Official OPPO BDP-103 Owner's Thread - Page 228 - AVS Forum | Home Theater Discussions And Reviews
 852Likes
post #6811 of 24343 Old 03-23-2013, 01:10 AM
Coyote Waits
htwaits's Avatar
Quoted: 918 Post(s)
Liked: 2030
Originally Posted by vinnie97 View Post
Maybe its time to clear the persistent storage.
It could be. Let us know.
htwaits is offline
post #6812 of 24343 Old 03-23-2013, 01:27 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2164 Post(s)
Liked: 2737
Originally Posted by cdittmer View Post
Bob, it happens on virtually all of my BD discs. All Universal Studios and Paramount titles for sure. I tried some MGM/20th Century Fox titles and they all failed to load. The only disc recently that has worked is the Hobbit. I have erased my Persistent Storage and it made no difference. What I meant by "completely loading" was that I could see the IP address appear on my Oppo and successfully run the Connection Test prior to the disc getting to the part where the disc menus should appear, there didn't seem to be a delay on the Oppo's part in connecting to the network.
I did watch the LED display on the Oppo itself during the power up sequence and the Oppo had already started loading the BD (as evidenced by the display reading BDMV) before the network icon appeared (this was all before the Oppo Main Menu screen became visible on my TV). During the Quick Start power up sequence the BDMV reading and the network icon appear simultaneously (which makes sense if the network connection is maintained even during power down). It's almost like in Energy Efficient mode the Oppo is loading the disc too quickly and there should be a second or two delay to allow the network connection to complete.
The Universal and Paramount titles frequently phone home well before they get to loading the menus to see if there are new Previews to stream. Even if there is no networking problem, they don't necessarily find them -- the studios have backed off their early enthusiasm for doing that -- but the discs look anyway.
You may be right that the disc loading is happening a bit too soon for Energy Efficient compared to the Network startup, but (1) that shouldn't lock up a properly authored disc, and (2) if it were true it would be easy for OPPO to reproduce. Seriously. If they told you they tried and couldn't duplicate what you are reporting you can believe it. They really do try what they say they are trying. Now, it could be they have not completely duplicated your player settings and cabling -- I don't know what exchanges you've had with them clarifying that.
I don't happen to have any Universal or Paramount titles handy as I write this, but for the heck of it I decided to try this with "The Simpson's Movie", which is a FOX title.
I'm using HDMI 1 (only), at explicit 1080p with Split A/V, 1080p/24 AUTO, LPCM Audio, YCbCr 4:4:4, Deep Color OFF (Dithered), 16:9 Wide/Auto, TV System Multi, 3D Mode AUTO, HDMI CEC OFF, and Wifi networking, BD Live ON, My Network ON, Gracenote ON. I also have a test USB stick plugged into the front port.
I powered up, Erased Persistent Storage, set Energy Efficient, put the disc in the Open tray, and powered down -- which also closes the Tray without ever starting to load the disc.
I then powered up.
On the subsequent power up (Energy Efficient), the disc loaded past the Previews to Top Menu without any problem.
With the disc now loaded, I power cycled again (Energy Efficient) with the disc stil in the tray, and once again it loaded past the Previews to Top Menu without any problem.
At this point I'm going to suggest you take a bigger hammer to the problem. This is a bit painful, because you'll have to re-enter your account credentials for any services you are using, but I'm going to suggest you do a complete Reset of the player. This is a good "first thing" to try whenever the player is behaving oddly -- particularly if others can't reproduce what you are seeing. To do that:
1) Remove any disc from the Tray
2) Go into Setup and jot down your personal settings if you don't have them memorized
3) Erase Persistent Storage
4) Reset Factory Defaults > Reset Accounts and Settings
5) When the Reset completes, exit the Setup menu and power down the player.
6) Pull the power plug for about 10 seconds <-- Do Not Skip This Step
7) Power up and re-enter your personal settings
8) Power down once more. Settings are saved during the power down cycle.
Now check and see if the same behavior is happening.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #6813 of 24343 Old 03-23-2013, 01:37 AM
Read the FAQ!
Liked: 2737
This has probably (hopefully) been reported before, but is anyone noticing some BD titles loading the menu screen without the textual menus? Whenever this happens, stopping and replaying the disc (from the home menu/screen) always resolves it on the second try. It's a minor inconvenience but frustrating nonetheless (and effectively doubles the disc-loading times). Maybe its time to clear the persistent storage.
Perhaps a full Reset of the player if simply Erasing Persistent Storage doesn't do the trick -- see my post just above.
--Bob
post #6814 of 24343 Old 03-23-2013, 03:47 AM
Jacob305's Avatar
Quoted: 80 Post(s)
Liked: 48
I had issues with one blu ray. it was from paramount. it was the thor movie. it would not load up on either my oppo 93 or the ps3. I was able to get a replacement from paramount. the new replacement is working good so far. like I said it was just one title.
Jacob
Jacob305 is offline
post #6815 of 24343 Old 03-23-2013, 08:38 AM
Neo_Reloaded's Avatar
Anyone have any experience with the Bluraychip.dk PRO mod for the BDP-103?
I installed the chip and updated the Oppo firmware, then started to test the mod capabilities. The power button powers on the unit like normal, but the 1, 2, and 3 button (which are supposed to start the unit up in region A, B, or C, respectively) do not work well at all. Sometimes the player doesn't respond at all, and just stays off. Other times, it turns on but doesn't send any signal to the TV. Other times still, it turns on but appears to be loading veerrrrryyy slowly - keeping the large Oppo logo on the screen, and flashing as if changing resolutions, for a much longer time than usual before eventually getting to the home menu.
Once it finally does get to the home menu, the region has been changed, so technically it "works" - but the process getting there can require multiple restarts before the player loads up well. And even once it turns on correctly, the problem is not resolved - menus react sluggishly, future player power-ons can be equally slow, etc. Only after doing a factory reset in the player menu does the functionality return to normal. And then the issue starts all over again the next time I want to change regions.
I received the pro mod from bluraychip.dk well after 12/20/2012, but I followed their advice for attempting to update the mod's firmware anyway - to no avail. I put the files on the USB stick and loaded it into the front of the player, and the player just said USB IN and then did nothing with it - no updating, no power off. I also checked that both the player and the remote were set to remote code 1, and they were.
Any advice from someone who has successfully gotten this to work well?
side issue: What the heck button is "Setup"? The Oppo player menus reference this button, as does the mod chip instructions, but I cannot for the life of me find any button labeled "Setup" on the remote...
Neo_Reloaded is offline
post #6816 of 24343 Old 03-23-2013, 08:45 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2586 Post(s)
Liked: 1770
Lower left, above Resolution:
-Bill]
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #6817 of 24343 Old 03-23-2013, 08:49 AM
Doh, thanks. I guess after a night of troubleshooting my eyes were getting tired and continually glossed over the small buttons down there.
post #6818 of 24343 Old 03-23-2013, 03:10 PM
Ganymed4's Avatar
Quoted: 102 Post(s)
Liked: 80
I don't have experience with the pro mod kit but I know the connectors needed for this and read the installation pdf. You have to check very thoroughly, that the cables are connected correctly - must fit into the connector straight 90 degrees and not in any other angle. Also the connectors have a lock you have to push that the cables have contact.
I mean, this is just an idea but could be a reason why this is not working. I mean the flat cables without a connector attached.
In doubt, you can also contact them. But may be there is another reason, why your mod kit is not working. Just an idea.
I ordered the standard kit but my player has a different circuit board layout. In this layout the most important connector for the mod kit is missing and bluraychip.dk took it back. Also Oppo UK confirmed this layout change.
Good luck
Ganymed4 is offline
post #6819 of 24343 Old 03-23-2013, 04:16 PM
cdittmer's Avatar
See my post below. You are having the exact same problem I have been reporting. Please report this to Oppo as they have told me that is not a common problem. There are several posts on here now reporting this problem. If you contact them this will further illustrate that this is a more widespread problem than they believe.
Originally Posted by hifi59 View Post
My issues so far with the Bdp-103 (connected via Hdmi to my Yamaha Rx-A3020 receiver).i just installed the 3020 receiver. It replaced an Onkyo . Same symptoms with either receiver. Both the Oppo and the Yamaha have latest fw. Tv is Pioneer Kuro Elite.
1. I went to play Star Wars BR Phantom Menace. When the main menu appeared, there was no option to hit play ,select language,bonus features,etc. nothing! I ejected disc and tried again. It worked this time. Same thing happened the next day.
2. I have several BR discs so far (and likely many more) that no audio plays whether I am bitstreaming or sending PCM.
This even happened when I went to watch the VUDU trailer of The Hobbit yesterday.
Luckily, I have the Bdp-93 still. It does not have these issues.
I experience the same thing you do with Stars Wars. In fact I can replicate this on all of my BD's. For me the problem occurs when powering on the Oppo with any BD already in the tray. Once powered on the player automatically loads the disc but the BD menus do not appear. I have dealt with OPPO on this and they claim they cannot replicate the problem. There are several other users who have posted here with similar problems. Please contact OPPO as when I contacted them they claimed they have not heard from others about this problem.
To get around the problem I have found a few options which work:
1. Disabling Internet connectivity gets rid of the problem.
2. Have the Oppo start using Quick Start as opposed to Energy Efficient. This gets rid of the problem. I use this method as I like Quick Start anyways.
3. Instead of ejecting your disc, try hitting stop and restart the disc from the Oppo menu. This works as well.
Again, please contact OPPO as they do not believe this is a common problem but would also not admit that my player is defective. It definitely appears to be Java related. I'm hoping a future firmware release will fix this but am not holding my breath.
cdittmer is offline
post #6820 of 24343 Old 03-23-2013, 04:46 PM
cdittmer's Avatar
I have the Pro-Chip and it works well for me. When I originally installed it I was having issues but I discovered I hadn't reseated the wide flat cable properly. You may want to check all of your cable connections.
cdittmer is offline
post #6821 of 24343 Old 03-23-2013, 05:07 PM
cdittmer's Avatar
I then powered up.
--Bob
Bob, did everything as per your instructions above. It did not correct the problem. The discs that failed before still failed. I did try my copy of The Simpsons Movie (which I hadn't tested previously) and it did load properly, so apparently not all discs are affected as this and The Hobbit both work.. The Fox/MGM titles which weren't working last night were my James Bond titles. My two test discs (which always fail to load) are Indiana Jones and the Temple of Doom and Snow White & The Huntsmen (I learned about these titles on the forums here from other users). Oppo tried their copy of Indiana Jones and the Temple of Doom and could not replicate the problem. The problem exists for Indiana Jones and The Last Crusade as well (I didn't try Raiders). I also tested several other titles and found the same behaviour on Catch Me If You Can (Paramount), They Live (Shout Factory), several WWE Blu-rays etc. It happens more often than not.
Given the fact that in the last couple of days there have been 2 new posts from owners with the same exact same problem there has to be something to this issue. Is it possible there is a bad batch of players out there? There are now several owners in this forum alone reporting this behaviour.
My setup is similar but not identical to yours. I leave BD Live off (turning it on makes no difference, I have tried turning on and off all of the various network options, only the Internet option makes a difference), I connect via Ethernet but WiFi results in the same problem, I have a USB stick plugged into a back port (again unplugging it makes no difference), I also have a Pro Mod Chip (which I also disconnected with no difference noted).
Thanks again, I really appreciate your efforts.
Curt
cdittmer is offline
post #6822 of 24343 Old 03-23-2013, 06:47 PM
bcarroll01's Avatar
I have been having a problem with the sound on oppo playing blue ray titles. I have my oppo connected to my yamaha rx-a710 then to my tv. Recently the sound and picture have been out of sync. I am not sure how to go about fixing this. Any suggestions?
bcarroll01 is offline
post #6823 of 24343 Old 03-23-2013, 06:51 PM
Hi Deaf's Avatar
Is there a lip sync control on the Yamaha?
Panny 65VT50 / DTV Genie / OPPO 103 / Roku 3 / Denon 1613 / Klipsch Quintet 5.0
Hi Deaf is offline
post #6824 of 24343 Old 03-23-2013, 07:36 PM
DSperber's Avatar
Quoted: 224 Post(s)
Liked: 186
Are you running in "Split A/V" mode? Do you have video going to your display via HDMI-1 and audio going to your AVR via HDMI-2?
Or do you have both audio and video going to your AVR via HDMI-1? Sounds like this is your situation, from your problem description.
I've not experienced any lip-sync problem when playing BluRay movies, but that's because when I do watch BR movies I'm utilizing "Split A/V" with video out HDMI-1 and audio out HDMI-2. I have an external headphone system attached to HDMI-2 for when I want to do "serious watching and listening", as with BR movies. HDMI-1 video goes to my AVR and then on to either of two attached HDTV's for display.
I've only experienced lip-sync (and it is TERRIBLY ANNOYING, as it gets worse and worse over time) when I am NOT using both HDMI-1 and HDMI-2, i.e. when my external headphone system attached to HDMI-2 is powered off because I want to listen to sound through real speakers managed by my AVR. This triggers the 103 to move audio over to HDMI-1 so that both audio and video are now delivered out HDMI-1 to the AVR. And it is in this situation where I've seen lip-sync occur, when both audio and video are on HDMI-1 so that "Split A/V" is not in effect.
Note that I had thought it was tied to the use of external HDMI input, since it's really only when watching HDTV (from DVR through 103 external HDMI input and then on out the 103 to the AVR with both audio and video delivered via HDMI-1 to the AVR, for listening to HDTV sound via speakers) that I myself have ever noticed the lip-sync symptom. But if I activate audio on HDMI-2 (i.e. listening to HDTV audio via my external headphone system on HDMI-2) then I do NOT have a lip-sync problem.
So... the evidence points not to the use of external HDMI input to the 103 as the culprit. The evidence points to HDMI-1 being used for both audio and video (even if "Split A/V" is enabled, but when it is not active as HDMI-2 is powered off) as the culprit. I don't do that with BR movies as you apparently do (as I listen through headphones via HDMI-2 when watching BR movies) so I've not seen the symptom which you say you've got.
Anyway, there is an INSTANT WORKAROUND when this happens. When I am watching HDTV via DVR through the external HDMI input of the 103, and the lip-sync builds up to where it is obviously annoying, I just give a quick push of the "12-second skip-back" button or the "30-second skip-forward" button on my DVR's remote, possibly the two of them in sequence to get back to where I wanted to be watching.
Apparently just that brief break in digital audio coming from the DVR to the 103 BREAKS the flawed ongoing lip-sync situation, and restarts the 103 to once again be perfectly in-sync (at least until it possibly builds up again, at which time it's just rinse/repeat for the workaround trick).
This workaround trick for me with the DVR remote is 100% successful in getting audio/video back in sync coming out of the speakers. You could try a similar workaround with the 103's remote while watching BR movies, just to FF and then REW, to purge the buffers and restart from scratch.
DSperber is offline
post #6825 of 24343 Old 03-23-2013, 08:17 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Interesting, I also have the Pioneer Kuro Elite TV, maybe that's the commonality. wink.gif I have a Pioneer Elite receiver also (older, SC-05), with no such audio problems as you're experiencing, however. Star Wars (Attack Of The Clones, gah) was the disc that initially failed to load for me as well, interestingly enough. I haven't had a chance to try any of the above-mentioned (or typically recommended solutions) yet (BD-Live is enabled and I also have no mod chip).
vinnie97 is offline
post #6826 of 24343 Old 03-23-2013, 08:39 PM
I will attempt to reseat all cables and see if that helps. Was it obvious upon second look for you, or did the flat cables appear to be seated perfectly properly and were just off by some minute amount?
post #6827 of 24343 Old 03-23-2013, 09:15 PM
cdittmer's Avatar
I do not have a Pioneer Kuro Elite TV though my AVR is a Pioneer. Don't see how that would affect this problem.
cdittmer is offline
post #6828 of 24343 Old 03-23-2013, 09:16 PM
cdittmer's Avatar
It was not obvious upon second look. It looked fine. I just undid all the connnections, reseated them and then it worked perfectly.
cdittmer is offline
post #6829 of 24343 Old 03-24-2013, 12:39 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Sorry, must've misread your post in haste. Now I see, you quoted another in the same post who had my panel. The only difference between us being he had a Yamaha AVR and me a Pioneer AVR. The common link could be Pioneer-related and to possible HDMI revision incompatibilities (I get single audio/video dropouts when watching special features for instance).
vinnie97 is offline
post #6830 of 24343 Old 03-24-2013, 02:01 PM
hifi59's Avatar
So far I have had 100% issues with every disc I have thrown in this turd of a player. Now it's the classic no audio unless I switch my receiver to another input and then back to the Oppo. I tried turning off or on every thing possible in every combination. My Oppo 93 continues to work like a charm. It never had issue on this level,then again,nothing I have every owned has. You think I'm a bit disappointed?
If you're talkin, you ain't learnin.
hifi59 is offline
post #6831 of 24343 Old 03-24-2013, 02:06 PM
hifi59's Avatar
The "commonality" is that we all own this sorry excuse of a player.
hifi59 is offline
post #6832 of 24343 Old 03-24-2013, 02:15 PM
wmcclain's Avatar
Liked: 1770
Are you asking us for help? Have you asked OPPO for help? Have you thought of returning it and moving on to something else?
-Bill
post #6833 of 24343 Old 03-24-2013, 02:25 PM
SeeMoreDigital's Avatar
Quoted: 464 Post(s)
Liked: 194
Out of interest. When were these Pioneer Kuro Elite TV made. And when was their last firmware update?
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is online now
post #6834 of 24343 Old 03-24-2013, 02:29 PM
Coyote Waits
htwaits's Avatar
Quoted: 918 Post(s)
Liked: 2030
I've high lighted the only thing that's clear about your post other than your anger. It's also clear that you don't want help because you've provided no information about what's causing your anger.
EDIT: I've gone back and read your 103 posts so I understand that you sent an email to OPPO. I don't know if you got a reply. I also know that what ever your problem is, it's happening with all your Blu-ray disks. I also know that you think that you've tried every possible combination of settings. I don't know if you've followed a systematic method of diagnosing your problem, with or without help from OPPO.
It seems to an ill informed outsider that your problem is either a defective OPPO or there is something wrong with your setup.
htwaits is offline
post #6835 of 24343 Old 03-24-2013, 02:32 PM
Coyote Waits
htwaits's Avatar
Quoted: 918 Post(s)
Liked: 2030
Very early 2009 or sometime in 2008.
htwaits is offline
post #6836 of 24343 Old 03-24-2013, 02:40 PM
Hi Deaf's Avatar
Hi Deaf is offline
post #6837 of 24343 Old 03-24-2013, 02:48 PM
Coyote Waits
htwaits's Avatar
Quoted: 918 Post(s)
Liked: 2030
Originally Posted by Hi Deaf View Post
htwaits is offline
post #6838 of 24343 Old 03-24-2013, 03:23 PM
fookoo_2010's Avatar
Quoted: 231 Post(s)
Liked: 80
I don't have any such problems with my 103 and have had it since it became available from oppo in late 2012. The obvious thing to do is make a toll call to oppo in California: (650) 961-1118, during the week. That is a lot faster than e-mail.
fookoo_2010 is offline
post #6839 of 24343 Old 03-24-2013, 03:25 PM
hifi59's Avatar
-Bill
No Bill,not asking for help today. Just another voice of discontentment and frustration with this player.
Your response to everyone who is not happy with their Oppo in its current state is to suggest they move on to another product.
I'm not moving on at this time. This player is not performing up to their usual standards. Is this thread this long this early in the game because its working like a charm ?
I have informed Oppo of my issues. Their response was rather generic. With many similar complaints on this forum,I would think at this point in time that they would at least acknowledge the issues and state that a fix is being worked on.
All I know as John Q Custumer and not an Oppo beta tester, is that my Oppo 93 does not nor ever did have issues like these. So up to this point, it is "a turd" to me until its fixed. I guess I feel that they should have a firm grip on these problems by now and not tell people "we never heard of this" as others have mentioned here.
I give Oppo a big thumbs up for customer support,but issues at this level rarely,if ever, occur with the major manufacturers. Yes,they have their share but not like these (at least in my experience).
hifi59 is offline
post #6840 of 24343 Old 03-24-2013, 03:34 PM
wmcclain's Avatar
Liked: 1770
-Bill
This is not OPPO's complaint department. Technical Q&A only here. If you need help we'll try but your attitude makes it difficult.
Sure makes like easier.
-Bill
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
