Official OPPO BDP-103 Owner's Thread - Page 292 - AVS Forum | Home Theater Discussions And Reviews
 884Likes
post #8731 of 24577 Old 05-13-2013, 10:55 AM
gwsat's Avatar
Quoted: 2360 Post(s)
Liked: 2661
Originally Posted by Blu_One View Post
like others have said, good luck trying to find a sound difference between internal (LPCM output) and external (DTS-HD / Dolby True HD bitstream output) decoding.
That been said, I'm kinda like you, now that I'm using the 103 for BD playback instead of my fat PS3 80GB, I kinda like seeing that DTS-HD logo light up on my Onkyo AVR biggrin.gifcool.gif
We agree that although it's kind of fun to see the HD audio lights illuminated on the receiver, there is no audible difference in the quality of HD audio decoded internally by the BD player and that which is sent in raw form to the receiver and decoded there.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Crestron Control System; Hsu VTF-3 MK3 Turbo subwoofer, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is offline
post #8732 of 24577 Old 05-13-2013, 12:03 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
Originally Posted by htwaits View Post
That depends on whether you think your AVR or the 103 will do the best job with DVD sources. I use these settings with an OPPO 93.
TV Aspect Ratio: 16:9 Wide/Auto
Output Resolution: 1080p
1080P24 Output:: OFF
On your Oppo 93, with the settings above for SD-DVD, are you using HDMI1 or HDMI2?
I'm using HDMI1 and direct pass through in our Denon 3312 and the Denon 3806 before it. UMR, when calibrating, and I haven't detected any signs of excessive processing from the OPPO 93.
Being movie buffs, we probably watch as much DVD as Blu-ray.
htwaits is offline
post #8733 of 24577 Old 05-13-2013, 12:15 PM
Blu_One's Avatar
Liked: 62
65" Panasonic ST60 | Onkyo 809 | Oppo 103 | Apple TV4 | Darbee Darblet | 5.2 system - 5x Arx A2 + 2x SVS SB12-NSD
Blu_One is offline
post #8734 of 24577 Old 05-13-2013, 12:23 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
In another logical fallacy, appeal to authority, UMR has calibrated our audio with both Denon receivers, and I've always used LPCM output from our OPPO players. Now I'm getting an itch to see our AVR tell me what we are hearing, but unfortunately it's housed in another room. eek.gif
Oh, I remember now, some problems have been fixed for other owners by switching from bitstream to LPCM. I think I'll just let it itch. wink.gif
I'm not going to make any financial decisions today. I'm feeling a little dingy. On the other hand, I almost never make financial decisions. rolleyes.gif
htwaits is offline
post #8735 of 24577 Old 05-13-2013, 12:40 PM
Blu_One's Avatar
Liked: 62
I'm sure you know I was joking around with that statement.. but what's the 'p' word ? confused.gif PM me if need be lol
I'm sticking to bitstream until I encounter any problems in that regard (knock on wood) cool.gif
But yeah for you, why fix what ain't broken.. especially when we both agree that there's no perceptible audible difference between LPCM and bitstream.
Blu_One is offline
post #8736 of 24577 Old 05-13-2013, 12:46 PM
billtsag's Avatar
Originally Posted by Manic_D View Post
I don't have Windows 8 but here's a post from earlier in the thread with some info:
http://www.avsforum.com/t/1432162/official-oppo-bdp-103-owners-thread/6420#post_23054304
Many thanks for the tip!
billtsag is offline
post #8737 of 24577 Old 05-13-2013, 12:57 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
There have been folks make the argument that bitstream is clearly better, and for them the "p" word is placebo. Yes, I did know you were joking, and it seemed to set me off to somewhere strange. No idea why.
My memory is fuzzy every day, but I think that the switch to LPCM in the OPPO had to do with problems in some bitstreaming AVRs. I started with LPCM because the Denon 3806 didn't know bitstream from Adam. The 3312 does know bitstream, but I just never made the change.
htwaits is offline
post #8738 of 24577 Old 05-13-2013, 01:00 PM
audiofan1's Avatar
Quoted: 1663 Post(s)
Liked: 1691
I'll beg to differ ! there is indeed a difference to be heard in my setup which consist of an Oppo 105 and Marantz 8801, setting the Oppo to LPCM for hdmi audio out rolls off the high frequencies and while the sound can be perceived as more robust and weighty in the mid and lower bass , the overall presentation seems lower in volume as well lackinking dynamics if you will! Now setting the 105 to bitstream via hdmi audio restores the dynamic presentation to the upper frequencies and to some degree more clarity and a perceived loudness increase overall. I'm not sure if this is still true from the latest update but I'll test and post back. but there is an audible difference and it's not subtle!
audiofan1 is offline
post #8739 of 24577 Old 05-13-2013, 01:06 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
htwaits is offline
post #8740 of 24577 Old 05-13-2013, 01:09 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2641 Post(s)
Liked: 3373
^ That strongly suggests there is something wrong in the way your Marantz is handling HDMI LPCM input. You mention a volume difference for example. If there is a volume difference then the Marantz is doing something wrong, either with the Bitstream or the LPCM (or both).
Just to cover the basics, settings to check in the OPPO: Dynamic Range Control OFF, DTS Neo:6 Mode OFF, Secondary Audio OFF (needed for the Bitstream comparison). And if you are using a dual HDMI cable hookup, confirm that Split A/V is set (with audio carried on the HDMI 2 output).
Another check would be to use the multi-channel Analog outputs of your 105, since of course they are fed with the LPCM that results from the decode in the player. If the decode to LPCM in the player was faulty, the 105 thread would be FULL of howls from the Analog enthusiasts.
--Bob
htwaits likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #8741 of 24577 Old 05-13-2013, 01:34 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
htwaits is offline
post #8742 of 24577 Old 05-13-2013, 01:34 PM
audiofan1's Avatar
Liked: 1691
--Bob
I wouldn't say faulty! just different remember who your talking to Bob! the 1k power cord ring a bell biggrin.gif If that doesn't help I also hear a difference between PCM and DSD, I have all the above recommendations covered and sorry I don't fall into bits are just bits camp! ( in perfect world perhaps) I'm of the change a variable change the end result camp!
post #8743 of 24577 Old 05-13-2013, 01:48 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
Now I've got to figure out if a HDMI cable can be faulty when transmitting LPCM, but not faulty when transmitting bitstream. Maybe it's a bandwidth problem.
htwaits is offline
post #8744 of 24577 Old 05-13-2013, 01:57 PM
audiofan1's Avatar
Liked: 1691
Good question , for awhile I did like the sound of LPCM as it had a closer presentation to the Sabre dac's via xlr ( more analog sounding) but as the 8801 settled and sounded more refined the switch back to bitstream was prefered after a lot of A/b listening on movies with hires codecs and multi/ch sacd! because of the differences I noted above.
post #8745 of 24577 Old 05-13-2013, 02:16 PM
Blu_One's Avatar
Liked: 62
Really ??
Blu_One is offline
post #8746 of 24577 Old 05-13-2013, 02:24 PM
Read the FAQ!
Liked: 3373
I'd be among the first to agree that change should not be discounted.
But then, if you buy enough $1K power cords you soon won't HAVE any change.
--Bob
post #8747 of 24577 Old 05-13-2013, 02:29 PM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
FYI: Seems the latest firmware fixes the 422 and 444 color space issues I was experiencing using Source Direct from HDMI 2 into a Lumagen Radiance vp and from there to a Sharp Elite (post 5276). RGB (both video and PC) is still screwed up. Didn't notice any change in noise reduction on HDMI 1 Source Direct. Would have been nice if the release notes had mentioned the fix since I found it by accident while evaluating a change in setup configuration.
Mike_WI likes this.
dsinger is offline
post #8748 of 24577 Old 05-13-2013, 02:36 PM
hifi59's Avatar
Jeff said to me on his last visit here a month ago that there are pros and cons to both. For one, lpcm is 4db low whereas bitstream is at Dolby level. So if your receiver is calibrated for audio and you want 0db to truly represent Dolby level, put player to bitstream. On the other hand, lpcm is less prone to potential data errors. Choose your poison.
If you're talkin, you ain't learnin.
hifi59 is offline
post #8749 of 24577 Old 05-13-2013, 02:41 PM
Blu_One's Avatar
Liked: 62
Now that I'm getting used to it I need that DTS-HD Logo to light up on my AVR.. cool.gifbiggrin.gif
Blu_One is offline
post #8750 of 24577 Old 05-13-2013, 02:45 PM
audiofan1's Avatar
Liked: 1691
--Bob
post #8751 of 24577 Old 05-13-2013, 02:52 PM
Read the FAQ!
Liked: 3373
LPCM should not be low, although it is easy to get an effect like that if, for example you are testing with Dolby tracks and the AVR is not paying attention to the Dialog Normalization meta-data in the incoming Bitstream. (4dB is common for that.)
--Bob
post #8752 of 24577 Old 05-13-2013, 03:07 PM
Read the FAQ!
Liked: 3373
Remember the Info button on the OPPO remote (along with Page Up/Down to see the rest of the info) can be used to find what type of track is playing and whether the player is sending out the Bitstream or not.
Think of it as a "patch" to help reduce the anxiety of little lit-up logo withdrawal.
--Bob
Blu_One likes this.
post #8753 of 24577 Old 05-13-2013, 03:53 PM
AYColumbia's Avatar
Quoted: 20 Post(s)
Originally Posted by AYColumbia View Post
2) SMB credentials not remembered. I temporarily set up a second server with SMB access for some testing. Switching between the servers required that re-enter my credentials even though they're the same on each one which seems fine as I'm sure the player is server-based since my servers are NOT on a domain. Now, though, I'm no longer using my test server. Every time I turn on the player and navigate to my server, it fails to log in with the "saved" credentials and I have type them in all over again. What's strange is that it won't accept the user name if I type it in the log in screen directly, however, it will accept it if I enter the user name in the keyboard input screen. This particular issue seems to be only related to the user name and not the password. Once I log in, it'll work fine until I turn off the player.
I heard back from Oppo on this issue and they said they're aware of it and are working on a solution in a future firmware. I'm hoping it's the next one.
AYColumbia is offline
post #8754 of 24577 Old 05-13-2013, 04:12 PM
Blu_One's Avatar
Liked: 62
--Bob
Nice ! Now I can confirm, and double-confirm, that's perfect for my anxiety tongue.gif
Thx Bob !
Blu_One is offline
post #8755 of 24577 Old 05-13-2013, 04:27 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
Really ??
Not in this case. The joke that you started is continuing. It has some relation to chaos theory. wink.gif
You know, the flutter of a butterfly wing in China ... sort of thing. Your LPCM joke was that butterfly wing.
htwaits is offline
post #8756 of 24577 Old 05-13-2013, 04:30 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
That's Jeff's job. His last visit was to calibrate our audio with the Denon 3312 installed. wink.gif
I take your point though. I won't be changing to bitstream any time soon anyway.
htwaits is offline
post #8757 of 24577 Old 05-13-2013, 04:33 PM
DSperber's Avatar
Quoted: 229 Post(s)
Liked: 186
Bill -- Thanks. Upon further investigation I have discovered that Oppo's implementation of the Bitstream setting is just what I need. I wanted a setting that would allow my receiver to display the information when one of the HD audio formats was being received. On my old PS3, the Bitstream setting does not pass that information to the receiver. All the receiver knows is that it is receiving a PCM stream. Anyway, I now know that my 103 is not so limited so I am a happy camper.
Actually, while I understand the "enjoyment" of seeing DTS-HD MA LED's lit up on your AVR (when delivering bitstream form the 103 to the AVR), the same information is available from the 103 itself even if you set it to do the decoding in the 103 and deliver LPCM to the AVR.
Just push the INFO button on the 103's remote ("i" button, just above the "pop-up menu" button, northeast of the center ENTER and arrow keys collection.
When using external HDMI input, pushing the "info" button produces an "info" display bar at the top of the screen showing the INPUT characteristics audio and video, and an "info" display bar at the bottom of the screen showing the output characteristics audio and video.
When playing a BluRay movie, the two "info" bars present all kinds of interesting and useful information as well, but at the bottom-left you will see the audio information details about the movie. And "DTS-HD MA 5.1 48K" will be shown, if that's what the audio track is.
And if you press the PAGE-DOWN button, the bottom bar will change to show you how the 103 is delivering output to the HDTV (actually to both HDMI-1 and HDMI-2, individually).
It's actually easier to see and more fun and informative to use the 103's "i" button than to try and see little LED's on the AVR panel screen. At least that's what I think, as I have decoding done in the 103 and send out LPCM (to both my HDMI-1/AVR and also to HDMI-2/Smyth Realiser headphone system).
DSperber is offline
post #8758 of 24577 Old 05-13-2013, 04:33 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
I've lived without it all my live, and since we've had the the 3312 I wasn't tempted to turn it on before today. The feeling made me a little giddy, but it passed.
Blu_One likes this.
htwaits is offline
post #8759 of 24577 Old 05-13-2013, 04:34 PM
Blu_One's Avatar
Liked: 62
Hahah k gotcha !
Blu_One is offline
post #8760 of 24577 Old 05-13-2013, 04:36 PM
Blu_One's Avatar
Liked: 62
Yeah but that cool logo wasn't available all your life. Unless of course you were born within the last decade and are an AVS genius kid wink.gif
Blu_One is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
