Official OPPO BDP-103 Owner's Thread - Page 220 - AVS Forum | Home Theater Discussions And Reviews
 735Likes
post #6571 of 23790 Old 03-14-2013, 07:43 AM
jboileau's Avatar
In regards to earlier discussions about the 103 better (or not) audio quality over HDMI. Some point out out that bits are bits and no gain can be achieved from the 103 over any other player. I am not a guru, but my readings point to the contrary. From what I read, and would love that experts here on the forum chime in with opinions, the audio digital bitstream's cadence has an influence on the quality of what is heard.
I believe that the regularity of the audio bits are sent to the DA decoder in our AV receivers makes a difference. In this respect, the 103 compared to other makes and even to its predecessors has an extremely stable clock that delivers the most stable stream of bits. I unfortunatly do not remember which of the reviews I read about the 103 that had graphs showing this, but its out there somewhere.
Again, I am no expert but there seems to be evidence that show that audio sent through HDMI may not be equally good from any player and it might be wrong to think that because its digital it must all be the same.
Any opinions?
jboileau is online now
post #6572 of 23790 Old 03-14-2013, 07:51 AM
AndrewFG's Avatar
Quoted: 21 Post(s)
Liked: 24
Originally Posted by kriktsemaj99 View Post
It has been reported before (search the thread for 3020 or 2020). Oppo have a fix but it's not yet in the official firmware. For now I think you can use HDMI 2 from the Oppo as that doesn't cause the problem. Or decode in the player instead of sending a bitstream.
I don't think it makes any difference whether you use HDMI1 or HDMI2. But anyway until the bugfix comes out, the interim solution is to set up the Oppo to always output its audio in PCM (aka LPCM) rather than "bitstream". (The only downside of this is that you can't see on the receiver front panel what the original audio format was).
( And just so you know: the issue also applies to the Yamaha 820 too (what I have) and 1020 too )
AndrewFG is offline
post #6573 of 23790 Old 03-14-2013, 08:21 AM
AndrewFG's Avatar
Quoted: 21 Post(s)
Liked: 24
Originally Posted by dmusoke View Post
When i push mp3 audio from my laptop to the Oppo via WMP or KooRaRoo(KRR) server, the metadata is corrupted (see below in the Artist & Album fields)). But if i access these mp3 files directly from the Oppo, no corruption occurs using either server.
Hmmm. The following is a guess that may or may not be true. My guess is that the bug is due to Unicode text encoding issues. Your meta data tags are embedded in MP3 files in either 8-bit ANSI, or an ISO locale specific 8-bit codeset, or in Unicode (16-bit codeset). When the player opens your music files directly, it reads the tags directly from the file and displays them on screen. Whereas when the player gets the track via UPnP push, then the server is reading the tags from the file, converting the encoding to UTF-8 (a 8-bit plus codeset), and sending that to the player. So it could be that the Oppo doesn't understand UTF-8 too well (??)
=> What country are you in? And do your tags contain accented / non roman characters?
Now, when stream(push) FLAC files to the Oppo using the KRR server, metadata doesn't up at all. All the fields are clear. But when access the flac files directly from the Oppo, metadata shows up fine.
Yes. I think the Oppo implementation of UPnP is still a bit buggy. For me, it is interesting to see that your player is showing the album art and choking on the texts, because in my case the texts are fine, but the art is missing.
Anyway, I am personally a bit of an expert in UPnP (I am the author of Whitebear media server), so I intend (when I can find some time) to run the Oppo through my test programs and see if I can find out what is going wrong. If I do find out more (especially if I can see a solution), then I shall report back on this forum and also directly to Oppo service.
AndrewFG is offline
post #6574 of 23790 Old 03-14-2013, 08:58 AM
SeeMoreDigital's Avatar
Quoted: 436 Post(s)
Liked: 179
All my audio CD's and DVD-A's are backed up to Flac and stored on my Synology NAS. I can honestly say, I've not had any problems with text or image display via UPnP. All tags were generated/amended using Mp3tag.
Cheers
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #6575 of 23790 Old 03-14-2013, 09:28 AM
dazzerxxx's Avatar
Any opinions?
If you're referring to the effect of different types of jitter Miller Audio Research has published the results of its measurement suite on the 105 (link below). HDMI doesn't carry a discrete audio clock and the sink device is required to regenerate the audio sample clock from the HDMI pixel clock. The process the sink uses to achieve this can vary hence the accuracy of the audio sample clock can vary and may be influenced by factors beyond the interface.
There are no HDMI source/sink correlated jitter measurements but there are some for S/PDIF input details 48kHz/24 210 psec and 96kHz/24 447 psec. More info in the link below.
http://www.milleraudioresearch.com/avtech/index.html
dazzerxxx is offline
post #6576 of 23790 Old 03-14-2013, 09:44 AM
AndrewFG's Avatar
Quoted: 21 Post(s)
Liked: 24
Sorry but I am a bit confused by your comment...
If your Oppo is pulling the music files directly from a share folder on your NAS, then it is not using UPnP, so none of my above comments would be relevant to your case.
The OP's discussion related to problems when the files are being pushed to the player via a UPnP (DLNA) Media Server. So my question is a) are you accessing (pulling) your files from a NAS share, or b) are the files being pushed to you by a UPnP server, or even c) are you pulling the files from a UPnP server?
If a) then there is no need for further discussion because we are talking about completely different things. But if b) or c), can you please say which UPnP server are you using?
AndrewFG is offline
post #6577 of 23790 Old 03-14-2013, 10:02 AM
Quoted: 436 Post(s)
Liked: 179
Now I'm confused...
I was of the opinion that the Oppo provided two methods of file retrieval, UPnP (DLNA) and SMB (which is experimental). I'm pulling FLAC files from my Synology NAS which has it 'Media Server' enabled and is described as offering: -
"Media Server provides a multimedia service for you to browse and play the multimedia contents on Synology DiskStation via DLNA/UPnP home devices. With Media Server, you can easily connect those devices such as TV sets and stereo systems to your home network, and stream multimedia files stored on DiskStation to the devices to enjoy music, photos, and videos."
post #6578 of 23790 Old 03-14-2013, 10:24 AM
wse
wse's Avatar
Quoted: 1707 Post(s)
Liked: 680
Any opinions?
Had the BDP 95 for two years the sound was always outstanding!
wse is offline
post #6579 of 23790 Old 03-14-2013, 10:24 AM
JJMONIE's Avatar
Hi all,
I think I have found a minor bug with the 103. I will send this to Oppo as well.
This has happened maybe 5 times in two plus months.
I am using my WDTV Live Hub via HDMI in at the rear of the 103. When I send the signal with my Harmony One to "Watch WDTV" it will normally power everything on and go to the correct input of the 103 which is HDMI rear. On these 5 occasions, the player does go to the correct input, however there is no picture present. The WDTV is set to always on. When I press the input button on the remote, it does cycle through the choices but very slow and laggy. Once I select "BD" it is fine as the home screen shows up and then when I go back to "HDMI rear", it's fine. Not a big deal but figured I'd point it out. Thanks.
JJ
JJ
JJMONIE is offline
post #6580 of 23790 Old 03-14-2013, 10:51 AM
Sidetracked's Avatar
Liked: 25
Originally Posted by k00zmi4 View Post
Great point here, rdgrimes! NR is part of 'features' Qdeo was marketed/admired for. For some it's still great. For me Auto processing features like 'Adaptive Contrast Enhancement ' or 'Intelligent Color Remapping' mentioned here, are unacceptable. So, not necessarily 'just use HDMI-2' resolves this moment. A simple 'Source Direct' mode should do the trick bypassing the Qdeo. But......(I sure hope I'm wrong guys, but there's only one way to find out - user/owner tests)
Well, I used 'Source Direct' for almost a year with my BDP-95, and only a few months ago I noticed offset/oversample issue when Source Direct is used with HDMI-1. Now I suspect the fw issue with the Mediatek chip, but still as much as possible test results are needed from you guys to prove me right/wrong. So still appreciate your contribution to resolve the issue mentioned here The reason I posted at 103/105 forums is my hopefully soon 100 series upgrade. Thanx again...
In arlier posts it seems that on HDMI 1 the QEDO chip still does NR, etc even on 'source direct'. I believe this was even confirmed
by Oppo. If you do a search of the thread I'm sure you can find that discussion.
The reason some of us see this as all 'an issue' is that HDMI 2 seems to have problems with color in some set ups (which Oppo has indicated to me
in emails they see as a likely real issue, even though they are still investigating - saying "it was confirmed by beta testers"), so, for the moment,
there's no perfect solution for those who want an unmolested and clean signal. Although Oppo's awareness of the HDMI 2 issue gives me great
hope that will be solved in a future firmware. At that point there really will be no 'issue'.
Sidetracked is offline
post #6581 of 23790 Old 03-14-2013, 10:52 AM
rdgrimes's Avatar
Quoted: 1352 Post(s)
Liked: 653
Now I'm confused...
If your NAS is running a DNLA server AND offering file shares, you will see 2 entries on the Oppo "Network" screen. The DNLA server will show an icon with 2 little monitors. The SMB share will show an icon with 2 little computer towers. The DNLA server may alternatively show a custom icon, such as the Microsoft icon that WMP uses.
If you don't see 2 entries on your Network screen, then the NAS isn't doing both. Your NAS setup options may include the ability to enable/disable one or the other.
rdgrimes is offline
post #6582 of 23790 Old 03-14-2013, 10:55 AM
ckronengold's Avatar
Quoted: 51 Post(s)
I'm doing the same with Plex Media Server and finding all the same benefits.
Curious how you came to settle on Twonky vs Plex or the other media servers.
Originally Posted by yoguy1 View Post
I just want to share my experience using the 103 with an iMac running Twonky Media Server and the Twonky Beam app on my iPad. With this combination, I'm able to browse my music files using my iPad and push those files to the Oppo. Love being able to play my music without turning on the tv :-) I also find it quicker and more convenient to browse my media files (music, bluray mkv files, ...) with the iPad than directly with the Oppo file browser.
Media Room: Epson 5030 / Pioneer VSX-822 / OPPO-103
Paradigm Mini Monitors v2 / Atoms (rears) / CC-370
House Audio: Onkyo NR-709 & Monoprice in-wall speakers
Server: WHS2011, i5 2500k CPU
HTPC:Win8 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #6583 of 23790 Old 03-14-2013, 10:59 AM
rdgrimes's Avatar
Liked: 653
Nobody has reported any issues on HDMI-2 when watching live content. The color issues reported are on calibration discs or tests, and it hasn't been demonstrated to translate into visible effects.
In any case, the NR employed on HDMI-1 is not an "issue", it's what the Qdeo chip does. Some folks may not appreciate it, (and I am one of them), but its not broken - it just is.
Don't be surprised when you put a video processor into the video chain and the video winds up looking processed.
rdgrimes is offline
post #6584 of 23790 Old 03-14-2013, 11:23 AM
Shingster's Avatar
Got another MKV question here, but imo it seems like a pretty major problem: I was watching a MKV film earlier today and noticed very jerky camera pans and sure enough when I checked my output settings it was because the Oppo was outputting this 1080p 24fps file at 50fps. I then tried other MKV files and the results were always the same: The Oppo is converting every single MKV file I play into 50fps or 60fps (it can't even decide what framerate it wants, some films get converted to 60, some to 50)
Does anyone know what's going on here? I went into the video settings to try and force native 24fps out, but the player wouldn't do it! Blu-ray plays back just fine in 24fps. Can the oppo not handle 24fps in MKV files or something?
Shingster is offline
post #6585 of 23790 Old 03-14-2013, 11:23 AM
Quoted: 436 Post(s)
Liked: 179
Thanks for the confirmation. This is exactly what I'm seeing. And to confirm, my preferred method of file retrieval is via UPnP (DLNA) which displays the image and text 'meta-data' from all my Flac, MP3 and AAC (.M4A) files perfectly...
post #6586 of 23790 Old 03-14-2013, 11:27 AM
Quoted: 436 Post(s)
Liked: 179
Originally Posted by Shingster View Post
Got another MKV question here, but imo it seems like a pretty major problem: I was watching a MKV film earlier today and noticed very jerky camera pans and sure enough when I checked my output settings it was because the Oppo was outputting this 24fps file at 50fps. I then tried other MKV files and the results were always the same: The Oppo is converting every single MKV file I play into 50fps or 60fps (it can't even decide what framerate it wants, some films get converted to 60, some to 50)
Does anyone know what's going on here? I went into the video settings to try and force native 24fps out, but the player wouldn't do it! Can the oppo not handle 24fps in MKV files or something?
I've seen the Oppo behave strangely when fed some 720x576p25 .MKV sources. What does MediaInfo report about some of your problem sources?
post #6587 of 23790 Old 03-14-2013, 11:30 AM
Shingster's Avatar
Nothing that screams out to me as strange, simple 1080p@23.976Hz on all files.
post #6588 of 23790 Old 03-14-2013, 11:35 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 1904 Post(s)
Liked: 831
No, I do that all the time. As suggested, what does mkvinfo or mediainfo say about the file?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #6589 of 23790 Old 03-14-2013, 11:47 AM
Quoted: 436 Post(s)
Liked: 179
Hmmm...
Most of my Blu-ray back-ups are 1920x1080p23.976 placed within the .MKV container, complete with chapters. I have the Oppo's '1080p24 Output' option enabled along with 'Direct Source'. And all my Blu-ray back-ups are output at 24Hz smile.gif
Sadly, the same positive observation cannot be said for any of my 720x480p23.976 or 720x576p25.000 .MKV sources eek.gif
Shingster likes this.
post #6590 of 23790 Old 03-14-2013, 11:50 AM
wmcclain's Avatar
Liked: 831
No can do. HDMI doesn't have standard def 24hz.
-Bill
post #6591 of 23790 Old 03-14-2013, 11:57 AM
Josh Z's Avatar
Quoted: 1873 Post(s)
Liked: 1304
When you turn the NR feature on the video processor off, it is reasonable to be surprised when it doesn't actually turn it off.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is online now
post #6592 of 23790 Old 03-14-2013, 11:58 AM
Shingster's Avatar
Ah by mediainfo I thought you meant something else! Downloaded and installed and now realise that I had the resolution wrong! They were actually 1280x720@23.976fps. Is it 720p files that can't be played in 24fps??
post #6593 of 23790 Old 03-14-2013, 12:01 PM
wmcclain's Avatar
Liked: 831
Correct.
-Bill
post #6594 of 23790 Old 03-14-2013, 12:03 PM
Shingster's Avatar
Crikey, never knew that! Is it an HDMI thing? Also, how come one file is playing at 50fps and the other at 60fps?
post #6595 of 23790 Old 03-14-2013, 12:06 PM
hernanu's Avatar
Quoted: 495 Post(s)
Liked: 913
PAL = 50 fps (or factors of it), NTSC = 60 fps (or factors of it).
hernanu is offline
post #6596 of 23790 Old 03-14-2013, 12:07 PM
Quoted: 436 Post(s)
Liked: 179
-Bill
Indeed...
However, although all my 720x480p23.976 .MKV sources (with 16:9 aspect ratio signalling) are displayed at the correct 16:9 aspect ratio on my TV. All my 720x576p25.000 .MKV sources (with 16:9 aspect ratio signalling) are displayed at 4:3. And different containers yield different output results with the same video stream.
By-the-way... Has anybody managed to get the Oppo's 'DVD 24p Conversion' option to function?
post #6597 of 23790 Old 03-14-2013, 12:15 PM
Shingster's Avatar
But both files are 720p@23.976fps? Is the player deciding that one is PAL and the other NTSC, or is there something in the file that would specify this?
post #6598 of 23790 Old 03-14-2013, 12:19 PM
Quoted: 436 Post(s)
Liked: 179
I've not carried out any tests with 1280x720 resolution sources... It might be worth trying...
post #6599 of 23790 Old 03-14-2013, 12:22 PM
JJMONIE's Avatar
Originally Posted by JJMONIE View Post
Hi all,
JJ
Wow! Oppo Support is super fast! I heard they were good but within a couple hours here was their reply. May be useful to some of you with Harmony Remotes.
JJ
"You may want to give a slightly longer delay between the power on and the input command. The player will take about 9 seconds to fully initialize after being turned on, so delaying the INPUT command another 2 seconds may alleviate this issue in the future."
JJ
JJMONIE is offline
post #6600 of 23790 Old 03-14-2013, 12:23 PM
wmcclain's Avatar
Liked: 831
It's for NTSC DVD only and works fine for discs with film-based cadence.
-Bill
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
