Official OPPO BDP-103 Owner's Thread - Page 186 - AVS Forum | Home Theater Discussions And Reviews
 860Likes
post #5551 of 24395 Old 02-12-2013, 08:30 PM
zombie1210's Avatar
Quoted: 16 Post(s)
Liked: 36
I hope any future firmware upgrades don't mess up my PQ.
BDP105D>TX-NR646>55"ES8000
zombie1210 is offline
post #5552 of 24395 Old 02-12-2013, 08:48 PM
JRDiAndrea's Avatar
Originally Posted by dmusoke View Post
Anyone using their 103/105 with a Synology NAS? What software are you using to 'push' audio/video to the Oppo via the NAS? I've tried Video Station but it seems inadequate to do so...
- David
I use a DS 1812+ to push music files to a 105 over my network via Ethernet. Works perfectly. I use DS Audiostation to push and manage playback with ap on my android phone. Have not had any issues at all with flac or wav up to 192kHz/24bit.
JRDiAndrea is offline
post #5553 of 24395 Old 02-12-2013, 10:09 PM
Smurfmj's Avatar
Hi Guys!
Just joined for Forum and I am a oppo 103 owner of about 6 weeks. I have been very impressed with the quality of bluray movies and its upconverting of cable via HDMI in. However, I started to notice something thats been eating at me the last two weeks, and its getting hard to ignore, so I wanted to put it out there and see if anyone else has experienced the same problem, and what they have done to correct!
The issue: variable length of audio delay relative to lip movement on screen when running my cable TV through the HDMI input and through to my TV. It doesn't happen all of the time, but I have noticed it more and more lately and I thought I was just being too picky, but when my wife started noticing it too, there must be something off! It can be anywhere from a quarter second, to a full second, and really no rhyme or reason for the cause. If I turn off the cable box and Oppo and turn them back on, it usually does away with it for a bit, but a few minutes later it could return.
What I am running: Standard cable box with HDMI out via older Monster cable to the Oppo input, and HDMI out 1 via HDMI that came with it, to my Samsung 55 in D8000. All plugged into a Monster stage 2 clean power.
According to the latest firmware update, other people must have been having a problem with it too, because it is addressed in the update, but whatever they did didnt do the trick unfortunately! I should also note that the problem goes away when I bypass the Oppo and go straight to the TV, but the picture isn't as good. Call me greedy, but I want both! smile.gif Also will note that the problem isnt there just playing a normal Bluray disc, further pointing the finger at the input/upscale function...
My initial thoughts: 1 Are my cables in need of upgrading to prevent any "jitter" or "skip" from the cable box or bluray that seem to create the initial lag? 2 Should I be using the analog audio output of the Oppo directly to the receiver rather than the audio out of the TV to the AVR? I wouldn't think so because the lag is there from TV volume as well with receiver off.... 3 Is there a setting in the unit that I could adjust so that audio/video runs through it more smoothly?
I haven't called Oppo yet to talk to someone live, but I have e-mailed their customer service so they are aware of further issues post firmware update. So please let me know if I am alone here with my issue with the HDMI IN feature, and if anyone can shine some light on the problem or point me down the right path!
Thanks in advance!
Smurfmj is offline
post #5554 of 24395 Old 02-12-2013, 10:48 PM
Christian Bergh's Avatar
Originally Posted by astrogeeker View Post
i've had this happen at least once as well.
It has happened to me to several times.
(Referering to post 5561)
/Christian
Christian Bergh is offline
post #5555 of 24395 Old 02-12-2013, 10:51 PM
dmusoke's Avatar
Quoted: 265 Post(s)
Liked: 140
Smurfmj:
If you connect the cable box to the TV, is there a lip sync problem? If not, then the problem is within the Oppo and/or AVR you are using.
Please disable any form of video processing (frame interpolation, imahe enhancers etc) in your Samsung display as this will delay the video further.
Same for the AVR, disable any fancy video processing modes within the AVR as well. You should simply have and use a video pass-through mode for your setup. Your bit and color space settings in the Oppo should match exactly with those in your AVR and display.
Your cables should be fine . They do not cause video lag (lol!). No need to change them.
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #5556 of 24395 Old 02-13-2013, 12:50 AM
dmusoke's Avatar
Quoted: 265 Post(s)
Liked: 140
- David
Thanks JRDiAndrea ...have you tried sending video to the Oppo via Video Station? I also have a DS1812+
dmusoke is offline
post #5557 of 24395 Old 02-13-2013, 06:25 AM
Terry Mann's Avatar
Originally Posted by Bob Pariseau View Post
Originally Posted by hodges69 View Post
I have had the 103 for a few days now......the only problem I have encountered so far deals with Netflix streaming.....for about 60-90 seconds.....the picture is fuzzy and looks worse than SD...after that...all is golden....I have changed my DNS1 and 2 settings per OPPO...but still having problems....using the 103 wireless(at a clocked speed of 11)..thru a Denon cs2311 receiver....input 1 on 103...directv...panny vt30 65"TV....all thru HDMI...
Any suggestion?
While playing Netflix, press the Info button on the remote and look at the text displayed in the upper left corner. You'll see that Netflix ignores what it already knows about your network speed and downshifts to playing the new stuff as an SD stream, then gradually gets more confident and shifts back up to HD.
This is just how Netflix works.
--Bob
This is why I cancelled Netflix and remain happy with my 103.
Terry
Terry Mann is offline
post #5558 of 24395 Old 02-13-2013, 07:02 AM
DSperber's Avatar
Quoted: 226 Post(s)
Liked: 186
Originally Posted by Smurfmj View Post
Hi Guys!
Welcome aboard!
Known problem. I have it too, running my HTPC's WMC extender (Linksys DMA2100) through the external HDMI input of the 103.
Exactly as you've observed, the lip-sync will not be present initially. But over time it builds up. And doing something to interrupt or restart things (like STOP and RESUME, or STOP and change channels and PLAY for a moment and then STOP and change channels back to where you were and then PLAY again, etc.) usually seems to make it go away for a while.
But it will inevitably return again.
My own observations are that it only happens (for me) when both audio+video are delivered out over HDMI-1 of the Oppo to my AVR (my audio output is set to LPCM). Video is then delivered from AVR to HDTV, and audio is sent by the AVR to speakers. This is my situation when I do "casual watching+listening" to HDTV through external speakers connected to my AVR, which is why I'm sending audio as well as video out over HDMI-1.
However if I power on my external audio system (headphones-based, requiring LPCM via HDMI) connected via HDMI to HDMI-2 out of the Oppo, using "Split A/V" on the Oppo so that now audio-only is going out over HDMI-2 (and then on to my headphone system) and video-only is going out over HDMI-1 (to the AVR, and then on to the HDTV), I've seen that the Oppo lip-sync problem does not occur. I use this approach when doing "serious watching+listening" to BluRay or HDTV through headphones.
I have spoken to Oppo several times about this problem, and they are well aware if it. Presumably that means they will eventually discover the cause and fix it in a future firmware upgrade.
You are not alone here. But I agree, it is very very annoying.
I am going to experiment today with another "possible solution" of my own, to see if that works to prevent the symptom.
Since my external speakers are simply a 2.0 stereo set (not a multi-channel surround system, which is why I have my headphone system instead for "serious" situations), I see no reason I can't just feed the FL/FR analog speaker outputs to a pair of analog L/R stereo inputs on my AVR with the 103 setup set to "downmix to stereo" (which will handle multi-channel audio source HDTV programs).
The digital-to-analog conversion for supporting speakers has to occur somewhere, so I might as well use the DAC in the Oppo and produce the stereo downmix to analog there, then going through an all-analog audio path to the AVR and 2.0 speakers beyond. This also allows me to insert my DBX 14/10 EQ for "tone control", as my old 2.0 B&W speakers need a bit more treble-enhancement than the AVR is willing to add.
I'm hoping that the lip-sync issue with audio+video out over HDMI-1 of the Oppo will simply disappear using this all-analog audio approach. Actually, even if it doesn't work to overcome the lip-sync problem I suspect I will use it anyway because of the ability to have my EQ improve the audio quality from the the 2.0 speakers, which right now is a bit "boomy" for my tastes.
I will report back.
DSperber is offline
post #5559 of 24395 Old 02-13-2013, 08:30 AM
ted_b's Avatar
Currently part of my multichannel HT is this: I have a SA 8300HD cable box and Oppo 83SE connected via HDMi to a Denon 4308 AVR (the Denons side and rear amps only being used; the remainder go preamp-out to my fronts/center/sub systems elsewhere in the room) and then HDMi out to my pj (JVC RS46). I use PLIIx Cinema to fake any 2.0 or 5.1 tv and movie sources into 6.1 or 7.1; otherwise I use BD codecs for 7.1. I have a second multichannel source (stacked Mytek DACs, etc) that goes into a Sony TAP-9000ES analog multichannel preamp, as does the fronts/center.sub of the AVR outs (called 5.1 bypass mode).
Correct me if I'm wrong:
I could remove my Denon 4308 AVR (as long as i have amplification of course), buy an Oppo 103/105, hook my cable box into the HDMi in of the Oppo 103/105, enable DTS NEO:6 Movies, and use a MSB MVC (multichannel volume control) to do channel trims and master volume. All codec decoding, channel delays and HDMI switching would be done in the Oppo. Correct? And any lip-synch issues discussed above are moot in my case cuz I'd have all audio coming out analog, not HDMI. And then i could remove my Sony TAP-9000ES and just use the second input on the MSB MVC for my Mytek stack. Right? anything missing here? Thanks in advance,
Ted
"We're all bozos on this bus" - F.T.
ted_b is offline
post #5560 of 24395 Old 02-13-2013, 09:34 AM
videoluvr's Avatar
Hey y'all,.,
Netflix problem solved.....so simple...but the most logical....I changred the Wi-Fi dongle from the back of the 103 to the front...Viola...Vudu test that Bob recommended.shows I can receive HDX....why is a simple fix the most obvious ?did I miss this n the manual or do I ve a bad USB port? BTW,Bob..I gave you bad info on the movie...should have been The Shooter.
Again,thanks to all for pitching in...netfix is golden.
The BDP-103 comes with a USB extension cable specifically to position the WIFI dongle for best signal.
videoluvr is offline
post #5561 of 24395 Old 02-13-2013, 11:30 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2253 Post(s)
Liked: 2819
Ted
You know of course that the 103 and 105 include their own Volume control and volume trims for Analog output right? So the reason for adding your external volume control is so that you can share that with a 2nd source?
What you describe ought to work presuming the SA cable box isn't screwing up its HDMI output. (SA boxes are kind of notorious for HDMI problems.)
The lip sync issues OPPO is working on can also happen on Analog audio output, although for the most part Analog is the least troublesome.
DTS Neo:6 on the OPPO will *ONLY* apply to stereo content input. I.e., it can not be used to raise 5.1 content to 7.1 speaker output.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #5562 of 24395 Old 02-13-2013, 11:36 AM
Read the FAQ!
Liked: 2819
Originally Posted by dstr212 View Post
Ok, I have had maybe 10-20secs of SD quality and then back to HD then sometimes in the middle of the movie it will go back to SD for a minute then to HD again. A little annoying seeing that I am hardwired, so I feel you.
Sometimes this has nothing at all to do with your service speed or in-house networking. For example, the Netflix server farm serving my area has had repeated capacity problems since the holidays, resulting in them restricting HD titles to High/SD streaming rate during peak viewing hours, particularly on weekends. At the same time Netflix is having problems, the VUDU Network Speed Test pegs at the top of the speed range.
This, of course, is one of the nifty things about shiny discs -- same quality every time.
--Bob
post #5563 of 24395 Old 02-13-2013, 01:30 PM
JJMONIE's Avatar
Hi all,
I have had my 103 since the start of January and love it so far. Have watched a bunch of Blu Rays and many DVD rips through my WDTV that is connected to HDMI in on the back of the 103.
I have been reading lots of this contrast thing and tried playing around with this last night. I do not think I saw a difference at all as far up as I set it or low. I am using HDMI 1 out to my Denon 2311CI and then Denon out to my Panny VT25. I have have video upconversion and scaling off on the Denon. This means the video signal is just passing it through right?
Have also tried playing with the resolution between 1080p and Source Direct mode and do not notice any difference at all either. I noticed a difference when using 480i so I know it should be working. My Panny is either using the stock THX settings, stock THX with a slight boost in contrast or the custom settings I got I think from D Nice.
I guess what I am asking is this. Is there something wrong with my eyes or is having it hooked up to the Denon for video messing around with something? I am very happy with the picture but I don't think I'm seeing all of this +1 & 0 stuff. Not being smart, just wondering. I would like to squeeze every ounce out of this player if I can. Thanks.
JJ
JJ
JJMONIE is offline
post #5564 of 24395 Old 02-13-2013, 01:40 PM
WannaKnowTech's Avatar
Quoted: 12 Post(s)
So im thinking about buying one of these. I have been looking at an Oppo player for a while mostly due to the upconverting abilities, ease of navigation for streaming(no freezing or 10 second delay when you press a button) and of course the after market region free mod. I looked at other region free players but there were all crappy players for under 100 that had all the issues I hate.
However now I have a few concerns.I want to completely get rid of my PS3 and just have one device for everything. This sharpness thing worries me though. Does it only affect DVDs? Does the processing do anything to blu-rays? Why would it need to? Because of this I was thinking about getting the 83 instead. However that can't do Netflix in 5.1 right? It's important to me not to have to use the PS3 or any other device for streaming.
WannaKnowTech is offline
post #5565 of 24395 Old 02-13-2013, 01:43 PM
umdad06's Avatar
I've been following this Netflix thread for some time now as I have not been satisfied with the PQ using the Oppo Netflix app. I have my Oppo 103 connected by Ethernet, but the PQ is terrible on Netflix, definitely NOT 1080p. (Vudu looks great BTW!) When I set it up I put my Roku box in the attic - one less box, 3 fewer cables, I thought. In frustration I finally got down the Roku. Problem solved, 1080p goodness! I'll keep it this way until I read on here that the Oppo app is fixed. Then I'll give it another try.
Otherwise the Oppo 103 has been performing wonderfully. It replaced an Oppo 83 about a month ago. Thanks to all for your continued work on this problem.
umdad06 is offline
post #5566 of 24395 Old 02-13-2013, 01:48 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2684 Post(s)
Liked: 1920
Sharpness is (I suspect) a transient error to be addressed in future firmware. It hasn't bothered me at all but others may be more sensitive to it. Until then you can try Source Direct on HDMI1 or use HDMI2 which has no QDEO processing.
The BDP-93 does not have Netflix 5.1 audio; the -83 has no Netflix at all.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #5567 of 24395 Old 02-13-2013, 01:50 PM
Quoted: 12 Post(s)
-Bill
Thank you so much but one more thing. If I use HDMI 2 will the DVDs still be upconverted?
post #5568 of 24395 Old 02-13-2013, 01:51 PM
poolratt's Avatar
For you guys out there using the Harmony 900 what did you choose when setting up your Oppo? I searched this thread and found somebody chose the bdp-103eu which looks like some kind of mini system. Basically I'm having trouble telling the Oppo to switch inputs between activities and Logitech support is clueless. Any suggestions?
poolratt is offline
post #5569 of 24395 Old 02-13-2013, 02:06 PM
Read the FAQ!
Liked: 2819
Yep
--Bob
post #5570 of 24395 Old 02-13-2013, 02:13 PM
Quoted: 12 Post(s)
Yep
--Bob
post #5571 of 24395 Old 02-13-2013, 02:23 PM
larryep's Avatar
Has the analog output hissing and popping been fixed. Do people out there use the 7.1 analog out have no popping and hissing hooked up to a amp. Is this a small minority.
larryep is offline
post #5572 of 24395 Old 02-13-2013, 03:04 PM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
Nothing that can be fixed. You either have it, or you don't, and there is no possibility of OPPO doing a running change to the player as this would require that you completely redesign the audio analog board.
Neuromancer is offline
post #5573 of 24395 Old 02-13-2013, 03:22 PM
larryep's Avatar
Does the 105 have this problem? If it doesn't I wonder if it is because of the upgraded power supply?
larryep is offline
post #5574 of 24395 Old 02-13-2013, 03:29 PM
DSperber's Avatar
Quoted: 226 Post(s)
Liked: 186
Just finished rewiring things, making use of the FL/FR output of the 103 (with audio downmixed to Stereo in setup) to feed an analog stereo input on my AVR (by way of first coming through my DBX 14/10 EQ for tone control) when I want to listen through 2.0 speakers.
My original reason for this was to hopefully eliminate the lip-sync produced by the 103 from external HDMI input (i.e. HDTV in my case) when sending both audio+video out over HDMI-1 to the AVR, which was my previous way to get sound to the 2.0 speakers. But my secondary reason was to get the analog EQ involved, to provide convenient preset-driven tone control for the two separate sets of 2.0 speakers I have. The use of the anaog EQ was not possible when HDMI audio from 103 to AVR was used.
And I'm really really pleased with the tonal results of using this analog audio approach with the EQ inserted, as the sound quality from both sets of speakers is really much more pleasing now when I watch HDTV and listen through speakers.
But I haven't watched HDTV long enough yet through the new cabling to determine whether or not the 103's lip-sync audio issue when using external HDMI input is still present, and if so is it any different in "degree" than when using the video+audio HDMI method for audio. As long as it's no worse I will still be very satisfied with this new arrangement, since the sound from either speaker set is markedly superior with tone control applied.
You've said the lip-sync problem is still present even using analog audio, so I'm prepared to face that reality if true.
DSperber is offline
post #5575 of 24395 Old 02-13-2013, 03:35 PM
ted_b's Avatar
--Bob
Thanks Bob. Yes, the MVC volume is due to the multiple mch sources.
Thanks for the heads up on not being able to do 5.1 to 7.1. Oh well, if that's all i lose being able to dump my AVR and all its noise, RF, etc...so be it. I will definitely trial the setup first, so as to check things like the SA8300HDC HDMi.
ted_b is offline
post #5576 of 24395 Old 02-13-2013, 04:05 PM
Recstar24's Avatar
Dsperber,
I am using analog out to a pair of powered speakers and while it sounds very good (the oppo stereo downmix processing is fantastic) i still have similar lip sync issues. This is with cable going to the hdmi oppo input. Oppo is aware and I am sure will fix it.
Recstar24 is offline
post #5577 of 24395 Old 02-13-2013, 04:38 PM
bokes's Avatar
Quoted: 13 Post(s)
Just make sure you can return if you run into issues.
I had a 103 for about a week and it was way too buggy for me to justify it at this time.
Folks here were nice and tried to help with my settings, etc.- but in the end-
I contacted support and here is their response to the Netflix issue:
If Netflix is freezing up every time that you try to use the service, or when loading specific titles, then this sounds DNS related.
Try power cycling your modem and router by removing their power cables for 5 minutes. Reconnect their power cables then try the player again another 5 minutes later.
Try upgrading the firmware on your router, as sometimes networking errors are due to out of date firmware.
Try using the USB extension cable that came with the player and move the WiFi dongle to a location where the reception is higher.
Try setting your IP Configuration (Network Setup) from AUTO (DHCP) to MANUAL. Change your DNS 1 to 008.008.008.008. Press Enter. Highlight OK at the bottom then exit Setup. Try the network streaming services again.
That's a whole lot of hoops for a $500 player. FWIW- my Ipad, laptops and Apple Tv all stream Netflix just fine and it looks pretty darn good- so it's not the DNS- it's the Oppo.
I also mentioned the sharpness issue.
They say;
If you do not like the output of HDMI 1 at the default Sharpness level then we would recommend using HDMI 2. HDMI 2 will give similar video quality results to HDMI 1 with a slightly sharper image, so it may give you a picture which is more to our liking.
Doesn't sound like they plan to address it in firmware- but they might. They should- enough folks seem to see it as an issue. IMO- Telling us to use the other output should not be a solution.
I also mentioned the DVD up-scale did not look any better than my cheaper Pioneer. I wondered if my setting were correct.
They responded;
The quality of the de-interlacing and scaling on the player will depend on the quality of the source and the display. If the source is already well mastered and the previous Pioneer was already a good player, then the difference in the performance may be minimal because there was no real processing needed to enhance the DVD-Video picture quality.
Fair enough.
So I returned it.
FWIW- I now have the BDP- 150.
It's build is not as solid as the Oppo.
CD's do not sound as good as the Oppo.
But Blu Ray discs in the 150 play, look and sound fantastic.
SD DVD looks no better or worse than what I was getting from Oppo.
All that said, If they fix these issues I would re-purchase the 103.
It's a promising machine and the 103 is built to last. (the 150 will most likely fail before 2 years)
Good Luck
bokes is offline
post #5578 of 24395 Old 02-13-2013, 05:37 PM
umdad06's Avatar
I had the same problem with my Harmony One. I would guess the setup software is the same for your Harmony 900(?). What I did was create a new button for the LCD screen and have the remote "Learn" the "Input" button. When I set up the remote I then could have it send the "Input" command followed by a "1" or a "3" to select the blu-ray player or the back HDMI. Works perfectly. Although i did have to put in a couple of seconds delay between commands.
HTH
umdad06 is offline
post #5579 of 24395 Old 02-13-2013, 05:41 PM
umdad06's Avatar
HTH
Sorry, I forgot to say that I used the Oppo BDP-83 as my device. Then you have to have your remote learn the commands that are missing, such as Input.
umdad06 is offline
post #5580 of 24395 Old 02-13-2013, 05:45 PM
esh516's Avatar
Liked: 49
Do not let the sharpness issue determine your purchase!
This player is top notch,best of the best,the picture and build quality of the 103 is top notch..the sharpness issue is really not a issue..this player puts out the very best picture I have ever seen from any player..the sharpness issue is for us tweakers that want to squeeze every bit out of this player..+1 sharpness on HDMI does this..I'm sure oppo will firmware this..but really this is absolutely no big deal at all..this player also sounds very very good,I have it running into my anthem Mrx avr using a audioquest coffee HDMI cable..and the sound surpasses my 1500$ DAC/CD combo!.. Highly recommended,not to mention when using it for CD playback it shows cover art of CD on your TV screen..
esh516 is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
