Official OPPO BDP-103 Owner's Thread - Page 214 - AVS Forum | Home Theater Discussions And Reviews
 884Likes
post #6391 of 24577 Old 03-07-2013, 02:48 PM
BBH
BBH's Avatar
I just set up my new BD-103. Love it. The only thing causing me grief is the seeming "touchiness" of the required wifi strength. After messing around with public DNS, etc, etc, I have it working ok, but.... the "front end" of the apps in my 2nd Gen (720P) Apple TV are simply better than those duplicated apps on the OPPO. Netflix and YouTube primarily. Also, as part of the Apple "walled garden", I can use my iPad's HBO GO to stream to the ATV. Then ATV via OPPO to my HDTV. Nice.
I plan on using the OPPO to process the output from the AppleTV. I think the OPPO upscaling to 1080p will allow me to pass on the ATV3. I do like those HDMI INPUTS. I'm also planning to get a ROKU3 and feed it through the OPPO. I've tried simply plugging the output of the AppleTV into the front HDMI input and it works just fine. The setup allows me to use a wireless bluetooth keyboard for all the ATV apps and take advantage of Apple's superior (IMHO) front end software. I assume the rear HDMI input will work just as well.
As I mentioned earlier, the wifi is the only issue. While I do have it worked out, at least for the moment, the ATV doesn't appear to have the streaming finickiness that the OPPO has. I would like to see the OPPO go "dual band" so I could use the 5ghz stream from my router.
And, as one more stream of thought.... I have McIntosh equipment, including a McIntosh SACD/DVD/CD player. The audio feeding my McIntosh MX134's external inputs (coming from the OPPO...) sounds outstanding. Even playing back files on my home network that reside on a NAS to primarily feed my SONOS system, sound great. This OPPO is one heck of a package.
Any thoughts or comments from the community?
BBH is offline
post #6392 of 24577 Old 03-07-2013, 02:54 PM
jerrygene's Avatar
I love it, got it this week as an upgrade but am still waiting for a more knowledgeable person to reply to my post of 5 hours ago....on best audio settings ...I am using it with 3 Polks a new Onkyo 5.1 only.
You are in the bigger league and the quality is impressive, also the sound and loading time is excellent.
My LS50's sound really warm and I like the universality of it....I feel that you get what you pay for here...a sturdy machine but then again I do not know if sound can be broken down into what component makes the difference but thus far this new set up is ideal. DVD's etc. play wonderfully and the USB handles Pandora,Netflix etc. well..I am using it from our wireless Time Capsule and connected rapidly...The graphics and ease of use and sturdy remote makes it all a very pleasing experience.... I think I got the right settings but just wish someone can offer me a tweak or a checklist for my simple set up....I am hooked. I may add I bought it primarily for music....down the road planning on surround bar or separates ....
jerrygene is offline
post #6393 of 24577 Old 03-07-2013, 03:41 PM
Ganymed4's Avatar
Quoted: 112 Post(s)
Liked: 81
Originally Posted by jerrygene View Post
Is it worth spending the cash on a high end BD player like the 103, if you only have a low-mid range sound set up? I need a new BD player and am considering the 103, mainly because of the great things I'm hearing about the sound reproduction, but my sound set up is currently an Onkyo SR508 (http://*******.com/c868frr) with Boston Acoustics Soundware 5.1 SE package (http://*******.com/cmyjtc8)
Am I going to hear much difference between the Oppo and my current player (Panny BDT110) using this set up?
I can't tell you about the difference between the Panasonic BDT110 and the Oppo BDP103 because I don't know the Panasonic. However, I also tested several sources and players and found, there is always a difference even via HDMI, which surprised me most, because it shouldn't.
This said, I can only recommend everybody to test the unit in your own chain and your room and then decide. In my understanding there is no common better or worse, you really have to judge for yourself.
I can give you an example. When I received my 103, I compared it to my old Denon DVD 3800 BDCI and found they are different especially regarding the sound. Same HDMI cable, same length, HDMI only and just switched the inputs on my AVR.
Well, this tells me clearly and it was clear to me before - compared Denon 3910, 3930, 2500, 3800 and a Samsung player, I forgot the name - there are differences, even via HDMI. If you hear this or not, depends on your setup, room and your listening habits.
Ganymed4 is offline
post #6394 of 24577 Old 03-07-2013, 04:11 PM
globalnomad's Avatar
Originally Posted by Elmar View Post
Yeah i could but... i wanted the pure solution hmpf...
I asked oppo service and got this answer:
For Windows 8 you will need to change the SMB sharing from SMB 3.0 to SMB 2.0 (which our player supports). We are not able to use the SMB 3.0 specifications, so we are not compatible with Windows 8 and Mac OSX Lion by their defaults.
Alternatively, you can use a DLNA server such as oShare to share your files over the network.
i dont think there is a way to revert smb sharing from 3.0 back to 2.0 on win 8 ?
Ganymed4 provided a lot of good links, I'm also going to supply this Microsoft Knowledge Base article to supplement what s/he found:
http://support.microsoft.com/kb/2696547
globalnomad is offline
post #6395 of 24577 Old 03-07-2013, 04:42 PM
Ganymed4's Avatar
Quoted: 112 Post(s)
Liked: 81
I am happy that you found this useful. I will test it myself and report here. I am experiencing exactly the same problems with SMB, Windows 8 and the Oppo as you all do. I use DLNA with my server and this works excellent with the Oppo, even for 1080p HD via WiFi 802.11n (300 Mbit/s). This is for me one of the great things of the Oppo, this works flawless. However, SMB should work, I see this the same way.
I will try it over the weekend and let you know.
BTW to Google for 'Windows 8 disabling SMB 3' is not this difficult, isn't it... cool.gif
PS: Thank you for using s/he, I am he. But the 'she' females should also post here their experiences and add to the discussion.
Ganymed4 is offline
post #6396 of 24577 Old 03-07-2013, 05:15 PM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
Noob question here...I am interested in improving PQ for HD cable broadcasts on my Panny GT50. It looks good but is a little inconsitent and I often see more grainyness, artifacts and a generally softer picture than I am used to. I am more interested in getting the best PQ and not too concerned with audio quality so I do not have an AVR. I have a HT in a Box (i know, i know). So my question is would running my HD Cable signal through the Oppo 103 improve the cable PQ dramatically? Say I can only afford one of the following...an Oppo 103, a Darbee Darblet, or an upconverting AVR, which will give me the most improvement in this area for the $300 to $500 spent?
One other question. Can I use the 103 for video processing and still use my HT in a box for audio?
wattheF is offline
post #6397 of 24577 Old 03-07-2013, 06:28 PM
KJSmitty's Avatar
Liked: 34
You didn't mention your current BD player so we don't know it's current performance level. With what you did mention PQ is what you're after thus I would try the Darbee. Doesn't sound like you would utilize an AVR, the 103 may just be a $500 PQ enhancer and the rest of its prowes would not be utilized. The Darbee is cheaper and all PQ.
And yes, as long as your HT in a box will accept an audio input I'm sure the 103 has an output that will be accommodating.
Cheers
Love DIY
KJSmitty is offline
post #6398 of 24577 Old 03-07-2013, 07:05 PM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
Cheers
Thanks. I have a PS3 and a newer Samsung 3D BD Player as part of the HT in a box.
I was leaning towards the Darbee but I just heard about how good the video processing on the Oppo is so I figured I would look into it.
wattheF is offline
post #6399 of 24577 Old 03-07-2013, 07:19 PM
KJSmitty's Avatar
Liked: 34
The one thing I haven't tried with my 103 is the HDMI input and resulting upscaling. The only input I would have is my Dish DVR.. I've hesitated due to so so chat on PQ improvements and numerous comments on lip sink and/or handshake issues - of which I know OPPO is working a firmware fix.
The Darbee has been on my radar from early last year. Really wish I would of grabbed one when at the intro price. Some people disliked it or didn't see the improvement where numerous claim its the cats meow.. I'd like to try it in my HT as well.. Return shipping is the only risk with either the 103 or DD. biggrin.gif
Love DIY
KJSmitty is offline
post #6400 of 24577 Old 03-07-2013, 07:29 PM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
So from what you have heard, the upscaling PQ of the Oppo is just OK other than the fact that it may cause those issues as well?
wattheF is offline
post #6401 of 24577 Old 03-07-2013, 07:49 PM
KJSmitty's Avatar
Liked: 34
Hopefully others who have utilized the 103s HDMI input will chime in. And yes, my comments stem purely from reading this thread and my perception of this topic. From user comments my take was running a cable box through the OPPO via HDMI was only a minor gain in PQ, some stating no improvement etc. The cable boxes that output "native" format worked the best. You didn't mention what service/box you have. May be run a search here on your specific box to see if someone has commented on PQ increases etc..
Cheers
Love DIY
KJSmitty is offline
post #6402 of 24577 Old 03-07-2013, 08:15 PM
dmusoke's Avatar
Quoted: 281 Post(s)
Liked: 147
Noob question ... I'm trying to use oShare as a dlna server so i downloaded it and selected my music/movie directories. Now what? How do i start to use it to play music or movies? I have many flc, flv and mp3 files.
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #6403 of 24577 Old 03-07-2013, 11:24 PM
Hi Deaf's Avatar
My Dish VIP612 works fine. The PQ is awesome. I have it set on 720p. I occasionally have a lip sync issue, but if I just skip back 10 seconds, it corrects it.
Panny 65VT50 / DTV Genie / OPPO 103 / Roku 3 / Denon 1613 / Klipsch Quintet 5.0
Hi Deaf is offline
post #6404 of 24577 Old 03-08-2013, 01:46 AM
DSperber's Avatar
Quoted: 229 Post(s)
Liked: 186
Originally Posted by Bob Pariseau View Post
You can NOT attach the iPhone and then browse its files of music or videos as if it was a hard drive.
In passing, I mention that there are other portable devices in the world besides Apple products, and in particular I own the very Windows-friendly (and SUPERB sounding) Cowon J3 PMP (which plays FLAC, MP3, and other common Windows-friendly music formats, as well as playing standard video formats like AVI and MPG, with common codecs like xVid and Divx, etc.) on which I have 96GB worth of storage (32GB internal, 64GB external) including about 25GB of FLAC and 35GB of MP3 music files (total about 7000 files). When the J3 is plugged into a PC via USB it appears as two removable drives with drive letters assigned, just like any USB drive should for 100% compatibility with 100% of Windows software and 3rd-party media products.
While the Apple products may connect in MTP mode, the 103 supports portable USB-connected devices in MSC mode, which in Windows would result in drive letters being assigned for the removable drives (i.e. internal/external storage of the J3). Apparently the 103 looks like a Windows computer to the J3, because when USB connected to the 103 both internal and external storage are directly accessible.
So all of the music folders/files on the J3's internal and external storage can be navigated through and browsed, and all of the MP3 and FLAC files on the J3 can be played by the 103, same as for network-available folders. In other words the J3 is just like two more external "network drives" to the 103, connected in MSC mode via USB.
"anythingbutipod.com"
DSperber is offline
post #6405 of 24577 Old 03-08-2013, 01:54 AM
I don't want to push this too far off topic, but I just wanted to say that I, too, love Cowon. I just wish the X7 had better support (and better GUI) than it did. I need the space for my big music collection. Here's hoping the next iteration has the ability to exceed 100GB (with or without external storage).
post #6406 of 24577 Old 03-08-2013, 04:06 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2833 Post(s)
Liked: 2076
On the OPPO, go to the Home screen and select the Network icon. After some searching, all the DLNA and SMB servers available on your network should appear in a list. Scroll down and select the oShare server.
SMB servers are all shown with a generic "two-server" icon. DLNA servers provide their own custom icon.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #6407 of 24577 Old 03-08-2013, 05:29 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
Apropos DLNA and icons, I have tried using two servers already (JRiver and Whitebear) and in both cases the Oppo does not display the album art when browsing down the albums / tracks tree, nor does it show the art on the now playing screen when actually playing a track.
This is odd, since I know that both those servers do include the album art in what they offer to the player, but it seems that the Oppo is not actually downloading the offered images from the server. (Note: other renderers - e.g. my Sony Tv - do download the art from those same servers). Does anyone else have this problem? Is this a weakness or a bug in the Oppo? Or is there some solution for it?
AndrewFG is offline
post #6408 of 24577 Old 03-08-2013, 05:42 AM
wmcclain's Avatar
Liked: 2076
My album art experiments were long ago and perhaps out of date for the BDP-103, but it seemed to me the player would display images embedded as a tag in the file. This is the same as for local files. I did not see it for any external images, and I didn't think it was common for DLNA servers to support that (but times change).
How is your album art stored, and what DLNA client displays it?
-Bill
post #6409 of 24577 Old 03-08-2013, 06:32 AM
SeeMoreDigital's Avatar
Quoted: 472 Post(s)
Liked: 197
I can confirm that album art works okay for me when playing AAC (M4A), MP3 and Flac files via NAS
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #6410 of 24577 Old 03-08-2013, 07:31 AM
AVfile's Avatar
Quoted: 260 Post(s)
Liked: 134
This makes sense as the Oppo or any decent VP in an AVR should have better SD upconversion than your average cable/sat box. As for HD potential improvements will not be dramatic. You are just converting one format 1080i60 or 720p to 1080p60 which should be a cake walk for any modern TV. The real limitation which some people call "grain" is actually excessive compression artifacts introduced by the broadcast process.
There is one more area for improvement when watching movies or programs shot in 24fps on cable/sat/antenna/DVD/etc. The telecine process converts 24p to 60i for transmission, using an uneven process which disrupts the natural cadence. I don't know if the Oppo supports this on the HDMI input (as it does when playing a DVD) but top notch VP's can perform inverse telecine to extract 1080p24 from a 60i source if a 24fps cadence is detected, resulting in smoother motion on displays that support 1080p24 natively.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is online now
post #6411 of 24577 Old 03-08-2013, 08:21 AM
Shingster's Avatar
Just a quick couple of questions I'm hoping someone can answer:
1. Is there a way for the Oppo BDP-103 to play a DVD directory on a USB stick or Hard Drive like it was a DVD-Disc? At the moment all I can get the player to do is play all the individual VOB files in a sequence.
2. Are Oppo aware of the crappy quality of the player-generated subtitles when playing a MKV with embedded subtitles?
Shingster is offline
post #6412 of 24577 Old 03-08-2013, 08:37 AM
wmcclain's Avatar
Liked: 2076
1. No. OPPO players have never supported VIDEO_TS as a directory structure. I'm not sure any Blu-ray player does that, although some media server products do.
I convert DVD structures to MKV, but that is best for 1 title per file, no menus.
2. I'm sure OPPO has seen the embedded subtitles the player produces. If you want to register a crappiness critique you should send them some feedback so they don't forget.
-Bill
post #6413 of 24577 Old 03-08-2013, 08:43 AM
Quoted: 472 Post(s)
Liked: 197
If you use the original 'graphics based' (VOBsub) subtitles from your DVD (instead of converting them to 'text based' subtitles) they will perform and look exactly the same as the DVD when placed within the .MKV container
post #6414 of 24577 Old 03-08-2013, 09:10 AM
KJSmitty's Avatar
Liked: 34
Thanks Hi Deaf,
I should just try it, pretty easy for me to accomplish given my config. I do know the Dish 722 does not have a native setting, only 720 or 1080i. I'm not sure I want to have the 103 on every time the TV is on however.. biggrin.gif
Cheers
Love DIY
KJSmitty is offline
post #6415 of 24577 Old 03-08-2013, 09:14 AM
videopotus's Avatar
I have the BDP-103 and love it. I got it for the video processing power it has and am very happy with the PQ it produces. That said, I've been looking at getting the Darblet but am not sure if I will see any PQ benefit given the abilities of the 103 that are currently enabled. Do any of you 103 owners also use the Darblet? If so, do you recommend it?
videopotus is offline
post #6416 of 24577 Old 03-08-2013, 09:44 AM
Josh Z's Avatar
Quoted: 2172 Post(s)
Liked: 1456
What the Darblet does is very different than any of the features in the 103. The 103 has traditional edge sharpening and contrast boosting options. You should turn those off. The Darblet uses proprietary technology to enhance detail without artifacts. The two products are complimentary.
There's a lengthy thread about the Darblet in the Video Processors forum with more information on what it does.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is online now
post #6417 of 24577 Old 03-08-2013, 10:18 AM
dazzerxxx's Avatar
With HD content the QDEO can employ a type of boundary luminance enhancement that alters pixel luminance to exaggerate the difference between areas without creating traditional halo type artefact associated with sharpening routines. This is similar to the process DVP uses except it's applied uniformly whereas DVP is selective based on frame content and the amount can be adjusted. The Oppo sharpening process is different for SD and will typically introduce artefacts.
On the previous generation setting the Oppo sharpness control to +1 on HDMI 1 wouldn't have an effect on assessment material i.e. Spears & Munsil luma/chroma tests but did have a visible affect on real world content.
dazzerxxx is offline
post #6418 of 24577 Old 03-08-2013, 10:33 AM
Ganymed4's Avatar
Quoted: 112 Post(s)
Liked: 81
I have switched off the secure negotiation feature on my server and could access the whole directory structure on the server.
The funny thing is, that e.g. my music folders are empty now, except for the jpegs of the album art, which are not shown in DLNA mode. The SMB/ CIFS mode doesn't show .flac or .wav files. But it works. I know it's experimental. In other words, I can access music files only via DLNA and play them, but not via SMB/CIFS. This is not as I thought the function would work. In the manual it is written on page 42: "Accessing a SMB/CIFS client...as if accessing an external USB hard drive."
Well, OK, it is experimental.
What you have to do is start the PowerShell in administrator mode on the Windows 8 PC - right click on the PowerShell, chose 'Run as Administrator'. Then type in the PowerShell window:
Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\LanmanWorkstation\Parameters" RequireSecureNegotiate -Value 0 -Force
That's it. To turn secure negotiate back on, change '-Value 0' to '-Value 1' and the same whole string.
Ganymed4 is offline
post #6419 of 24577 Old 03-08-2013, 11:26 AM
Reefdvr27's Avatar
Quoted: 1567 Post(s)
Liked: 1046
I would like to know what will I gain by getting the 103. I have a Samsung BD-D5500 and thought about upgrading up to the oppo 103 because I hear what a great player oppo is. Now on the flip side I hear from some people I will see no difference in sound or picture over my current blu ray player, at least nothing I will notice anyway I am told. Can anyone tell what I can or cannot gain by laying down the cash for a new oppo 103. I lean more towards sound than picture and I have been told anything my blu player does not have, my AVR will reproduce it. I have a Denon AVR 3312ci.
Thank you in advance for any help.
Reefdvr27 is offline
post #6420 of 24577 Old 03-08-2013, 12:16 PM
JJMONIE's Avatar
You will not notice a huge difference in sound or picture quality over HDMI. I have a Denon 2311CI and noticed just a slight difference in PQ. I shut off all video processing on the Denon. Not $500 worth that's for sure.
The great thing about the Oppo is all the features it has to offer and they do have a great track record on firmware releases and customer service.
I have had the player just over 2 months and love it. The load times are super duper fast, great menu's and set up features. It also plays almost anything you can throw at it and has 2 HDMI in's that you can hook up other devices to take advantage of the players video processing or use it to extend the number of HDMI inputs your systems has.
My old player was a Panny BDP100 and like I said have noticed a small difference in PQ/AQ but the 103 blows it away in speed, ease of use and networking capabilities. If these extra's mean nothing to you, then keep what you have and enjoy.
JJ
JJ
JJMONIE is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
