Official OPPO BDP-103 Owner's Thread - Page 225 - AVS Forum | Home Theater Discussions And Reviews
 3145Likes
post #6721 of 24842 Old 03-19-2013, 07:21 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3396 Post(s)
Liked: 2651
Originally Posted by scottc1992 View Post
I am using imageburn. I have it unzipped as a folder, and burn it as such, but when I place it in the Oppo, it reads it as a data disc. Thank you, by the way! smile.gif
Don't unzip it. Leave the ISO file as is.
"In ImgBurn, go to 'Write image file to disc' and select the ISO image you downloaded."
That's OPPO's instructions for burning their own firmware to disc, but it the same procedure for any ISO file.
Must be CD-R for Superdisc, not a DVD.
-Bill
lanping09 likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #6722 of 24842 Old 03-19-2013, 07:34 AM
PlatinumSV's Avatar
Quoted: 280 Post(s)
Liked: 171
Originally Posted by erray View Post
I have this title and I just watched a little over an hour of it on my 103 and it played without ant problems.
Sorry I can't help you solve your problem.
Thank you for the response.
Joe
Sony XBR65A1E | Sony XBR75X940D | Fujitsu AVIAMO P65FT00AUB
PlatinumSV is offline
post #6723 of 24842 Old 03-19-2013, 07:56 AM
davehale's Avatar
Location: US, Earth, Milky Way Galaxy, Virgo SuperCluster
Quoted: 395 Post(s)
Liked: 351
AndrewFG
He seems to be saying that the player is properly responding to UPNP SSDP M-SEARCH discovery messages, but not sending SSDP NOTIFY "alive" messages (either not within its Cache-Control:max-age period, or just not frequently enough, or even perhaps not at all). This is a beginners level error...
Could this be the reason why both my OPPO's dont show up in my network streaming options in Windows 7? Discovery is on and all my other devices always show up. The OPPO's only show up as unknown devices. Sorry if I mis quoted.
Dave
Sony 65Z9D, OPPO 203, ATV4K, Denon X4300H, 7.1 setup
TCL P605, Denon 4311, BJC cables, EVGA 1080ti, Star Citizen
Ethernet everything, AT&T 24Mbps
davehale is offline
post #6724 of 24842 Old 03-19-2013, 07:58 AM
scottc1992's Avatar
I feel really dumb right now! I got it, thank you so much for the help. It worked!
scottc1992 is offline
post #6725 of 24842 Old 03-19-2013, 09:01 AM
jerrygene's Avatar
How does one clean the Oppo? Inside...any recommended commercial brand? Thanks
jerrygene is offline
post #6726 of 24842 Old 03-19-2013, 11:18 AM
AB Hancock's Avatar
Originally Posted by Bob Pariseau View Post
Sorry for the slow response -- some networking issues here. It sounds to me like you have external interference present on your chassis grounds. This is most commonly "ground loop" interference, which is garbage current that hops between your pieces of equipment along the shields of the cables connecting them, looking for a path back to ground so that current can flow. Your "hum" with the 103 would be a typical symptom of that. This garbage current can traverse devices even if they are powered off. Exactly what SYMPTOMS it produces depend on the pieces of equipment you have turned on and the path the current is using to get back to ground. It is quite common for the 3rd prong in a 3-prong power plug to be the path back to ground. Both the 103 and 105 have 3-prong plugs. Your older equipment may not. My guess at this point is that you have ground loop interference that is passing between your amps and the 105. It may have caused the hum you had with the 103, and it may be causing the pop you are hearing now due to "volume" being present when you come out of mute between tracks (even though the content itself is silent) -- that's what I meant by DC bias.
The trick to fixing ground loop interference is finding the source of the garbage current.
These days there are two common ways for this to happen (and other less-common ways). The single most common source of such garbage is stuff coming into your house on the cable shield of a cable or satellite TV feed wire. This can cause problems even when you are not viewing that TV feed. The check for this is simple: Temporarily disconnect the feed wire where it comes out of the wall. If that cures your noise then there are things you can do to fix it, starting with correcting the grounding of that feed where it ENTERS your house.
The second most common source arises if you are using more than one wall socket to power your set of equipment and if they are not all on the same circuit breaker. To check that disconnect everything from power except the OPPO and the amp, and temporarily plug the OPPO and the amp into the same wall socket -- directly, i.e., not through some sort of power conditioner. If the noise goes away, then try plugging the OPPO and the amp in "normally". If the noise is still gone, connect the rest of you gear to power (you can leave them turned off) one at a time checking for when the problem comes back.
if you have more than one circuit breaker feeding wall sockets in your listening room there's an easy way for this problem to happen. The power feed into your house is "3 phase power", which, simplified, means there are two different ways each circuit breaker can be connected to that power feed. Circuit breakers connected the opposite ways may easily have different "ground potential", which means if you've got two pieces of gear plugged into each of them, the gear will be operating at different ground potential. In typical circuit breaker boxes, breakers installed one above the other are connected to the opposite rails of the power feed -- and thus the problem. The fix, if this is the problem, is to have the electrician move the breakers feeding your theater so they are all on the same rail in that breaker box.
A less common problem is that some piece of gear in your set has a fault and is incorrectly presenting voltage on its chassis ground. This is not a good thing. Figuring out WHICH device might be doing that is tricky, as you have to connect different combos of gear in a logical fashion to figure out which device might be the culprit.
--Bob
Just got this Bob, thanks, and I'll run these tests--but an essential question remains: why is my Denon DVD-3910, 7.1 analogs to the same receiver, dead quiet at maximum, speaker-blowing volume and has no "pops" whatsoever? I asked Oppo this and they correctly guessed that I wasn't using my HDMI on the 3910. They seem to believe all of this is due to a handshake issue with the HDMI.
AB Hancock is offline
post #6727 of 24842 Old 03-19-2013, 11:39 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3777 Post(s)
Liked: 4916
^ Yes, that would be a natural reaction for these symptoms. HOWEVER, you just reported that the problem STILL exists even with ALL HDMI cables disconnected from the OPPO, right?
This is a critical question. We have to be clear on the answer. No HDMI cables connected to the OPPO -- not Inputs, not Outputs -- none. But the problem still exists on the Analog audio outs, right? If so, it can't be HDMI related.
Does your prior Denon player have a 3-prong power plug?
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #6728 of 24842 Old 03-19-2013, 12:56 PM
SteveCS's Avatar
I have an issue with my 103 that Oppo says has not been presented to them before now. I'm using 5.1 analog outs to a receiver, and then pre-out to amps. What I have discovered is that after playing something for over an hour (this has happened with blu-ray and Pandora), and I then pause the machine for 10-15 minutes (ice cream break!), the audio gets shot to hell upon restart. It will have devolved to a very faint tinny sound with huge amounts of static. If I wait long enough, the audio comes back. Sometimes it takes minutes. This has happened with different pre-amps and different amps. It almost sounds like an overheating issue. But my player sits alone on an open shelf in a 65-68 degree basement. For some reason, it took Opps 2 weeks and many e-mails before they would believe I had an issue. I finally got an RMA out of them, so the player goes back on Monday. Has anyone run into any similar audio issues?
SteveCS is online now
post #6729 of 24842 Old 03-19-2013, 01:20 PM
Read the FAQ!
Liked: 4916
^ First I've heard of anything like that. At a guess the player is having trouble coming out of Mute when you start it Playing again. That would be a very unusual sort of failure.
--Bob
post #6730 of 24842 Old 03-19-2013, 03:15 PM
amoergosum's Avatar
I've just received a reply from Oppo >>>
"The ability to completely disable or reduce the amount of Noise Reduction used by defaults is something that we are considering, but there are no guarantees that we will make any changes to the picture quality through additional firmware releases."
amoergosum is offline
post #6731 of 24842 Old 03-19-2013, 03:56 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
At least you have an easy workaround. Just space out your ice cream breaks so that you're eating ice cream between feature films. wink.gif
htwaits is offline
post #6732 of 24842 Old 03-19-2013, 04:40 PM
Rondog32837's Avatar
Quoted: 32 Post(s)
I am considering buying the Oppo103,but I have a Pioneer Elite plasma that can only show 1080I. I watch cable (Fios) and some netflix on an Apple TV. Would I see much benefit from this purchase or do I need 1080P or 3D?
Rondog
Rondog32837 is offline
post #6733 of 24842 Old 03-19-2013, 04:58 PM
Hi Deaf's Avatar
Quoted: 18 Post(s)
Liked: 30
Get a good 1080p display first, you may not even need the Oppo.
Sony 940E / Sony X800 / DTV 4K / Denon / Klipsch
Hi Deaf is offline
post #6734 of 24842 Old 03-19-2013, 05:28 PM
calpon's Avatar
Originally Posted by AndrewFG View Post
Hmmm. I don't want to be rude, but it sounds like he does not really know what he is talking about ;-)
Oppo needs to get themselves a copy of the UPnP Device Certification Test tool, which would have picked up such an elementary failure immediately (the SSDP discovery tests are the first ones to be run in the whole test suite). This tool is available to members of the UPnP implementers forum (www.upnp.org), but it seems that Oppo is not a member of that forum, so perhaps they are not completely committed to the technology (??)
EDIT: I write UPnP software myself, so I know intimately how an implementation of this standard should work, and I would be delighted to work with the Oppo guys to help them fix this player. So please PM me if you want to put me in contact with them directly...
This is the screenshot I sent to them:
calpon is offline
post #6735 of 24842 Old 03-19-2013, 05:51 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
The most direct path is to call them and make a specific offer.
htwaits is offline
post #6736 of 24842 Old 03-19-2013, 05:51 PM
dmusoke's Avatar
Quoted: 388 Post(s)
Liked: 192
Originally Posted by davehale View Post
AndrewFG
Dave
It shows up on my Win 7 laptop after i re-installed windows. It was erratic at best before that...
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #6737 of 24842 Old 03-19-2013, 05:53 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
The old "clean reinstall" fix. How many times have I had to do that since Windows was first introduced. wink.gif
htwaits is offline
post #6738 of 24842 Old 03-19-2013, 05:59 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
If you enjoy 3D then that amounts to an extra at some additional cost for glasses, and Blu-ray movies. Your call.
htwaits is offline
post #6739 of 24842 Old 03-19-2013, 08:39 PM
rdgrimes's Avatar
Quoted: 2475 Post(s)
Liked: 1785
The answer is the same for ANY question about buying an Oppo with concerns about picture or audio quality benefits. And that is that you should buy the Oppo for it's support for all disc formats and media files, networking capability, etc. None of that changes if you have an older display. If all you need is a BD/DVD player, get something cheaper.
rdgrimes is offline
post #6740 of 24842 Old 03-20-2013, 12:42 AM
Hi Deaf's Avatar
Quoted: 18 Post(s)
Liked: 30
Well, a BD player won't help him much if he doesn't have a 1080p display. Get a 1080p TV first, then a BD player.
Hi Deaf is offline
post #6741 of 24842 Old 03-20-2013, 03:38 AM
erray's Avatar
+1
erray is offline
post #6742 of 24842 Old 03-20-2013, 03:54 AM
Kruse's Avatar
Hi there
I have just bought the new BDP-103 bluray player which replaces my 3 year old BDP-83 player. I never had any trouble with the BDP-83, but this new one have a seriously problem with synchronization of the audio and video.
The new player is connected to the exact same equipment and in the same way like the old payer was HDMI 1 to my JVC projector and coaxial out (bit stream) to my older surround amplifier. This works perfectly before, but now with the BDP-103 there is a terrible problem with lip synchronization.
The BDP-103 was already completely updated with the newest firmware when it was delivered to me one week ago.
I can’t find any options in the setup menu which can help me, such as sound delaying for example.
I hope for your feedback, with some solution about what to do, because this out of sync did not work for me.
Kruse is offline
post #6743 of 24842 Old 03-20-2013, 05:20 AM
BillP's Avatar
Quoted: 277 Post(s)
Liked: 223
I disagree. I used to have a 720p DLP, and BluRay discs absolutely looked better than SD DVDs on that display. BluRay will always look better than SD if you have an HD display, no matter what the native resolution. That being said, a 1080p display is even better.
BillP is offline
post #6744 of 24842 Old 03-20-2013, 06:05 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
Could this be the reason why both my OPPO's dont show up in my network streaming options in Windows 7? ... The OPPO's only show up as unknown devices.
Yes, that would indeed explain it.
Windows uses a variety of mechanisms to discover neighbouring devices in the local network, and one of those mechanisms is UPnP. If the players show up as unknown devices in Windows, it probably means that one of the other mechanisms was able to discover the player (as some entity on the network having an IP address), but that Windows was not successful in using the UPnP mechanism to find out more about said device (i.e. it could not use UPnP Discovery & Description processes to learn that the device is a Digital Media Renderer "DMR").
When the UPnP Discovery & Description processes are fully supported, then a player will appear as a DMR in Windows Networking, and also under the "Play To" context menu in Windows Media Player, and Windows Explorer.
AndrewFG is offline
post #6745 of 24842 Old 03-20-2013, 06:10 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
Yup! The red lights explain it all. Confirming what I said in my prior post.
( As I said before, this is a pretty basic error that should never have gotten past their QC people... )
AndrewFG is offline
post #6746 of 24842 Old 03-20-2013, 06:16 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
Given the earlier post and screen shot, I would be most surprised if a Windows 7 re-install would fix it. The problem seems clearly to be an Oppo problem not a Windows one.
I don't know it for a fact, but it could just be possible that a Windows clean install might reset Windows into being more lenient towards mis-behaved UPnP devices, but one would assume that such leniency would wear off over time. Wait and see...
AndrewFG is offline
post #6747 of 24842 Old 03-20-2013, 07:03 AM
jdlynch's Avatar
Quoted: 197 Post(s)
Liked: 73
Question regarding analog outputs and the subwoofer output level:
I learned here that the subwoofer RCA output is 10 db less than the other channels.
I set the speakers in the oppo to large because I use speaker management in my pre-pro. Since my speaker settings in the Oppo are set to large, then , wouldn't all the bass information be directed into the main channels? I am trying to determine if I need to boost my sub output, in my pre/pro, by 10 db,
I do cross my speakers over at 80 hz in my pre/pro.
Current Equipment: Datasat LS10 w/ Atmos and DIRAC. Datasat RA7300, Aerial Acoustics LR5's (LCR), Aerial Acoustics LR3's (sides), RBH in-walls (rears), Seaton Submersive, Marantz VP15s1, 123" diag 16:9 Stewart Cima Neve screen, Oppo BDP-103.
jdlynch is offline
post #6748 of 24842 Old 03-20-2013, 07:16 AM
JazzGuyy's Avatar
Quoted: 346 Post(s)
Liked: 345
Yes, you would need the boost but depending on how your pre/pro works, your settings in the pre/pro may be meaningless. For many pre/pros using analog inputs bypasses all processing so that settings for crossover and distance inside the pre/pro have no effect. Same for any room correction. For some pre/pros the crossover settings will work but not distance settings. Finally, there are some pre/pros that re-digitize analog input and apply all their settings, including room correction. You need to find out exactly what your pre/pro does with signals to its analog inputs.
JazzGuyy is offline
post #6749 of 24842 Old 03-20-2013, 07:26 AM
jdlynch's Avatar
Quoted: 197 Post(s)
Liked: 73
Thanks Jazz-
I use a Lexicon MC-12 B which does allow me to adjust the sub output level.
jdlynch is offline
post #6750 of 24842 Old 03-20-2013, 08:32 AM
SteveCS's Avatar
We've been doing "Dinner and a movie" on Friday nights at my house. Like me, a bunch of older folks. Having no mid-movie breaks will be a challenge. I will get the 103 mailed out on Monday. Hopefully Oppo can find the problem.
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
