Official OPPO BDP-103 Owner's Thread - Page 247 - AVS Forum | Home Theater Discussions And Reviews
 910Likes
post #7381 of 24719 Old 04-04-2013, 10:39 AM
Flave's Avatar
If I understand the "Split A/V" feature correctly, HDMI1 is used to send video to my TV and HDMI2 to send audio to my AVR. But I notice that audio is also being sent to my TV on HDMI1. Was I wrong in assuming that this connection would be video only? If so, is there a setting to disable audio on HDMI1 in Split A/V mode? TIA.
Flave is offline
post #7382 of 24719 Old 04-04-2013, 10:42 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3174 Post(s)
Liked: 2456
Originally Posted by Flave View Post
Originally Posted by wmcclain View Post
There is a trick to make recent Samba servers sort correctly...
-Bill
Would you mind sharing this trick? Thanks.
In /etc/samba/smb.conf, place this line under "[global]":
Code:
    vfs objects = dirsort
Restart the server.
I believe this requires Samba v3.3.3 or later.
Someone tried it on a NAS and couldn't get it to work. We suspected that some administrative tool on the NAS didn't like configuration files being changed behind the scenes.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #7383 of 24719 Old 04-04-2013, 11:24 AM
rdgrimes's Avatar
Quoted: 2343 Post(s)
Liked: 1673
The two little servers icon is SMB.
DLNA servers provide their own icons, and so will be different for each type. Is there a generic icon? I forget.
-Bill
The generic DNLA icon on the Oppo is 2 little PC monitors. The Microsoft icon is always going to be the retarded WMP server, which can be shut off without affecting SMB.
rdgrimes is online now
post #7384 of 24719 Old 04-04-2013, 11:54 AM
Tornado Red's Avatar
Quoted: 389 Post(s)
Liked: 448
My set up is split like yours. HDMI will carry both audio and video from the source if both are available which they would be with the Oppo's 2 HDMI outputs. So the short answer is to just keep the volume turned off on your display if you want to use your AVR to control the audio.
Tornado Red is offline
post #7385 of 24719 Old 04-04-2013, 12:12 PM
DSperber's Avatar
Quoted: 237 Post(s)
Liked: 191
This is incorrect. If your HDMI-2 connection is "powered off", then both audio and video will be output from HDMI-1. But if HDMI-2 is "powered on" and you have "Split A/V" set, then HDMI-1 will be video-only. HDMI-2 will be both audio and video.
If you have "Split A/V" set, according to page 53 of the PDF user manual:
2. Dual HDMI Output: Allows you to select the output mode when both HDMI Output ports are in
use. If only one HDMI Output is active, this selection will not apply.
Split A/V (recommended) – Use HDMI 1 OUT as the dedicated video output port and
HDMI 2 OUT as the dedicated audio output port. This setting will ensure the best possible
picture quality and the highest possible audio resolution.
Dual Display – Send digital audio and video signals to both HDMI Outputs simultaneously.
This setting is only recommended when two HDMI displays are required, since the surround
sound audio signal may be down-mixed to stereo and the original audio quality may be lost.
In Split A/V mode, HDMI 1 OUT has video only with no audio, but HDMI 2 OUT will have audio
and possibly video. This is because HDMI embeds audio into video data so there must always
be a video signal, even if it’s only a blank screen, to carry audio through.
DSperber is offline
post #7386 of 24719 Old 04-04-2013, 12:43 PM
Quoted: 389 Post(s)
Liked: 448
Sorry for the wrong info. So it sounds like the OP has his player set to split mode, but is still getting audio from HDMI 1 to the display. Shouldn't that be automatically off if he's chosen split and is running audio via HDMI 2?
post #7387 of 24719 Old 04-04-2013, 01:03 PM
scottc1992's Avatar
O.K., I get no audio while playing some video files thru oshare (I am new at this, so bear with my ignorance), I think WMV files play ok, also 24/192 HD tracks don't play thru oshare, any guidance would be appreciated.
scottc1992 is offline
post #7388 of 24719 Old 04-04-2013, 01:03 PM
Flave's Avatar
Exactly -- both my HDMI ports are connected to an active powered-on device but I'm still getting audio on HDMI1.
Flave is offline
post #7389 of 24719 Old 04-04-2013, 01:08 PM
wmcclain's Avatar
Liked: 2456
Could you test the files on local storage to eliminate the DLNA server as a factor?
If still no good, post the mediainfo (http://mediainfo.sourceforge.net/en) results for the problem files.
What type of files are the HD tracks?
-Bill
post #7390 of 24719 Old 04-04-2013, 01:10 PM
Flave's Avatar
-Bill
Any idea how to check my Samba version?
And I think you're right about not being able to change the file -- it seems to take the edit but when I reboot the edit's gone from the config file. Any way around this?
Flave is offline
post #7391 of 24719 Old 04-04-2013, 01:14 PM
wmcclain's Avatar
Liked: 2456
This is on an NAS? I can only suggest finding a support forum for your model, or asking the vendor.
My experience is on Linux, which (of course!) always works for everything.
-Bill
post #7392 of 24719 Old 04-04-2013, 01:18 PM
scottc1992's Avatar
Thanks Bill, the 24/192 are FLAC files and the video files are mp4. I did notice that 24/96 FLAC files will play though, at least the one set of 24/96 files I have play.
post #7393 of 24719 Old 04-04-2013, 01:20 PM
Flave's Avatar
-Bill
Yes this is on a DNS-323 running ffp. Will investigate further as you suggest. Thanks Bill.
Flave is offline
post #7394 of 24719 Old 04-04-2013, 01:34 PM
SeeMoreDigital's Avatar
Quoted: 487 Post(s)
Liked: 207
Hmmm...
Unfortunately, this SMB Samba trick does not explain how/why all my Mediatek and Sigma A/V chip-set based media players are able to list SMB shared directories (stored on my Synology NAS) in the correct way!
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is online now
post #7395 of 24719 Old 04-04-2013, 01:38 PM
wmcclain's Avatar
Liked: 2456
Originally Posted by SeeMoreDigital View Post
Hmmm...
Well, no. One thing has nothing to do with the other.
The OPPO is not sorting SMB listings and the other devices are. If you can get the server to sort the listings before sending them then the OPPO does not need to.
But the ultimate solution is for the player to sort. We went through the same thing on USB devices ages ago on earlier players.
-Bill
post #7396 of 24719 Old 04-04-2013, 01:49 PM
Quoted: 487 Post(s)
Liked: 207
Arrrgh... It all so infuriating!
post #7397 of 24719 Old 04-04-2013, 04:20 PM
DSperber's Avatar
Quoted: 237 Post(s)
Liked: 191
Certainly shouldn't be happening.
I'd call Oppo for support, and to decide if your unit is defective or if there's something else configured incorrectly in your setup.
But in my mind, that's exactly what "Split A/V" is for, as long as the HDMI-2 device is sensed and powered on, HDMI-1 should be video-only. That's the design.
DSperber is offline
post #7398 of 24719 Old 04-04-2013, 04:21 PM
Flave's Avatar
Code:
Restart the server.
-Bill
Bill, I just wanted to tell you that I managed to upgrade my NAS's Samba to 3.4.6. I then added that line in the smb.conf file and voila -- it worked! I now have beautifully sorted files when accessing my NAS from the Oppo using SMB. Thanks again.
And if you're at all interested why you can't change the conf file on some NAS's it's because on these machines the conf file is actually loaded from NVRAM (and placed in /etc/samba) when the NAS boots. So you can make all the changes you want but when you reboot the file gets clobbered. This is probably done so you can't inadvertently hose SMB -- make a mistake in that conf file and you've lost your SMB access.
Flave is offline
post #7399 of 24719 Old 04-05-2013, 12:22 AM
globalnomad's Avatar
I haven't ventured into the beta firmware, but is there any update on whether YouTube will now remember your account information and device pairings across reboots?
globalnomad is offline
post #7400 of 24719 Old 04-05-2013, 01:36 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3521 Post(s)
Liked: 4514
It's working for me.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #7401 of 24719 Old 04-05-2013, 01:56 AM
^ Thanks!
post #7402 of 24719 Old 04-05-2013, 05:46 AM
adler98's Avatar
Forgive me if this question was answered before. Is there a difference in quality between the 103 and 105 for a SACD playing in bitstream?
I just bought the new processor from Marantz Av8801, and I’m wondering if it worth buying the 105.
adler98 is offline
post #7403 of 24719 Old 04-05-2013, 05:49 AM
wmcclain's Avatar
Liked: 2456
Over HDMI? No difference.
-Bill
adler98 likes this.
post #7404 of 24719 Old 04-05-2013, 05:54 AM
adler98's Avatar
-Bill
Yes, over HDMI!
Thanks Bill!
adler98 is offline
post #7405 of 24719 Old 04-05-2013, 06:03 AM
jd371's Avatar
Originally Posted by Bob Pariseau View Post
The first reaction whenever you have connectivity problems like this is that something needs to be fixed in the HDMI cabling. For example, don't use short HDMI cables between any two devices (which includes the Darbee). The sweet spot in length for HDMI cables is about 6 feet (2 meters) between any two devices. Second, make sure ALL your HDMI cables are marked as "High Speed" or "For 1080p". Keep in mind that HDMI is an end to end protocol so ANY cable in the signal path could be the problem, including cables beyond the Darbee. Third, consider the entirety of your HDMI cabling and see if there is more than one possible HDMI path from the Source to the AVR or Source to the Display. If so, temporarily DISCONNECT the path you don't think you are using and see if the problem goes away. Some devices keep HDMI connections "live" even when you don't think they are selected for use. Some devices EVEN do this when the device is supposedly OFF!
Still having problems after the above? Try 1080i from end to end instead of 1080p. If 1080i works but 1080p does not, that's a pretty strong indication that some cable is marginal, perhaps a faulty cable.
--Bob
Thanks Bob. Replaced one of the short cords with a longer one and that seems to have done it. It was working with the short cord with my previous blu-ray players so I assumed the problem was something else.
jd371 is offline
post #7406 of 24719 Old 04-05-2013, 06:41 AM
Read the FAQ!
Liked: 4514
--Bob
post #7407 of 24719 Old 04-05-2013, 07:44 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 3806
Looking to make sure I am correct. My display is soon to be calibrated, and I just strictly want accurate source direct output from the 103 (Bluray only).
I understand HDMI 2 is probably best for me, just wanted to make sure there isn't anything else to consider. I was going to setup in this manner:
HDMI 2 out to Denon 3313
Source Direct
1080p/24hz
I do watch some 3d
Ycbcr 444
Deep color off
How does that look? It seems there was a chroma issue with the mediatek output, but I don't recall. Thanks.
gadgtfreek is online now
post #7408 of 24719 Old 04-05-2013, 07:55 AM
wmcclain's Avatar
Liked: 2456
Source Direct
1080p/24hz
I do watch some 3d
Ycbcr 444
Deep color off
You might let the calibrator select the color space, but otherwise that looks fine.
Note that 1080p/24hz applies only to 1080p output. Source Direct will give you whatever is on the disc, meaning the output resolution and frame rate may alter quite a lot during intro material and previews, although not during the feature itself. People who have systems displaying long HDMI handshake times may find this exacerbated by Source Direct.
DVDs will be 480i with Source Direct, but you say Blu-ray only so it is not an issue.
-Bill
post #7409 of 24719 Old 04-05-2013, 07:56 AM
Mongo171's Avatar
Quoted: 961 Post(s)
Liked: 1387
Not sure if this has been covered or not. I am having problems with Netflix. Just now I started having the delayed audio problem. Netflix is locking up on me. I am running the Public Beta firmware.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #7410 of 24719 Old 04-05-2013, 08:00 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 3806
-Bill
You are right, there was no need to state resolution because source direct is what it is lol. The only reason I have used 444 is because I see less banding than 422, and the vt50 has a 444 pure mode.
When I do have the occasional DVD, I will force 1080p.
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
