Official OPPO BDP-103 Owner's Thread - Page 208 - AVS Forum | Home Theater Discussions And Reviews
 860Likes
Old 03-03-2013, 05:25 AM
Nicodimus22's Avatar
Quoted: 16 Post(s)
Just a quick question here for anyone that uses an external HDD with this unit. Does the HDD have to be formatted FAT32 or NTFS?
Denon AVR-X4000 | Paradigm Monitor 11v7 L/R | Paradigm Monitor Center 3v7 C | Paradigm Monitor Surround 3v7 LS/RS | Klipsch SW-350 sub
Vizio P652ui-B2 4K TV | Oppo BDP-103 blu-ray player | Logitech Harmony 650 | Sony PS3 Slim 500gb | Nintendo Wii
Nicodimus22 is offline
Old 03-03-2013, 05:26 AM
Frenshprince's Avatar
That's interesting,
Because I just tried again with two different sources, one at 23,976 and one at 24.000, and they both interpreted at 24hz by the 103.
You can check by pressing info on the 103 remote.
Same results on both hdmi inputs.
Frenshprince is offline
Old 03-03-2013, 05:28 AM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
Yes.
JazzGuyy is offline
Old 03-03-2013, 07:00 AM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
I wonder why they assumed that everyone would use Netflix anyway. I thought DNR was a big no-no because it scrubs away fine detail. I mean, as an option for people that want to mess with it, fine, but to have it forced on in every mode seems odd.
Anyway, when my unit comes on Tuesday, would you recommend hooking up with HDMI 2 to get around this problem, or using HDMI 1 and putting the sharpness at +1? My setup is: Blu-ray===HDMI===AVR===HDMI===HDTV
IMO HDMI 2 set to Source Direct has a sharper and more detailed picture. However, as I said in post 5276, there may be color upsampling issues with some setups. My advice is to try HDMI 2 but check the 3 color space settings using familiar reference sources.
dsinger is offline
Old 03-03-2013, 07:21 AM
thrang's Avatar
Quoted: 1605 Post(s)
Liked: 1381
Originally Posted by j2037 View Post
I just ordered one from Amazon for this reason, to play back 23.976 bluray content smoothly, as the PC is unable to do this. I was hoping to play the iso's from the PC and pass it through the Oppo.
I don't know if the oppo has any such issue at the moment, but if your playback source has problems with proper frame rate, passing hdmi through the oppo isn't going to fix that.
thrang is offline
Old 03-03-2013, 08:55 AM
JAMES MCHUGHES's Avatar
Quoted: 153 Post(s)
Liked: 52
I have a question for anyone that may know I think I read here in this forum that redbox will soon start streaming there movies and not sure when. When they do will we be able to get them here on the bdp-103 and if so how. Are we able to download the app to our player or how does this work.
JAMES MCHUGHES is offline
Old 03-03-2013, 09:27 AM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
No downloading of apps to the player. As far as native apps on the Oppo, this depends on the app supplier. They determine whether they want to let Oppo have their app and add it to the Oppo. Then Oppo can roll it out in a firmware update. So far, only a few companies have supplied a movie downloading app to Oppo.
The best choice for someone who wants the ability to have more sources would be the Roku stick (available to Oppo owners for $49 directly from Oppo) which provides many different sources and would probably offer Redbox, once available (though there is no guarantee). Some users have had some issues with the Roku stick so check out what has been said about it in this forum by using search.
JazzGuyy is offline
Old 03-03-2013, 09:52 AM
Quoted: 153 Post(s)
Liked: 52
Hmmm I just bought a roku stick on amazon for $99 and was considering just sending it back since I havent opened it yet. Thought I needed it before knowing there was a wireless adapter that came with my oppo
What other sources can I pick up right now if I were to plug in the roku stick.
I believe I have the roku 3400
Old 03-03-2013, 10:14 AM
117olddude's Avatar
Quoted: 21 Post(s)
You can return the stick to Amazon, buy it from Oppo for half the price (no downside there) and then use the stick as is. I use it with Plex (free) from my Mac to stream from my computer- simple and easy. Roku also has tons of apps you can add (Oppo's apps are limited, and you can't add more), some free, some pay, some sorta in the middle. Best $50 I've spent in a while.
117olddude is offline
Old 03-03-2013, 10:57 AM
cdittmer's Avatar
It really is a matter of personal preference. I have gone back and forth between HDMI1 and HDMI2. I currently am running on HDMI1 with sharpness at +1. I have the same setup as you.
Nicodimus22 likes this.
cdittmer is offline
Old 03-03-2013, 01:26 PM
zombie1210's Avatar
Quoted: 16 Post(s)
Liked: 36
The Avengers looked absolutely perfect. Sharpness on -0.
BDP105D>TX-NR646>55"ES8000
zombie1210 is offline
Old 03-03-2013, 06:16 PM
subavision212's Avatar
Quoted: 62 Post(s)
Liked: 38
What other sources can I pick up right now if I were to plug in the roku stick.I believe I have the roku 3400
http://streamfree.tv/apps/
Here is a link to the best listing of pretty much all the channels, public, private and in the Roku store as well as some other info you can add to the Roku. There is a LOT!
subavision212 is offline
Old 03-04-2013, 07:04 AM
WannaKnowTech's Avatar
Quoted: 12 Post(s)
Ok so...maybe run everything through HDMI 2 for blu-rays when I get my player back (had to send it back, guy sent me one with standard mod instead of pro mod by mistake). However for DVDs which do you recommend. Everyone has always crowd about oppos amazing DVD upscaling capabilites. Do I still see any of that through HDMI 2?
WannaKnowTech is offline
Old 03-04-2013, 07:24 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2690 Post(s)
Liked: 1921
Surely not.
Best to try it yourself and trust your own eyes. Mediatek processing on HDMI2 is quite good for DVDs these days.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
Old 03-04-2013, 07:54 AM
vahighland's Avatar
What's the difference between getting the Roku Stick vs. the Roku Box in terms of features and performance?
vahighland is offline
Old 03-04-2013, 08:59 AM
Quoted: 12 Post(s)
Originally Posted by wmcclain View Post
Surely not.
-Bill
They haven't? I thought Oppo was known for being the best with upscaling DVDs. Back when DVD still mattered everyone always said Oppo were great. Back then I couldn't afford one.
Old 03-04-2013, 09:04 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2263 Post(s)
Liked: 2825
The ROKU Streaming Stick uses the OPPO remote instead of a separate remote.
The Stick uses its own built-in Wifi, separate from any network connection of the OPPO. So you must have Wifi to use the stick. At least one Roku box can be hooked up by Ethernet instead of Wifi.
The Stick must use the Front HDMI Input of the OPPO, since that one has MHL power. The box is separately powered, and if you want to run it through the OPPO you can use either the Front or Rear HDMI Input.
The Stick as sold by OPPO does not include its own Roku remote, and also has special discount pricing.
The Stick runs the same Roku Channel apps as their 1080p-capable boxes, evidently with the same performance.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
Old 03-04-2013, 09:10 AM
Sidetracked's Avatar
Liked: 25
The upscaling is still very good, but it has taken a step back from the days of the ABT chip (in terms of pure accuracy).
I kept my 983 and 83 Oppos partly because a lot of my collection are films that have never been released on BR.
On the 103, in terms of pure accuracy HDMI 2 is the better bet. The picture looks very nice from HDMI 1, but
there's a bit too much NR, and some artificial contrast enhancement. (I say this based on comparison tests on
DVDs I was involved in mastering).
All that said these are subtle differences. But HMDI 2 will give you a touch more subtle detail, especially in shadow
areas, and doesn't have any artificially added 'pop'. But it's not like HDMI 1 is some horrible distortion of the image.
If you like it best, you're still getting an image that looks quite good, and is closer to the original than most lesser players.
Sidetracked is offline
Old 03-04-2013, 09:19 AM
rexdragon's Avatar
Originally Posted by noway1 View Post
browse to a file on the USB drive and although it can find the drive where the media files are (nested in folders two deep) it endlessly goes into "loading" when trying to display all the 800 file names. The only cure is to power it down, unplug the HDD usb cord from the back of the Oppo and plug the usb cord back in. Then it quickly finds all the file names.
Do you have gracenote activated in the oppo's settings? I suspect the "endlessly loading" is somehow connected to gracenote accessing the internet and downloading metadata(including thumbnail artwork) pertinent to each media file contained in the usb drive. Depending on your internet bandwidth, this process may take a couple minutes or more. I suggest deactivating gracenote in the oppo's settings and see if your accessing/loading problem remains.
rexdragon is offline
Old 03-04-2013, 09:57 AM
AVfile's Avatar
Quoted: 239 Post(s)
Liked: 126
Since Oppo has declared the HDMI1 issue non-fixable, I am curious how Cambridge Audio's Azur 752BD handles the situation.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
Old 03-04-2013, 10:03 AM
sergiosantos's Avatar
After three months waiting my BDP-103 due a huge burocratic methods from my post services (I am a Brazilian customer), I start to test my unit.
Unfortunately, I am getting several issues with the Oppo and my set-box, which freezes when plugged into HDMI IN of Oppo. Probabily some handshake issue. I'll wait that newests versions of firmware could fix it.
The BDP-103 continues without support for MKV MVC 3D (USB, Network or even Media Server) and ".cue" files also are not supported.
At least, the support for netflix was greatly improved and I can get fullHD images with 5.1 audio.
sergiosantos is offline
Old 03-04-2013, 10:58 AM
vahighland's Avatar
--Bob
Thanks. I wish the stick could leverage Ethernet hookup from OPPO. Also, not liking the idea of plugging in a stick from the font. Wish they had a rear MHL port.
Old 03-04-2013, 11:21 AM
wmcclain's Avatar
Liked: 1921
I missed that. I haven't seen a statement of any sort.
-Bill
wmcclain is offline
Old 03-04-2013, 11:22 AM
wmcclain's Avatar
Liked: 1921
I meant we hadn't "crowd" about it here, or even "crowed".
You have a 30-day return on the player, all it costs you is return shipping. Try it and see,
-Bill
wmcclain is offline
Old 03-04-2013, 11:49 AM
jboileau's Avatar
Quoted: 20 Post(s)
I just like to emphasize that the way your TV is setup can make a huge difference. I contacted Oppo last week stating that I had some files that had a jerky playback. They where ready to receive my files but I first opted to double check them first. I even decided to check my TV using my S&M disc. While doing that I came accross a few settings in my Sony TV that where set to auto and one in particular that was for motion improvement. I decided to turn them all off and bingo no more jerky playback! cool.gif
I was also appalled to discover that by default my Sony TV was set to over-scan and zoom the image losing about an inch all around my 46 inch TV. This is forcing scaling even on a blue ray disc! eek.gifmad.gif This is now turned off too.
I do have question for any expert on this forum. On my TV the sharpness comes at a default of 15. I turned that down to zero to let the Oppo solelly do the job. But I was wondering if the sharpness control on a TV as a range that includes removing sharpness? Does it go from removing sharpness to no change to adding sharpness? Am I wrong to set it to zero?
jboileau is offline
Old 03-04-2013, 11:58 AM
wmcclain's Avatar
Liked: 1921
I had a similar experience with a friend's new display (also a Sony, although that may be coincidence). He called me up in a panic because people were coming over to be impressed and it wasn't looking quite right. With the S&M disc we found:
  • overscan in the default mode (the rule should be to always use 1:1 pixel mapping)
  • default sharpness was turned up to "ugly"
  • motion interpolation was on by default
  • we had to do the more usual black level, white level, color and tint adjustments
It made a night and day difference.
There is no standard for sharpness control range. Sometimes 0 is "off" but sometimes it may introduce softness. Put up a hidef test pattern with fine detail and run the control up and down. I think we set the display above to 0.
-Bill
wmcclain is offline
Old 03-04-2013, 12:49 PM
Hi Deaf's Avatar
I had to do a hard reset on my Dish box before it would work with the 103. You might want to try that if you haven't.
Panny 65VT50 / DTV Genie / OPPO 103 / Roku 3 / Denon 1613 / Klipsch Quintet 5.0
Hi Deaf is offline
Old 03-04-2013, 12:52 PM
Quoted: 16 Post(s)
With HDMI 1 or HDMI 2?
Old 03-04-2013, 01:02 PM
Quoted: 16 Post(s)
So, if the choices for hooking it up are:
A) HDMI 1 with sharpness at +1 (but the image looks processed)
OR
B) HDMI 2 with sharpness at 0 (but the colors are different)
I have to ask, how noticeable are these differences? Does HDMI 1 look so processed that it's like Vivid mode accidentally got turned on on the TV? Does HDMI 2 make blue look like teal, or is it just something that a calibration tool might pick up, but your naked eye would not? Has anyone found any screenshot comparisons of the two outputs playing the same material?
Still eagerly waiting for my unit to arrive. Only 18-23 hours to go. biggrin.gif
Old 03-04-2013, 01:07 PM
wmcclain's Avatar
Liked: 1921
OR
Soon you'll be able to test it yourself and tell us.
-Bill
wmcclain is offline
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
