Official OPPO BDP-103 Owner's Thread - Page 271 - AVS Forum | Home Theater Discussions And Reviews
 888Likes
post #8101 of 24590 Old 04-26-2013, 01:22 PM
ferdy777's Avatar
Originally Posted by wmcclain View Post
Yes, both.
-Bill
hello bill, I would like to ask for clarification.
I created the mkv, bluray discs using as sources.
when I listen to the Dolby TrueHD, I see that the player oppo103 recognize the track as MLP 5.1, but not Dolby TrueHD. I used MakeMKV profile "copy as 1:1." other player (popcorn A300 and DUNE player) recognize the track properly. Do you have any advice?
ferdy777 is offline
post #8102 of 24590 Old 04-26-2013, 01:34 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2842 Post(s)
Liked: 2089
I believe they are the same thing. See: http://en.wikipedia.org/wiki/Meridian_Lossless_Packing
The player OSD could be changed to avoid confusion.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #8103 of 24590 Old 04-26-2013, 01:45 PM
ferdy777's Avatar
okay. as I understand it, is the player to change the name of the track HD.
if I insert the original disc, the player indicates the correct encoding. Do you know why in the mkv file name is wrong? thanks
ferdy777 is offline
post #8104 of 24590 Old 04-26-2013, 01:50 PM
wmcclain's Avatar
Liked: 2089
What's wrong with the file name?
You mean the codec label? It's not wrong, just not what you were expecting. Changing it would be a small matter of programming. Contact OPPO with your need if this is important to you.
-Bill
post #8105 of 24590 Old 04-26-2013, 01:50 PM
lujan's Avatar
Quoted: 2059 Post(s)
Liked: 844
Originally Posted by Done Deal DR View Post
What did you add it as? When I first got my 103 a couple months ago the configuration was very convoluted for the 103 (when adding as the 103). It made you try to add is as a "mini system" and it was a little strange. I added mine as a BDP-95 and manually added a few buttons and am happy with the functionality.
I may have to re-do my Harmony settings for the 103. Use either a 93 or like you did, use a 95? I'll keep using it for a while with the current settings and see what happens...
lujan
147 Ultra HD
822 HD
19 HD DVD
4 SD
lujan is offline
post #8106 of 24590 Old 04-26-2013, 01:58 PM
ferdy777's Avatar
-Bill
ok, thank you. last question.
when I create a mkv with at least 2 languages ​​DTS-MA (ITA and ENG), first on the list is recognized correctly, the second is identified as a simple DTS. have you ever? what program do you think is valid for the conversion of bluray? I currently use MakeMKV. is good? thanks again
ferdy777 is offline
post #8107 of 24590 Old 04-26-2013, 02:06 PM
wmcclain's Avatar
Liked: 2089
Are you going by the audio popup window? I've noticed that it does not always give complete information on a audio track that has not been selected yet. When you select the track the popup should be correct.
If the full On Screen Display shows only DTS than I suspect that is what is in the file. You can confirm that with the free utility "mediainfo".
Recommending ripping programs is a bit off topic here. See this thread: http://www.avsforum.com/t/1336046/ripping-blu-rays-ii
-Bill
post #8108 of 24590 Old 04-26-2013, 02:33 PM
ferdy777's Avatar
I checked some mkv files, mediainfo reports traces HD audio (DTS-MA) correctly. A-300 recognizes the DTS-MA (and dolby trueHD) correctly. the DUNE (base 3.0) recognizes correctly. the 103, in some cases, identifies the DTS-MA as DTS, even when I select the track. the display of 103 confirms the simple DTS.
I noticed that this fact is especially true if there are more than 1 track DTS-MA. or if the DTS-MA is not the first on the list. I did many experiments. thanks for the link!
ferdy777 is offline
post #8109 of 24590 Old 04-26-2013, 02:43 PM
dmusoke's Avatar
Quoted: 281 Post(s)
Liked: 147
Originally Posted by darthkringle View Post
Wanted to get a read from Darbee Darblet users on if most of you are using HDM1 or HDMI 2 as the primary video output into the Darblet. I realize HDMI2 is the more "purist" signal at this point and to use that makes sense, but if I like HDMI1 OTHER THAN the "softening/NR" would the Darblet not be ideal for me on HDMI1?
Thanks for any feedback from Darblet owners with the BDP-103/105.
Thanks all!
I have it on HDMI1 and like the picture the way it is. On  HQ source material(BD or broadcast tv), its PQ is excellent...
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #8110 of 24590 Old 04-26-2013, 02:45 PM
slimoli's Avatar
Quoted: 550 Post(s)
Liked: 250
I have the 93 and the 103 side by side linked through HDMI1 to a Pioneer receiver. When I put a 5.1 DSD SACD disk on the 93, it plays as a DSD and shows as a DSD on the Pio. The same disk on the 103 is output as PCM, regardless of setting the player at DSD or PCM under SACD. The player menu shows SACD 5.1 PCM on the 103 and 5.1 SACD DSD on the 93. Tried several disks, same result. Is this a known bug ?
I don't have the latest beta firmware on the 103 and the 93 is still with the last ISO compatible firmware.
I was so happy without HDR...
slimoli is offline
post #8111 of 24590 Old 04-26-2013, 02:47 PM
wmcclain's Avatar
Liked: 2089
DSD is not available over HDMI1 on the -103. This is a hardware limitation. It works on HDMI2.
-Bill
post #8112 of 24590 Old 04-26-2013, 04:13 PM - Thread Starter
Neuromancer's Avatar
Quoted: 86 Post(s)
Liked: 328
Seems the Spears & Munsil HD Benchmark 2nd Edition is available on the OPPO website.
The new edition has some new features that the previous disc did not such as a full suite of audio calibration and evaluation test tones and the ability to calibrate your display in 3D.
Neuromancer is offline
post #8113 of 24590 Old 04-26-2013, 04:15 PM
slimoli's Avatar
Quoted: 550 Post(s)
Liked: 250
-Bill
Thanks Bill.
slimoli is offline
post #8114 of 24590 Old 04-26-2013, 04:19 PM
Medieval Guy's Avatar
I honestly don't remember. Whatever I had to do, it wasn't enough hassle to register in my (admittedly not-great) memory.
In my Harmony set-up software, the 103 has a DVD player icon, for what that's worth...
AKA Rob Helmerichs
Medieval Guy is offline
post #8115 of 24590 Old 04-26-2013, 04:44 PM
subavision212's Avatar
Quoted: 62 Post(s)
Liked: 38
I do this also and love the way my PQ looks in my HT.
subavision212 is offline
post #8116 of 24590 Old 04-26-2013, 05:14 PM
darthkringle's Avatar
Thanks so much. May I ask what you have the Darblet set to? Thanks again!!
darthkringle is offline
post #8117 of 24590 Old 04-26-2013, 06:56 PM
dmusoke's Avatar
Quoted: 281 Post(s)
Liked: 147
HD 50% smile.gif!
dmusoke is offline
post #8118 of 24590 Old 04-26-2013, 08:08 PM
kobyh15's Avatar
Would anyone care to comment on the PQ improvement I would see coming from a PS3 to a BDP-103? I'm in the process of purchasing my first set of "grown-up" A/V components, and I am weighing the benefits of selling and upgrading my PS3. I only use it as a Blu-ray player these days, and it's a pretty good one. Just wondering if it would be worth it to replace it with the Oppo. Thanks!
kobyh15 is offline
post #8119 of 24590 Old 04-26-2013, 08:30 PM
Sidetracked's Avatar
Liked: 25
On paper, blu-ray PQ difference is apt to be minimal at most - most decent blu-ray players,
including the PS3 are pretty darn good, and perform well on all the various tests.
The gains in the Oppo are more in other areas; speed, build quality, sound (it can function as
an audiophile level CD player), image processing options, DVD-upscalling, number of formats
it can handle, comparative ease of making it region free, etc. etc.
That said, some people see bigger differences in the BR PQ of various players than
others. Whether that's their sensitive eyes, or equipment dancing together better, or
a placebo effect, it's very hard to say.
One great thing about Oppo, they have a liberal return policy, so if you decide within 30
days the cost isn't worth the features or PQ for you, all you're out is shipping.
Sidetracked is offline
post #8120 of 24590 Old 04-26-2013, 08:39 PM
djPerfectTrip's Avatar
Liked: 29
Here is a link to my oppo review coming from a PS3:
http://community.klipsch.com/forums/t/168922.aspx
Turn it up!
djPerfectTrip is offline
post #8121 of 24590 Old 04-26-2013, 08:45 PM
kobyh15's Avatar
I agree! I am interested in using the HDMI input for my cable box. I've read that using the Oppo's video processing helps out when viewing bad cable source material. I believe build quality and aesthetics will be superior to the PS3.
kobyh15 is offline
post #8122 of 24590 Old 04-26-2013, 10:00 PM
Nicodimus22's Avatar
Quoted: 17 Post(s)
Originally Posted by Nicodimus22 View Post
In theory, Bitstream and LPCM should sound identical, but lots of people claim to hear differences. If I can't fix this, I'll just go back to LPCM I guess, not a big deal...it's just nice to see the signal displayed on the receiver too.
The player is already at 1080p and 1080p24 is already off as well. Once the cables arrive, I'll see if the short ones were screwing it up. If not, I can always use an extra HDMI cable for something else down the road.
Just following up...got my 6' cable today, and replaced the 18" one. It still does the exact same thing where the audio cuts out for 2-3 seconds when something starts to play (on Bitstream output.) So, that rules out the possibility of the shorter cable causing the problem.
At this point, I'm just going to put the 18" cable back on, switch the output to LPCM, and never look back. My receiver won't display the signal type on the front, but it should sound the same.
Denon AVR-X4000 | Paradigm Monitor 11v7 L/R | Paradigm Monitor Center 3v7 C | Paradigm Monitor Surround 3v7 LS/RS | Klipsch SW-350 sub
Vizio P652ui-B2 4K TV | Oppo BDP-103 blu-ray player | Logitech Harmony 650 | Sony PS3 Slim 500gb | Nintendo Wii
Nicodimus22 is offline
post #8123 of 24590 Old 04-26-2013, 10:50 PM
Liked: 29
^^^true
Turn it up!
post #8124 of 24590 Old 04-27-2013, 05:36 AM
RamGuy's Avatar
Quoted: 21 Post(s)
Eagerly awaiting my Oppo BDP-103EU region unlocked from Ebay, might arrive sometime during next week.
Now I have to decide whether I should bother to redo my whole x264 encoded library with Dolby Digital / DTS 5.1 and get them into remuxed MKV's with TrueHD and Master Audio instead...
RamGuy is offline
post #8125 of 24590 Old 04-27-2013, 06:12 AM
AYColumbia's Avatar
Quoted: 20 Post(s)
What kind of keyboard do you need for search YT on the Oppo?
I picked up this little thing and it works great.
FAVI Wireless Keyboard
AYColumbia is offline
post #8126 of 24590 Old 04-27-2013, 07:36 AM
lujan's Avatar
Liked: 844
Obviously: verify that the OPPO remote is doing the same thing. If not, it's an issue with your Harmony and how it learned the button.
-Bill
The "Netflix" button is working correctly from the original Oppo remote so it is something with the Harmony. I guess I can try to "Learn Raw" which is different from just learning the button command, not sure what but I will try?
lujan
147 Ultra HD
822 HD
19 HD DVD
4 SD
lujan is offline
post #8127 of 24590 Old 04-27-2013, 09:06 AM
SARHENTO's Avatar
I just acquired a bdp-103 to replace my bdp-95. I noticed that the jitter in 103 is worse than in 95. I played the same test dvd and the difference is very pronounced. Has anyone else found this to be true?
SARHENTO is offline
post #8128 of 24590 Old 04-27-2013, 09:10 AM
obie_fl's Avatar
Liked: 33
^ Jitter??? Are you referring to the audio of a DVD? How are you connected?
obie_fl is offline
post #8129 of 24590 Old 04-27-2013, 09:21 AM
SARHENTO's Avatar
I'm referring to the video image of the same DVD. The panning from right to left of the same scene. Comparing it to the way the 95 renders it, it is not as smooth. I'm connected: OPPO >HDMI >RECEIVER>HDMI>Projector
SARHENTO is offline
post #8130 of 24590 Old 04-27-2013, 09:38 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2664 Post(s)
Liked: 3392
Start by checking that you have DVD 24p Conversion turned off. The disc you are playing may not be appropriate for that.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
