Official OPPO BDP-103 Owner's Thread - Page 202 - AVS Forum | Home Theater Discussions And Reviews
 860Likes
Old 02-24-2013, 08:35 PM
BadClams's Avatar
Originally Posted by Bob Pariseau View Post
It sounds like what happened is that your current HDMI cable can't handle the extra bandwidth for Deep Color at 1080p.
--Bob
FWIW, I'm using new 6ft Monoprice Redmere cable(s). Not sure what might be a better choice?
Thanks for the help as always, Bob.
BadClams is offline
Old 02-24-2013, 08:36 PM
Phil Tomaskovic's Avatar
Quoted: 35 Post(s)
Originally Posted by Tornado Red View Post
I'm good on the firmware (1220) so I'll drop a note to Oppo Tech Support, thanks for your time Bob.
Isn't there an option for priority on which layer to play? Is this happening on all sacds or just one?
Phil Tomaskovic
Phil Tomaskovic is offline
Old 02-24-2013, 08:37 PM
Dick Laurent's Avatar
Quoted: 21 Post(s)
Originally Posted by Neuromancer View Post
Your Onkyo setup may be different, but on my Integra 70.2 under Hardware Setup I have HDMI and "Lip Sync" set to OFF.
Under Source Setup I have "A/V Sync" set to 0, but in the past I had to use 75ms prior to the player being released.
I have 0 audio and video sync issues with HDMI 1 going into the Integra 70.2 and video feeding to a JVC DLA-RS50.
Interesting. I don't have the option to change the sync ms per source, just hardware. I will try changing the sync as you did, but then I'd think that would throw the sync off for my other devices using the Onkyo. But really, this is the only theory that makes sense.
OPPO also suggested to change to 75ms as well. I may just have to buy a new AVR that's a little more "compliant"... My Onkyo is about 6 years old, I beleive.
"A skilled TV repairman, or the shop in which you buy your set, can detach the audio section of the unit from the amplifier and plug it into your hi-fi rig." - Martin Mayer, Hi-Fi, 1956
Dick Laurent is offline
Old 02-24-2013, 09:01 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2257 Post(s)
Liked: 2823
--Bob
Check that the plugs are fully inserted into the sockets at both ends. Keep in mind that HDMI is an end to end protocol, so if you are running video through an AVR, the problem may be the output cable from the AVR. Also, many Redmere technology cables are directional. Make sure you have the cable plugged in the right way around.
Now that you know the trick with adjusting Resolution using the remote, try lower Resolutions with Deep Color enabled. If Deep Color works with 720p and 1080i, but does not work with 1080p (even though 1080p without Deep Color works fine), that's pretty good sign that there's a cabling problem. If you have any adapters, wall plates, daisy-chained cables, HDMI switches or other gizmos in the video path, they alone could be the cause of the problem.
It's also possible you just had a temporary glitch in the HDMI handshake -- i.e., a change of resolution to 1080i and then back to 1080p (which forces a new handshake) might be all that was needed.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
Old 02-24-2013, 09:04 PM
Read the FAQ!
Liked: 2823
The key is that he said if he retried loading the hybrid SACD enough times, then he COULD get it recognized as an SACD. That means the Priority setting in Setup is correct.
--Bob
Old 02-24-2013, 09:10 PM
JAMES MCHUGHES's Avatar
Quoted: 153 Post(s)
Liked: 52
Wondering if someone could answer a question for me regarding my new oppo bdp103 that will arrive tomorrow. How does it compare to the bdp 93 im wondering if maybe I should have bought a bdp93 because im noticing on ebay there going even for more than the new bdp103. Im new to the oppo bluray dont really know to much about it. Also wondering if I need to do a firmware update it is brand new in box bought from Amazon for 499.99
JAMES MCHUGHES is offline
Old 02-24-2013, 09:24 PM
KJSmitty's Avatar
Liked: 34
James, don't look back, you will enjoy the 103. I own both and regardless of there likes, the differences like speed and minor upgrades with streaming and HDMI in/outs makes the 103 a nice upgrade to the 93.
As for the 93s "used" pricing.. Many going for top dollar probably have the older firmware capable of ISO playback. The 93 also did not have the Cinavia code/hardware/software thus it does have that appeal for many. I decided to keep my 93 for those reasons as well - and if I did sell it I would still replace it with another 103.
Firmware upgrade: maybe, but its painless once hooked up to our LAN/wifi. It's been a bit since the last official update thus you very well may receive one with the latest.
Cheers
Love DIY
KJSmitty is offline
Old 02-24-2013, 09:44 PM
Tornado Red's Avatar
Quoted: 292 Post(s)
Liked: 238
--Bob
That's correct, I have the menu set for SACD Multi Channel and DSD, so settings should be right. Oppo answered back asking about the firmware (Main, Loader and Sub) they mentioned, like Bob said, there is a known bug if the firmware is not up to date. Waiting for a second reply, if there are any new revelations on this issue I'll share it here. Thanks again...
Tornado Red is offline
Old 02-24-2013, 09:49 PM
Quoted: 153 Post(s)
Liked: 52
Thx for the quick reply KJSMITTY
Im replacing my Panasonic bdt350 3d bluray player
Does the oppo103 play 7.1
Old 02-24-2013, 10:39 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
--Bob
What about turning off Deep Color? As far as I know it's only value is theoretical.
htwaits is offline
Old 02-25-2013, 02:05 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
Originally Posted by rdgrimes View Post
I suppose one lesson here is that deep color might be more trouble than its worth.
Apparently no studios have actually released any source material with this level of colour resolution, so setting deep color is effectively the same as padding the existing colour information with extra zeros...
AndrewFG is offline
Old 02-25-2013, 08:22 AM
Tal L's Avatar
Originally Posted by thrang View Post
Anyone experiencing audio drops with the 103 (using the Marantz 8801) via HDMI? I was watching Monsters Inc 3D (True HD 7.1) and had several drops, and a few weeks back, during The Dark Knight Rises, lost audio completely, requiring a reboot of the 103.
Bitstreaming, HDMI 1, to the 8801.
I watch The Dark Knight Rises over the weekend and didn't have any drop outs. So far I haven't had any audio drop outs on anything I have played. I have the unit set to split A/V and have the audio going through a Denon 989.
Tal L is offline
Old 02-25-2013, 08:33 AM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
Are you set to bitstream, or LPCM? I have very little success with bitstream, and occasional delays --Handshaking?--with LPCM into my Bryston SP3.
______________________
__________
Dave
moonhawk is offline
Old 02-25-2013, 01:29 PM
essexboy's Avatar
So I
Originally Posted by essexboy View Post
ok ill try to contact the people who done the modification as i got the player though amazon. ca
and one thing u might be able to help me with is on the player when u have the hdmi split in the set up menu are u meant to have the audio and video coming from both of the hdmi???? if so dose this not defeat the purpose of the slit audio and vidio
Many thanks for the help
essexboy is offline
Old 02-25-2013, 01:32 PM
essexboy's Avatar
So I
So I contacted the guy who did the region mod and he first said I because I live in Canada and oppo server is USA I believed this until I saw that my friends player which is the same as my and get got it from the same guy works great. Any idea if it could be the router problem
essexboy is offline
Old 02-25-2013, 01:36 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2688 Post(s)
Liked: 1921
So I
Probably not but you could take your player to the friend's place and try it with his router.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
Old 02-25-2013, 02:57 PM
Quoted: 21 Post(s)
Just to update on my audio sync issue, OPPO has again proven their stellar customer service, even via email. They sent quite a bit of detailed info and links to help out. I finally decided to just go ahead and adjust the sync for the OPPO source into my Onkyo. I had to get it all the way up to 165ms to see the best results with my test material, but it seems to be working just fine like that. As long as this is a relatively normal setting to adjust the sync on a single device, then I will call it good. Just seems odd as I've never had to do that before.
I could have sworn that everything I played up until noticing the issue was not out of sync. But I suppose I was paying closer attention to color and black levels than the actual dialogue. I can admit I was wrong in my assumption.
Thanks again for all the help.
Old 02-25-2013, 03:05 PM
giedrys's Avatar
Quoted: 13 Post(s)
Originally Posted by DSperber View Post
If you only have one TV on and the other is off, to avoid potential HDMI handshake issues and limit the handshake to just the TV which is on, is the 103's video output set to AUTO? This would trigger an HDMI video re-handshake when one or both of the TV's is powered on or off, so that the video output from the 103 is compatible with "the lowest common denominator" of the two TV's. There's no way the source device can send out two separate video streams when there are downstream display devices that have different video characteristics, so the lesser of the two display devices "wins" which certainly makes sense.
Again... your audio issue is controlled by the "HDMI pass-through" of audio from 103 through your AVR and on to the 2-channel speakers of your second TV. If you used the AVR as your sound system controller, and only needed to pass video on to your second TV, you wouldn't have an audio problem involving the 103 as the source device. Disable "HDMI pass-through" on the AVR when the second TV is powered off, and your multi-channel audio problem should disappear.
Both TVs are 1080p. Yes, video output is set to auto although I've tried 1080p too.
HDMI passtrough (called HDMI control in Denon) is disabled (always was) but I still only get 2ch audio regardless if 2nd TV is on or off. Again, the only way to get MCH sound back is to physically disconnect HMDI 2 cable from Oppo. But that immediately brings back green flashing screen and i still don't get it why.
I appreciate your lengthy post but so far I've made no progress.
giedrys is offline
Old 02-25-2013, 05:55 PM
KJSmitty's Avatar
Liked: 34
Most definitely. Via analog or digital out.
I utilize HDMI 2 for audio on my 93 but went analog out for my 103 instal due to using an older yet great sounding Yamaha flagship receiver. No complaints.!
Have you owned any OPPOs previously?
Love DIY
KJSmitty is offline
Old 02-25-2013, 11:55 PM
turboman123's Avatar
Quoted: 24 Post(s)
Liked: 25
AV Receiver to match BDP-103
I got a BDP-103 since about a month ago. Since then I have been looking for an AV Receiver to match the BDP-103.
So I considered an AV Receiver to be in the same price range as the BDP-103.
A visual match was also important, and due to space constraint, I definitively wanted a slimline receiver. And that is where the problem starts, because there are not that many slimline receivers around.
I considered the Pioneer VSX-S300/500, but I was told by shops in Hong Kong (where I live) that these models were discontinued. They are still available in Europe and North America.
l considered a Cambridge Audio Azur 551R , but dropped the idea due to price.
Then I looked at Marantz NR1403/1603, but visually they don't match the Oppo that well.
By accident, I saw a new entry model from Cambridge Audio, the Azur 351R. And that was a perfect match for the Oppo BDP-103. Or the Oppo a match for the Azur. Whatever.
I bought the Azur and I am now installing it.
Judge for yourself:
Higher resolution picture:
Oppo BDP-103 & Azur351R.JPG 1440k .JPG file
Name:	Oppo BDP-103 & Azur351R.JPG
turboman123 is offline
Old 02-26-2013, 12:13 AM
tokyoav's Avatar
Got a bit of a scare this morning. Last night, I turned off the TV (plasma), but left on the OPPO BDP-103. This morning when I got up, I found the TV switched on with the input coming from the OPPO. The home screen was being displayed without the screensaver running. After turning off the OPPO, still some ghost of the home menu was remaining. Hopes it goes away :-(
tokyoav is offline
Old 02-26-2013, 12:18 AM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
htwaits is offline
Old 02-26-2013, 01:09 AM
Bob Fosse's Avatar
Quoted: 90 Post(s)
Liked: 94
Originally Posted by JKR1963 View Post
I have done some testing of the Dvd picture quality of my new 103 vs my old 83..........no contest .......the 83 has a vastly sharper picture with more depth.........just like the 83 compared to all my other Dvd players (Denon 2930, LG 200 combo, and all of my other players).
I have seen reviews that seem to suggest that the dvd upscaled picture is of the highest quality, but it does not compare to the 83 at all. This is swithced through my Onkyo 3009 (in direct mode) and into my Panasonic 60GT50 in THX Theater mode.
Keep your Oppo 83 if you care about dvd picture quality. The 103 has full quality Blu ray picture quality and looks the same as the 83.......but Blu rays like Aliens load up like a Dvd compared to the wait loading on the 83...this is worth the upgrade just for that alone. The smooth disc drawer is very nice, the 103 remote is heavier than the 83's by a fair bit.
A/V SYSTEM: Sony Z9D 75" LCD main, LG EF9500 OLED, Anthem 525 5.1 channel amp, Anthem AVM 60 processor, ProAc D80 L+R, ProAc Response CC, AT surround Speakers, SVS SB12+ Sub, Oppo 203 UHD player, TiVo Bolt, PS Audio P10 power plant, Auralex room treatments, black out curtains.
2 CHANNEL: Aurender N10 music server, Ayre QX-5 & PSAudio DS DACs, PS Audio DMP tranport, ARC Ref6 preamp, ARC Ref75SE or Ayre VX-5 20 amps, Sonus Faber Amati Futura speakers.
Bob Fosse is online now
Old 02-26-2013, 01:24 AM
Bob Fosse's Avatar
Quoted: 90 Post(s)
Liked: 94
I just ordered the 103 to replace my 83 and bring down the 83 to our vacation home. I read the reivews and I came to the conclusion that the 103 would be at least as good as my 83 with DVDs. I did not check the 103 owner's thread or see your post before ordering.
Since DVD PQ is still important to me I am now wondering if I should cancel my order for the 103 before it ships? I am not into streaming video and have a dedicated 2 Chanel system for music so the 83 serves me well on both DVD and BD with my 60" Pioneer Kuro Elite plasma TV.
I have not had time to check out all the comments and findings here on AVS regarding DVD PQ regarding these two players. Any input would be most appreciated by anyone that have owned both of them with regards to DVD PQ.
Thanks and appreciated.
Bob
Old 02-26-2013, 03:31 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Originally Posted by dmusoke View Post
 On newer films, the PQ is darn close. Audio is another thing altogether. DD+ is just too lossy for my tastes as compared to DTS MA or Dolby TrueHD from bluray.
DD+ at full 1.5Mbps was shown in controlled laboratory settings to be transparent to the master for the record (this was several years back, during the height of the HD disc format war; not sure of any more recent tests). wink.gif Granted, this was again in a controlled studio/lab environment where the bitrate and associated encoding parameters were known by those conducting the test. Vudu might be using a lower bitrate or VBR for scaling purposes.
vinnie97 is offline
Old 02-26-2013, 05:11 AM
Frenshprince's Avatar
Originally Posted by Sidetracked View Post
True, but then you have to define 'normal'. 'Normal' to Oppo, need not be the same as 'optimal' for you.
Oppo is acknowledging there is some NR on at all times with HDMI 1, and that in turn means the signal is at least
slightly processed. Whether you like it, or it bothers you is more an 'art' decision than a 'science' one. Their feeling is
that it should be so minor you won't notice it on shiny discs, but I'm not sure my eyes agree.
The way I read it, they're saying 'this level of NR looks the way we want it to'. But whether you agree with their taste
or prefer the slightly different unprocessed look of HDMI 2, or even the somewhat artificially sharpened look of
+1 is personal, not right and wrong.
To my eye, certainly, for example on SD-DVD discs, there is a notable difference between HDMI 1 and 2 with
both at 0. It affects both sharpness and contrast. On discs I've helped master, HDMI 2 actually
looks closer to the master, while HDMI 1 has slightly more 'pop', but slightly less fine detail. HDMI 1 is
a more eye catching picture, but a less 'accurate' one. (And ironically, on SD-DVD, to me both options
trail the old ABT chip results on the 83 and 983.)
But it does sound clear that the way oppo has implemented the QEDO chip is intentional and not a bug. Now
it's up to each of us to decide what we like. At least we have options.smile.gif
I've always been bothered with 93 and 103 sharpness details.
No matter what, with sharpness at 0 (or source direct), picture was always less sharp than my other bluray players, and masters.
I managed a studio mastering for Bluray and TV, so my eyes are quite hypercritical.
I've made a lot of comparisons A/B/X with other players, and the Oppo 93 and 103 were always the less accurate (for sharpness).
So now there is an explanation.
Frenshprince is offline
Old 02-26-2013, 05:44 AM
wmcclain's Avatar
Liked: 1921
Bob
I've had both and the DVD image on the -103 looks fine to me. With HDMI1 & 2 you have your choice of QDEO vs Mediatek processing.
That said, I still have an old 983H DVD player and I still appreciate its DVD quality above all.
Calibration of your display is going to matter more than these input choices.
-Bill
wmcclain is offline
Old 02-26-2013, 07:52 AM
Maestro J's Avatar
Quoted: 75 Post(s)
Liked: 55
Quick question regarding the 103...
I was an initial purchaser of an 83 which is slowly dying so I'd like to purchase the 103. I like that it has 4k pass-thru for future proofing.
I'm confused about the HDMI input though. In Joerod's review, he stated he connected his Directv receiver to the input and let the Oppo do the processing and then sent that to his display or AVR (whichever the connection)
Is this the optimal way to set this up if I want to have my Directv receiver upscaled and processed by the 103? I'd be using a single cable to my AVR from the Oppo for audio processing (Denon 4311) and then send the signal to my Sony projector. I currently just have my Directv box connected to one of the HDMI inputs on the 4311.
Just making sure I have this feature correct and that this setup would work for me.
Maestro J is offline
Old 02-26-2013, 08:23 AM
Tal L's Avatar
I believe I am using bitstream But I'll double check and report back.
Tal L is offline
Old 02-26-2013, 08:27 AM
wmcclain's Avatar
Liked: 1921
OPPO will fix that for a modest fixed price.
I haven't paid much attention to 4k but I thought this was for upscaling only by the player, that is does not read 4k content. Would that apply to the HDMI inputs as well?
-Bill
wmcclain is offline
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
