Official OPPO BDP-103 Owner's Thread - Page 277 - AVS Forum | Home Theater Discussions And Reviews
 3146Likes
post #8281 of 24854 Old 05-02-2013, 10:47 PM
indy911's Avatar
Originally Posted by IRJ View Post
Thanks guys. I like the idea of buying from a regular source with proper warranties etc:)
If your intention is to install the mod chip yourself, just make sure that the player actually has the required internal connector for the mod chip. Some players out there no longer have this connector. Your only options then are either a soldered mod (very hard to do yourself) or one that hooks up to the external serial port.
This mod chip is only needed for Blu-ray region mods. DVD region can be modified easily with a software patch (already mentioned in this thread and the FAQ).
indy911 is offline
post #8282 of 24854 Old 05-02-2013, 11:13 PM
scottc1992's Avatar
Originally Posted by wmcclain View Post
Are you asking for help?
-Bill
Well, I am a little frazzled at myself really and was blowing off steam, sorry. I just wish it was a little more "plug and play". Has anyone found a media player that works? Oshare keeps crashing on my computer, it will not launch at all and I have to reinstall it, then when setting it up it will crash again. Thanks for letting me ramble.
scottc1992 is offline
post #8283 of 24854 Old 05-03-2013, 12:22 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
Originally Posted by Josh Z View Post
What "critics" are you reading? You should stop reading them, because they are either blind, or idiots, or very likely both. The Dune Blu-ray is literally (and I literally mean "literally" in the proper use of that word) one hundred billion times better than the DVD you own. It's also at least 500 million times better than the last "remastered" DVD, which was so smothered in DNR that it had no textural detail at all left. The Blu-ray has no DNR at all, no edge enhancement at all, tons of detail and great colors.
Is the Blu-ray perfect? It has a few specks of dust that weren't digitally erased. Heavens to betsy.
The disc is currently $9 on Amazon. Buy it.
You are absolutely right...
...so I bought it!
AndrewFG is offline
post #8284 of 24854 Old 05-03-2013, 02:08 AM
biliam1982's Avatar
Quoted: 492 Post(s)
Liked: 248
Can anyone comment on the 103's Audio/Video streaming quality?
Like can it do all the 3D from Netflix, Amazon, Vudu or whomever?
What about higher audio codecs like DD+?
Is there any benefit to getting the Roku stick or just get the Roku 3?
biliam1982 is offline
post #8285 of 24854 Old 05-03-2013, 04:13 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3403 Post(s)
Liked: 2658
You can't give up after trying just one thing. This is home networking.
The DLNA servers people have reported using are listed in the FAQ: What are some DLNA servers?
Most everyone reports immediate success with Twonky. It has a free trial and is not expensive if you want to keep it.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #8286 of 24854 Old 05-03-2013, 04:20 AM
wmcclain's Avatar
Liked: 2658
Mostly we like it a lot.
I didn't know Netflix had 3D.
Vudu does, and that is supported.
No Amazon: you need Roku for that.
Yes.
Advantage Roku Streaming Stick: can use the OPPO remote (but not for games), one less box in your setup.
Advantage: Roku box: can use wired ethernet, no large dongle sticking out the front of the player
-Bill
wmcclain is offline
post #8287 of 24854 Old 05-03-2013, 05:33 AM
biliam1982's Avatar
Quoted: 492 Post(s)
Liked: 248
Yes.
-Bill
Thanks, Bill. Thats what I was trying to figure out, if its worth it to even get a Roku as the Oppo has a lot of the streaming services I use. Was wanting to make sure it supported 1080P, 3D streaming and all that. Shouldn't have doubted the Oppo. smile.gif
Didn't catch that it doesn't have Amazon though. So I guess I'll just end up getting the Roku 3.
post #8288 of 24854 Old 05-03-2013, 05:42 AM
IRJ
IRJ's Avatar
Quoted: 27 Post(s)
Originally Posted by thirdkind View Post
If you perform the mod yourself, which involves plugging one cable into one port and closing the player back up, you'll still retain the Oppo warranty. As far as anyone here is aware, Oppo has never denied warranty service for a player modified by the owner (assuming the mod isn't permanently soldered to the board); you can even leave the mod in the player when you send it in for service. However, if you buy a player from a reseller that's been modified, the warranty is void.
You're better off buying an unmodified player from an authorized dealer and installing the mod yourself than buying a modified unit.
Thanks I appreciate the input.
Ian
IRJ is offline
post #8289 of 24854 Old 05-03-2013, 05:46 AM
IRJ
IRJ's Avatar
Quoted: 27 Post(s)
That's use re the DVD region free. Are you saying that the latest irteration of the player requires a soldered chipset for the BD RF work or does Oppo randomly change the build?
Ian
IRJ is offline
post #8290 of 24854 Old 05-03-2013, 06:53 AM
scottc1992's Avatar
-Bill
Thanks, I just hate thinking i'm not up on all this tweaking lingo and methods. The player is fine, didn't want people discouraged from my ineptitude.
post #8291 of 24854 Old 05-03-2013, 06:54 AM
Flave's Avatar
Originally Posted by SeeMoreDigital View Post
Out of interest...
If anybody here has their SACD.ISO files stored on a Synology NAS. Have you tried playing them using the Synology's ISO mounting application?
"Failed to mount image."
*sadface*
Flave is offline
post #8292 of 24854 Old 05-03-2013, 06:58 AM
wmcclain's Avatar
Liked: 2658
I've heard of internal changes to the EU player, but the not US version.
-Bill
wmcclain is offline
post #8293 of 24854 Old 05-03-2013, 09:05 AM
rdgrimes's Avatar
Quoted: 2482 Post(s)
Liked: 1785
FWIW, the Roku Stick now has the same version software as the Roku-3. Other operational differences still apply. (remote, connectivity, etc.)
rdgrimes is offline
post #8294 of 24854 Old 05-03-2013, 09:46 AM
Done Deal DR's Avatar
Quoted: 99 Post(s)
Liked: 146
I was watching Avatar 2D Bluray on my 103 with the latest available official software last night, and around 3/4's the way through on a chapter I believe called "I see you" I lost audio. I've never had that happen, and the only way I could get it back was to stop the movie and restart/resume it. Not sure what the issue is, but I've watched this movie before on the PS3 and I know I didn't see it then. Guess I'll just have to watch it again sometime and see if the same thing occurs.
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is offline
post #8295 of 24854 Old 05-03-2013, 11:05 AM
Josh Z's Avatar
Quoted: 2476 Post(s)
Liked: 1627
...so I bought it!
Nobody knows this movie better than I do. The Blu-ray is a massive upgrade. If you like the movie, you'll be glad you bought it.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #8296 of 24854 Old 05-03-2013, 11:06 AM
RON82ND's Avatar
Just got a 80" 844u and oppo 103 arrived today and debating getting a cheaper av receiver what do you all think no more than 500. Will this be sufficient enough? Also will the 103 create a better picture to the sharp from direct tv and if so how do i go about hooking it up?
RON82ND is offline
post #8297 of 24854 Old 05-03-2013, 11:13 AM
Blu_One's Avatar
Liked: 62
Oh man I'm at work shaking, my wife sent me this pic, I need to get home ASAP biggrin.gif
65" Panasonic ST60 | Onkyo 809 | Oppo 103 | Apple TV4 | Darbee Darblet | 5.2 system - 5x Arx A2 + 2x SVS SB12-NSD
Blu_One is offline
post #8298 of 24854 Old 05-03-2013, 11:33 AM
Quoted: 99 Post(s)
Liked: 146
Congrats!
post #8299 of 24854 Old 05-03-2013, 11:38 AM
Mongo171's Avatar
Quoted: 994 Post(s)
Liked: 1425
Hook DirecTV up to the 103 using the HDMI Input on the rear. You will get a better picture.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #8300 of 24854 Old 05-03-2013, 12:07 PM
jboileau's Avatar
Quoted: 20 Post(s)
jboileau is offline
post #8301 of 24854 Old 05-03-2013, 12:12 PM
alnilam1's Avatar
Just got a 80" 844u and Oppo 103 arrived today and debating getting a cheaper av receiver what do you all think no more than 500. Will this be sufficient enough?
My opinion only. You just spent a whole bunch for your Sharp and the Oppo. The receiver is the heart of any system and offers a myriad of options and quality that both of these new devices must go through. Spend a hundred dollars more ($600) and run as fast as you can to the nearest Costco that still has the Pioneer SC-1522-K in stock and get it into your car. It has a MSRP of $1600 and is identical to their SC-65 Elite. There is a separate 1522 thread on this forum (see below) which you can review at your leisure. If you don't like it, bring it right back to Costco anytime. It's the sale of the year but you need to get moving and find the right store quickly. Where are you? Someone close to a source is bound to pipe in. Good luck.
http://www.avsforum.com/t/1465612/official-pioneer-sc-1522-9-2-network-ready-av-receiver-owners-thread
Bob Sackett
alnilam1 is offline
post #8302 of 24854 Old 05-03-2013, 12:13 PM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
^^^^ this ^^^^^
Depends on your speakers, features you want, etc. Plenty of good receivers at that price if everything else fits well. I'd ask in the amp / receivers forum.
hernanu is offline
post #8303 of 24854 Old 05-03-2013, 12:48 PM
lujan's Avatar
Quoted: 2765 Post(s)
Liked: 1282
Congratulations! I know I'm loving mine and learning more about it all the time. Tonight I'm going to try my first USB MKV movie to see how it works...
lujan
234 Ultra HD
780 HD
18 HD DVD
4 SD
lujan is offline
post #8304 of 24854 Old 05-03-2013, 12:51 PM
SeeMoreDigital's Avatar
Quoted: 502 Post(s)
Liked: 216
*sadface*
Bummer!
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #8305 of 24854 Old 05-03-2013, 01:04 PM
RON82ND's Avatar
Im in charlotte nc and heading there after work to look. I appreciate the feedback guys.
RON82ND is offline
post #8306 of 24854 Old 05-03-2013, 01:39 PM
RON82ND's Avatar
K i have got my wife picking this up as we speak it is a display model for 499 is it worth it? He stated it has a small scratch other than that great condition and everything that is suppose to be in the box is. Would you all get this? Also if i have this and the 103 how would i run wiring from the 80" to get best picture with direct tv and from the player?
RON82ND is offline
post #8307 of 24854 Old 05-03-2013, 01:56 PM
Blu_One's Avatar
Liked: 62
Originally Posted by jboileau View Post
Originally Posted by Done Deal DR View Post
Congrats!
Thx man !
Thx, that's one of the main reason I got the 103 - I wanna rip all my BDs into MKV, retaining the BD quality, and transfer it all to a 4TB USB hard drive to connect to the Oppo. That's my next project, I've never ripped any movies before so I need to look into things first. My main concern is retaining the BD quality, I don't care how much space it takes..
Enjoy your movie tonight ! Can't wait to install mine, probably after the hockey game tonight so a late night is in order I think !
! GO SENS !
Blu_One is offline
post #8308 of 24854 Old 05-03-2013, 03:13 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
Picking what up? An AVR? Which one? I alway buy last years model, after the current model reaches the market. If you're talking about an AVR, if it has a normal warranty, you should be fine.
I would, depending on the unknown AVR, run high speed HDMI from the OPPO (set to output 1080p 60 Hrz) to the AVR. I would do the same for cable or satellite (set to output native), and let the AVR convert your TV signal to 1080p 60Hrz. With the OPPO you can try running your cable/satellite box (set to output native) through the OPPO's HDMI inputs if you think it's going to do the conversion to 1080p better than the AVR. There are many other options, but that's where I would start. Then use another high speed HDMI cable to connect your AVR to the TV.
Eventually you should use the setup that looks the best to you.
htwaits is offline
post #8309 of 24854 Old 05-03-2013, 03:32 PM
msr999's Avatar
All of a sudden I am having problems with wireless. Was working flawlessly last few months. Now it does't want to connect (sometimes it does after a very long time). I have changed nothing (Same router, same router firmware , same 103 firmware). Every other device on my network (phones, computers and even my TV) connect perfectly to my router. This has been very furstating as I play network media files heavily. Could this be a problem with wireless stick? Any ideas on how to identify where the problem is?
MSR
msr999 is offline
post #8310 of 24854 Old 05-03-2013, 03:45 PM
alnilam1's Avatar
OK I have got my wife picking this up as we speak. It is a display model for $499. Is it worth it? He stated it has a small scratch. Other than that great condition and everything that is supposed to be in the box is. Would you all get this?
Yes, I would get it. Amazon is selling them for over $1200! I'd look out one thing: it is either the store demo (as your post seems to say) or a return. Some folks have had a problem with the Pioneer making a "buzzing" sound (transformer buzz) and a few have been returned. Be aware that it has a fan in it and some slight noise could be normal. But remember; it is COSTCO. If anything is wrong, or even if not, just bring it back and look for another store. Go on the Pioneer thread I told you about and talk to the folks there. This isn't the best place, You found me here just by luck. This will be a great match for your new Oppo! I've had more problem with the Oppo than the Pioneer.
Bob Sackett
alnilam1 is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
