Official OPPO BDP-103 Owner's Thread - Page 259 - AVS Forum | Home Theater Discussions And Reviews
 890Likes
post #7741 of 24616 Old 04-14-2013, 07:48 AM
kemiza's Avatar
Liked: 92
I think people should stop comparing the 103 to other bluray players. First of all its a "universal player" which means it does more than a typical bluray player. If 90% of your use is bluray this not the player for you.
ckronengold likes this.
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
post #7742 of 24616 Old 04-14-2013, 09:22 AM
jh901's Avatar
Quoted: 464 Post(s)
Liked: 168
I hope it's ok to simply pose the question though. This is a blu-ray player forum after all. If the answer is that the 103 is overkill for those using it for 100% blu-ray, then so be it. The 103 does offer SOURCE DIRECT, which is not so common for for blu-ray players currently on the market (AFAIK). This option may make sense for those with a video processor if SOURCE DIRECT will allow for the very best handling of the video. Faster load times would be an extra bonus too. So then we come to the bottom line for those looking ONLY for a blu-ray player in a home theater:
1) Two HDMI outs. There are less pricey blu-ray players with two such as the Panny BDP-330, so this feature alone does not justify the expense.
2) SOURCE DIRECT. Desirable and if so, why? If desirable for some, then are there players on the market for less with this feature?
4) Faster load times. Alone, this isn't worth it to me, but I wouldn't blame someone for going for it.
5) Build quality, customer service, etc. These things have value too, but alone, for me, it isn't worth it. Again, I couldn't blame someone for paying for this and faster load times.
HT: Panasonic BDT 460 | JVC RS600 | 106" x 45" Stewart ST 100 | Marantz AV7005 | NAD M27 | Elac Uni-Fi UF5, UC5, Debut B6 | Focal CMS Sub
Stereo: Cary Audio 306 SACD Pro | Cary Audio SLP-05 tube line level | Cary Audio SA-200.2 | Focal Diablo Utopia III
Den: Panasonic BDT 220 | 60" Panasonic VT60
jh901 is offline
post #7743 of 24616 Old 04-14-2013, 09:25 AM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
Originally Posted by wmcclain View Post
The -103 supports the Roku Streaming Stick, which has Amazon and many other things. You can get one for a discount from OPPO.
As an Amazon Prime member, would this allow me to stream Amazon content via the Oppo for no additional charge?
gweempose is offline
post #7744 of 24616 Old 04-14-2013, 09:37 AM
rdgrimes's Avatar
Quoted: 2183 Post(s)
Liked: 1519
Roku offers Amazon. Using the Roku Stick via the Oppo allows you to access Amazon and play it through the Oppo. But its a convenience only, there's no real gains in PQ/AQ by doing so.
rdgrimes is offline
post #7745 of 24616 Old 04-14-2013, 09:45 AM
darklord700's Avatar
Quoted: 184 Post(s)
Liked: 89
Is there any advantage in plugging the HDMI out to the TV directly instead of passing thru the receiver? I was under the impression that HDMI is HDMI so assuming your receiver is HDMI 1.4 ready, what's the point of having 2 HDMI out? Thanks.
darklord700 is offline
post #7746 of 24616 Old 04-14-2013, 09:52 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3358
Some AVR's can cause issues, and insert video issues. Proper testing ir required, but if an AVR passes thru properly, then no there isnt an advantage.
gadgtfreek is online now
post #7747 of 24616 Old 04-14-2013, 09:54 AM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
There are no real gains in PQ/AQ compared to what? Watching it through a PC?
post #7748 of 24616 Old 04-14-2013, 09:59 AM
Sidetracked's Avatar
Liked: 25
Originally Posted by amoergosum View Post
Are you satisfied with the pq (upscaled DVDs) when you use HDMI2 ?
Personally not really, but a) I'm very picky, b) I still have my 83 and my 983 hooked up to my system,
and after A/Bing I'd never watch SD-DVDs on the 103.
If I had never done the comparison it might not bug me as much. Although I will say, the first time
I played an SD-DVD I mastered (I started on HDMI 1) I immediately thought 'am I crazy, or is this picture
not as good?" That led to lots of comparing HDMI 1, 2 and my older players. And while HDMI 2 was
certainly closer to accurate than HDMI 1, it was certainly behind the older ABT chipped Oppo players in
shadow detail and other key features.
It's fine, probably better than many players, but I'm used to Oppo blowing most other SD-DVD players away,
the 103 seems a step back compared to the ABT players from A+ to B+ in terms of SD-DVD. For example
I couldn't say that the 103 was better with SD-DVDs than my Pioneer 51, something I can definitely say
about the older players.
Sidetracked is offline
post #7749 of 24616 Old 04-14-2013, 10:44 AM
rdgrimes's Avatar
Liked: 1519
Compared to using a Roku box or Stick connected direct to your TV.
rdgrimes is offline
post #7750 of 24616 Old 04-14-2013, 11:57 AM
Jottle's Avatar
Still having intermittent Netflix audio sync issues. This was supposed to be resolved on the latest (non-beta) firmware from a few months ago, but it isn't. Is anyone not on the beta still having issues with audio/video sync on Netflix? These have been resolved for me for blu-ray/dvd playback, but every once in awhile I'll turn the player on, access the netflix app, and pick a stream which will have audio delayed by one second. This happens both on the digital and analog audio outputs on the 103. Stopping the stream, pausing the stream, or exiting the netflix app, or even power cycling the player doesn't fix the issue. If I choose a different stream and then go back to the orignal problematic stream, occasionally that fixes the problem, but sometimes it just stays messed up for the whole night, and then is fine the next day. I assumed this was a netflix issue, but it's completely random and doesn't get resolved even after cycling the app or bdp-103. And it's not dependent on particular streams, sometime a problematic stream is perfectly fine the next day. It usually manifest itself on the first stream I choose after starting the netflix app. Other streams tend to work better. It's annoying because i can't fix it no matter what i do once it's started to happen. I'd guess it was my system setup, but I never had these issues with the bdp-93 at all in the exact same configuration. And the auio/video lip sync issues happen randomly once or twice every week or so. Anyone else have this issue?
Jottle is offline
post #7751 of 24616 Old 04-14-2013, 12:02 PM
Flave's Avatar
Big assumption. Some of us have absolutely no wish to replace our uber-expensive AVRs for new ones that support HDMI 1.4. This feature is a god-send if we want to watch 3D.
pgodden likes this.
Flave is offline
post #7752 of 24616 Old 04-14-2013, 12:42 PM
KJSmitty's Avatar
Liked: 34
There are several. As mentioned above and eluded to by you the most referenced being non 1.4 AVRs/processors. I fall into that boat, as well as run a main room plasma and bedroom plasma off my 103. The panels have different resolutions thus the OPPO easily accommodates them where an HDMI switch was always finicky. Having both two outputs and the input on the OPPO just adds flexibility.
Cheers
Love DIY
KJSmitty is offline
post #7753 of 24616 Old 04-14-2013, 12:53 PM
roach's Avatar
I have been having audio problems with my Pioneer SC-05 and my 103. I have the latest updates but still this problem is there. When I play a 3d movie I get videio but no audio. If I play the blu-ray disc I get both video and audio.Has anyone else had this issue with theirs?
LG 60LM7200, Pioneer SC-05, Panamax M4300-PM, Oppo BDP-103, Paridigm Monitor7's (fronts and center), Velodyne F-1200, Infinity surrounds.
roach is offline
post #7754 of 24616 Old 04-14-2013, 01:33 PM
Coyote Waits
htwaits's Avatar
Quoted: 932 Post(s)
Liked: 2076
htwaits is offline
post #7755 of 24616 Old 04-14-2013, 01:39 PM
Coyote Waits
htwaits's Avatar
Quoted: 932 Post(s)
Liked: 2076
Are you saying that you have no audio when you play a 3D Blu-ray disk, but that you have both audio and video when you play a 2D Blu-ray disk? What's the source for your 3D movies?
htwaits is offline
post #7756 of 24616 Old 04-14-2013, 02:20 PM
alnilam1's Avatar
I have followed a number of posted suggestions but find myself unable to unite my PC with my 103. When I type in its URL on the PC (192.168.0.13) I get a message "Unable to connect." My Windows Device searcher doesn't find it either although it just found my new Pioneer SC-1522-K sitting right next to the 103. Everything is hooked into the same network by cable. I've opened all the sharing settings I can find and turned off my Firewall briefly with no success. When I select the Oppo Network icon it starts loading and gives me one listing, "BOBSACKETT-PC:Bob Sackett:>Music>All Artists 0/0" I don't know where it is getting this info from or how it knows the name of my computer.
The Oppo shows up on my Control Panel/Network/Network Sharing/Media Streaming, but not on my Control Panel/Hardware/Devices.
Any ideas?
Bob Sackett
alnilam1 is offline
post #7757 of 24616 Old 04-14-2013, 02:26 PM
roach's Avatar
yes that is exactly what is happening. It was working perfectly for the last few weeks and suddenly it started acting up like that again. As you might expect I am not happy about the situation. Thank you for writing.
roach is offline
post #7758 of 24616 Old 04-14-2013, 02:29 PM
roach's Avatar
I am using the BDP-103 as a source.
roach is offline
post #7759 of 24616 Old 04-14-2013, 02:31 PM
roach's Avatar
The 3d movies that are not working are on a dick not streaming.
roach is offline
post #7760 of 24616 Old 04-14-2013, 02:43 PM
smoore's Avatar
I have been using Intel WiDi on my Windows 7 computer to stream my desktop to my Panasonic VT30 and my old Sony Blu-Ray. On those devices my computer shows up under the list of networked devices and so does my computer with WiDi after it. On the Oppo I do not see the WiDi. Does anyone know if Intel WiDi works with the Oppo 103? If so what should I be doing to make it visible? Thanks
smoore is offline
post #7761 of 24616 Old 04-14-2013, 03:58 PM
Coyote Waits
htwaits's Avatar
Quoted: 932 Post(s)
Liked: 2076
The 3d movies that are not working are on a disc not streaming.
OK. Your 2D Blu-rays are playing correctly, but, after working in the past, any 3D Blu-rays that you try have no audio. I'm assuming that having your firmware up to date doesn't include the new beta firmware.
You probably need to post your HDMI cable setup and any relevant audio settings in the OPPO. For instance are you using Split A/V. I don't recall if your AVR is 3D capable.
htwaits is offline
post #7762 of 24616 Old 04-14-2013, 06:04 PM
globalnomad's Avatar
Any ideas?
A few things:
1. Make sure you do not have any Microsoft Live products installed on your computer. This includes Essentials or Live for Games. Live - for some reason - interferes with OPPO's ability to connect with your computer.
2. Why are you trying to access your OPPO from your computer? To set up SMB you just need to input your User/Pass in the OPPO. Forgive me for asking an obvious question, but did you share folders already? Are you using DLNA instead of SMB? When you login to an SMB share, the default top tree is Pictures, Music, and Video. This is not an actual folder, but the OPPO's way of deciding which filetypes to filter for in the actual directory structures. Once you selected P/M/V, it'll display your shared folder structure, but only the files of the selected type.
3. I don't believe the OPPO should appear under Hardware/Devices and that it is indeed appearing in the right spot as it is viewed as a Media streaming device. I could be wrong on this though.
globalnomad is offline
post #7763 of 24616 Old 04-14-2013, 06:47 PM
rdgrimes's Avatar
Liked: 1519
disc..sorry
There's a setting in the Oppo called "blank HDMI-2", its in the 3D setup menu. That should fix the audio problem if HDMI-1 goes directly to display and HDMI-2 goes to AVR.
rdgrimes is offline
post #7764 of 24616 Old 04-14-2013, 06:58 PM
pgodden's Avatar
I had a similar issue yesterday, couldnt figure out for the life of me. Once I changed the cables... HDMI2 to the AVR and HDMI to my projector it worked. Of course the HDMI is set to Split AV. Is it posssible you have your cables reversed?
pgodden is offline
post #7765 of 24616 Old 04-14-2013, 07:01 PM
pgodden's Avatar
I have just hooked up a new 103, had some 3D blue disc iso backup on my NAS. These obvously I cannot anymore, does anyone know what format can I convert them to that is high quality and the 103 CAN play them therough the network?
pgodden is offline
post #7766 of 24616 Old 04-14-2013, 07:04 PM
alnilam1's Avatar
globalnomad,
1. I have no Microsoft Live products.
2. I'm not really trying to access my Oppo from my computer but rather the opposite. I think I should be able to play my computer's music files via the Oppo. I just tried from the computer to see if there was mutual recognition. I have shared my folders. I have to look into DLNA vs. SMB. I'm not up to speed on these choices but from what you said I suspect it is SMB because I can get the default folders which you mention (that are empty.) Will the Oppo detect the music folders or must the music files, with the proper suffixes, be exposed out of their folders?
3. I don't know either, but, as I said, my Pioneer receiver is present. I'm not sure why the Devices would select one but not the other.
I'll go to work on the DLNA and SMB options. I don't know what this means and am not sure how to check on it but I'll pour through the settings. I'm guessing SMB is the right choice.
Thanks for your time and thoughts. I'm breaking into the Oppo 103 and the Pioneer SC-1522-K within a week of each other and it is a fairly steep learning curve.
Bob Sackett
alnilam1 is offline
post #7767 of 24616 Old 04-14-2013, 07:15 PM
esh516's Avatar
Liked: 49
Hello ..just wondering how anyone out there listens to there CDs on the 103.. Are you using HDMI to pre-amp,or using HDMI for bluray and analog cables for CD?
I have a anthem Mrx so my hi-end CD/DAC combo is pretty much useless since the Mrx digitizes the analog outputs for arc..I know I can set the oppo up using HDMI & analog and assign them to the Mrx for different sources..my CD/DAC combo sounds great thru the Mrx..but its going thru processing of the DAC and then again In the Mrx..not a very idea situation..even though it sounds great.
Any ideas?
esh516 is offline
post #7768 of 24616 Old 04-14-2013, 07:24 PM
globalnomad,
Did you see my post here from awhile ago? Maybe this will help with SMB. I don't use a DLNA server so I can't help you there.
post #7769 of 24616 Old 04-14-2013, 07:54 PM
Brian-HD's Avatar
Quoted: 46 Post(s)
Liked: 42
Any ideas?
Use Z2
Brian-HD is offline
post #7770 of 24616 Old 04-14-2013, 08:04 PM
alnilam1's Avatar
I read your previous post. I don't use a password on my computer. Are you saying that I must or I can't access my network on the Oppo? I've never used a password and I'm not crazy about having to sign in every time I boot my computer. I've read for years how foolhardy this is but it's never bitten me yet. Is this my problem?
Bob Sackett
alnilam1 is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
