wait was in the 10 second range.Therefore,my concern.
Ok, I have had maybe 10-20secs of SD quality and then back to HD then sometimes in the middle of the movie it will go back to SD for a minute then to HD again. A little annoying seeing that I am hardwired, so I feel you.
dstr212 is offline
post #5540 of 24395 Old 02-12-2013, 05:35 PM
electricmanscott's Avatar
Originally Posted by wmcclain View Post
What disc was that? Was it the player screensaver or the disc screensaver?
-Bill
I just tried it again. The disc is Jaws, blu ray. The Oppo screensaver is on. When I hit play to continue the oppo screensaver goes away and the Universal screensaver is there. The buttons are all unresponsive except for stop which brings up the disc main menu screen.
Dedicated theater
JVC RS46U
Lumagen XE3D
115"d 16:9 DIY AT Seymour XD screen with DIY masking
Marantz SR7008
Oppo BDP103
Darbee Darblet
Klipsch RF7II mains
Klipsch RC64II center
PSA XS15 Sub
Roku3
Harmony 900
electricmanscott is offline
post #5541 of 24395 Old 02-12-2013, 05:38 PM
wmcclain's Avatar
Liked: 1920
The Universal Studios screensaver is widely beloved by everyone who has encountered it. We had a topic on it in the original BDP-83 FAQ: How do I resume from the screensaver on Universal Studio discs?
-Bill
post #5542 of 24395 Old 02-12-2013, 06:01 PM
Snejenka's Avatar
I was hoping the BDP-103 could help replace my AppleTV 2 with Firecore in accessing my Seagate BlackArmor 220 NAS via SMB. It needs to be via SMB, because apparently the DLNA on Seagate's NAS is very limited. Anyway, all was going ok with the Firecore (AppleTV) way, but it could only do 720p, it couldn't do some types of FLAC, and there were memory buffering issues. The problem I am seeing that I cant find on this thread yet is after the Oppo logs in and I try to dig down through the folders to where my files are I get the "Loading" screen and it just keeps spinning the blue lights forever. It does this every time, without fail. If I use the wrong username or password it tells me so, so I know it gets past the logging in to the NAS. Also, when it shows "loading" it becomes almost completely unresponsive. I cannot back out of it, I cannot go 'Home', I can't power it off by hitting the power button as usual. I sometimes can power it off by holding power for I am guessing 20-30 seconds.
I suspect the issues is both the Oppo and the Seagate NAS because when accessing these folders through Firecore I almost always get an error message the first time. I just became used to seeing the error message, immediately trying again and it working. I have a feeling the Oppo is getting an error the first time as well, but instead of immediately backing out and saying so it gets hung up on this eternal "loading" screen.
I've tried numerous searches in this thread and elsewhere, so forgive me if this specific issue has already been posted. I've only seen SMB issues brought up in regards to some form of Windows which doesn't apply to my case. I don't have a PC, I have a Mac, and the whole point I'm trying to do is to directly access the NAS from the Oppo without any computers turned on or present.
Snejenka is offline
post #5543 of 24395 Old 02-12-2013, 06:56 PM
globalnomad's Avatar
I had a similar problem earlier in this thread. After several email exchanges with OPPO, I ultimately had to replace the player at my local distributor. I haven't had problems since.
globalnomad is offline
post #5544 of 24395 Old 02-12-2013, 07:02 PM
candoan's Avatar
Quoted: 13 Post(s)
Thanks. That means I need to contact Amazon for exchange then.
candoan is offline
post #5545 of 24395 Old 02-12-2013, 07:05 PM
TracerJohn's Avatar
I've had the Oppo 103 for a couple weeks. Replaced a Panasonic Bluray & Pioneer DV-45 DVD Player with SACD and DVD Audio capability. Pretty cool that the 103 could replace 2 components and half a dozen cables. Best manual I have ever seen. However, it is awfully buggy. Lock ups, freezes, sidebars appearing when switching stations, audio drop outs after rewinding.... Based on Oppos reputation I imagine these will be fixed eventually, but I am seriously considering returning it and reconnecting the old equipment.
TracerJohn is offline
post #5546 of 24395 Old 02-12-2013, 07:35 PM
turboman123's Avatar
Quoted: 22 Post(s)
Liked: 25
Ode to Bob and Bill
(free from Jack and Jill)
Bob and Bill went up the Oppo-103 hill
To fetch a pail of posts
Bob fell down after one page and broke his pen
And Bill came tumbling after one word.
Bob and Bill: thanks for all the good help and your strong continuous support.
turboman123 is offline
post #5547 of 24395 Old 02-12-2013, 07:41 PM
hodges69's Avatar
Quoted: 60 Post(s)
Liked: 44
Hey y'all,.,
Netflix problem solved.....so simple...but the most logical....I changred the Wi-Fi dongle from the back of the 103 to the front...Viola...Vudu test that Bob recommended.shows I can receive HDX....why is a simple fix the most obvious ?did I miss this n the manual or do I ve a bad USB port? BTW,Bob..I gave you bad info on the movie...should have been The Shooter.
Again,thanks to all for pitching in...netfix is golden.
hodges69 is offline
post #5548 of 24395 Old 02-12-2013, 08:00 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Hey y'all,.,
You must have a WiFi dead spot in the area behind your player. That's my only theory, and I'm sicking with it. biggrin.gif
Wired forever!
htwaits is offline
post #5549 of 24395 Old 02-12-2013, 08:10 PM
hodges69's Avatar
Quoted: 60 Post(s)
Liked: 44
Wired forever!
Well,that matches the dead spot on the left side of the brain.....only prob with your theory is that the dongle for the 93 was basically in the same place ith no problems....just saying..smile.gif
hodges69 is offline
post #5550 of 24395 Old 02-12-2013, 08:26 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Wired forever!
Can you move your OPPO to conduct tests?
htwaits is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
