Official OPPO BDP-103 Owner's Thread - Page 274 - AVS Forum | Home Theater Discussions And Reviews
 890Likes
post #8191 of 24616 Old 04-30-2013, 05:52 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2902 Post(s)
Liked: 2157
Originally Posted by Blu_One View Post
I've been wanting an Oppo player for years now !
If it can do what I wanna do I'm gonna pull the trigger on it today ! So hopefully this will work out..
I want to rip all my BDs and put them on a 4TB WD external USB 3.0 hard drive - I'll want to rip my BDs with the highest quality possible, space is no issue.. so playback might require lots of 'power' (1080p high bit rate..)
So my question is. If I connect this 4TB external hard drive to the Oppo via USB, will the Oppo 103 play back those BD rips?
Thx !
What format? BDMV folders are no longer supported.
The player is USB 2.0, but that is fast enough for this purpose.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #8192 of 24616 Old 04-30-2013, 06:10 AM
Blu_One's Avatar
Liked: 62
I have no experience ripping DBs, I know all of the info is out there and I will look it up.. I'll want to rip only the video and audio track, no extras, but at the highest quality possible (closest to BD playback as possible..). I think I can create MKVs for this, not sure I'll look it up.
But you are saying that the 103 will playback large 1080p high bit rate files via USB, but the format of the file is the key, right? Any suggestion on what's better for BDs? Since I haven't ripped anything yet, might as well do it correctly to ensure proper playback on the 103.
It's looking promising, might be able to pull that trigger today after all smile.gif
Thx for your help, much appreciated !
65" Panasonic ST60 | Onkyo 809 | Oppo 103 | Apple TV4 | Darbee Darblet | 5.2 system - 5x Arx A2 + 2x SVS SB12-NSD
Blu_One is offline
post #8193 of 24616 Old 04-30-2013, 06:22 AM
rdgrimes's Avatar
Quoted: 2171 Post(s)
Liked: 1502
M2TS and MKV are the most common. Each has its advantages and shortcomings. Both can be lossless.
rdgrimes is online now
post #8194 of 24616 Old 04-30-2013, 06:23 AM
Holzohr's Avatar
You have the choice between MKV, M2TS and AVCHD. When you hurry up and buy your Oppo before they release the next stable firmware you simply can copy the BD content into an AVCHD folder. Not sure if BDMV folders are still suported with the last stable... Bill?
Holzohr is offline
post #8195 of 24616 Old 04-30-2013, 06:23 AM
wmcclain's Avatar
Liked: 2157
These details are a bit off-topic here; try reading the recent pages in this thread: http://www.avsforum.com/t/1336046/ripping-blu-rays-ii
Yes, it must be of a supported format. MKV is what I use. If you want the original audio and video without alternation, MakeMKV is often recommended. There are links to that and other tools in the BDP-93 FAQ: What are the alternatives to .iso files?
-Bill
post #8196 of 24616 Old 04-30-2013, 06:25 AM
wmcclain's Avatar
Liked: 2157
I've lost track. Best just to forget it.
The AVCHD trick is still working for single-title BR copies, but no one knows how long that will continue.
-Bill
post #8197 of 24616 Old 04-30-2013, 06:48 AM
Blu_One's Avatar
Liked: 62
Thx !
Should I hurry up to get it like you said ?? If MKV works fine on the 103, then I wouldn't need to transfer them into an AVCHD folder, right? Sorry, I'm new to this whole thing..
If a file format is currently supported but might not be in a future FW release, wouldn't I be better off just not installing the new FW and keep running off the old one?
-Bill
Thx so much Bill, I will look those up.
So looks like I'm good to go, thx to all !
Blu_One is offline
post #8198 of 24616 Old 04-30-2013, 06:54 AM
wmcclain's Avatar
Liked: 2157
You don't want a BR player where you are afraid to update to update the firmware[*] so just forget the past formats and go with MKV.
[*]Some people do keep old machines on old firmware in order to retain features that are no longer allowed, but since you are starting fresh, I would advise you not to get into that habit.
-Bill
post #8199 of 24616 Old 04-30-2013, 06:59 AM
Holzohr's Avatar
Briefly, copying the content of a BD 1:1 into an AVCHD folder is the easiest and fastest way. You don`t need to rip/extract anything and afterwards mux to M2TS or MKV.
That will be the trick.
Holzohr is offline
post #8200 of 24616 Old 04-30-2013, 07:26 AM
Blu_One's Avatar
Liked: 62
Thx very much for the assistance guys !
Now that I know that it will work, I'm comfortable dropping five bills today for this beast biggrin.gif
I'll have to look at that whole MKV v. AVCHD thing, I know the info is all out there. I don't want to burn the whole disc (no menus no extras) only the video and audio track in the highest quality possible..
One last important question. In the external link that Bill provided, it says that the largest supported USB hard drive is 2TB. Is that still the case?? If so, that 4TB hard drive I was planning on getting wont work, I would have to get the 2TB version instead.. So I'm hoping that things have changed and that hard drives bigger than 2TB are now supported..
Blu_One is offline
post #8201 of 24616 Old 04-30-2013, 07:30 AM
wmcclain's Avatar
Liked: 2157
That was true on the -93 but not on the -103. You should be ok.
Read the -103 FAQ for many such details.
-Bill
post #8202 of 24616 Old 04-30-2013, 07:37 AM
Blu_One's Avatar
Liked: 62
-Bill
Thanks very much Bill !
I'll do that now and order it later, hopefully work is quiet for the test of the day wink.gif
Blu_One is offline
post #8203 of 24616 Old 04-30-2013, 09:22 AM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
I'd love it if the dedicated "Netflix" an "Vudu" buttons on the remote acted as discrete commands which would both turn on the unit, and automatically start the corresponding streaming service. This would make it a lot easier to program macros into my MX-980 universal remote. Would anyone else find this useful?
gweempose is offline
post #8204 of 24616 Old 04-30-2013, 09:35 AM
Blu_One's Avatar
Liked: 62
Just ordered an Oppo 103, will get it in a couple days, so looking forward to it, should be a fun weekend, I'm hoping for rain now tongue.gif
Blu_One is offline
post #8205 of 24616 Old 04-30-2013, 09:56 AM
b11051973's Avatar
Just ordered one today. I had bought an LG player a little over a year ago. The thing started making this grinding noise when I put a disc in and then I'd get an error message.
I've read people loving Oppo players since their DVD players. This will be my first Oppo. Figured I'd spend some more money to get a better quality player. It will be nice to have DVD-A and SACD player again. I had a DVD player that played both, but it got retired when Blu-ray came out. I've got a small library of both formats.
b11051973 is offline
post #8206 of 24616 Old 04-30-2013, 10:00 AM
Blu_One's Avatar
Liked: 62
Originally Posted by b11051973 View Post
You have two years manufacturers warranty, put in on a good credit card, and that will go up to three years, so you're good for a while !
Blu_One is offline
post #8207 of 24616 Old 04-30-2013, 10:08 AM
gwsat's Avatar
Quoted: 2635 Post(s)
Liked: 2917
Bought a BDP-103 from Amazon and it arrived yesterday evening. Earlier, I had bought an all regions mod for the Oppo from JVB Digital. This morning I got the mod installed and the Oppo configured. So far so good. I have confirmed that it can now be set to play BDs from any region (one region at a time, though) and can handle all DVDs without having to worry about the region code.
The Oppo BDP-103 is stoutly made (it should be considering what it cost) and I am very pleased with it so far, unlike my experience with World Import from whom I bought an LG BD550 BD player, pre modified for all regions playback. From the beginning the LG was flakey but finally wouldn't play at all. I sent it in for repair twice, both times having to pay for shipping it back to World Import out of my pocket. When it completely stopped working a third time, I was told by World Import, for the first time, that they had never been able to find anything wrong with it and that they wouldn't do any more for me. So I ate the $200 plus I had paid and, for obvious reasons resolved to do no more business with World Import and to get the word out to others of the company's utter failure to support me.
Back to the 103, though. Installing the all regions chip required that I remove the BD player's cover, which called for the removal of 9 philips head screws. Once the cover was removed installing the chip was a straightforward operation. I plugged the chip assembly's cable into a 4 pin receptacle on the mother board and affixed it to the inside of the player's case with a strong adhesive pad supplied by JVB. Now, pressing the right buttons in the right order on the Oppo remote allows me to see Region A, B, or C BDs. Installation of the chip automatically set the DVD playback operation to Region 0, which covers all regions.
I seem to remember that there is a thread somewhere that more directly addresses all regions modifications but thought I would come here first and report my experience thus far, as well as to throw World Import under the bus to the widest audience possible.smile.gif
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Crestron Control System; Hsu VTF-3 MK3 Turbo subwoofer, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is online now
post #8208 of 24616 Old 04-30-2013, 10:38 AM
rdgrimes's Avatar
Liked: 1502
Not to mention that Oppo will repair any player with a 1-day turn around and a smile.
post #8209 of 24616 Old 04-30-2013, 10:55 AM
Hi Deaf's Avatar
I picked up the Roku 3 a week ago. Pretty awesome. Instantly connects to Netflix, Super HD, DD+. The Wii type remote is cool with games, although I don't play them.
Tested the 103 last night. Tried Netflix and it couldn't connect, as usual.(no beta) The Roku connected fast.
So unless you're hell bent on using the 103's remote for Roku, spend the extra $50 and get the 3.
Panny 65VT50 / DTV Genie / OPPO 103 / Roku 3 / Denon 1613 / Klipsch Quintet 5.0
Hi Deaf is offline
post #8210 of 24616 Old 04-30-2013, 10:57 AM
lujan's Avatar
Quoted: 2129 Post(s)
Liked: 875
I've had mine for 6 days and so far I'm loving it. Had some problems programming a Harmony remote but love the functionality. I like how easy it is to bring up subtitles on blu-ray movies and all the movie information you get from the "Status" button. I'm going to be spoiled now and always want to get an Oppo from here on out. This is also my first Oppo.
lujan
150 Ultra HD
822 HD
19 HD DVD
4 SD
lujan is online now
post #8211 of 24616 Old 04-30-2013, 11:13 AM
gwsat's Avatar
Liked: 2917
As noted in an earlier post, I configured my BDP-103 this morning. It's working mostly all right but I have a problem, which I hope is a matter of configuration but I can't figure out what to do. Here is the problem: When I use the volume control on the Oppo remote it won't control my Yamaha RX-V3900 AV receiver, although the receiver is connected to the Oppo via an HDMI cable. When I use the volume control on the remote, the display shows a horizontal volume bar near the bottom of the screen but it has no effect on the level of the audio being delivered by the receiver. What must I do to get the Oppo remote to control the AV receiver's volume? Thanks a million in advance for any advice as to how I can solve this irritating problem.
gwsat is online now
post #8212 of 24616 Old 04-30-2013, 11:16 AM
Ali is mental's Avatar
I thought that this doesn't work with the latest Beta.
Ali is mental is offline
post #8213 of 24616 Old 04-30-2013, 11:21 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2749 Post(s)
Liked: 3536
The Volume on the OPPO is only for its Analog audio outputs -- except for Volume 0, which is implemented as Mute and affects all outputs.
For HDMI audio, you need to use the volume control in your Yamaha receiver.
The remote that comes with the OPPO can not be configured to control other devices. If you want to use one remote to control both the OPPO and the Yamaha, you might look into one of the programmable remote products such Logitech's Harmony line of remotes.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #8214 of 24616 Old 04-30-2013, 11:22 AM
Blu_One's Avatar
Liked: 62
I think I saw this as well while reading the FAQ earlier. But large MKV files still work? Does anyone think they would remove this in a future firmware release?
Blu_One is offline
post #8215 of 24616 Old 04-30-2013, 11:36 AM
wmcclain's Avatar
Liked: 2157
Yes.
I think that's unlikely but no one can promise you. The studios don't want you copying BR at all. If they think MKV copies are hurting them they will do something about it.
-Bill
post #8216 of 24616 Old 04-30-2013, 11:48 AM
clayhans's Avatar
I have an Oppo BDP-103 Blu-ray player connected to a Samsung UN55F800 TV for video and all things seem right with that. My problem is that the Oppo is connected from HDMI 2 to a Pioneer VSX-1018AH-K A/V receiver on HDMI BD connection. My read out on the Pioneer receiver tells me I am getting a PCM single from the Oppo, but I am not getting any sound out of my Pioneer receiver. I have connected a center speaker to the Pioneer receiver but no sound comes through. Is it the Oppo or the receiver? How do I get things to work?
LG Oled TV 65C6P/Oppo UDP-203/Pioneer Elite SC-LX501
Klipsch RF-52II Home Theater Bundle/Klipsch RP-450C Center Speaker/Klipsch RP140SA Height Speakers
Premier Acoustic PA-120 Titanium Subwoofer
Set Up - http://www.blu-ray.com/community/gal...&uploaded=true
Movie Collection - https://cloud.collectorz.com/clayhans/movies
clayhans is offline
post #8217 of 24616 Old 04-30-2013, 11:58 AM
Read the FAQ!
Liked: 3536
I take it you've got HDMI 1 going to the TV and HDMI 2 going to the Receiver? First double check that you haven't confused those two sockets on the OPPO, as when both outputs are live (with Split A/V set) the HDMI 1 output will be muted for audio.
Next, when you say you have a Center speaker connected, do you mean that is the ONLY speaker connected? If the content you are playing on the OPPO is stereo, you likely need to make a Surround Sound choice in the Pioneer to tell it that it is OK to create audio for the Center speaker from that Left/Right channel input.
--Bob
post #8218 of 24616 Old 04-30-2013, 12:06 PM
Blu_One's Avatar
Liked: 62
-Bill
Thx Bill got it !
As we know what's in FW releases when they come out, if they do take the ability to play large MKV files away, I could simply stay with the FW version thats already on it at that time and I'd be ok to keep playing those files right ? I believe that's correct, but just wanted to confirm. The 103 is ordered now..
Blu_One is offline
post #8219 of 24616 Old 04-30-2013, 12:13 PM
wmcclain's Avatar
Liked: 2157
Thx Bill got it !
Yes, you can do that. The issue would be: what if new firmware has features you want? BR disc compatibility is a moving target and players require new firmware to keep up with studio schemes.
This is usually less of a problem with ripped copies than with the original discs. Ironically, copies are more robust than the originals. Copies strip out the java which is the source of 99% of the problems. That percentage is scientifically exact.
-Bill
post #8220 of 24616 Old 04-30-2013, 12:14 PM
Holzohr's Avatar
Blu_One has ordered his Oppo today. He should get delivered the player with the last stable firmware installed.
Holzohr is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
