Official OPPO BDP-103 Owner's Thread - Page 211 - AVS Forum | Home Theater Discussions And Reviews
 888Likes
post #6301 of 24590 Old 03-05-2013, 06:21 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3223
Originally Posted by AYColumbia View Post
Oh no, not electrical tape. Check out lightdims. They work great and don't leave the nasty guck behind if/when you remove them. wink.gif
I have those things on all kinds of stuff.
LG 65E6P / Sony X800
Marantz AV7702II / Outlaw Model 7140
Klipsch RF7II's / RC64II / Dual Rythmik FV15HP's
gadgtfreek is online now
post #6302 of 24590 Old 03-05-2013, 08:05 PM
giedrys's Avatar
Quoted: 13 Post(s)
When you say "Compares favorably to HTPC", what does that mean exactly ?
Easier to use for instance.
You say: "Never liked any of the software BD players that much+"... Really ?? Maybe difference of opinion, but I do I do prefer to store and play movies from XBMC...
I meant BD software players like TMT Or PowerDVD
You say: "all those video card settings to mess with just to get as close to original unaltered picture as possible" Besides setting your TV resolution... what other card settings do you need to adjust ?
If it was that simple, there will be no threads such as this on HTPC forum:
http://www.avsforum.com/t/1387832/htpc-tweaks-and-fixes
Note: I'm just trying to see which is better or are they the same in terms of video quality.
To me there is little to no difference in PQ. YMMV.
Again, Oppo wins for me because it's easier to use, takes less time to tweak, boots almost instantly etc. Never liked playing movies from PC anyway- only did that because of file compatibility. That's not an issue anymore when you have 103.
Try to compare it your system. You don't have much to lose- just return shipping in case you don't like it.
giedrys is offline
post #6303 of 24590 Old 03-05-2013, 09:05 PM
biotechy's Avatar
I recently purchased the Oppo 103 and have it hooked up to a Denon 4311CI and then to a Panasonic VT50. I am tempted to use the "enhanced color" for some reason. smile.gif Not really sure I understand what it does. Has anyone tried this and at what level. (+1 to +4). I'm using Dnice's settings on the VT50 and check those with WOW disk. Wonder how much "enhanced color" messes with cal setting.
biotechy is offline
post #6304 of 24590 Old 03-05-2013, 10:45 PM
Sidetracked's Avatar
Liked: 25
Originally Posted by AVfile View Post
No, the "good news" was that they acknowledge the errors on HDMI2 and plan to fix it in the next firmware update.
I agree, for a videophile company, I am shocked at their current direction with the BDP-103. People are going back to the BDP-83 and that shouldn't be happening.
Well, frustratingly I just got a more qualified response about fixing HDMI 2 in an email exchange today;
Me: Has Oppo now found that there are indeed chroma sampling errors in HDMI 2, and is the plan to
address those in a future firmware release?
Oppo: Issues related to chroma sampling errors with HDMI 2 have been confirmed by a beta tester and their
observations have been sent to the firmware engineers for additional replication and verification. Ideally
if
there is anything wrong with the HDMI 2 output will be corrected through a future firmware release.
Doesn't sound like they've accepted there are definitely errors or are promising a fix yet either.
"Ideally'...
Sidetracked is offline
post #6305 of 24590 Old 03-06-2013, 03:55 AM
Elmar's Avatar
Quoted: 18 Post(s)
It drives me crazy... SMB via the 103. I have Windows 8 Pro. I guess my settings are ok because from my smartphone i can access my shared drives through a SMB app (AndSMB) without any problem. On the 103 i always get "Login failed", my access settings are simple, account no special characters, password no special characters and as said - works like a charm from Smartphone. I looked up in Google for help - nothing found that worked.
Is there any hint ? I read that Win 8 makes problems in general with SMB compared to Win 7 - is it a known issue with the oppo ?
Elmar is online now
post #6306 of 24590 Old 03-06-2013, 04:03 AM
globalnomad's Avatar
Unfortunately, it is a known issue with Win 8/OPPO. Win8 is supposed to have backwards compatibility with SMB 1 and 2, but something isn't quite right yet (either with documentation for developers to implement SMB 3 or with the actual compatibility system).
globalnomad is offline
post #6307 of 24590 Old 03-06-2013, 04:08 AM
Elmar's Avatar
Quoted: 18 Post(s)
Thanks. Thats fun, since they advertise it as experimental they don't even need to take big attention to this issue then... direct access was one of the buying reasons to replace the 93 mad.gif
Elmar is online now
post #6308 of 24590 Old 03-06-2013, 04:22 AM
To their credit, my Win 7 share works flawlessly and I couldn't be happier. Also, I don't know how much access they would have had to Win 8 for testing prior to its release considering both the OS and player were released in October if I remember correctly.
post #6309 of 24590 Old 03-06-2013, 04:32 AM
Also, make sure you don't have any Microsoft Live programs installed as they conflict with SMB shares, even on Win 7. This includes MS Live Essentials, Live Games etc.
post #6310 of 24590 Old 03-06-2013, 04:44 AM
Elmar's Avatar
Quoted: 18 Post(s)
No live services installed. I made a fresh install as well this week. and i use a local account, no live account for logon
Elmar is online now
post #6311 of 24590 Old 03-06-2013, 06:20 AM
Terry Mann's Avatar
Originally Posted by Bob Pariseau View Post
The ROKU Streaming Stick uses the OPPO remote instead of a separate remote.
The Stick uses its own built-in Wifi, separate from any network connection of the OPPO. So you must have Wifi to use the stick. At least one Roku box can be hooked up by Ethernet instead of Wifi.
The Stick must use the Front HDMI Input of the OPPO, since that one has MHL power. The box is separately powered, and if you want to run it through the OPPO you can use either the Front or Rear HDMI Input.
The Stick as sold by OPPO does not include its own Roku remote, and also has special discount pricing.
The Stick runs the same Roku Channel apps as their 1080p-capable boxes, evidently with the same performance.
--Bob
Was frustrated with the variable quality of Netflix on my Oppo BDP-103 and so cancelled Netflix.
Should the new Roku 3 provide (a) visibly and audibly better and (b) more consistent results from Netflix (with Roku signal then passed thru the Oppo) than the 'downgraded' signal Netflix seems to frequently send to the Oppo?
Terry Mann is offline
post #6312 of 24590 Old 03-06-2013, 07:59 AM
Tal L's Avatar
Originally Posted by moonhawk
Are you set to bitstream, or LPCM? I have very little success with bitstream, and occasional delays --Handshaking?--with LPCM into my Bryston SP3.
Originally Posted by Tal L View Post
I believe I am using bitstream But I'll double check and report back.
Sorry, for the delay... I reconfirmed my settings and yes, I am definitely using bitstream.
Tal L is offline
post #6313 of 24590 Old 03-06-2013, 08:26 AM
Tony Vega's Avatar
Any owners having any luck getting the BR of Wreck it Ralph to work? The player is un-responsive. The DVD works just fine and for kicks, I moved the BR to another player and had no issues.
Tony Vega is offline
post #6314 of 24590 Old 03-06-2013, 08:30 AM
KJSmitty's Avatar
Liked: 34
Originally Posted by skoor View Post
Same here. Really wanted to like the OPPO, but the Panasonic BDT-220's SD playback is excellent. And with the sharpness issue, I would say the BR playback is much more satisfying too. File support and streaming on a single box unit would have been very nice and the very reason I went with the OPPO in the first place. But I cannot do it at the price of PQ regardless of cost. For now the Panasonic will have to do. And at one time, I was in the camp that all BR images would look the same. However, I do see a difference on these two units even for BRs with OPPO's soft vs processed look. Perhaps OPPO will or can get it fix. Then we can get back to focusing on SD support, file and streaming support again. Not for now, unfortunately.
I think it definitely depends on the displays - and of course personal likes etc. I had two BDT-220s and returned them both. One on a 54 inch Panny GT15 and the other a 60 inch GT50. I surely wouldn't say the 220s stunk in regards to video prowess yet definitely "would not" say I liked it over the OPPOs. If BD playback/PQ was its only use I too would probably say $120 works over the $500. My biggest issues with the 220 were what I would call a very finicky HDMI circuit and antiquated home network features with lousy playback/format support. The HDMI issues definitely relate to my home/HDMI runs in that short direct runs to a display worked fine. Anything beyond that resulted in flaky video if video at all - where other players work flawlessly. I replaced one with the 103 and the other with an even cheaper Sony BD player. I do respect your position however as its been said many times that if you are not utilizing the many other features/functions of an OPPO you're paying for more than you need.
Regardless of item purchased, merchant etc, the best thing ever created was the 30 day return policy. Reviews and research don't always cover the specifics and each of us can have unique set ups and/or desires and opinions on performance. It's great to beable to perform a little trial and error/test and review prior to long term ownership. biggrin.gif
Cheers
Love DIY
KJSmitty is offline
post #6315 of 24590 Old 03-06-2013, 08:33 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2840 Post(s)
Liked: 2086
Yours is the first problem report I have seen.
What exactly is the player doing? When does it stop being responsive?
The general procedure for dealing with problem Blu-rays is to do all of:
  • turn off BD-Live
  • erase Persistent Storage
  • reboot the player
If still no good, try the same thing with BD-Live on.
If still no good, contact OPPO support with the details.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #6316 of 24590 Old 03-06-2013, 08:40 AM
Tony Vega's Avatar
  • turn off BD-Live
  • reboot the player
-Bill
I'll give this a try. The disc and player just remain unresponsive at the menu screen. The closest thing I get to a reaction from the player is a circle with the line thru it in the top left corner when I try and push various buttons on the remote. I'm sure Oppo will get it sorted out. Sounds like a BD-Live issue.
post #6317 of 24590 Old 03-06-2013, 08:56 AM
Josh Z's Avatar
Quoted: 2178 Post(s)
Liked: 1459
Browsing this thread late and have only read back a few pages. Regarding the discussion about the HDMI 1 softness issue, I see some people say that they've gone back to the BDP-83. Where does the BDP-93 fall? Does it supposedly have this issue also?
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is online now
post #6318 of 24590 Old 03-06-2013, 09:04 AM
AVfile's Avatar
Quoted: 262 Post(s)
Liked: 134
I defer to others on the 93 image quality, but the culprit in the 103 seems to be the QDEO processing which Oppo enabled mainly for 4K scaling and NR. The decoding solution provided by Mediatek seems to do everything else adequately, which is why HDMI2 will be preferred for most users once they sort out the Chroma issues (I am still hopeful that a fix for this imminent, despite the latest generic response from low-level tech support).
I will point out that many are holding onto the older 83 for its superior IR remote responsiveness and front panel ergonomics over the newer 93.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #6319 of 24590 Old 03-06-2013, 09:08 AM
Liked: 25
Sorry to give a non-answer answer, but I'm the one who spoke of going back to the 83. I do have
the 93, but it's in a different system, with a lesser display, so I've always attributed any quality
differences to the display, not the player.
I did think of testing the 93 in my main system to try and answer exactly your question, but just
haven't had the time.
post #6320 of 24590 Old 03-06-2013, 09:10 AM
Tornado Red's Avatar
Quoted: 329 Post(s)
Liked: 287
FYI, no issues with my 103 on the Wreck It Ralph blu-ray...
lanping09 likes this.
Tornado Red is offline
post #6321 of 24590 Old 03-06-2013, 09:10 AM
Jacob305's Avatar
Quoted: 81 Post(s)
Liked: 48
while i am no expert. I found the sharpness at +1 with my oppo 93 much better for some reason. specially with 3d titles. I am using a panasonic gt25.
Jacob
Jacob305 is offline
post #6322 of 24590 Old 03-06-2013, 09:17 AM
darthkringle's Avatar
All- Before I go behind my TV/Rack and give HDMI 2 a try for video, I want to be sure I understand something. If I am now going to use HDMI 2 for Video only direct to display and HDMI 1 for Audio only to the Receiver, I assume I have to pick "Dual Display"? Then I assume Audio and Video are passed from BOTH HDMI? Thanks!!
darthkringle is offline
post #6323 of 24590 Old 03-06-2013, 09:41 AM
Josh Z's Avatar
Liked: 1459
The 93 also has QDEO, but not 4k scaling. I don't know if it's been implemented the same way.
It was my understanding that both units used Mediatek for decoding, and QDEO only came into play for image processing (or scaling to 4k).
Josh Z
post #6324 of 24590 Old 03-06-2013, 09:53 AM
warrian's Avatar
Originally Posted by Jacob305 View Post
what HDTV do you have if I may ask?
Jacob
Sorry for the delay in answering your question. If you're still interested, I've had a Sony KDL-55BX520 for the past year and change.
________________________________________
Sony Bravia KDL-55BX520 / Pioneer VSX-54TX
OPPO BDP-103D / Xfinity X1 / Klipsch Speakers
warrian is offline
post #6325 of 24590 Old 03-06-2013, 09:56 AM
larryep's Avatar
new update from slysoft about cinivia
7.1.6.0 2013 03 05- New: Option to disable Cinavia detection when using AnyDVD with ArcSoftTMT 5.3, TMT 6.0 or PowerDVD 12- New: Rip to image will create sparse files to reduce the size ofrequired disc space and faster image creation- New (Blu-ray): Support for new discs- New (DVD): Support for new discs- Fix (DVD): Removing annoyances could make some discs unplayable- Some minor fixes and improvements
does this have any worth when using AVCHD WITH OPPO?
larryep is offline
post #6326 of 24590 Old 03-06-2013, 09:59 AM
BakeApples's Avatar
Quoted: 256 Post(s)
Liked: 144
I'm also interested in this matter, i own the 93 myself and have sharpness set to 0. Personally, i don't think it looks soft at all but i havn't tried out using HDMI 2 yet so can't say if there is a noticeable difference.
What i would like to know is, does the Qdeo apply the exact same processing on HDMI 1 on both 93 & 103 or is it different? If so, how?
Sony VPL-VW550 | DNP Supernova 08-85 116" 2.35:1 | Lumagen Radiance Pro 4440 | Pioneer SC-LX89 | Oppo UDP-203 | Zappiti One 4k HDR | PS4 | Audio Pro/Pioneer 5.1.4 Atmos | SVS SB-1000
BakeApples is online now
post #6327 of 24590 Old 03-06-2013, 10:21 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1098 Post(s)
Liked: 1075
IIRC, the 93/95 uses the QDEO for more than just 4K and supplemental processing (such as NR), while the 103/105 use it only for those 2 things. So differences should be expected between the 93/95 and 103/105 for video processing.
From what I've heard, this only works during playback to trick the software into thinking it's actually playing the original disc so AnyDVD HD needs to be active during playback.. So the solution isn't actually removing the Cinavia watermark and this won't help with playback on the Oppo players.
gsr is online now
post #6328 of 24590 Old 03-06-2013, 10:46 AM
JJMONIE's Avatar
Hi all,
I have had the 103 since the start of January and I do not notice anything on BR playback with the sharpness at 0 or +1.
As others have said, maybe it depends on your display and eyes. I have a 54 inch VT25 that I use D Nice's settings I think and do not notice anything. I barely even notice anything when I crank it right up on sharpness.
I don't watch DVD shiny discs using the 103. I play them through my WDTV that is connected to the HDMI in on the back of the 103. Most movies have looked great this way except for Boyz N the Hood which looked awful.
As far as BR's go, the 103 has been fantastic. Maybe only a slight improvement from my old Panny BDP100 but the load speeds and other features are pretty useful.
I wonder still, why do I not notice what many of you are seeing? You can't all be wrong if you see the same issues. My 103 is connect with 1 HDMI cable to my Denon 2311CI with video conversion and upsampling off and from there to my VT25.
JJ
JJ
JJ
JJMONIE is offline
post #6329 of 24590 Old 03-06-2013, 11:13 AM
Nicodimus22's Avatar
Quoted: 17 Post(s)
Originally Posted by JJMONIE View Post
Hi all,
It's not a massive difference, but it's noticeable. If you have a calibration blu-ray, put on the sharpness test pattern, and then jump between 0 and +1. It's easier to see this way than by watching a movie.
Denon AVR-X4000 | Paradigm Monitor 11v7 L/R | Paradigm Monitor Center 3v7 C | Paradigm Monitor Surround 3v7 LS/RS | Klipsch SW-350 sub
Vizio P652ui-B2 4K TV | Oppo BDP-103 blu-ray player | Logitech Harmony 650 | Sony PS3 Slim 500gb | Nintendo Wii
Nicodimus22 is offline
post #6330 of 24590 Old 03-06-2013, 11:24 AM
Quoted: 17 Post(s)
After another round of testing, I have overcome some issues, and I also found a new one. I think I will e-mail this list to Oppo:
Firmware wishlist:
-Correct the color issue on HDMI2 so we can have a truly accurate output option.
-Make it so that you can completely turn off the front display. Right now when it's set to Off, it still comes on for 10-15 seconds every time you press a button on the remote. It's obnoxious in a dark room. Off should mean...off.
-During the playback of mp3s from an external drive, the 103 often chops off the first second or so of the song. This may be related to seek times on the hard drive, but other devices manage not to do it somehow. It would be preferable to wait a second or two to start the track from the beginning rather than starting instantly, but chopping off the start of the song.
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
