Official OPPO BDP-103 Owner's Thread - Page 236 - AVS Forum | Home Theater Discussions And Reviews
 872Likes
Old 03-28-2013, 11:47 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2770 Post(s)
Liked: 1995
Originally Posted by Reefdvr27 View Post
New 103 owner here. I just received my new oppo last night via the AVS store. I do have a question to who can answer. I was reading the set up in the manual and I see that two HDMI's are suggested for set up. Is this really necessary? I mean how does the AVR recognize both cables? I am pairing this to a new Denon AVR 4520. Sorry, but this is the first time I seen this on a BD player. Thanks.
Two HDMI are mostly for people who have 3D displays but receivers that do not pass HDMI 1.4. In that case you can run HDMI1 to the display and HDMI2 to the receiver.
Now and then we see cases were troublesome HDMI handshaking behavior is improved by using two cables, but the most common case is for one cable to do it all.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Old 03-28-2013, 11:55 AM
bluechunks's Avatar
Quoted: 98 Post(s)
Liked: 126
Originally Posted by astrogeeker View Post
anyone tried pushing music to the oppo via DLNA DMR (i'm using twonky) with the new firmware? this is very flakey on the current firmware.. hoping its solid with the new beta firmware. specifically, the oppo doesn't broadcast itself very consistently, so tools that list available devices to push content to sometimes see the oppo and sometimes do not. it usually works on a fresh restart of the 103, but after using the 103 for blu ray or other video playback, it will not show up as an available output source anymore.
I was experiencing some the same symptoms when attempting to use the DMR functionally of my NAS. Using the beta with the DMR function of my Synology NAS (Audio Station) and the Synology iPhone App (DS Audio) the difference was immediate. The Oppo is now apparently broadcasting itself properly because the 103 is consistently showing up. (Knock on wood.)
Caveat: I have not tried any other DLNA servers (yet) so YMMV.
lanping09 likes this.
__________
4K madness: Visio P65-C1 (4K HDR10 & DV) / Oppo UDP-203 / Nvidia Shield / Roku Ultra / TiVo Bolt
1080P: Apple TV (4th gen) & Intel Nuc (LibreElec/Kodi)
Yamaha RX-A2060 5.1.4 / KEF iQ & Speakercraft (Ceiling) - Celerity 50' Fiber Optic HDMI between AVR and TV
bluechunks is online now
Old 03-28-2013, 12:12 PM
SergeantYnot's Avatar
Liked: 31
I have the exact same setup as you. Unless you are using dual outputs (TV and Projector), just connect HDMI 1 to your 4520.
SergeantYnot is offline
Old 03-28-2013, 12:15 PM
DSperber's Avatar
Quoted: 229 Post(s)
Liked: 186
Originally Posted by wse View Post
Of course.
I've now phoned Oppo to give them my own observations (all tied to the use of external HDMI input source from DVR, which for me is actually a Linksys DMA2100 Windows Media Center Extender), and they have recorded them:
(1) with beta firmware, much slower "audio recovery" time when using 30-second skip-forward on DVR remote, from brief disappearance of audio until its reappearance
(2) with beta firmware, Oppo sometimes reverts to main LOGO screen when pushing 30-second skip-forward on DVR remote several times in quick succession (to pass through a several minute commercial pod)
(3) with beta firmware, non-smooth "staccato" video, most visible when motion onscreen. Others have certainly observed this and also reported it to Oppo.
(4) since 103 product introduction, ever-growing accumulated larger-and-larger lip-sync audio/video problem tied to use of external HDMI input and "Split A/V" but with HDMI-2 external audio system powered off so that both audio+video are sent out HDMI-1; starts at 0, but begins to accumulate and get worse and worse; can be vaporized (temporarily anyway) by pushing 30-second skip-forward or 15-second skip-back, or PAUSE/PLAY, or anything else on DVR remote which briefly causes audio to disappear so that when audio returns all buffers (which produced the audio/video lip-sync problem) have been flushed and start anew with audio and video at least once again initially in-sync.
On TWO (very rare) occasions, I have also seen the lip-sync problem (4) occur EVEN WITH HDMI-2 ACTIVE, WHEN USING MY EXTERNAL HEADPHONE SYSTEM! This was a stunning surprise, and I was NOT ever able to make it go away... not by using the usual button pushes on the DVR remote, nor even by turning off everything and turning it on. It appeared to be PERMANENT! However after finally turning everything off for the night and letting all equipment "cool down", the next day the problem had disappeared. In fact, the Oppo had been powered on (and thus heated up) for a very extended period when these situations involving lip-sync on HDMI-2, so maybe it was somehow tied to overheating.
DSperber is online now
Old 03-28-2013, 12:22 PM
pav56's Avatar
Originally Posted by wmcclain View Post
You are producing BDMV or AVCHD folders? That will no longer work.
You can produce M2TS files with tsMuxeR which will still work. That container does not have chapter support, though.
-Bill
According to http://en.wikipedia.org/wiki/AVCHD, BDMV directory is located in the AVCHD folder. I used BDMV folder in the root for backups on a directly connected external HD and BDMV placed in AVCHD folder for SMB. My question is: what the difference between homemade AVCHD from camcorder and movie backup? Chapters? Menu presence? 8.3 file format?
pav56 is offline
Old 03-28-2013, 12:25 PM
DSperber's Avatar
Quoted: 229 Post(s)
Liked: 186
I have a particular use of this "Split A/V" capability, where video-only is sent out HDMI-1 to the HDTV and audio-only (decoded LPCM) is sent out HDMI-2 to my external headphone audio system (which requires decoded LPCM).
HDMI-1 actually goes through my Yamaha AVR, so that when the headphone system is powered off (and thus HDMI-2 is inactive) and I want to listen through speakers managed by the AVR, the Oppo moves audio over to HDMI-1 so that both audio and video are delivered out HDMI-1 to the AVR. When the external headphone system is powered on only video arrives from HDMI-1 to the AVR. Sending HDMI-1 out of the Oppo to the AVR allows me to make use of speakers, when HDMI-2 is powered off.
I also have two HDTV's connected to the two HDMI outputs on the Yamaha AVR, so I can watch on either HDTV depending on situation. That's another reason HDMI-1 out of the Oppo goes to the AVR rather than directly to the HDTV (if I only had one).
Old 03-28-2013, 12:32 PM
wmcclain's Avatar
Liked: 1995
I have never heard what makes the difference. AVCHD is parallel to Blu-ray video but no one ever said the structures would be identical. Somehow the player detects that the BDMV or AVCHD/BDMV comes from a copy protected source and will not play it back.
If you can research this and discover how to convert BR backups to playable AVCHD the smart thing would be to keep it to yourself so the technique doesn't get out and come to the studios' attention.
-Bill
Old 03-28-2013, 12:48 PM
Recstar24's Avatar
Dsperber,
Thanks for chiming in and reporting to oppo. Customer service let me know that engineering will be working on the "staccato" motion issue for the future firmware release.
In the meantime it appears our hdmi inputs are essentially "bricked". Disappointing.
Recstar24 is offline
Old 03-28-2013, 01:12 PM
Reefdvr27's Avatar
Quoted: 1567 Post(s)
Liked: 1045
-Bill
Thanks guys! I believe for now that I will just use one cable till I get all this stuff figured out. Thanks again.
Reefdvr27 is offline
Old 03-28-2013, 01:46 PM - Thread Starter
Neuromancer's Avatar
Quoted: 83 Post(s)
Liked: 319
Originally Posted by kennyboy2 View Post
I am at a loss as to how to get my Oppo to access my music and photos. I even set up a password but the Oppo 105 won't accept it. I downloaded oShare but there are no instructions and I've no clue as to how to use it.
Open oShare and then press the huge + button. Select a folder you want to share then OK. The program will now index all files and folders.
On the player select Network then select oShare. Select either Music, Movies or Photos depending on the type of media you want to playback. Now browse your files and folders.
Neuromancer is offline
Old 03-28-2013, 02:08 PM
kennyboy2's Avatar
Problem finally solved. My Actiontec M1424WR router provided by Verizon FIOS was blocking my DLNA. After trying a second computer, I concluded that my PC was probably not at fault. I had to disable the IGMP Proxy in my router. If I had only known this before I racked my brain trying to resolve the issue.
kennyboy2 is offline
Old 03-28-2013, 03:38 PM - Thread Starter
Quoted: 83 Post(s)
Liked: 319
Good to know that you were able to resolve your issue, though it is odd that any kind of Proxy was enabled by default.
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3135
I saw this mentioned the other day, but only noticed it for myself last night. Too late I'm afraid, as the new beta is already installed. So I look forward to any update you get from Oppo on when/if/how this can be corrected.
I also noticed two other issues (which I have not reported to Oppo). One is when hitting the 30-second skip-forward button on the DVR remote it takes much longer for the audio to return (after disappearing momentarily until the FF skip action stops) than it used to. This ALWAYS now occurs, and the slowdown to get audio back is quite annoying.
The second is that it is not uncommon now for hitting the 30-second skip-forward a few times in succession to trigger the Oppo to return back to the main LOGO screen and lose contact with the HDMI input from the DVR. This then requires a whole series of recovery steps (as if I were starting from scratch power-on again) to get back to the rear external HDMI input on screen.
Making this second symptom even worse is the fact that several times there has been NO AUDIO even after getting video restored from the rear HDMI input source. Recovery on this one is either (a) put a BluRay disk in and change input to play that movie briefly, which restores audio so that when you go back to external HDMI input there is once again audio, or (b) power off the Oppo, so that when powering it back on and getting external HDMI input restores there is once again audio.
Given the appearance of symptom 1, the fact that symptom 2 also has an audio component to it (i.e. its disappearance!!) is not entirely surprising.
I have seen symptom 2 occur quite a bit since installing the beta firmware a few days ago.
I finally gave up on using it as a VP. Had lip sync quirks since Oct...
65E6P / UB900 / X800
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is online now
Old 03-28-2013, 03:39 PM
jmschnur's Avatar
Will oshare handle dsd files on a PC ?
jmschnur is offline
Old 03-28-2013, 03:47 PM
wmcclain's Avatar
Liked: 1995
I haven't tried it but I don't believe DSD will work over DLNA. Yet?
-Bill
Old 03-28-2013, 03:58 PM
Kal Rubinson's Avatar
Quoted: 690 Post(s)
Liked: 470
The beauty of oShare is that it is that it will share whatever is in the chosen folders.
The Oppo's ethernet input will not accept DSD files (yet, I hope).
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
Old 03-28-2013, 05:43 PM
darthkringle's Avatar
Originally Posted by darthkringle View Post
Has anyone actually tested HDMI 1 to see if the NR and/or Sharpness adjustments are in fact not altered in the new firmware? I could "see" a scenario (no pun intended) where Oppo might address this to some degree without advertising it since it is not actually thought to be an "issue" and that they likely would open up the door to be expected to fix every user's perceived imperfections with firmware. With that said, I do think HDMI 1 is a touch "soft" and would love to know if anyone with the new firmware has confirmed that nothing in fact changed there.
Also, if I use an external USB drive with a large library of .wav files, what does the "CUE file" change give me in reality? All of my WAV files were ripped via dbpoweramp and I had to remove the "tags" that it embedded as they created a static noise at the end of each track. Does this CUE change as part of the firmware do either of the following:
Eliminate the "static" at the end of each track (Which I think could have been a side effect of the tagging from dbpoweramp on WAV files)
Read the information as Tags and therefore take precedence over Gracenote?
And yes, I know about FLAC, but I want to use WAV for my own reasons.
Thanks everyone as always. This is a fantastic group/thread.
Guys- Any feedback on either of these questions/comments? Thanks again
darthkringle is offline
Old 03-28-2013, 05:51 PM
Jano18's Avatar
Originally Posted by Sidetracked View Post
Indeed, part of what I like about Jeff so much (having worked with other calibrators) is that he seems most concerned with real world
results, over test results. I also like that he's willing to challenge mainstream thinking about calibration. He made certain decisions
in calibrating my Kuro that were unordodox, but ultimately led to a better, more accurate picture, at least to my eye with material I
knew intimately. I know this is off-topic,but, what the heck, I figure it's worth giving him a shout-out. smile.gif
Jeff calibrated my 141 also. He advised me to use 4:4:4 because there is a RGB bug with the 141. He is a very smart guy I trust him & he did a fantastic job on my Kuro & 7.1 system. It has never looked or sounded better. He put in a Star Wars movie in my old 93 & I thought it was BD until he told me it was just a DVD.
Jano18 is offline
Old 03-28-2013, 06:43 PM
Manic_D's Avatar
Quoted: 13 Post(s)
Just tested a DSD file over SMB & that works just fine.
I think foobar supports DSD it in some way over DLNA, but I have not tried it myself.
Manic_D is offline
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2045
You've shown amazing patients and restraint to have been at AVS for six years and posted only a little over four times a year. The answers you seek will come, as they have in the past. wink.gif
htwaits is offline
Old 03-28-2013, 06:56 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2045
Jeff calibrated my 141 also. He advised me to use 4:4:4 because there is a RGB bug with the 141. He is a vey smart guy I trust him & he did a fantastic job on my Kuro & 7.1 system. It has never looked or sounded better. He put in a Star Wars movie in my old 93 & I thought it was BD until he told me it was just a DVD.
Thanks for your calibration report. If you've posted in the owner's thread for the 141, let me know where it is and I'll link it with this one in the flat panel (post number two) lists that are linked in the signature area at the bottom of my post.
htwaits is offline
Old 03-28-2013, 07:19 PM
jmschnur's Avatar
Thanks. We can wait and hope.
Joel
jmschnur is offline
Old 03-28-2013, 07:23 PM
Manic_D's Avatar
Quoted: 13 Post(s)
Joel
No need to wait. As I just posted, it works over SMB.
Manic_D is offline
Old 03-28-2013, 07:25 PM
Jano18's Avatar
I never made a post in the owners thread, but feel free to quote me in the flat panel owners thread.
Jano18 is offline
Old 03-28-2013, 07:29 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2045
htwaits is offline
Old 03-28-2013, 07:32 PM - Thread Starter
Quoted: 83 Post(s)
Liked: 319
No change in this firmware to any of the default Picture Adjustment values.
Gapless audio playback and the ability to create a persistent playlist.
Old 03-28-2013, 07:50 PM
Quoted: 690 Post(s)
Liked: 470
Can you describe what you did?  You selected a DSF/DFF file from the Oppo's GUI?  When I try that with Foobar or oShare, the DSF/DFF files do not appear and their folders seem to be empty.
Kal Rubinson
Old 03-28-2013, 08:15 PM
Arrius's Avatar
As for Manic_D it worked for me too last night.
I just access directly my DSF/DFF files (stored in my NAS) from the OPPO GUI (network) and play them.
As they are only 2 channels I can't comment on multichannel though.
As for pushing over DLNA, I'll experiment with JRiver MC18 (my one and only music player/server) tonight when back home.
Kami
Arrius is offline
Old 03-28-2013, 08:25 PM
Arrius's Avatar
I just access directly my DSF/DFF files (stored in my NAS) from the OPPO GUI (network) and play them....
To better reply Kal request, I have SMB activated on my NAS, so then I have the choice to access my files either through MC18 or directly from the NAS.
It is like having 2 servers, one "soft" through MC18 and one "hard" through the NAS itself.
You then need to select the SMB ("hard") one (bearing your NAS network name) rather than the "soft". Depending on your music collection size, it might be a pain (long) to navigate, but worth it sound wise!
I'll try to post a picture if I am not clear enough...
Best
Kami
Arrius is offline
Old 03-28-2013, 08:31 PM
Quoted: 690 Post(s)
Liked: 470
Wow, that works.  I had been pushing files from MC18 and also pulling them from various DLNA sources with no success.  I switched to SMB and I can stream DFF, stereo or multichannel.
Kal Rubinson
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
